Results 1 to 2 of 2
Thread: 2015 vw t5 fault codes
    Sep 2017
    Cumbria, UK
    Hi all looking for some help with the few fault codes that appeared on a friends van i scanned the codes and cleared them off and they seemed to stay clear and not reappear when i scanned it for the second time (egr fault only)
    one of them the mirrors i can put down to the door been open while doing the scan ?. The satnav coding error im not sure about and how to fix it
    Friday,19,April,2019,19:32:58:56460
    VIN: WV1ZZZ7HZFH104843   License Plate:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 10 15 17 19 25 37 56 0B
    VIN: WV1ZZZ7HZFH104843   Mileage: 55140km-34262miles
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
       Component: R4 2,0L EDC   H45 6303
       Revision: 26H45---    Serial number: 00000000000000
       Coding: 01194012232400080000
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
       ROD: EV_ECM20TDI01103L906019FM_003.rod
       VCID: 77A8E3F26F408C7FAF7-8022
    4807 - EGR System
              P0401 00 [237] - Insufficient Flow
                        Fault Frequency: 12
                        Mileage: 53225 km
                        Date: 2019.02.25
                        Time: 13:51:36
                        Engine speed: 1682.50 /min
                        Normed load value: 41.2 %
                        Vehicle speed: 37 km/h
                        Coolant temperature: 60 C
                        Intake air temperature: 24 C
                        Ambient air pressure: 1030 mbar
                        Voltage terminal 30: 14.320 V
                        Air mass: specified value: 333.9 mg/stroke
                        Air mass: actual value (mg/stroke): 504.6 mg/stroke
                        EGR Solen.val.: actual value: 16.02 %
                        Throttle valve adapter: actual value: 28.56 %
                        Charge air pressure specified value: 1151 hPa
                        Charge air pressure: actual value: 1147.2 hPa
                        Mean injection quantity: 10.66 mg/stroke
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
       Component: ESP MK25A XT  H50 0113
       Revision: 00H50001
       Coding: 508724AD89A40A9924AA9175C96112
       Shop #: WSC 02737 790 49152
       VCID: 3B203FC21368681F8BF-806E
       Component: LENKW.SENSOR  H07 0070
       Serial number: 06011504650777
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA6F6D6407ABD37EC1-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
       Component: Climatic-T5   H20 0506
       Revision: 00001012
       Coding: 0000000002
       ROD: EV_ClimaT5Basis.rod
       VCID: 7CA2FCDE5666AF27C25-8028
       Part No SW: 7H0 937 087 P    HW: 7H0 937 087
       Component: BCM T5GP H+4  H34 0424
       Revision: BO034001    Serial number: 0673 015150118
       Coding: A0A4303A0AE13431922848106C2B9C540088632F60840000320000000800
       Shop #: WSC 02739 790 00000
       VCID: 41DC4D2A718402CFD13-8014
       Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8653
       Serial number: KU0KU013011550133933
       Coding: 1000B0
       Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8653
       Serial number: KU0KU013011550130423
       Coding: 0000A0
       Subsystem 3 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 7E1 951 172
       Subsystem 6 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TK6  H07 0023
       Serial number: 70000000000000847713
       Coding: E20000
                        Fault Status: 00101011
                        Reset counter: 61
                        Mileage: 54543 km
                        Date: 2019.04.07
                        Time: 18:18:20
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0106
       Revision: --------    Serial number: 32931433703197
       Coding: 108001
       Shop #: WSC 02739 790 50316
       ASAM Dataset: EV_VW75XParkAssis4K 001004
       ROD: EV_VW75XParkAssis4K_001.rod
       VCID: 3A2E3AC61CD25117909-806E
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00UPLL9
       Shop #: WSC 02734 790 50316
       VCID: 353429FA35CCBE6F7DB-8060
       Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
       Component: KOMBI         H04 0805
       Coding: 760800
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 H34 0424
       Revision: BO034001
       Coding: 042300
       VCID: 70BAD8EE0AAEDB476ED-8024
       Component: IMMO          H04 0805
       VCID: 6A8ECA862CF22197209-803E
       Part No SW: 2K0 035 279 B    HW: 2K0 035 279 B
       Component: RNS315-EU   H85 0501
       Serial number: VWZAZ2R0650775
       Coding: 000002110200140000039002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 290CF58AE974EA8FE93-807C
       Component: EUR_W_V7  0066
    1048641 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [ECU wrong coded]
                        Reset counter: 3
                        Mileage: 43271 km
                        Date: 2018.04.16
                        Time: 15:59:13
                        Correction for sound system: OK
                        Traffic sign display: OK
                        CD changer: OK
                        Status of antenna 2 for radio: OK
                        Digital radio (DAB): OK
                        Antenna diagnostic: OK
                        Telephone baseplate diagnostic: OK
                        Speaker status: ERROR
                        Rearview camera: OK
                        Telephone Transceiver: OK
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.3V/12.2V)-----------
    Feb 2018
    Czech Republic
    The egr could be clogged, some logging and/or other (output) test will be good to prove why the MAF is 170mg/stroke higher than expected while the boost little lower/almost specified.
    And the second fault looks like wrong coded number of speakers.
