I would like to enable the Automatic Parking Brake in [03 - ABS] but can't find the security access code.
Thursday,18,April,2019,17:36:36:55430
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(Parallels)
VCDS Version 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: WAUC4CF59JA081319 License Plate:
Chassis Type: F5-AU49 (8W8)
Scan: 01 02 03 08 09 15 16 17 19 20 29 32 36 39 3C 42 44 46 47 52
5F 6C 6D 74 81 A9 BB BC CA CF D6 D7
VIN: WAUC4CF59JA081319 Mileage: 807km-501miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels:. 07K-907-309-V1.clb
Part No SW: 8W0 907 559 H HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0008
Revision: B2H22000
Coding: 1A2A00322326010E34280000000000000000000000000000
Shop #: WSC 06334 790 00001
ASAM Dataset: EV_ECM30TFS0118W0907559H 001009
ROD: EV_ECM30TFS0118W0907559H.rod
VCID: 4ACD63663C328137009-801F
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 8W0 927 158 C HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1006
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 42DD4B4604025977C89-8017
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Coding: 1CAA149A30AA0A9711A1489240865292E4258838280C508812024A4927A411
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4DC7687ACD5C960F25B-8019
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 1608050D5544000D10020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14D5E1E165747FA5-8011
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002102864
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: B1815C0900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501563E0691CCD050D511918AC9CB9110B1D040000000000000000200016010A690122025709
VCID: 025D8B4644829977889-8057
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 301117 036 0471
Serial number: 00000001711270302282
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 21058202X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AK HW: 4M0 941 531 AK
Component: E1 - LDS H06 0008
Serial number: 15 12 2017 01218242
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z00K002
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180111103259 00644
Interior Light Module:
Subsystem 6 - Part No SW: 8W0 947 135 CS HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00657566
Subsystem 7 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2817000294597004
Subsystem 8 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0034
Serial number: 7008174235B180101213
Coding: BF0500
Subsystem 9 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0034
Serial number: 7008174235B180101924
Coding: B30500
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 J HW: 8W0 959 655 J
Component: Airbag10.44 H09 0107
Serial number: 003US000F1WN
Coding: BFCCF0C000800000A0000033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 50F9710EDA6EBBE74ED-8005
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 8W0857705G0023S01851
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 8W0857706J0023S00873
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180008SGWB0/
Subsystem 4 - Part No SW: ----------- HW: 442 060 601 18
Serial number: 3577Y00A126EBEF4424E
Subsystem 5 - Part No SW: ----------- HW: 442 060 601 18
Serial number: 3587Y00A328643D171C+
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 901 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700A128FA3F6B2AU
Subsystem 7 - Part No SW: ----------- HW: 442 0B0 901 18
Serial number: 3527700A128FA3F1E24N
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 607 17
Component: FrontSensor_D 1C5 014A
Serial number: 35575009D27ACA12C2EX
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 607 17
Component: FrontSensor_P 1C5 014A
Serial number: 35675009D27ACA13135G
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GB HW: 4M0 907 129 GB
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E796184AB5D7B41-8023
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0373
Coding: 08AF49CB38A800080223E9401800000000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 43D34E421B18507FC3F-8017
Part No SW: 8W8 907 468 F HW: 8W8 907 468 E
Component: Gateway H42 0123
Revision: 7D000001 Serial number: 0187D757218125
Coding: 03010001000006405407000000590012EC980000900000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4FFB7272C750A41F577-801B
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20180120014950 00160
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 7405356404
Address 20: High Beam Assist. (J844) Labels:* None
Part No SW: 8W0 857 511 C HW: 8W0 857 511 C
Component: FLA H10 0003
Revision: AB001001
Coding: 0404000B00010001000002
ASAM Dataset: EV_HighBeamAssisAU736 001015
ROD: EV_HighBeamAssisAU736.rod
VCID: 3D2738BA7DFC268FB5B-8069
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
VCID: 78A9E9AE125EC3A7A6D-802D
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605803505200707
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 79AFECAA2954DAAFD93-802D
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000300631956
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 0E0002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 3635279658CAF5D7741-8063
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0129
Serial number: 0000300211189
Coding: 005D5B625E001080001104B2
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 013400004FB100C0650BA0006E01080233004000810026502F0400000F04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 015F844A4184826F913-8055
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1734702K0
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099865526
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: >1197986
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Fault Frequency: 37
Reset counter: 74
Mileage: 764 km
Date: 2019.04.18
Time: 09:31:06
Supply voltages-Supply voltage: Terminal 30: 12.636 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.555 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 98
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA03E0R3
Coding: 0194030800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI_AU49.rod
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0129
Serial number: 0000297915682
Coding: 005D5B225E001080001104B0
Part No SW: 8W5 035 880 C HW: 8W5 035 880
Component: MU-P-LNS-US 034 1316
Serial number: A798A0JB082306
Coding: 019453020000000053220002041A00002F0012E401700104FE
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 3FDB42B277F0349FA77-806B
Subsystem 1 - Part No SW: V03 959 802 DK HW: -----------
Component: NAR 2018/2019 --- 0066
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00127101700820071
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK113121700020004
Component: Gracenote2 --- 3012
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG061911
Coding: 02940302BA0FA10038404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
VCID: 3537209A45CCFECF7DB-8061
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0163
Revision: -------- Serial number: 31760475100000
Coding: 0630
ASAM Dataset: EV_DeckLidCONTIAU736 001015
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 48C9596E223E732716D-801D
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 H HW: 8W0 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 1501180581
Coding: 1460484958
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 4CC1657E36469F07325-8019
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18010845488195
ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 H HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 171220202074
VCID: 46D55756282A6557E41-8013
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0129
Serial number: 0000298929270
Coding: 000D5B2200001080400000A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 45D7505A152C6E4FEDB-8011
Component: TSG HBFS 005 0129
Serial number: 0000298924175
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 228000049301
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 0E0002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 33331E824BB8E0FF53F-8067
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176BCA123F002CDF4F7-8043
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----------(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.2V)-----------
