2018 Skoda Karoq - tyre pressure fault
Dalg
C?ID=366943
Hi guys,
I’ve got a warning light for the tyre pressure monitoring service being unavailable.
I’ve found the following error on the ABS module. Would really appreciate some help as never had any experience with this system before.
Bit of background info is the vehicle was involved in a minor front end collision, I can’t see it being that however the only physical possibility that any damage to wheels or sensors near wheels could be the forklift that is used to move the vehicles around.
   Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
   Component: ESC           H25 0423
   Revision: 00000000    Serial number: 53367000000302
   Coding: 1F078AA134220C6E4778060762CA25F8512C30E26046A4733041F078C202420B000C6212120B095A35351919323200
   Shop #: WSC 33361 790 00144
   ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
   VCID: 025C7FB324849E07889-8056
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
16411 - Display for Tire Pressure Monitoring
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:17:07
PetrolDave
Westbury, UK
C?ID=1423
On a 2018 Karoq AFAIK the TPMS is done by software only using the ABS wheel speed sensors, have any coding changes been made to the ABS from the OEM value?
Dalg
C?ID=366943
Hi Dave,
Firstly thank you for the reply.
As far as I’m aware since the vehicle has only done 2000 miles and I purchased it directly fro the insurance company there have been no coding changes.
However I have the build sheet and it includes Pr codes for tpms sensors?
Dalg
C?ID=366943
Continued from:
https://forums.ross-tech.com/showthread.php?18273
Since these are network related faults, please post a complete Auto-Scan.
No problems. Was trying to avoid it as there are a lot of errors as most of the front end has been removed and in the process of putting all the new parts on. Essentially everything from the front panel has been removed and putting back together.
Tuesday,16,April,2019,16:48:26:47345
VIN: TMBKG7NU8J50xxxx   License Plate:
Chassis Type: NU-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 69
VIN: TMBKG7NU8J50xxxx   Mileage: 3370km-2094miles
Address 01: Engine (J623-DDYA)       Labels: None
   Part No SW: 04L 906 056 MJ    HW: 04L 907 445 E
   Component: R4 1.6l TDI   H01 5227
   Revision: 22005001
   Coding: 0125401244351D097000
   ASAM Dataset: EV_ECM16TDI03004L906056MJ 004004
   ROD: EV_ECM16TDI03004L906056MJ.rod
   VCID: 015E70BF2182851F913-8054
32096 - Active Radiator Shutter 1
          P05A2 00 [175] - Open Circuit
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 23:22:40
                    Engine speed: 763.50 /min
                    Normed load value: 29.0 %
                    Coolant temperature: 74 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.750 V
                    Air mass at air mass meter 1: 21.6 kg/h
                    Standardised airflow ratio: 1.736 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 26.39 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Charge air pressure specified value: 1.020 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1044 mbar
                    Mean injection quantity: 6 mg/stroke
                    Index of current engine mode: 0
                    Index of next requested engine mode: 0
                    Index of engine target mode: 0
15649 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [175] - Signal too High
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 23:22:36
                    Engine speed: 762.50 /min
                    Normed load value: 29.4 %
                    Voltage terminal 30: 14.718 V
                    Air mass at air mass meter 1: 36.0 kg/h
                    Standardised airflow ratio: 1.110 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.07 %
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1053 mbar
                    Index of current engine mode: 4
                    Index of next requested engine mode: 4
                    Index of engine target mode: 4
15652 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 3370 km
                    Date: 2019.04.10
                    Time: 20:19:38
                    Coolant temperature: 11 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.125 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Accelerator pedal travel: raw value: 0.00 %
                    Extern.temp.sens.1 bank 1: raw value: -50.0 °
                    Coolant fan 1: activation: 10.00 %
                    Coolant fan 2: activation: 0.00 %
                    Fuel temp. sensor 1 bank 1: raw value: 11.2 °
                    Fuel consumption: 0.00 l/h
                    Engine oil temperature: 10.4 °C
Readiness: N/A
   Part No SW: 0CW 300 042 F    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1607
   Revision: 00005008    Serial number: CU501712215821
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 392ED85F09D21DDF993-806C
21193 - No Communication with Cruise Control Module
          U0104 00 [047] - -
