Results 1 to 2 of 2
Thread: VW Golf Cornering lights switch off
    Aug 2016
    Customer got damaged car and repaired but he put in new lights that does not have cornering lights and can't change them because it is already fitted.
    He asked me to switch off this feature,
    How can I reprogram the BCM to have no cornering light fitted as he get warning on dash insert of bulbs failer.
    Thursday,18,April,2019,12:56:21:46973
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
    Workshop Code: 000 18261 018261
    VIN: WVWZZZAUZFW295472   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
    VIN: WVWZZZAUZFW295472   Mileage: 84360km-52418miles
    Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0005
       Revision: --H13---
       Coding: 091900322446050B2004
       ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
       ROD: EV_ECM20TFS0205G0906259E.rod
       VCID: B02C599DEB94AECAED-80E4
    Readiness: 1110 0001
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 60665000000243
       Coding: 01FA93A154292971077B070741C56980C92A94E0E08296F714405078C008
       VCID: C8DC117D7304060AD5-809C
       Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
       Revision: 00001K08
       Coding: 00120004200100011005000000101000
       VCID: E99AF4F908CE1F02EA-80BC
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 69
                        Mileage: 84360 km
                        Date: 2019.03.27
                        Time: 12:53:35
                        Outside air temperature: 12.0 °C
                        Engine speed: 0 /min
                        Temperature after evaporator: 16.7 °C
                        System run time-Terminal 15 on: 6 s
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011506505044
       Coding: 03000A42C20122F30B244080B10C07281000000000000000000000000000
       Shop #: WSC 18261 000 18261
       ROD: EV_BCMBOSCH_013.rod
       VCID: 804CC95D1BB4FE4A5D-80D4
       Component: WWS    150224  042 0551
       Serial number:         150228192055
       Component: RLHS  037 0059
       Serial number: S4Y15M03D12H16M59S25
       Coding: 00A8DD
       Serial number: 000000000ZY150400FWX
       Serial number: 00000000000031849870
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391506504356
       Coding: 0071051001
       VCID: BD3270A92CC653A276-80E8
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 11021503271489
       Coding: 00000300FE0739
       VCID: B83C61BD03E4768AA5-80EC
       Component: AirbagVW20    014 0386
       Serial number: 003MLR0D5FDX
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: FF4E4AA1664A81B224-80AA
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169661C10021570840
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34169662C10021540987
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 303 15
       Serial number: 357670000003C995931-
       Subsystem 4 - Part No SW: -----------    HW: 480 000 303 15
       Serial number: 358670000007A565931W
       Subsystem 5 - Part No SW: -----------    HW: 480 402 502 15
       Serial number: 3516502A51993FB641FP
       Subsystem 6 - Part No SW: -----------    HW: 480 402 502 15
       Serial number: 3526502A31993FB3531A
       Subsystem 7 - Part No SW: -----------    HW: 480 400 403 15
       Serial number: 3556502AF19DB8A1812T
       Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 06031504401130
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: FBB6BEB172529D9208-80AE
       Part No SW: 5G1 920 958     HW: 5G1 920 958
       Component: KOMBI         304 4310
       Coding: 27AD00002F80260001882A011400000000000000
       VCID: EE9087E53120F83ABF-80BA
       Revision: --------    Serial number: 25021510802548
       Coding: 030100042F085900EF00027E080F00010001050000000000000000000000
       ROD: EV_GatewConti_011_VW37.rod
       VCID: F2A893952518DCDA5B-80A6
       Component: E221__MFL-DC1  H10 0040
       Serial number: 27150000389820075095
       Coding: 2CFFFF
       Serial number: 7686495903
       Serial number: HA1-00004.02.15
       Coding: 0001
       VCID: C6C01F457910107A27-8092
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 220215BBM09259
       Coding: 003F0220D001048100001000
       VCID: C2C8035555382C5A0B-8096
       Coding: 8103
       VCID: B73E62810EFA79F2AC-80E2
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 010315BC100299
       Coding: 003F0020DE01048100801000
       VCID: C1CA0C59503E374212-8094
       Coding: 02AE01000B000200
       VCID: C0CC095D5B343E4A1D-8094
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H04 0012
       Coding: 2E0000
    5276691 - Stationary Cornering Lamp Right
              C1084 13 [137] - Open Circuit
                        Reset counter: 5
                        Mileage: 81755 km
                        Date: 2018.12.27
                        Time: 00:05:55
       Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
       Component: MU-S-D-ER     041 0421
       Serial number: V5C00403152850
       Coding: 02730000FF00000021111201000800001F0207060100010001
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 9F0EAA21860A21B244-80CA
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H60 0030
       Serial number: VWZ8Z9RS207RZ2
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 150129202011
       VCID: AD1240E9FCA6C322C6-80F8
    End----------(Elapsed Time: 01:50, VBatt start/end: 12.1V/12.1V)-----------
    I changed coding in Address 55: Headlight Range (J745)
    from Coding: 02AE01000B000200
    to Coding: 02AE01000B000000
    Is this correct for Corning lights deactivate?
    ^^^ hmm........ changing Byte 6, Bit 1 on hex55 module is worth a try (IMO).
    As for BCM (if the hex 55 module change isn't enuff), the software switches that tell the module what type of lighting is installed happens in Byte 2, Bits 0-2 like this:
    No Function=hex0
    Basic_FLA=hex1
    AFS,BCM-Highbeam=hex2,
    AFS,FLA,BCM-Highbeam=hex3
    AFS,Highbeam+ueber AFS=hex4
    AFS, FLA Highbeam+ueber AFS=hex5
    AFS,FLA_High_beam(GLW,MDF)= hex6
    Your BCM is currently coded as hex2 - so the BCM believes that the car still has Xenon headlight assemblies. If "he" did not retrofit with incandescent headlights, there isn't a specific combination of software switches for Xenon without AFS (Advanced Frontlighting System). If the car does have incandescent headlight lamps - try hex0
    However, if Xenon lamps are fitted (without AFS lamps - is this possible?) there is an adaptation channel in the BCM with the name IDE03638-ENG116674-static AFS light-Vorschrift which I believe means AFS light - regulation. I don't have access to a mk7 at the moment, but there may be a "not active" setting in this channel- perhaps
    VW Golf MkVII (103TSI) my13
  3. Likes Souriau liked this post
