Results 1 to 10 of 10
Thread: 2018 Skoda Karoq - tyre pressure fault
    Apr 2019
    Hi guys,
    I’ve got a warning light for the tyre pressure monitoring service being unavailable.
    I’ve found the following error on the ABS module. Would really appreciate some help as never had any experience with this system before.
    Bit of background info is the vehicle was involved in a minor front end collision, I can’t see it being that however the only physical possibility that any damage to wheels or sensors near wheels could be the forklift that is used to move the vehicles around.
       Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
       Component: ESC           H25 0423
       Revision: 00000000    Serial number: 53367000000302
       Coding: 1F078AA134220C6E4778060762CA25F8512C30E26046A4733041F078C202420B000C6212120B095A35351919323200
       Shop #: WSC 33361 790 00144
       ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
       VCID: 025C7FB324849E07889-8056
    8196 - Databus
              [FCAN : ACC_10 message is not received]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
    16411 - Display for Tire Pressure Monitoring
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:17:07
    On a 2018 Karoq AFAIK the TPMS is done by software only using the ABS wheel speed sensors, have any coding changes been made to the ABS from the OEM value?
    Apr 2019
    Hi Dave,
    Firstly thank you for the reply.
    As far as I’m aware since the vehicle has only done 2000 miles and I purchased it directly fro the insurance company there have been no coding changes.
    However I have the build sheet and it includes Pr codes for tpms sensors?
    Continued from:
    https://forums.ross-tech.com/showthread.php?18273
    Since these are network related faults, please post a complete Auto-Scan.
  5. Likes Jack@European_Parts liked this post
    Apr 2019
    Continued from:
    No problems. Was trying to avoid it as there are a lot of errors as most of the front end has been removed and in the process of putting all the new parts on. Essentially everything from the front panel has been removed and putting back together.
    Tuesday,16,April,2019,16:48:26:47345
    VIN: TMBKG7NU8J50xxxx   License Plate:
    Chassis Type: NU-SK37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 69
    VIN: TMBKG7NU8J50xxxx   Mileage: 3370km-2094miles
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    Address 01: Engine (J623-DDYA)       Labels: None
       Part No SW: 04L 906 056 MJ    HW: 04L 907 445 E
       Component: R4 1.6l TDI   H01 5227
       Revision: 22005001
       Coding: 0125401244351D097000
       ASAM Dataset: EV_ECM16TDI03004L906056MJ 004004
       ROD: EV_ECM16TDI03004L906056MJ.rod
       VCID: 015E70BF2182851F913-8054
    32096 - Active Radiator Shutter 1
              P05A2 00 [175] - Open Circuit
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 23:22:40
                        Engine speed: 763.50 /min
                        Normed load value: 29.0 %
                        Coolant temperature: 74 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 14.750 V
                        Air mass at air mass meter 1: 21.6 kg/h
                        Standardised airflow ratio: 1.736 counts
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 26.39 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Charge air pressure specified value: 1.020 bar
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1044 mbar
                        Mean injection quantity: 6 mg/stroke
                        Index of current engine mode: 0
                        Index of next requested engine mode: 0
                        Index of engine target mode: 0
    15649 - Sensor for Ambient Air Temperature (G17)
              P0073 00 [175] - Signal too High
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 23:22:36
                        Engine speed: 762.50 /min
                        Normed load value: 29.4 %
                        Voltage terminal 30: 14.718 V
                        Air mass at air mass meter 1: 36.0 kg/h
                        Standardised airflow ratio: 1.110 counts
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.07 %
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1053 mbar
                        Index of current engine mode: 4
                        Index of next requested engine mode: 4
                        Index of engine target mode: 4
    15652 - Coolant Fan Control Circuit 1
              P0480 00 [039] - Electrical Malfunction
                        Mileage: 3370 km
                        Date: 2019.04.10
                        Time: 20:19:38
                        Coolant temperature: 11 °C
                        Intake air temperature: 13 °C
                        Voltage terminal 30: 11.125 V
                        Air mass at air mass meter 1: 0.0 kg/h
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Accelerator pedal travel: raw value: 0.00 %
                        Extern.temp.sens.1 bank 1: raw value: -50.0 °
                        Coolant fan 1: activation: 10.00 %
                        Coolant fan 2: activation: 0.00 %
                        Fuel temp. sensor 1 bank 1: raw value: 11.2 °
                        Fuel consumption: 0.00 l/h
                        Engine oil temperature: 10.4 °C
    Readiness: N/A
       Part No SW: 0CW 300 042 F    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1607
       Revision: 00005008    Serial number: CU501712215821
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 392ED85F09D21DDF993-806C
    21193 - No Communication with Cruise Control Module
              U0104 00 [047] - -
                        Fault Frequency: 8
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 23:22:35
                        Engine speed: 15622.25 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 60 km/h
                        Control Module temperature: 75 °C
                        CURRENT pressure: -9.5 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_6
                        Driving position: N
                        Accelerator position: 0.0 %