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 23:22:35
                    Engine speed: 15622.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 60 km/h
                    Control Module temperature: 75 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 45568
8196 - Databus
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:17:07
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0465555937
   Coding: 032C0C070F
   VCID: 3E24CB4310FC3AE7AC1-806A
   Part No SW: 565 907 044 BL    HW: 565 907 044 BL
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 06110104002110011005000800101022
   Shop #: WSC 33361 790 00119
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 6694432328EC4227041-8032
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 62526321
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 147
                    Mileage: 3370 km
                    Date: 2019.04.10
                    Time: 20:19:43
                    Outside air temperature: 63.0 °C
                    Engine speed: 800 /min
                    Compressor current: actual value: 0.020 A
                    Temperature after evaporator: 17.0 °C
                    System run time-Engine running time: 3 s
                    System run time-Terminal 15 on: 5 s
590082 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:59
                    Outside air temperature: 63.5 °C
                    Engine speed: 1000 /min
                    Compressor shut-off requirement: Low pressure event
                    Compressor current: specified value: 0.000 A
459527 - Databus
          [Klima_Sensor_02 - empfangener Fehlerwert]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Reset counter: 187
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
                    Voltage terminal 30: 14.2 V
                    Auxiliary heater: in stages-Act.val.: 0
   Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H36 0253
   Serial number: 01001735700121
   ROD: EV_BCMBOSCH_018.rod
   VCID: 065463A308ACA227A41-8052
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  047 0105
   Serial number: TAY18M01D04H02M26S11
   Coding: 00186E
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1729032K0
   Subsystem 3 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223973253779
6 Faults Found:
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 147
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 23:30:13
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [009] - Open or Short to Plus
                    Reset counter: 148
                    Mileage: 3370 km
                    Date: 2019.04.13
                    Time: 16:17:46
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:54
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Reset counter: 148
                    Mileage: 3370 km
                    Date: 2019.04.13
                    Time: 16:17:02
137217 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
204546 - Remote key 2
                    Reset counter: 147
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 23:35:29
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419617364
   Coding: 0601150111
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000.rod
   VCID: 49CEA89F59328D5F093-801C
13637888 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:59
Address 13: Auto Dist. Reg
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4PS5UWTG
   Coding: 98CCC0C0000000005C5400CF008800000065
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 055664AF35AAA93FADB-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 001 412 17
   Serial number: 357000000008493CEA2Y
   Subsystem 2 - Part No SW: -----------    HW: 454 001 212 17
   Serial number: 35800000000032404A2+
   Subsystem 3 - Part No SW: -----------    HW: 454 801 312 17
   Serial number: 3510057C48F12000000K
   Subsystem 4 - Part No SW: -----------    HW: 454 800 812 17
   Serial number: 352001A8EB512000000J
   Subsystem 5 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
1054981 - Databus
          [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                    Fault Frequency: 10
                    Reset counter: 148
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:56
   Part No SW: 5Q0 953 521 ER    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20171218501035
   Coding: 1414
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 565 920 941 A    HW: 565 920 941 A
   Component: KOMBI         204 0312
   Coding: 27A40C1D2380A60001882A011001000080000000
   Shop #: WSC 73430 031 00144
   VCID: 1A6C27D3AC1436C7709-804E
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:57
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:54
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:54
13639936 - Databus
          [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:54
   Component: GW MQB High   518 5323
   Serial number: 28121710801809
   Coding: 030100345F087300EB0002481C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewNF_VW37.rod
   VCID: 3828DD5B32D804D766D-806C
