Results 1 to 8 of 8
Thread: Need Login Code for Address 13: Auto Dist. Reg (J428)
    Verified VCDS User Amedeo's Avatar
    Apr 2019
    Romania - Rm.Valcea
    Hello Ross-Tech Forum
    I need Loghin Code for Address 13: Auto Dist. Reg (J428)
    Code 14117 not working
    Monday,15,April,2019,11:57:51:61525
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4502.4
    VIN: TMBCJ9NE5J0098561   License Plate: xxxxxx
    Mileage: 29982km-18629mi   Repair Order:
    Chassis Type: NE-SK37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 4B 52
              5F D6 D7
    VIN: TMBCJ9NE5J0098561   Mileage: 29982km-18629miles
    Address 01: Engine (J623-DCYA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 RH    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H24 4380
       Revision: B5H24---
       Coding: 01250012036605081000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM20TDI01104L906026RH 004001
       ROD: EV_ECM20TDI01104L906026RH.rod
       VCID: 014A4E3E90F95F42D2-8054
       Part No SW: 0GC 300 012 B    HW: 0GC 927 711 G
       Component: GSG DQ381     H06 1405
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061.rod
       VCID: 220821B2353FA45AEB-8076
       Revision: 00000000    Serial number: 61467000001354
       Coding: 2407629124290974407C070640C4292446249002E002947236615070C089430000000012121212B8586C384E4484EE
       VCID: 77BE20E6CE3D11F2EC-8022
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0442412915
       Coding: 032C0C
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C34FFCAB79BF2AAC1-8068
       Part No SW: 5E0 907 044 AS    HW: 5E0 907 044 AS
       Component: Climatronic   H04 2001
       Revision: 00001K00
       Coding: 01010104002110011005000D00101022
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 76A02DE2C93768FAF7-8022
       Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H36 0253
       Serial number: 01001713900984
       Shop #: WSC 73430 790 00000
       ROD: EV_BCMBOSCH_018.rod
       VCID: 095A561EA8C917028A-805C
       Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 170424  051 0915
       Serial number: 887353F0401711401359
       Coding: 164DDD
       Component: RLHS  042 0105
       Serial number: S8Y17M05D29H06M27S08
       Coding: 00885D
       Serial number: 000308418617145
       Coding: 0471055051
       VCID: 4BD6AC16E235451278-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 3300600101FFC728949C810520400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E30F5C2A187E0BAEF-806A
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 47
                        Mileage: 29982 km
                        Date: 2019.04.15
                        Time: 11:12:56
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 14.6 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
    0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
              [FAULT_MISALIGNMENT_VERTICAL]
                        Reset counter: 47
                        Mileage: 29982 km
                        Date: 2019.04.15
                        Time: 11:12:56
       Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
       Component: Airbag VW21   006 0702
       Revision: --------    Serial number: 003W6P7AKRFG
       Coding: 98FCC000000000005C5400CC000800000065
       ROD: EV_AirbaVW21TS6VW48X_VW37.rod
       VCID: 085C531AB3C36E0A95-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169593D27051790602
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169592D26051790757
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 454 001 605 17
       Serial number: 35700000000DB6C8B42$
       Subsystem 4 - Part No SW: -----------    HW: 454 001 605 17
       Serial number: 35800000000F86D8B42/
       Subsystem 5 - Part No SW: -----------    HW: 454 801 705 17
       Serial number: 3510048469010000000+
       Subsystem 6 - Part No SW: -----------    HW: 454 801 705 17
       Serial number: 35200C2BDC310000000L
       Subsystem 7 - Part No SW: -----------    HW: 454 800 105 17
       Serial number: 3550028C74D10000000H
       Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0245
       Revision: FF036036    Serial number: 20170529500520
       Coding: 6414
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7CB43FCAF71B32AA81-8028
    291104 - Temperature Sensor for Heated Steering Wheel
              B1455 01 [008] - Electrical Failure
                        Reset counter: 87
                        Mileage: 29982 km
                        Date: 2019.04.15
                        Time: 11:25:14
                        Ubat 30 Voltage: 12.90 V
                        Internal error state: 0
                        LIN_Temp: 254
                        Isense: 0
                        Max.Leistung: 110
                        PWM: 0
                        Offset: 18
                        Slope: 133
                        kp: 18
                        OUT: 50
                        Temperatur Statisch: 30
                        p_t_soll_0: 34.00 °C
                        p_t_soll_1: 39.00 °C
                        p_t_soll_2: 44.00 °C
       Part No SW: 5E0 920 751 E    HW: 5E0 920 751 E
       Component: KOMBI         303 0310
       Coding: 07A40018AD80000801882A095001000000000000
       VCID: 271E30A65E1D4172BC-8072
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   433 4303
       Revision: --------    Serial number: 0006365022
