Results 1 to 6 of 6
Thread: 07 jetta 2.0 FSI lean burn off idle, and possible 519 control module network issues?
    May 2016
    This car has several issues, main one key does not communicate with locking system. Have not validated key battery, but wonder is J519, which I guess many manufacturers call body control has an issue. Also need to get a wire diag but on the 07Jetta is this thing under the seat and floating in water. Also the lean burn up off idle would like to access is the HPFP follower going west, all questions as I'm not into the gas engines, mostly diesel. Question??, with vag hooked up will I see a signal if looking at specific door locks when key buttons is initiated?? He is driving it now and will see what pops up again over time, but some went away and did not come back initially, will see.
    Showed 2 scans here, then cleared all codes and see which come back over time as did not know who has played around in there before me. any advice would be appreciated, have a nice day.
    LARIMORE.
    Tuesday,16,April,2019,08:03:40:01722
    VCDS Version: 18.9.1.0 (x64)
    VIN: 3VWXJ71K07M053595   License Plate: KENT
    Mileage: 182360km-113313mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 37 42 44 46 47 52 55 56 62
              65 72
    VIN: 3VWXJ71K07M053595   Mileage: 182360km-113313miles
    62-Door, Rear Left -- Status: Malfunction 1010
       Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0040
       Revision: 5BH14---    Serial number: VWZ7Z0F8085563
       Coding: 0403010A1C070160
       Shop #: WSC 23322 444 50471
       VCID: 2B5E1D9C8A038A1258-807E
    008567 - Bank 1; System Too Lean off Idle
                   P2177 - 001 -  - MIL ON
                        Fault Status: 11100001
                        Mileage: 182174 km
                        Time: 00:41:23
                        RPM: 2349 /min
                        Load: 32.5 %
                        Speed: 92.0 km/h
                        Temperature: 90.0C
                        Temperature: 10.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.224 V
       Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
       Component: GSG DSG         070 1158
       Revision: 04507000    Serial number: 00000607190247
       Shop #: WSC 00066 000 00000
       VCID: 142CA660377D35EA69-8040
       Revision: 00H11001
       Coding: 0021122
       VCID: 73EEC5FC12B392D2D0-8026
       Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
       Component: ClimatronicPQ35 090 0909
       Revision: 00090016    Serial number: 00000000000000
       VCID: 70E4CAF063A5A9CA2D-8024
                013 - Check DTC Memory
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Revision: 00H46000    Serial number: 00000000449768
       Coding: 17078E234004150007140000001400000028770B5C0000
       VCID: 377631EC464B3EF22C-8062
       Component: Wischer 200906 020  0501
       Coding: 00038805
       Shop #: WSC 00066
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 231
                        Mileage: 182367 km
                        Voltage: 13.75 V
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7F8017815
       VCID: 2A50189885F9931AA3-807E
                000 -  -
                        Reset counter: 219
                        Mileage: 164555 km
                        Time: 01:02:56
       Component: 6A AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D05SLVW
       Coding: 0013889
       VCID: 6CDCDE804F8D4D2A11-8038
       Subsystem 2 - Serial number: 6332MSME123B61296
       Subsystem 3 - Serial number: 6342MSME117B6829H
       Subsystem 4 - Serial number: 6351HSME2B2153630
       Subsystem 5 - Serial number: 6361HSME0A6D0D77O
       Subsystem 6 - Serial number: 63727SME0A5C47121
       Subsystem 7 - Serial number: 63827SME0A600C12Z
       Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
       Component: J0527           035 0070
       Coding: 0012121
       VCID: 030E953C4213A252C0-8056
       Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
       Revision: V0003000    Serial number: VWZ7Z0F8085563
       Coding: 0023207
       Shop #: WSC 25807 067 57207
       VCID: 31620FF4A82FE0C262-8064
       Revision:   H12       Serial number: 31001067180623
       Coding: 7FBF036A07001002
       VCID: 2C5C1E808F0D8D2A51-8078
                        Reset counter: 253
                        Mileage: 181984 km
                        Time: 17:19:43
       Component: IMMO            VDD 1610
    Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
       Part No: 1K0 919 887 G
       Component:      Navigation     0050
       Coding: 0000101
       VCID: 3D7A23C4647714A2F6-8068
       Component: J386  TUER-SG FT    1125
       Revision: 12006001    Serial number: 00000528468825
       Coding: 0001205
       VCID: 3B7E2DDC7A631A92C8-806E
                        Fault Status: 00100101
                        Reset counter: 6
