My problems started when I left my car in the garage for two months and the battery was drained. After charging I got a start stop system error on my dash.
Took the car 100 km away to a dealer and the faults were cleared. The mechanic said the faults were all caused by low voltage. Got home, figured I will need a vcds so I can resolve issues like this, received my new hex net and connected to the car.
Found some hanging error codes as in first scan. Figured they were caused by the low battery so I cleared the and to my suprise I got a message on my dash Brake system transport mode and start stop error again. Tried to clear and turn of transport mode but no luck. Below is the first scan and the present scan.
Help
Help
Thursday,18,April,2019,15:47:07:59453
VCDS Version: 18.9.1.0 HEX-NET CB: 0.4437.4
VIN: WAUZZZF57JA03xxxx License Plate: DUxxxxx
Mileage: 13576km-8435mi Repair Order:
Chassis Type: F5-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 29 39 3C 42 44 46 47 52 5F 6C
6D 74 81 82 8B A5 AC BB BC CF D6 D7
VIN: WAUZZZF57JA03xxxx Mileage: 13576km-8435miles
Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 AG HW: 04L 907 309 L
Component: R4 2.0l TDI H35 1969
Revision: B1H35---
Coding: 0A254032236605083438
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
ROD: EV_ECM20TDI01104L906026AG.rod
VCID: 6FAED9E2B675313234-803A
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 BD HW: 0CJ 927 156
Component: 0CL 20TDIRdWH04 0001
Revision: --H04--- Serial number: 0000001816
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU48.rod
VCID: 0444864E8FF3226AF9-8050
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 0C4 0572
Serial number: 75117081170187000056
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 M HW: 8W0 907 379 D
Component: ESP9 Premium H13 0767
Coding: 0CAA489A28A50A9811A54897008152A2E4A5DA301214508812004A4527A55B
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4FEE79621635113214-801A
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0210
Coding: 141800295544410D02000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44C4464ECF73E26AB9-8010
Subsystem 1 - Part No SW: 4M1 820 021 A HW: 4M1 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001680198
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0006
Serial number: 9550DAB880PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501143C13900CD0545511918AD80F9130B31080000000000000000600016810A4502AB22B70A
VCID: 0248805695E72C5ACB-8056
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 010617 036 0471
Serial number: 00000001705290302734
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20585971X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AB HW: 4M0 941 531 AB
Component: E1 - LDS H06 0008
Serial number: 28 02 2017 00803147
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE101051723611730
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00447216
Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H17 0010
Serial number: 2617000026801004
65536 - Internal Control Module Memory Check Sum Error
B2000 00 [009] - -
[Control module: faulty]
Mileage: 12706 km
Date: 2019.02.11
Time: 00:41:57
average_Voltage_terminals: 11.90 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 10.50 °C
interior_temperature: 12.00 °C
Vehicle speed: 0.00 km/h
Terminal control-Terminal 75 status: OFF
Terminal control-Terminal 15 status signal: OFF
Terminal control-Terminal 15 via CAN: OFF
65544 - Internal Control Module Memory Check Sum Error
B2000 49 [009] - Internal electronic failure
[Control module faulty: terminal 15 signals not plausible between the main computer and the emergency computer]
Mileage: 12706 km
Date: 2019.02.11
Time: 00:41:55
Vehicle speed: Insuff. voltage
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 8W0 907 561 C HW: 8W0 907 561
Component: LRR4 H10 0330
Coding: 3477FFF358FFEC0A959A81A0
ASAM Dataset: EV_ACCBOSCHAU49X 003022
ROD: EV_ACCBOSCHAU49X.rod
VCID: 3E3034A6A19F88BAEF-806A
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0106
Serial number: 003UP006WFSA
Coding: AACCF0C00C800000985400F3D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006015
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CD46E6EE7232A2A71-8018
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 8W0857705F0191R00880
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 8W0857706G0192R00653
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 063 006 17
Serial number: 3577Y00A32489D9403A2
Subsystem 4 - Part No SW: ----------- HW: 442 063 006 17
Serial number: 3587Y00BB24DEB61E42L
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 706 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700B12694C9232FD
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 706 17
Serial number: 3527700B126B8790D13A
Subsystem 7 - Part No SW: ----------- HW: 442 0C3 005 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A5263F7B123AE
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 442 0C3 005 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A5263F7B3C32J
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 442 0C3 005 17
Component: PedP_Sensor_C 1C5 014A
Serial number: 23075009D25FB8F1E15U
Subsystem 10 - Part No SW: ----------- HW: 442 432 806 17
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00C324DEB6353CU
Subsystem 11 - Part No SW: ----------- HW: 442 432 806 17
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00BD24DEB6284D1
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HH HW: 4M0 907 129 HH
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7DB2F3AAEC1953A2B6-8028
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0371
Coding: 058441C67C98000800A3E9601000400000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 43C64552CA7DE55280-8016
Part No SW: 8W7 907 468 E HW: 8W7 907 468 E
Component: Gateway H42 0116
Revision: 6C010002 Serial number: 0286C814117717
Coding: 03010001000006404107000000590012DC980007100000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003092
