Results 1 to 7 of 7
Thread: Adapting instrumenr cluster
    Apr 2019
    Norway
    Hello!
    In a few posts i have mentioning that i ordered a new instrument cluster, and that was just put in and the car started. Lucky for me since the seller didnt send the pin for instrument cluster.
    Sooo, my immo is "deleted" or removed or something from a tuner. But immo lights are flashing..
    Even if the immo is "deleted" can i adapt the cluster to the ecu so i can get rid of the blinking immo light?
    Quote Originally Posted by Krish View Post
    Hello!
    It will be very difficult for anyone to provide meaningful answers here without knowing what kind of car this is.
    Of course there is always the low-tech approach too.
    Apr 2019
    Norway
    ah so sorry about that! it is an 2000 mod audi a4 b5 1.8tqs
    here is the auto scan:
    Tuesday,16,April,2019,21:36:26:20400
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    Mileage: 243230km-151136mi   Repair Order:
    Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
       Mileage: 243230km-151136miles
    Address 01: Engine        Labels: 058-907-557-AJL.lbl
       Part No: 8D0 907 558 DA
       Component: 1.8L R4/5VT MOTR HS D01
       Coding: 04001
       VCID: 73B3DE9502A1D39F93F-4B1E
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
       Part No: 8E0 614 111 A
       Component: ABS/EDS 5.3 QUATTRO D10
       Shop #: BB 24334
       VCID: 1C61D529CFBF3CE7625-51F2
    Address 08: Auto HVAC        Labels: 8D0-820-043-1D.lbl
       Part No: 8D0 820 043 P
       Component: A4     KLIMAAUTOMAT D57
       Coding: 00040
       Shop #: WSC 06325
       VCID: 2D0708EDA405C56F05B-259E
    00792 - A/C Pressure Switch (F129)
    Address 15: Airbags        Labels: 8D0-959-655-AI8.lbl
       Part No: 8D0 959 655 F
       Component: Airbag Front+Kopf  2001
       Coding: 00306
       Shop #: WSC 00030
       VCID: 392F2CBD604D69CF993-5160
    Address 17: Instruments        Labels: 8D0-920-xxx-17.lbl
       Part No: 8D0 920 980 G
       Component: B5-KOMBIINSTR. VDO D07
       Coding: 00144
       Shop #: WSC 00050
       VCID: 2F3B12E5AE09B77F377-5160
       Component: AUZ7Z0X1172883
            AUZ7Z0X1172883
    01176 - Key
                07-00 - Signal too Low
    01177 - Engine Control Unit
                49-00 - No Communications
    Address 35: Centr. Locks        Labels:. 8D0-862-257.lbl
       Part No: 8D0 862 257 B
       Component: ZV-Pumpe, Funk      D12
       Coding: 12865
       Shop #: WSC 06325
       VCID: 2C0105E99F1FCC67125-4F0C
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
                35-00 -  -
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00102
       Shop #: WSC 06325
       VCID: 6099A1D9A3575807FED-4AA4
    End----------(Elapsed Time: 03:57, VBatt start/end: 12.0V/12.2V)-----------
    OK, this car is nominally Immo-2, but with "Immo-3 ready" cluster. I don't think there is much that can be done here without the PIN code for the cluster.
    Keys would need to be matched to the cluster to make the immo light stop flashing, and it looks like the cluster has problems talking to the key at all: 01176 - Key -- Signal too Low.
    This is also puzzling: 01177 - Engine Control Unit -- No Communications
    Apr 2019
    Norway
    Could the fault codes be because of an immo defeat/delete? Since i can drive the car normally, and it starts normally?
    It was just to plug the cluster in and it started.
    How can i match the key? Do i need pin?
    Had to swap the old cluster since it was wrong for the car, and had to jump the k and w wire.
    If there is some good how to's to match keys i would appriciate it.
  6. #6
    Jun 2014
    Newcastle, England
    Yes.
    ...had to jump the k and w wire.
    Why?
    This is what will be causing 01177 - Engine Control Unit -- No Communications
  7. Likes Uwe liked this post
    Apr 2019
    Norway
    Yes.
    Why?
    This was on the old cluster, the one that i changed. It was broken and not original for the car so all warning lamps was glowing.
    Now i got another used cluster, so i removed the jumper from k and w wire.