                        DTC memory status: 45568
    8196 - Databus
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:17:07
       Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0465555937
       Coding: 032C0C070F
       VCID: 3E24CB4310FC3AE7AC1-806A
       Part No SW: 565 907 044 BL    HW: 565 907 044 BL
       Component: Climatronic   H04 2002
       Revision: 00001K00
       Coding: 06110104002110011005000800101022
       Shop #: WSC 33361 790 00119
       ASAM Dataset: EV_ACClimaBHBVW37X 006147
       ROD: EV_ACClimaBHBVW37X_006_SK37.rod
       VCID: 6694432328EC4227041-8032
       Air quality sensor:
       Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 62526321
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 147
                        Mileage: 3370 km
                        Date: 2019.04.10
                        Time: 20:19:43
                        Outside air temperature: 63.0 °C
                        Engine speed: 800 /min
                        Compressor current: actual value: 0.020 A
                        Temperature after evaporator: 17.0 °C
                        System run time-Engine running time: 3 s
                        System run time-Terminal 15 on: 5 s
    590082 - Control Circuit for A/C Compressor
              B10A9 15 [009] - Open or Short to Plus
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:59
                        Outside air temperature: 63.5 °C
                        Engine speed: 1000 /min
                        Compressor shut-off requirement: Low pressure event
                        Compressor current: specified value: 0.000 A
    459527 - Databus
              [Klima_Sensor_02 - empfangener Fehlerwert]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
    1048835 - Functionality limited due to Engine Control Module
              P1719 00 [008] - -
              [PTC-Reduzierung durch MSG]
                        Reset counter: 187
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
                        Voltage terminal 30: 14.2 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                        Auxiliary heater: in stages-Act.val.: 0
                        Auxiliary heater: in stages-Specified value for control: 3
       Part No SW: 5Q0 937 084 CN    HW: 5Q0 937 084 CE
       Component: BCM MQBAB M   H36 0253
       Serial number: 01001735700121
       ROD: EV_BCMBOSCH_018.rod
       VCID: 065463A308ACA227A41-8052
       Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
       Component: RLHS  047 0105
       Serial number: TAY18M01D04H02M26S11
       Coding: 00186E
       Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Serial number: 000000000ZY1729032K0
       Subsystem 3 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223973253779
    5386 - Bulb for Front Right Turn Signal
              B11EA 15 [009] - Open or Short to Plus
                        Reset counter: 147
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 23:30:13
    6922 - Bulb for Low Beam Headlamp Right
              B1218 15 [009] - Open or Short to Plus
                        Reset counter: 148
                        Mileage: 3370 km
                        Date: 2019.04.13
                        Time: 16:17:46
    8458 - Bulb for Right DRL
              B121E 15 [009] - Open or Short to Plus
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:54
    9994 - Bulb for Right Parking Lamp
              B12E9 15 [009] - Open or Short to Plus
                        Reset counter: 148
                        Mileage: 3370 km
                        Date: 2019.04.13
                        Time: 16:17:02
    137217 - Outside temperature sensor
              B103F 1B [009] - Resistance Too High
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
    204546 - Remote key 2
                        Reset counter: 147
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 23:35:29
       Part No SW: 5QA 919 283 B    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0044
       Serial number: 000308419617364
       Coding: 0601150111
       ASAM Dataset: EV_EPHVA14AU3700000 009033
       ROD: EV_EPHVA14AU3700000.rod
       VCID: 49CEA89F59328D5F093-801C
    13637888 - Databus
              [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:59
    Address 13: Auto Dist. Reg
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W4PS5UWTG
       Coding: 98CCC0C0000000005C5400CF008800000065
       ROD: EV_AirbaVW21TS6VW48X_VW37.rod
       VCID: 055664AF35AAA93FADB-8050
       Subsystem 1 - Part No SW: -----------    HW: 454 001 412 17
       Serial number: 357000000008493CEA2Y
       Subsystem 2 - Part No SW: -----------    HW: 454 001 212 17
       Serial number: 35800000000032404A2+
       Subsystem 3 - Part No SW: -----------    HW: 454 801 312 17
       Serial number: 3510057C48F12000000K
       Subsystem 4 - Part No SW: -----------    HW: 454 800 812 17
       Serial number: 352001A8EB512000000J
       Subsystem 5 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_D  --- ----
    1054981 - Databus
              [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                        Fault Frequency: 10
                        Reset counter: 148
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:56
       Part No SW: 5Q0 953 521 ER    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20171218501035
       Coding: 1414
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 565 920 941 A    HW: 565 920 941 A
       Component: KOMBI         204 0312
       Coding: 27A40C1D2380A60001882A011001000080000000
       Shop #: WSC 73430 031 00144
       VCID: 1A6C27D3AC1436C7709-804E
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_AWV_0x1B keine Kommunikation]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:57
    16776960 - Databus
              [ACC_02 keine Kommunikation]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:54
    16776961 - Databus
              [ACC_04 keine Kommunikation]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:54
    13639936 - Databus
              [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:54
       Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5323
       Serial number: 28121710801809
       Coding: 030100345F087300EB0002481C0F00010001070000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewNF_VW37.rod
       VCID: 3828DD5B32D804D766D-806C
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000C1028141217
       Serial number: 75886000001712291439
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
              [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                        Fault Frequency: 8
                        Reset counter: 148
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:55
                        Supply voltage: Terminal 30: 14.7 V
                        Terminal 15: On
       Serial number: 17000381976014
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BE207F1122959F613-8024
       Component: TSG FS        011 0032
       Serial number: 0000296520159
       Coding: 00110020D001040000001100
       VCID: 47CAAEA74F267B2F1F7-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000018233467
       Coding: 1D0200
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1081
       Coding: 01170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73B22A776B3EA78F93F-8026
       Component: TSG BFS       011 0032
       Serial number: 0000293933283
       VCID: 46D4A3A3482C6227E41-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000018157791
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 842 C    HW: 5Q0 035 842 C
       Component: MU-S-D-ER     H41 0468
       Serial number: SKZAZ2U0364585
       Coding: 03230600FF00000001111201008808002F0208D60120050003
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2F3AE607C796C36F377-807A
       Subsystem 1 - Part No SW: 565 919 605 C    HW: 565 919 605 C
       Component: ABT_Std-2  H50 8130
       Serial number: SKZ6ZHV0040005
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 146
                        Mileage: 3370 km
                        Date: 2019.04.09
                        Time: 22:16:57
                        Voltage terminal 30: 14.8 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0464516015
       Coding: 0100000202000000
       VCID: 42DCBFB364045E07C89-8016
    End----(Elapsed Time: 01:47, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
    I suspect the source of your first ABS faults is here:
    As for the tire pressure fault, I'm not sure. Put the car back together, get rid of the other faults, and then we'll see...
  8. Likes PetrolDave, Dalg liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Dalg View Post
    As Uwe said, lots of that stuff can be related. Sometimes there's a whole chain of faults and you need to see the whole picture to find where the avalanche started. Certainly feel free to contextualize any of it for us, like the fact that it's missing due to ongoing repairs, etc as you have already done.
    You say you have PR-code indications for direct TPMS sensors, which seems to be improbable for this car. You redacted the VIN as is your right but I can't verify the PR codes myself via PL24 without it. For indirect TPMS, I wouldn't expect any real ability to validate that without the car assembled and driven, and I'd be surprised if you can get any sort of fault to happen except a flag for some dependency it's missing.
    Speaking of dependency it's missing, I believe both direct and indirect TPMS need to factor in ambient air temperature, which in your case, probably comes from G17 Sensor for Ambient Air Temperature, which is either detached or damaged. As a test, stick that back on and see if your TPMS fault becomes Intermittent and/or clearable.
    Silence gives consent.
  10. Likes Uwe, Jack@European_Parts, Dalg liked this post
  11. #8
    Dec 2016
    Amsterdam
    From experience, I know that in BMW motorcycles with direct TPMS sensors (which do not differ from the ones they use in the cars except for the mounting hardware), the sensors actually know individually both air pressure and temperature. AFAIK, the temperature value is not part of what the sensor sends to the receiver (= control unit), but rather used to apply a correction on the pressure value sent to the control unit. Would have been nice to have displayed on the dashboard on a motorcycle, since knowing if your tires are warm is actually quite essential...
    Anyway, regarding the OP:
    As stated by previous posters; first you need to confirm what tire pressure monitoring PR-code this vehicle actually has. Indirect TPMS is also a PR-code of which the description sometimes looks pretty deceiving.
    If your vehicle did have direct TPMS but no sensors are present in the wheels, a sizeable amount of control units will need coding and adaptation changes to switch over to indirect TPMS. But since there is no module 65 in your scan and no other control modules complain about that, my guess is that this vehicle never had direct TPMS or it did, they tried to code it out but half-assed it.
    Current:
  12. Likes jyoung8607, Uwe, PetrolDave, Dalg liked this post
  13. #9
    Cincinnati, OH
    Quote Originally Posted by MasterTommy View Post
    Wheel-level temperatures are definitely sent by the gen 1 Beru systems used on the direct TPMS vehicle I have access to (a 2006 Phaeton). I can't speak for the gen 2 stuff. Comparison to ambient temperature figures into the calculations and warning thresholds.
    Anyway, this was only an offhand theory. If OP plugs in the G17 and it doesn't help, I don't think it's worth pursuing any further until the vehicle is assembled and driving and they can carry out a TPMS reset.
  14. Likes Uwe, Jack@European_Parts, Dalg liked this post
  15. #10
    Apr 2019
    Cars back together and all good. It was the outside temp sensor and all the further databus errors across most of the other systems was caused by a crimped wire to the radiator automatic blind that’s on the 1.6 diesel.
    It’s nice to see no DTC’s on the car! Once the vehicle is back from the paint shop I’ll do the final fitment and hopefully that’s it. If not. See you then
    Thanks everyone!
  16. Likes jyoung8607, Dana liked this post
