- Joined
- Jul 15, 2018
- Messages
- 4
- Reaction score
- 0
- Location
- Netherlands
- VCDS Serial number
- HC475228 (2nd Hand)
Hi all,
I just finished retrofitting my trailer hitch. Everything seems to work fine, except for the brake light. Also I have issues coding the module, only the first byte can be changed (region), all other bytes are throwing an "out of range" exception.
What I have done to troubleshoot:
Replaced fuses
Checked wiring/connectors to/from the module
Tried to change the modules code without longcode helper
Changed WSC
Changed region (US -> braking is using the signal lights which is not allowed in Europe/RoW -> No brake lights)
Used meas. blocks which result in:
Group 003 - Input signals - Goes on and off
Group 005 - Output signals - Nothing happens
Group 008 - Input signals via CAN - Goes on and off
Errors when trailer is connected:
Trailer
Cent. Electr.
Full log:
Replaced fuses
Changed WSC
Trailer
Wednesday,17,April,2019,20:17:40:29879
VCDS Version: 18.9.1.0 (x64)
Workshop Code: 123 12345 000001
VIN: License Plate: TARABASS
Address 69: Trailer Labels: 1K0-907-383-V2.clb
Control Module Part Number: 1K0 907 383 E HW: 1K0 907 383 E
Component and/or Version: Anhaenger H07 0050
Software Coding: 4100000100000000
Work Shop Code: WSC 12345 123 00001
VCID: 2F66D0E37E69FB3274-807A
02562 - Trailer; Brake Lamps
Fault Status: 11101010
Reset counter: 136
Mileage: 259074 km
Date: 2047.14.11
Time: 20:14:21
Cent. Electr.
Wednesday,17,April,2019,20:26:07:29879
VIN: WVWZZZ3CZ7E036138 License Plate: TARABASS
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 J HW: 3C0 937 049 J
Component and/or Version: Bordnetz-SG H37 1301
Software Coding: EF8A0F0F001E1A0000000F001E000000001B4D435C0000
Work Shop Code: WSC 16272 162 16272
Additional Info: 3C1955119 Wischer VW461 012 0503 1K0955559AE RLS 160606 014 1201
VCID: 3064D39FA357E4CA6D-8064
Reset counter: 136
Mileage: 259074 km
Voltage: 14.05 V
Full log:
Sunday,14,April,2019,14:36:57:29879
Workshop Code: 000 12345 000000
Mileage: 258900km-160873mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 53 55 56 62 69
6C 6D 72 7D
VIN: WVWZZZ3CZ7E036138 Mileage: 258900km-160873miles
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 NK HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 9972
Revision: --H02--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00420 211 96882
VCID: 75EA228B1CB581E2FE-8020
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667621424
Coding: 0032034
Shop #: WSC 05311 000 00000
VCID: 3260D997AD5BD6DA1B-8066
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AF HW: 3C0 907 044 AF
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 65CA72CBAC1571624E-8030
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005827875
Shop #: WSC 16272 162 16272
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 16272
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 160606 014 1201
Coding: 00471085
Shop #: WSC 16272
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 56D 919 475 HW: 56D 919 475
Component: PARKHILFE 8K H01 0005
Revision: -------- Serial number: 64211214800215
Coding: 318001
ASAM Dataset: EV_EPHVA18VW4110000 001006
ROD: EV_EPHVA18VW4110000.rod
VCID: 72E01997A5DB96DADB-8026
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 04 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PARDEQ1
Coding: 0012340
VCID: 2D5ACAEBB465892246-8078
Subsystem 1 - Serial number: 6332MSME0D75385A
Subsystem 2 - Serial number: 6342MSME1168735D
Subsystem 3 - Serial number: 6351HTS6QLL6APD2
Subsystem 4 - Serial number: 6361HTS6OLLQQMN2
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0000512
VCID: 72E019976DDB96DADB-8026
Subsystem 1 - Part No: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Coding: 00000226
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 D HW: 3AA 920 870 D
Component: KOMBI H03 0607
Coding: 161D00
Shop #: WSC 05314 115 12345
VCID: 336EDC939A41DFD210-8066
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P077160F1B
Coding: F9A17F564242022002
Shop #: WSC 05792 115 22390
VCID: 234E2CD3E2A14F52E0-8076
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 00742 003 1048576
VCID: 3972EEBB702D2582DA-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 HW: 3C0 035 279
Component: RNS315 H05 0010
Serial number: VWZAZ2L8395963
Coding: 000500110100000000020000
Shop #: WSC 06186 123 06186
ASAM Dataset: EV_RNS315VWEUV1UDS A01005
ROD: EV_RNS315VWEUV1UDS.rod
VCID: 60C463DF7B37144ABD-8034
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0529
Revision: 12110009 Serial number: 0002610770
Coding: 0011F7
VCID: 356AE28B9435C1E23E-8060
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388__TSG-HL 004 1114
Serial number: 00000000221584
Coding: 0000D0
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.135 H07 1806
VCID: 346CDF8F574FD8EA09-8060
Component: KSG PQ46 ELV 042 0472
Coding: 0891080851034E7F0002951570088F0B607C00
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0529
Revision: 14110009 Serial number: 0002615641
Coding: 0011F6
ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
VCID: 3668E5878933CAFA37-8062
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389__TSG-HR 004 1114
Serial number: 00000000213110
Coding: 0000D0
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
VCID: 214226DBF8BD5D42F2-8074
Component: AFS-Steuergeraet 0136
Coding: 2311185
Shop #: WSC 05674 123 12345
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000035
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0050
Revision: 3A002002 Serial number: 00000113171119
Coding: 0100000100000000
Shop #: WSC 12345 000 00000
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J850797
Coding: 0030007
VCID: 5FC660238E492BB284-800A
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 J HW: 3C9 827 383 J
Component: J605 HECKDECKEL 0804
Revision: 00H52001
Shop #: WSC 05311 000 08193
VCID: 3874EBBF4B273C8A25-806C
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
014 - Defective
End-------------------------(Elapsed Time: 02:40)--------------------------
