Hi
Been a busy few weeks, what with a broken coil spring, service, etc. Car is a Skoda 1.6 TDI Fabia (105PS).
Not sure if it's related, I changed the fuel filter today - and the damn thing wouldn't start. I wouldn't mind but, I topped up the filter with fresh diesel. As I was cranking it - it sounded 3 warning chimes. This car has done it to me before. I cycled the ignition a few times, with the battery on charge (still connected) and then fired it up.
I used VCDS (should have used that in the first place) to prime the filter and the following code is there:
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 HW: 5J0 919 475
Component: PARKHILFE 4K H10 0002
Revision: --H10--- Serial number: 76231008302939
Coding: 100001
Shop #: WSC 13765 790 00048
ASAM Dataset: EV_SK25XParkiAssis2 S01002
ROD: EV_SK25XParkiAssis2.rod
VCID: 72BED34B74232527989-8026
1458176 - Internal Control Module Memory Check Sum Error
B2000 46 [008] - Calibration/parameter memory failure
[Steuergerät defekt - Fehler im EEPROM]
Any pointers for me to check please. I tried to clear the error - but it remains.
Coding: 100001