       Coding: 030100045F087300EB00025E1C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 3326D4F69AC53DD210-8066
       Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000D0979120517
       Serial number: 758860000017051912EE
       Serial number: HA1-00020.04.17
       Coding: 0001
       VCID: 4AD8A912ED4F5C1A43-801E
       Revision: 00000000    Serial number: 17000143810004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424D7EA9FCB3AEA09-8060
       Component: Sitzmemory    H08 0022
       Serial number: Y0006QE328166
       Coding: 0010000000000500018480808080000000008181000000D400
       Component: HRE_Master    H12 0080
       Serial number: 0441162265
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D32F2CEAC81FBA2F6-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0440460711
       Coding: 020111
       Serial number: 0000259295020
       Coding: 001D0120DE00048000001100
       VCID: 47DE9026FE5DA1725C-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_DRV  005 0007
       Serial number: 00000000000014931721
       Coding: 010200
       Component: EPS_MQB_ZFLS  129 1072
       Coding: 0107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45C29A2EC451B362AE-8010
       Serial number: 28051710801347
       Coding: 000000070100047200003D00010000000000000000000000000000000000
       VCID: 72A811F2A55F74DADB-8026
       Serial number: 0000259188596
       VCID: 46C09D22F957B87AA7-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_PSG  005 0007
       Serial number: 00000000000014919328
       Coding: 190200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 840 C    HW: 5Q0 035 840 C
       Component: MU-S--ER      H41 0456
       Serial number: SKZAZ2T5227265
       Coding: 03730100FF00000051110001000002232F0208C40120850003
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 2D12C28E7CE16B2246-8078
       Subsystem 1 - Part No SW: 5E0 919 605 N    HW: 5E0 919 605 N
       Component: ABT_Std-2  H50 8120
       Serial number: SKZ6ZHT1530910
       Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
       Component: LED1L         H06 0005
       ROD: EV_LED_PLUS_L_KEBODAVW416_SK26.rod
       VCID: 7EB035C2E10720BAAF-802A
       Component: LED1R         H06 0005
       ROD: EV_LED_PLUS_R_KEBODAVW416_SK26.rod
    End----------(Elapsed Time: 01:33, VBatt start/end: 14.7V/14.8V)-----------
                    Address 13: Auto Dist. Reg  (5Q0 907 572 J)
    12:00:15
      IDE06307-MAS00109   Stop prevention history data-Hours 19
      IDE06308-MAS00109   Start request history data-Hours 17
      IDE08768   Mirror deviation: horizontal 24.464 °
      IDE08936   Misalignment angle: horiz -0.146 °
      IDE08937   Misalignment angle: horiz: fast algorithm -0.397 °
      IDE09380-MAS08804   Performed adjustment-Horizontal offset angle -0.02 °
      IDE11924-MAS13427   Correction angle-Horizontal correction angle: dynamic 0.000 °
      IDE11924-MAS13429   Correction angle-Horizontal correction angle: currently -0.390 °
      IDE11924-MAS13887   Correction angle-Horizontal correction angle static -0.020 °
    12:00:43
      IDE08769   Mirror deviation: vertical -24.464 °
      IDE09380-MAS08805   Performed adjustment-Vertical offset angle 2.10 °
      IDE09906   Vertical deadjustment 6.783 °
      IDE11924-MAS13428   Correction angle-Vertical correction angle: dynamic 0.000 °
      IDE11924-MAS13430   Correction angle-Vertical correction angle: currently 6.770 °
      IDE11924-MAS13888   Correction angle-Vertical correction angle static 2.100 °
    The car was moved in service with the plugs of Sensor for Automatic Distance Regulation removed. The angles were ok before.
    Thank you for your help.
    Use your brain. It does not wear out.
    I'm not sure why you posted this in Forum Support and Feedback. Moved to Car Repair Support.
    If the sensor(s) were not moved at all, have you tried just driving the car some?
    Apr 2019
    Romania - Rm.Valcea
    Mr. Uwe,
    First of all, I apologize for the place I posted, and thank you for moving it where it should be. This is my first post and I hope I will not make mistakes anymore.
    Yes, I drove my car behind the other machine at about 50 km / h and the fault did not change to intermittent.
  4. Likes Uwe liked this post
    Oct 2017
    Northwest UK
    You'll either need to adjust the screws a little or I would personally get it recalibrated. I've removed my own ACC numerous times and re-fitted it without seeing that issue. It usually happens when it's been knocked or the adjustment is slightly out.
    Apr 2019
    Romania - Rm.Valcea
    It has no screws except fastening. Everything adapts with the tester. Thanks anyway.
    Oct 2017
    Northwest UK
    If you remove it you'll see that it's fixed onto adjustment screws.
    Apr 2019
    Romania - Rm.Valcea
    I was at the dealership, and in 20 minutes was ready. Only with the tester on the stand they did recalibration. Do not have walked in any adjustment screw.
    The customer will return next week, I will make the test again and I'll post here.
    Thank you, and if you have the security code, please send me. Maybe next time I can do it myself."
  9. #8
    Quote Originally Posted by Amedeo View Post
    I need Login Code for Address 13: Auto Dist. Reg (J428)
    What exactly do you need login for, which basic setting or Adaptation, or other ?
    Did they use calibration boards, together with tester ?
    Was is static or dynamic calibration procedure ?
  10. Likes Uwe liked this post
