Results 1 to 1 of 1
Thread: Volkswagen TDI Diesel Engines Overview
    Administrator Andy's Avatar
    Sector 7G
    This thread is a brief overview of TDI information for Santos/Bruce to give out the URL to students in tomorrow's demonstration at Morton's Automotive.
    There are 3 basic types of Volkswagen TDI engines:
    1. VE = "Verteiler" or distributor/divider. Older (typically 1996-2003) that use relatively low pressure mechanical pump to inject fuel via ball-and-spring injectors.
      http://www.cs.rochester.edu/~jag/vw/...i/injpump.html
      http://ross-tech.com/vag-com/cars/tdi.html
      http://forums.tdiclub.com/showthread.php?t=163435
    2. PD= "Pumpe Düse" or Unit Injector, typically 2004-2005
      http://en.wikipedia.org/wiki/Unit_injector
      http://forums.tdiclub.com/showthread.php?t=44072
      https://sites.google.com/site/1810ma...e-health-check
      Source: http://forums.tdiclub.com/showthread.php?t=61956
    3. CR = Common Rail, typically 2009-present
      http://en.wikipedia.org/wiki/Common_rail
      http://www.natef.org/natef/media/nat...-0-tdi-ssp.pdf
      http://www.volkswagen.co.uk/technology/diesel/tdi
    VATN (Variable Area Turbine Nozzle) Turbocharger
    Source: http://www.technologie-entwicklung.d...t15-turbo.html
    Some useful TDI procedures from the Ross-Tech Wiki:
    http://wiki.ross-tech.com/wiki/index...y_Regeneration
    http://wiki.ross-tech.com/wiki/index...CR_TDI_Engines
    http://wiki.ross-tech.com/wiki/index.php/2.0L_CR_TDI
    http://wiki.ross-tech.com/wiki/index...BKS/BMK/BUN%29
    Nice overview of DPF and Urea Injection:
    http://www.myturbodiesel.com/1000q/v...pf-audi-q7.htm
    Ross-Tech VCDS user manual:
    http://www.ross-tech.com/vcds/tour/main_screen.html
    The Ross-Tech Wiki encyclopedia of repair information:
    http://wiki.ross-tech.com/wiki/index.php/Main_Page
    Official Factory Repair Information:
    http://www.bentleypublishers.com/vol...ical-training/
    Bentley Publishers Technical Training:
    Here's an example scan of a 2012 Jetta TDI:
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Friday,23,November,2012,16:55:59:47158
    Chassis Type: 6N0
    Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
    VIN: 3VWLL7AJ9CM026390
    Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 EG HW: 03L 907 309 AA
    Component: R4 2,0L EDC G000AG 1590
    Revision: 12H14--- Serial number:
    Coding: 0050078
    VCID: 74C914C2170319B835D
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 057 A HW: 02E 927 770 AL
    Component: GSG DSG AG6 511 2705
    Revision: 05351113 Serial number: 00001105081061
    VCID: 1713034E263592A0F0F
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: B14B400C492400008D0E02ED92190042A70000
    VCID: 7BDB3FFEFA5D56C0747
    Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
    Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
    Component: VWKESSYPQ35GP 085 0802
    Revision: 00085000 Serial number: 0148571123
    Coding: 030C0C
    ASAM Dataset: EV_KESSY_PQ35GP A01018
    ROD: EV_KESSY_PQ35GP_VW36.rod
    VCID: 334BD7DE9A8D5E80EC7
    Address 08: Auto HVAC Labels: 5C0-820-047.clb
    Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
    Component: J301 Klimaanlage 0203
    Revision: 2001010S Serial number: 00000000493878
    VCID: 6FC31BAE7E253A60C8F
    Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
    Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
    Component: BCM25 JLB H3 H66 0251
    Revision: B2066001 Serial number: 04371214111142
    Coding: 7A994BBF28EB2E0008382000240884C50082502E6000000030 A000000000
    Shop #: WSC 00066 123 12345
    VCID: 2F43DBAE7EA57A6088F
    Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 002 3464
    Coding: 820000
    Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 002 3464
    Coding: 820000
    Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
    Component: J245 PS41.019 H08 0006
    Coding: 180000
    Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
    Component: E221__MFL-TAS H09 0013
    Coding: 020000
    Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
    Component: J388__TSG_HL 002 3464
    Coding: 800000
    Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
    Component: J389__TSG_HR 002 3464
    Coding: 800000
    Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
    Component: AirbagVW10G 013 0807
    Serial number: 003GTM014M2D
    Coding: 00003936
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3449D4C29F8359B8F5D
    Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
    Component: BF-Gewichtss. H10 0027
    Serial number: 6940000Y1100006A8Z0S
    Coding: 303241
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME182B6560ZZZW
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME2B04265FZZZ$
    Serial number: 3516KSME444D5411ZZZP
    Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
    Serial number: 3526KSME514D5711ZZZR
    Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Serial number: 3556LSME410B1712ZZZL
    Crash sensor for front airbag; passenger side:
    Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
    Component: F.Sens.Beif H02 ----
    Serial number: 3566LSME2A031712ZZZL
    Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
    Component: KOMBI H04 0604
    Coding: 270A01
    Shop #: WSC 00066 000 00118
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 297735B64841145056B
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 5C0 937 087 A
    Component: GW-K-CAN TP20 H66 0251
    Revision: B2066001
    Coding: 102200
    VCID: F0C198D2231BA598515
    Component: IMMO H04 0604
    Coding: 000007
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EAF58ABA0DC75F481F1
    Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
    Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
    Component: ELV-PQ35 H20 0230
    Revision: 00000000 Serial number: 11000144042004
    Coding: 4900000000000000
    Shop #: WSC 00066 790 50316
    ROD: EV_ELVMarquMPVW36X_VW36.rod
    VCID: 2E7DC6AA71AF7368839
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Revision: A1001003 Serial number: 7660318597
    Coding: 020000
    VCID: 297735B64041145056B
    Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
    Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
    Component: RNS315-NAR H32 0265
    Serial number: VWZAZ2L8461464
    Coding: 040904410100060000001000
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_RNS315NARV2UDS A01004
    ROD: EV_RNS315NARV2UDS_VW36.rod
    VCID: 236B279E2A6DCE001C7
    Component: NAR_V2 0002
    1048646 - Rear View Camera
    B1102 31 [009] - No Signal
    Fault Frequency: 10
    Reset counter: 168
    Mileage: 34973 km
    Date: 2014.14.16
    Time: 09:59:39
    B11CF 53 [009] - Deactivated
    Reset counter: 144
    Mileage: 8984 km
    Date: 2006.14.27
    Time: 10:38:57
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 70 3201
    Revision: 00H20000
    VCID: 3449D4C2578359B8F5D
    Address 47: Sound System (R12) Labels: 3T0-035-456.clb
    Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
    Component: KonzernAmp10K H06 0362
    Revision: -------- Serial number: BP225319934040
    ROD: EV_AudioVerst10KanalSTT3_VW36.rod
    VCID: 3041D8D26B9B6598915
    End ---------------------------------------------------------------------
    From: http://forums.vwvortex.com/showthread.php?4868432
    NOT a VW Marine Engine :-)
    https://www.youtube.com/watch?v=WSBOTSC2hAs
    Tinyurl of this thread:
    http://tinyurl.com/ommlump
