Results 1 to 8 of 8
Thread: Audi A6 4g, C7, Gateway and EPS bench test - EPS Unreacheable
    Apr 2019
    Romania
    Dear All,
    I`m new to this forum and i`m trying to bech test the Audi A6 (4g, C7) EPS on bech. In the past i did the same with EPS for Vw Passat B6 and worked like charm, using a passat B6 gateway, the correct wiring and VCDS.
    For now I`ve connected the (Audi A6, 4G - >2011)Gateway on bech and connected to it using CAN, but in gives me the following error :
    0276 - FlexRay Databus
    U1032 00 [009] - Initialization Failed
    Reset counter: 85
    Mileage: 149511 km
    Date: 2018.05.24
    Time: 09:44:01
    Voltage terminal 30: 11.9 V
    Voltage terminal 15: 11.9 V
    Control Module temperature: 20 C
    System status: Terminal 15 on
    Engine running: OFF
    IN ZAS_Te_X: OFF
    Terminal 15 status: On
    Datenfeld: 0
    Of course the EPS is connected as well, but it is connected on FlexRay pins of Gateway (Pin 24 + Flexray and Pin 8 - Flexray) ... and it`s not reacheble.
    Any advice ?
    I`ve triple checked the wiring and it`s correct, Maybe this EPS can be bech tested using different pins or approach, i`ve noticed the data plug has 6 pins but only 3 of them are in use. Now i`m using: Pin 2 - +12V, Pin 3 - positive Flexray (pink), Pin 5 - negative Flexray (Green) on the EPS ecu. How can i connect to this EPS on bech? I`m tired of try outs ( the EPS is 100% ok, i`ve tested it on a car not long time a go. The gateway is accesible on bech without any issues, but EPS is unreacheble. The Gateway also has optical data on it. Maybe i should loop that connection ?
    FlexRay isn't as flexible as CAN, you can't just wire up modules arbitrarily.
    At one point I saw a training video from VAG about this, but I don't think it was on Youtube, and I can't find it at the moment.
  3. Likes Dana liked this post
    Apr 2019
    Romania
    Thank you Uwe, this is the first reply on this thread. I know what you`re saying about flexibility of Flex Ray but i still need a way to communicate wth this kind of equpiment. If it works on the car, it should work on the bench. But how? Should i connect all ecus of a car on bech in order for the flexy ray to be initialized. The Gateway sais: "0276 - FlexRay Databus U1032 00 [009] - Initialization Failed" There must be a reason for this.
    Thank you all for the help!
    Quote Originally Posted by colonna View Post
    I don't know. We've not tried to do this on a bench ourselves.
    Here's a screen-shot from the AoA training video I found again:
    You should check the wiring diagrams for the car to see if the EPS is on the end of the chain or in the middle. I suppose you could determine that by measuring resistance across the + and - pins.
    Then there's the question: How many FlexRay branches exist in the car itself? It is not clear to me what (if any) interaction there is between those branches.
    Lastly, you mentioned only three pins in use:
    It seems to me that somehow, this module needs a ground connection too.
  6. Likes Viking, Dana liked this post
    Apr 2019
    Romania
    Hi Uwe, It has four branches. and J500 stand`s alone on one of them. The Flexray cable go directly to the EPS. I will try to add resistor on each branch, based on your graph, to to see if it works. This module has a different 2 pins Connector with Permenent + and -, the "-" is shared with the ecu. There is data transmision between all of them ... but before everything, the FlexRay must be initialized by the Gatwway.
    Big Thanks for the idea! I wil try it and provide feedback!
  8. Likes Uwe, Dana liked this post
  9. #6
    Apr 2019
    Romania
    I`ve tried using resistor to terminate the Flexray but without succes And, i also realized that on my gateway one branch is missing. J428 was not on this car I, also have Optical bus open circuit. Shoud i try to close the Optical bus ?
  10. #7
    I doubt the optical bus has anything to do with this.
  11. Likes colonna liked this post
  12. #8
    Apr 2019
    Romania
    It`s frustrating allready! I`m thinking to get all ecu`s for one car and do trials until i find the answer. I don`t know what i can try next
  13. Likes Uwe liked this post
