Results 1 to 2 of 2
Thread: Skoda Octavia NE needs to display videos while driving
    Verified VCDS User mo_ferwana's Avatar
    Palestine Gaza
    Hi
    This is Octavia NE 2015 need to display media( video ) while driving on screen
    Saturday,20,April,2019,12:09:20:25282
    VCDS Version: 17.8.1.0 (x64)
    Dealer/Shop Name: Gaza Automotive Solutions
    Workshop Code: 116 27465 022987
    VIN: TMBJG7NE4E02xxxxx  License Plate: NAWAF MANSOUR
    Mileage: 277108km-172186mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F 6D A5
    VIN: TMBJG7NE4E0214042   Mileage: 277108km-172186miles
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 6545
       Revision: 84H22---
       Coding: 01110032032401090000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM16TDI01104L906021M 002011
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F6777FE767F8E3E38-807A
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 60994000000B49
       Coding: 1C076291142109700077060441C5243846289000608224F0F043F072C002
       Shop #: WSC 73430 031 00063
       VCID: 4B9F036EE2A7D21E34-801E
    0147 - Door Contact Switch
              C1076 29 [008] - Signal Implausible
                        Reset counter: 173
                        Mileage: 273803 km
                        Date: 2019.04.06
                        Time: 14:55:39
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 169
                        Mileage: 273464 km
                        Date: 2019.04.04
                        Time: 17:24:54
       Part No SW: 5E0 907 044 H    HW: 5E0 907 044 H
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 02010104002100011005000100100000
       VCID: 2A5166EA4D9DEB16EF-807E
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 128
                        Mileage: 273242 km
                        Date: 2019.04.03
                        Time: 19:28:13
                        Outside air temperature: 18.0 °C
                        Engine speed: 700 /min
                        Temperature after evaporator: 29.0 °C
                        System run time-Engine running time: 255 s
                        System run time-Terminal 15 on: 255 s
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Reset counter: 203
                        Mileage: 274927 km
                        Date: 2019.04.10
                        Time: 16:33:16
                        Voltage terminal 30: 13.3 V
                        Outside air temperature: 26.0 °C
                        System run time-Engine running time: 24 s
                        System run time-Terminal 15 on: 26 s
       Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
       Component: BCM PQ37BOSCH 026 0097
       Revision: --------    Serial number: 86581103140200
       Coding: 0C000B66424722FB4FE44004001C17080000000000000000000000000000
       Shop #: WSC 73430 790 12345
       ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
       ROD: EV_BCMBOSCH_012.rod
       VCID: 48953C62F3D1390619-801C
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 140409  041 0570
       Serial number:         140411183052
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y14M04D13H05M12S03S7
       Coding: 02805D
    12307 - License Plate Light
              B12CA 01 [008] - Electrical Failure
                        Reset counter: 180
                        Mileage: 273578 km
                        Date: 2019.04.05
                        Time: 11:08:45
       Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H11 0042
       Revision: --------    Serial number: 61131410500487
       Coding: 0031061041
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_EPHVA2CAU3700000 003019
       ROD: EV_EPHVA2CAU3700000_003_SK37.rod
       VCID: 40852442DBE10146D1-8014
    1113619 - Parallel Parking Assistance Indicator Lamp
              B10FE 13 [008] - Open Circuit
                        Reset counter: 190
       Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
       Component: ACC Bosch MQB H04 0200
       Serial number: 17031477030043
       Coding: 00000400FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001014
       VCID: 3669429A8925BFF67B-8062
    1067 - Brake Temperature
              C10DF 00 [008] -  -
                        Reset counter: 182
                        Mileage: 273539 km
                        Date: 2019.04.04
                        Time: 19:46:51
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 13.9 V
                        Vehicle speed: 5.95 m/s
                        Acceleration: -1.53 m/s²
       Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
       Component: Airbag VW20   012 0189
       Revision: --------    Serial number: 003P4P7NJDPF
       Shop #: WSC 73430 790 00000
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F0767BEE69FBEBEE8-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 604 14
       Serial number: 3576U000000A48A4AF0Q
       Subsystem 2 - Part No SW: -----------    HW: 454 000 604 14
       Serial number: 3586U00000062314AF07
       Subsystem 3 - Part No SW: -----------    HW: 454 800 504 14
       Serial number: 3516R1B785A030000001
       Subsystem 4 - Part No SW: -----------    HW: 454 800 504 14
