Results 1 to 4 of 4
Thread: Help! Canít recode abs with vcds lite
    Verified VCDS-Lite User
    Apr 2019
    Help! Canít Recode ABS with VCDS Lite
    Chassis Type: 4B - Audi A6 C5
    Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
    Address 01: Engine       Labels: None
       Controller: 4D0 907 560 CE
       Component: 4.2L V8/5V      G   0002
       Coding: 07752
       Shop #: WSC 02325
       VCID: 6BA94FB00A9D
       WAUML64B62N148552     AUZ7Z0B2121682
    Readiness: 0110 1101
    Address 02: Auto Trans       Labels: 01L-927-156.LBL
       Controller: 4D0 927 156 EA
       Component: AG5 01L 4.2l5V  RdW 1010
       Coding: 00001
       Shop #: WSC 02314
       VCID: 6CAB4CAC0F93
    Address 03: ABS Brakes       Labels: 4B0-614-517.LBL
       Controller: 4B0 614 517 R
       Component: ABS/ESP allrad      2330
       Coding: 06397
       Shop #: WSC 12345
       VCID: 301398DCE33B
    01486 -  System Function Test Activated
                35-00 -   -
    Address 06: Seat Mem. Pass       Labels: None
       Controller: 4B0 959 760 C
       Component: Sitzmemory R1 BF    0103
       Coding: 00003
       VCID: 2D2D81A8F409
    Address 08: Auto HVAC       Labels: 4B0-820-043-MY1.LBL
       Controller: 4B0 820 043 AD
       Component: A6-Klimavollautomat 0105
       Coding: 00010
       Shop #: WSC 02325
       VCID: 5CCB1C6CDF33
    01810 -  Actuating Motor for Temperature Flap; Right (V159)
                41-10 -  Blocked or No Voltage - Intermittent
    00716 -  Air recirculation Flap Positioning Motor (V113)
    01592 -  Air Quality Sensor (G238)
                57-10 -  Electric Circuit Failure - Intermittent
    01317 -  Control Module in Instrument Cluster (J285)
                49-10 -  No Communications - Intermittent
    01314 -  Engine Control Module
    Address 15: Airbags       Labels: 4B0-959-655-AI7.LBL
       Controller: 4B0 959 655 N
       Component: Airbag 8.4E         5001
       Coding: 0000305
       Shop #: WSC 02325
       VCID: 3B09BFF03A7D
    Address 16: Steering wheel       Labels: 4B0-907-487.LBL
       Controller: 4B0 907 487 H
       Component: Lenkradelektronik   D01
       Coding: 01015
       Shop #: WSC 02325
       VCID: 31159DD8E831
    Address 17: Instruments       Labels: 4B0-920-xxx-17.LBL
       Controller: 4B0 920 981 P
       Component: KOMBI+WEGFAHRS. VDO D11
       Coding: 03283
       Shop #: WSC 19411
       VCID: 331997D0122D
    01176 -  Key
                07-10 -  Signal too Low - Intermittent
    00849 -  S-contact at Ignition/Starter Switch (D)
                31-10 -  Open or Short to Ground - Intermittent
    01315 -  Transmission Control Module
    Address 35: Centr. Locks       Labels: 4B0-962-258.LBL
       Controller: 4B0 962 258 J
       Component: Central Lock/Alarm  D35
       Coding: 15885
       Shop #: WSC 02325
       VCID: 301398DCE33B
    9 Faults Found:
    01366 -  Opened Due to Crash Signal
                35-00 -   -
    01371 -  Alarm triggered by Door Contact Switch; Driver's Side
                35-00 -   -
    01572 -  Alarm triggered by Door Contact Switch; Passenger Side
                35-00 -   -
    01374 -  Alarm triggered by Terminal 15
                35-00 -   -
    01370 -  Alarm triggered by Interior Monitoring
                35-00 -   -
    01368 -  Alarm triggered by Luggage Compartment Switch
                35-00 -   -
    00955 -  Key 1
                09-10 -  Adaptation Limit Surpassed - Intermittent
    00956 -  Key 2
    01573 -  Alarm triggered by Door Contact Switch; Left Rear
                35-00 -   -
    Address 36: Seat Mem. Drvr       Labels: None
       Controller: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C2B8CACCF13
    Address 45: Inter. Monitor       Labels: None
       Controller: 4B0 951 178 A
       Component: Innenraumueberw.    D04
       Coding: 00101
       Shop #: WSC 02325
       VCID: 263F7E84D1FF
    01377 -  Ultra Sonic Sensor for Alarm System; Left (G170)
                27-00 -  Implausible Signal
    Address 55: Xenon Range       Labels: 4Z7-907-357.LBL
       Controller: 4Z7 907 357
       Component: dynamische LWR       D07
       Coding: 00050
       Shop #: WSC 02325
       VCID: 047B040C0703
    Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
       Controller: 4B0 035 195 J
       Component: symphony II NP2    0050
       Coding: 00225
       VCID: 27217380D6F5
    Address 75: Telematics       Labels: None
       Controller: 8E0 035 616
       Component: Telematik USA1
       Coding: 0002303
       Shop #: WSC 02325
       VCID: E2B7A2947D57
    01528 -  Auxiliary Antenna for Telematic (R90)
                004 -  No Signal/Communication - Intermittent
    00003 -  Control Module
                014 -  Defective - Intermittent
    Address 76: Park Assist       Labels: 8Z0-919-283.LBL
       Controller: 8Z0 919 283
       Component: Parkingsyst. A6 USA D08
       Coding: 01166
       Shop #: WSC 02325
       VCID: 027702141D17
    01547 -  Sensor for Parking Aid; Rear Mid-Right (G205)
                31-00 -  Open or Short to Ground
    End   --------------------------------------------------------------------------------------------------
    Hi - trying to code my abs as per Ross tech procedure but canít get past the last necessary step of calibrating the steering angle sensor
    - after coding & clearing any dtcís when I open up basic settings 001 it doesnít let me press ďGo!Ē To activate the calibration -
    I have tried many times, any help would be greatly appreciated- Thanks!!!
    Jun 2014
    Newcastle, England
    Quote Originally Posted by RunsDeep View Post
    - after coding & clearing any dtc’s when I open up basic settings 001 it doesn’t let me press “Go!”
    Because that BS Group is already selected and running. If you place your cursor in the TextBox with '001' in it; clear out the 001, re-enter it, the [Go!] button will now be Enabled to run BS on that group.
  3. Likes Uwe liked this post
    Yup, looks like the last button he clicked was [Up], which implicitly does a [Go!] on the next group.
    The fact that field 3 shows "OK" also means it did the Basic Setting successfully. The scan also shows a Coding: 06397, so I'm not sure I understand what the problem is, other than he needs to carry out the System Function Test.
    Apr 2019
    Thanks for all your help, performed system function test and all lights went away and abs is now successfully coded
    it was confusing as I was under the impression it would run some sort of test that took a few seconds. It should be noted that all you really have to do is go to 001 in basic functions - & it doesnít matter how you get there
    (pressing go is only necessary if you type 001 in the box; as just pressing the arrow up to one does the same exact thing) ... now to bleed the abs pump :0)
  6. Likes Uwe liked this post
