Results 1 to 8 of 8
Thread: 2015 Golf Sportwagen NAR Rear Lights Stuck On
    Jan 2018
    I have a US spec car and I have the following light (both sides) stuck on when the car is turned off and locked:
    Not sure what channel this is --any thoughts? No code, no errors. I can post [09] Cent. Elect admap if needed.
    Here is the auto scan:
    Monday,15,April,2019,15:59:22:56357
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    Dealer/Shop Name: Chimuel
    VIN: 3VWC17AU3FM516313   License Plate:
    Mileage: 75638km-46999mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
    VIN: 3VWC17AU3FM516313   Mileage: 75638km-46999miles
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5GM 906 264     HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091A00122424002F0000
       Shop #: WSC 00066 790 00218
       ASAM Dataset: EV_ECM18TFS0205GM906264 001001
       ROD: EV_ECM18TFS_VW37.rod
       VCID: 844409AC0FC7BA6A79-80D0
    Readiness: 0010 0101
       Part No SW: 09G 927 749 D    HW: 09G 927 749 D
       Component: AISIN AG6 G3  129 2866
       Coding: 010100000C000000000000000000000000000000
       ROD: EV_TCMAQ250031_002_VW25.rod
       VCID: BA38B7543D833C9A53-80EE
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 50875000000483
       Coding: 04FA6AA124210972007A020181C6292056249000408194B400430050C002
       Shop #: WSC 01383 790 50316
       VCID: C7DEDEA07E715172DC-8092
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Revision: 00001K01
       Coding: 02020004100100000000000012000000
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 854214A804FD83626E-80D0
       Part No SW: 5Q0 937 087 S    HW: 5Q0 937 087 S
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 865805111602BP
       Coding: 000018424041804169E44000000403001000000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: CBD6E2906219B512F8-809E
       Component: WWS    150403  043 0581
       Serial number:         150521102520
       Serial number: 003GCR01LNV5
       ROD: EV_AirbaVW20SMEVW37X.rod
       Occupant Detection:
       Component: BF-Gewichtss.  H11 0021
       Serial number: IBH0000J150002PRED0N
       Coding: 303138
       Subsystem 2 - Part No SW: -----------    HW: 480 003 003 15
       Serial number: 35700000000DCCFCE31B
       Subsystem 3 - Part No SW: -----------    HW: 480 002 603 15
       Serial number: 35800000000C2951931F
       Subsystem 4 - Part No SW: -----------    HW: 480 403 103 15
       Serial number: 3510002C51941315D11O
       Subsystem 5 - Part No SW: -----------    HW: 480 403 103 15
       Serial number: 3520002A31A878548381
       Subsystem 6 - Part No SW: -----------    HW: 480 400 104 15
       Serial number: 3550002AB1A14CA2035+
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 104 15
       Serial number: 3560002AB1A14CA5F2CN
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150327500211
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: BFCEC64026A119B264-80EA
       Part No SW: 5G1 920 840     HW: 5G1 920 840
       Component: KOMBI         243 4270
       Coding: 0BB5110A2180CF0502087E001000000000000000
       VCID: E484292CEF871A6AD9-80B0
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 30041510000556
       Coding: 0101000820085900FF0000081C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07027
       VCID: F1AA50782075BFC2A2-80A4
       Component: E221__MFL-DC1  H16 0101
       Serial number: 27140002727850095154
       Coding: 31FFFF
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 18051506050GBN
       Coding: 003003208C00040000000000
       VCID: BE30BB4421AB10BA6F-80EA
       Serial number: 00000000000001182805
       Coding: 011000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: C3C6CAB04A497D5200-8096
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 1505150605098O
       VCID: BD32BC482CAD0BA276-80E8
       Serial number: 00000000000001160412
       Coding: 091000
       Part No SW: 5G0 035 844     HW: 5G0 035 844
       Component: MU-S-S-US     014 0655
       Serial number: V7B01504153511
       Coding: 02730200FF00000021220001001800001F0206040100010002
       Shop #: WSC 47844 001 104857
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
       Component: ABT_Std_Plus  H60 0030
       Serial number: VWZ8Z9RS501QCL
              B11CF 53 [009] - Deactivated
                        Reset counter: 43
                        Mileage: 75615 km
                        Date: 2019.04.15
                        Time: 12:11:57
                        Voltage terminal 30: 12.9 V
                        Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                        Satellite radio tuner status-Channel selection for satellite radio: 0
                        Satellite radio tuner status-Audio Signal: Not available
                        Satellite radio tuner status-Antenna current: 0 mA
                        Satellite radio tuner status-Reception quality: Not available
                        Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2821A017F1E06000000
       Shop #: WSC 00066 790 00323
       ROD: EV_OCULowMQB.rod
    End----------(Elapsed Time: 01:17, VBatt start/end: 12.5V/12.5V)-----------
    Apr 2018
    ITALY
    it looks more of a reflex in the picture to me. is it on even with the light switch in the 0 position? how would you like those lights to behave instead?
    post an admap of 09 and let's see.
  3. Likes Chimuel liked this post
    Jan 2018
    Here is the light in question from the other side:
    Admap for 09:
    https://www.dropbox.com/s/9c4kwxfv5g...-1929.CSV?dl=0
    Jan 2018
    I have a euro switch (front/rear fog, and auto) -- in the 0 position it's on (when car is on or off). From what I can tell these should only be on when the headlights are on (low beam/high beam) but off when just on DRL.
    Retrofits!
    God loves backups.......& JPPSG!
    FOD
    Jan 2018
    Jack, not sure what you are trying to get at --and maybe it's my fault for not asking outright. I found on erWin items called M37 and M38 --I'm just not sure what those translate to (read: what 09 Adaptation Channel) in VCDS.
    Ninja edit:
    M38 descriptor ...M37 is just the other side.
    Oct 2017
    Northwest UK
    Morning
    I've not worked on a US spec car before but from what I've read the wiring and subsequent behaviour of the Leuchte sets are different from an EU spec. Have you changed any coding yet or simply installed the switch?
  9. Likes Chimuel liked this post
  10. #8
    Jan 2018
    I did perform coding to follow the RoW taillight code. Will most more details when I get to a PC.
    EDIT:
    I figured it out... the following channel was set to 183 (Unknown):
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Unknown (183) 16
    Correct:
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