       Serial number: 3526RF8DA5A03000000L
       Subsystem 5 - Part No SW: -----------    HW: 454 800 603 14
       Serial number: 3556V52D41C030000004
       Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
       Revision: --------    Serial number: 13041408491402
       Coding: 1400
       ROD: EV_SMLSKLOMQB_009_AU37.rod
       VCID: 77F78F9ECEAF86FEA0-8022
       Part No SW: 5E0 920 871 D    HW: 5E0 920 871 D
       Component: KOMBI         333 2210
       Coding: 07A50A006994000801886A03000000
       Shop #: WSC 73430 031 12345
       VCID: 295399E6489BE00EE6-807C
       Revision: --------    Serial number: 0001830707
       Coding: 030100040F087300EF00064A080F00010001050000000000000000000000
       ROD: EV_GatewLear_010.rod
       VCID: 3F8727BEA61F7EBEA8-806A
       Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Serial number: 000000000A0328100414
       Serial number: 4580193103
       Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
       Component: TSG FS        009 0014
       Serial number: 0000098926516
       Coding: 00150920D000040000001100
       VCID: 448D2852CFF91D66F5-8010
       Serial number: 00000000000002353674
       Coding: 010200
       Coding: 1302
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41832146D0EB084EDE-8014
       Part No SW: 8V0 035 223     HW: 8V0 035 223
       Component: MIBAMP1ALPINE H11 0300
       Serial number: SKZ8Z1E7600KE2I
       Coding: 03730200AA002AAA00
       ASAM Dataset: EV_AMPMst16C2ALPI 004016
       ROD: EV_AMPMst16C2ALPI_SK37.rod
       VCID: 6DDBADF6BCF33C2E4A-8038
    0607 - Loudspeaker 2 in Double-Subwoofer
              B130D 12 [008] - Short to Plus
                        Reset counter: 198
                        Mileage: 276282 km
                        Date: 2019.04.16
                        Time: 19:22:31
    6695 - Databus
                        Reset counter: 182
                        Mileage: 273885 km
                        Date: 2019.04.06
                        Time: 18:44:31
    0527 - Front Right Treble Speaker
              B1064 13 [008] - Open Circuit
                        Fault Frequency: 39
                        Reset counter: 204
                        Mileage: 273264 km
                        Date: 2019.04.04
                        Time: 08:51:16
    0522 - Front Left Treble Speaker
              B1061 13 [008] - Open Circuit
                        Fault Frequency: 40
                        Reset counter: 204
                        Mileage: 273264 km
                        Date: 2019.04.04
                        Time: 08:51:16
       Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0014
       Serial number: 0000099568838
       Coding: 00150120D000040000001100
       VCID: 438F2B4ECAF71A5ECC-8016
       Serial number: 00000000000002323460
       Coding: 190200
    589849 - Window Regulator Switch; Rear Passenger Side
              B1324 29 [008] - Signal Implausible
                        Fault Frequency: 10
                        Reset counter: 198
                        Mileage: 276319 km
                        Date: 2019.04.16
                        Time: 20:47:29
       Coding: 03CA02003F010000
       Coding: 3E0000
       Coding: 3E0000
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-HGH1.clb
       Part No SW: 5E0 035 020 B    HW: 5E0 035 020
       Component: MU-H-ND-EU    H42 0292
       Serial number: A313D0E7526707
       Coding: 03730201000000001111120200A800002F0000E401000100F6
       ASAM Dataset: EV_MUHig6C3HBAS 001041
       ROD: EV_MUHig6C3HBAS_SK37.rod
       VCID: 1629A21AE9E55FF65B-8042
       Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
       Component: ABT_High  H50 0022
       Serial number: SKZ8Z9PL100NMK
       Subsystem 2 - Part No SW: V03 959 800 MB    HW: -----------
       Component: ECE 2014  --- 0078
       Part No SW: 5E0 959 107     HW: 5E0 959 107
       Component: HDSG-Modul    H01 0744
       Revision: 42001001    Serial number: 092400258
       Coding: 1233074002
       ASAM Dataset: EV_HDSGSk462 301136
       ROD: EV_HDSGSk462_SK37.rod
       VCID: 69D3D9E6881B200E26-803C
    0128 - Closing Assistance Closed
              B113E F1 [137] - Implausible Signal
                        Fault Frequency: 54
                        Reset counter: 165
                        Mileage: 273439 km
                        Date: 2019.04.04
                        Time: 16:48:55
                        13.73 V
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0052
       Serial number: 10000065741
       Coding: 0101010001030303000400000100000100
       ROD: EV_MFKBoschAU370.rod
       VCID: 3B7F53AEB207629E84-806E
    End-------------------------(Elapsed Time: 04:12)--------------------------
    Address 03: DTCs cleared
    Regards from Palestine
    VCDS User from 2004
    Sorry Mo, but a request for Video In Motion does not belong in Car Repair Support. Moving to Tweaks.
    Also, please be aware that due to liability concerns, RT does not wish to have VIM instructions in our forum at all, so if someone knows how to do this, please contact Mo privately about it.
  3. Likes mo_ferwana liked this post