                        Mileage: 182163 km
    01552 - Motor for Central Locking; Drivers Door (V56); Lock
                        Fault Status: 00101100
                        Reset counter: 16
                        Mileage: 149518 km
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 231
                        Mileage: 149518 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Shop #: WSC 02069 000 90108
       VCID: 346C06E0573DD5EA09-8060
       Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
       Component:    KSG PQ35 RDK 051 0215
       Revision: 00051000    Serial number: 00000000000000
       Coding: 13900F880186281B0904058FB0880F0488DC00
       VCID: 74ECC6E017BD95EAC9-8020
                        Fault Status: 01101101
                        Reset counter: 231
                        Mileage: 182367 km
                        Time: 07:57:13
    Address 47: Sound System        Labels: 3C0-035-456.clb
       Part No: 1K6 035 456 A
       Component: 08K Audioverst.     0005
       Revision: 00003000    Serial number: 00000000010980
       Component: J387  TUER-SG BT    1125
       Revision: 12006001    Serial number: 00000045668825
       Coding: 0001204
       VCID: 3C7C2EC07F6D1DAAC1-8068
       Part No: 1T0 907 357
       Coding: 0000003
    Address 56: Radio        Labels: 1K0-035-095.lbl
       Part No: 1K0 035 095 H
       Component:        Radio        0050
       Coding: 0010046
    00857 - CD Changer Unit (R41)
       Component: J388   TUER-SG HL   1115
       Revision: 12005001    Serial number: 00000000409119
       Coding: 0001168
       VCID: 3E7824C869710FBAEF-806A
                        Reset counter: 16
                        Mileage: 151011 km
    01554 - Motors for Central Locking; Rear Doors; Lock
                        Fault Status: 01101100
                        Reset counter: 231
                        Mileage: 151011 km
       Component:    RDK              0420
       Coding: 0100101
       Component: J389   TUER-SG HR   1115
       Revision: 12005001    Serial number: 00000000453392
       Coding: 0001168
       VCID: 3F8659CC6E7B06B2E4-806A
                        Reset counter: 16
                        Mileage: 164552 km
                        Fault Frequency: 69
                        Reset counter: 231
                        Mileage: 164552 km
    End-------------------------(Elapsed Time: 02:21)--------------------------
    Tuesday,16,April,2019,08:14:38:01722
    VIN: 3VWXJ71K07M053595   License Plate: KENT 2
              65 72
    Readiness: 0110 0101
       Revision: 00H11001
       Coding: 0021122
       Coding: 00038805
       Shop #: WSC 00066
                        Reset counter: 232
                        Mileage: 182367 km
                        Voltage: 13.85 V
                000 -  -
                        Reset counter: 232
                        Mileage: 182367 km
                        Time: 08:09:06
       Coding: 0013889
       Coding: 0012121
       Coding: 0023207
       Coding: 0000101
       Coding: 0001205
                        Reset counter: 232
                        Mileage: 182367 km
                        Time: 08:11:20
       Coding: 0001204
       Coding: 0000003
       Coding: 0010046
       Coding: 0001168
       Component:    RDK              0420
       Coding: 0100101
       Coding: 0001168
    End-------------------------(Elapsed Time: 02:19)--------------------------
    May 2016
    Update, talked today, key has ability to remote trunk, so does work.
    Was able to lock and unlock back doors by removing a plug on drivers door and clickingna red switch, all new to me. Will research more
    Larimore
    http://wiki.ross-tech.com/wiki/index...9/P2177/008567
    More likely a vacuum leak or MAF Larrymore because if under load the other codes and misfires should show their face ...........unless of course FOD!
  4. Likes Uwe liked this post
    Larimore now has 500 posts here and I still have to do the CODE tags for him.
    May 2016
    Jack, thanks. Code has not resurfaced yet. Still getting my head around crank case pressure issues on these as seems more a VW issue than other cars. I know if you pull dip stick or oil fill cap idle Will get rough. Having trouble grasping how that intake is attached to crank pressure. Some think because of less ring tension in newer models that crank pressure helps in sealing. All I know is on VW is a game changer.
    Thanks again will look at leaks or MAF,
    LARIMORE
    May 2016
    UWE, have no idea what that means but works for me.
    Also lock Smith here said door lock issue might be key fob as has 4 transmitters, meaning why it worked on trunk and not door,.
    He also apprised me that this car can be key coded with the VAG, all new to me, uncharted territory.
    Great scanner by the way. Everything now is $XXXX, and a yearly subscription, great investment, if I was smart enough to use it, still time.
    LARIMORE