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4DD2636A1C39232266-8018
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170720153937 21857
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 5047434604
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
VCID: 79BAE7BAF8316F829A-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 36202C8689AF40FA37-8062
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0125
Serial number: 0000266972556
Coding: 005D5B6250000080000014B0
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 0D888380008080
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41CA4F5AD061F74292-8014
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 DC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 019 0366
Coding: 01340000002000E06309A0000E00080233004000804F06502F0400000504803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU49.rod
VCID: 004C8A5E9BEB3E4ADD-8054
Subsystem 1 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: >1126190
131164 - Internal Control Module Memory Check Sum Error
B2000 96 [009] - Component internal failure
[LF chip faulty]
Mileage: 12706 km
Date: 2019.02.11
Time: 00:02:56
Supply voltages-Supply voltage: Terminal 30: 9.782 V
Supply voltages-Supply voltage Terminal 30 - 2: 9.782 V
Supply voltages-Supply voltage Terminal 30 - 3: 9.782 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 13 04 F8
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
defect_fusi_voltage_error_freeze_frame: 11111111 11111111 11111111 00000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA02A7J/
Coding: 0194030800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
VCID: 76A0EC86C92F00FAF7-8022
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0125
Serial number: 0000267049398
Coding: 005D5B225C000080000014B0
VCID: 42C84056D567EC5A8B-8016
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 A HW: 8W5 035 035
Component: MU-P-LND-EU 034 1117
Serial number: A829G0HB031996
Coding: 019403010000000053111102000A00332F000EE5017001009E
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 35222B8A94A94BE23E-8060
Subsystem 1 - Part No SW: V03 959 802 DE HW: -----------
Component: ECE 2019 --- 0175
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0160
Serial number: TPO00117061700820715
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK130061700020380
Component: Gracenote2 --- 1016
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 27
Mileage: 12929 km
Date: 2019.04.09
Time: 13:36:03
Voltage terminal 30: 12.0 V
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG019219
Coding: 02940301BE0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31461471400000
Coding: 0630
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 48DC527EF35BC60A55-801C
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 H HW: 8W0 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 2610160122
Coding: 1050404958
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 G HW: 8W1 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 17071043326048
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 373E21828EA5B9F22C-8062
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 8W6 919 617 HW: 8W6 919 617
Component: HeadUpDisplay H09 1640
Coding: 4F01C0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736.rod
VCID: 06409C46B9CF107AE7-8052
Address 8B: Adaptive Cruise 2 (J850) Labels: None
Part No SW: 8W0 907 541 C HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 003022
ROD: EV_ACC2BOSCHAU49X.rod
VCID: 3C343EAEB7839AAAC1-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H15 0050
Coding: 0404090300000402022023A6CD0000FCB0F0C020E280
ROD: EV_BVSMLBevKOSTAAU736.rod
VCID: 40CC4A5EDB6BFE4A9D-8014
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 302C1A9E6BCB6ECA6D-8064
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0125
Serial number: 0000265871203
Coding: 000D592200000080000010A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 45C25B4AC449DB62AE-8010
Component: TSG HBFS 005 0125
Serial number: 0000265871561
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 332615929ADD55D210-8066
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 1A78D8361D77849A33-804E
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
End----------(Elapsed Time: 02:08, VBatt start/end: 12.1V/12.1V)-----------
Friday,19,April,2019,18:25:24:59453
VIN: WAUZZZF57JA03XXXX License Plate: DUXXXXX
Mileage: 13620km-8463mi Repair Order:
VIN: WAUZZZF57JA032XXXX Mileage: 13620km-8463miles
Revision: B1H35---
VCID: EFAE59E23675B132B4-80BA
Coding: 000001
VCID: 8444064E0FF3A26A79-80D0
VCID: CFEEF9629635913294-809A
297728 - Transport Mode Active
U1105 00 [047] - -
[Transport_Mode_is_activated]
Mileage: 13620 km
Date: 2019.04.19
Time: 18:22:20
7F 00 00 00 CA 24 00 80 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
VCID: C4C4C64E4F73626A39-8090
VCID: 8248005615E7AC5A4B-80D6
Coding: 5FC7F7
Coding: 02005D
Light switch:
Coding: 030000
B2000 00 [009] - -
Mileage: 12706 km
Date: 2019.02.11
Time: 00:41:57
Mileage: 12706 km
Date: 2019.02.11
Time: 00:41:55
VCID: BE30B4A6219F08BA6F-80EA
VCID: CCD4EE6E6723AA2AF1-8098
Coding: 88001B
Coding: 88001B
VCID: FDB273AA6C19D3A236-80A8
VCID: C3C6C5524A7D655200-8096
VCID: CDD2E36A9C39A322E6-8098
VCID: F9BA67BA7831EF821A-80AC
Revision: --------
Coding: 0EC002
VCID: B620AC8609AFC0FAB7-80E2
VCID: C1CACF5A5061774212-8094
VCID: 804C0A5E1BEBBE4A5D-80D4
[LF chip faulty]
Mileage: 12706 km
Date: 2019.02.11
Time: 00:02:56
VCID: F6A06C86492F80FA77-80A2
VCID: C2C8C05655676C5A0B-8096
VCID: B522AB8A14A9CBE2BE-80E0
Reset counter: 46
Mileage: 13620 km
Date: 2019.04.19
Time: 18:22:20
Voltage terminal 30: 12.9 V
Coding: 0630
VCID: C8DCD27E735B460AD5-809C
Coding: 1050404958
VCID: B73EA1820EA539F2AC-80E2
Coding: 4F01C0
VCID: 86401C4639CF907A67-80D2
VCID: BC34BEAE37831AAA41-80E8
VCID: C0CCCA5E5B6B7E4A1D-8094
VCID: B02C9A9EEBCBEECAED-80E4
VCID: C5C2DB4A44495B622E-8090
Revision: --------
Coding: 0EC002
VCID: B32695921ADDD5D290-80E6
VCID: 9A7858369D77049AB3-80CE
End----------(Elapsed Time: 02:04, VBatt start/end: 12.9V/12.8V)-----------