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000C1028141217
   Serial number: 75886000001712291439
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 148
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:55
                    Supply voltage: Terminal 30: 14.7 V
                    Terminal 15: On
   Serial number: 17000381976014
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE207F1122959F613-8024
   Serial number: 0000296520159
   Coding: 00110020D001040000001100
   VCID: 47CAAEA74F267B2F1F7-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000018233467
   Coding: 1D0200
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B22A776B3EA78F93F-8026
   Serial number: 0000293933283
   VCID: 46D4A3A3482C6227E41-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000018157791
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 842 C    HW: 5Q0 035 842 C
   Component: MU-S-D-ER     H41 0468
   Serial number: SKZAZ2U0364585
   Coding: 03230600FF00000001111201008808002F0208D60120050003
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2F3AE607C796C36F377-807A
   Subsystem 1 - Part No SW: 565 919 605 C    HW: 565 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: SKZ6ZHV0040005
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 146
                    Mileage: 3370 km
                    Date: 2019.04.09
                    Time: 22:16:57
                    Voltage terminal 30: 14.8 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0464516015
   Coding: 0100000202000000
   VCID: 42DCBFB364045E07C89-8016
End----(Elapsed Time: 01:47, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
I suspect the source of your first ABS faults is here:
As for the tire pressure fault, I'm not sure. Put the car back together, get rid of the other faults, and then we'll see...
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
As Uwe said, lots of that stuff can be related. Sometimes there's a whole chain of faults and you need to see the whole picture to find where the avalanche started. Certainly feel free to contextualize any of it for us, like the fact that it's missing due to ongoing repairs, etc as you have already done.
You say you have PR-code indications for direct TPMS sensors, which seems to be improbable for this car. You redacted the VIN as is your right but I can't verify the PR codes myself via PL24 without it. For indirect TPMS, I wouldn't expect any real ability to validate that without the car assembled and driven, and I'd be surprised if you can get any sort of fault to happen except a flag for some dependency it's missing.
Speaking of dependency it's missing, I believe both direct and indirect TPMS need to factor in ambient air temperature, which in your case, probably comes from G17 Sensor for Ambient Air Temperature, which is either detached or damaged. As a test, stick that back on and see if your TPMS fault becomes Intermittent and/or clearable.
MasterTommy
Amsterdam
C?ID=295586
From experience, I know that in BMW motorcycles with direct TPMS sensors (which do not differ from the ones they use in the cars except for the mounting hardware), the sensors actually know individually both air pressure and temperature. AFAIK, the temperature value is not part of what the sensor sends to the receiver (= control unit), but rather used to apply a correction on the pressure value sent to the control unit. Would have been nice to have displayed on the dashboard on a motorcycle, since knowing if your tires are warm is actually quite essential...
Anyway, regarding the OP:
As stated by previous posters; first you need to confirm what tire pressure monitoring PR-code this vehicle actually has. Indirect TPMS is also a PR-code of which the description sometimes looks pretty deceiving.
If your vehicle did have direct TPMS but no sensors are present in the wheels, a sizeable amount of control units will need coding and adaptation changes to switch over to indirect TPMS. But since there is no module 65 in your scan and no other control modules complain about that, my guess is that this vehicle never had direct TPMS or it did, they tried to code it out but half-assed it.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Wheel-level temperatures are definitely sent by the gen 1 Beru systems used on the direct TPMS vehicle I have access to (a 2006 Phaeton). I can't speak for the gen 2 stuff. Comparison to ambient temperature figures into the calculations and warning thresholds.
Anyway, this was only an offhand theory. If OP plugs in the G17 and it doesn't help, I don't think it's worth pursuing any further until the vehicle is assembled and driving and they can carry out a TPMS reset.
Dalg
C?ID=366943
Cars back together and all good. It was the outside temp sensor and all the further databus errors across most of the other systems was caused by a crimped wire to the radiator automatic blind that’s on the 1.6 diesel.
It’s nice to see no DTC’s on the car! Once the vehicle is back from the paint shop I’ll do the final fitment and hopefully that’s it. If not. See you then ;)
Thanks everyone!
