Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2014 Skoda Citigo MFSW retrofit
    Jul 2014
    Let us have your postcode and see if anyone is near you.
    Regards HMC
  2. Likes PetrolDave, Uwe liked this post
  3. #12
    Unverified
    Apr 2019
    I did got in touch with a guy with VCDS nearby from another forum, but than again I do NOT want to make a foul of myself and post another dodgy autoscan.
    Quote Originally Posted by HMC View Post
    Much apreciate Your help, Im in TW4, its nearby Heathrow Airport.
    Oh, I dont mind paying for doing the autoscan at the end of the day its someone's time.
    My goal is to get an answer to my main question how to and what I need to get MFSW to work on my Citigo. Im prepared to change the BCM if needed but firstly, someone need to direct me in to the right direction and apparently Ross-Tech forum is the only place were there are knowledgeable people to provide some support on the issue.
    Above all, I need to get VCDS autoscan sorted so I can make a progress...
  4. #13
    Nov 2015
    As said before, why not buy VCDS yourself and remove all doubt. It's an essential tool if you're doing stuff like this.
  5. #14
    Quote Originally Posted by pepsigo2pl View Post
    PM me a snippet of it (at least one full control module's worth of data) and I'll let you know whether it's safe to post it.
  6. Likes iichel, PetrolDave liked this post
  7. #15
    Unverified
    Apr 2019
    Quote Originally Posted by Viking View Post
    As said before, why not buy VCDS (...) It's an essential tool if you're doing stuff like this.
    it's a rather one off job, I won't be doing this once this will be all sorted so I don't think it's realy 'essential' tool for me.
    PM me a snippet of it and I'll let you know whether it's safe to post it.
    will do for sure
    Guys, to be fairly honest, this forum is my last hope. If it wouldn't be for my desperation to get it working - most probably I would just think to myself sod that I will leave it as it is - however I would realy love to have it sorted.
  8. #16
    Unverified
    Apr 2019
    Thanks to a very helpful member from the other group I do now have a legitimate autoscan.
    So can we please return to the main question: where do I connect LIN wire from MFSW, can I use LIN2 pin described as 'roof' or do I have to change BCM to something different if so, with which BCM should I replace it with....
    Wednesday,17,April,2019,21:40:29:42399
    VCDS Version: 18.9.1.0 (x64)
    VIN: TMBZZZAAZED625328   License Plate: KY14CFL
    Mileage: 55190km-34293mi   Repair Order:
    Chassis Type: AA-VW12 (6N0)
    Scan: 01 03 09 15 17 19 25 44 56 61
    VIN: TMBZZZAAZED625328   Mileage: 55190km-34293miles
    Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
       Part No SW: 04C 906 020 AP    HW: 04C 907 309 P
       Component: 1.0l R3 MPI   H23 6703
       Revision: UNH23---
       Coding: 00110012020401000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM10MPI01104C906020AP 001007
       ROD: EV_ECM10MPI01104C906020AP.rod
       VCID: 69DE313488DC7D026A-803C
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 E    HW: 1S0 614 517 E
       Component: EBC 460 ESP   H08 0012
       Serial number: A00IAPK
       Coding: 31BF24718BAF02F68CFD24F7D1B14090590100
       ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
       ROD: EV_Brake1ESPMP1TRWVW120.rod
       VCID: 316E9954608CC5C262-8064
    Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V1.clb
       Part No SW: 1S0 937 090 B    HW: 1S0 937 090 B
       Component: PQ25 BCM      H59 0563
       Revision: -8------    Serial number: --------------
       Coding: 7CB829000001000000020FF46C6BACD07740426F7E860440200000420000
       Shop #: WSC 42843 002 104857
       VCID: 326C96586D8AFEDA1B-8066
    00901 - Back-Up Lamps
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 204
                        Mileage: 55087 km
                        Date: 2019.04.16
                        Time: 10:27:16
       Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
       Component: VW10Airbag00M H03 0006
       Revision: --------    Serial number: 003MY006C5A6
       Coding: 00000000000000000000000000000000304D
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       VCID: 3D76B564ACD431A2F6-8068
       Serial number: 3575HRB405N25BG0212H
       Serial number: 3585HRB400I50L5CEOQX
       Serial number: 3555NRB401C50Q3OJ9U/
    Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
       Part No SW: 1ST 920 960 L    HW: 1ST 920 960 L
       Component: KOMBI         H32 0205
       Revision: X0032013    Serial number: 00000000000000
       Coding: 414200
       ASAM Dataset: EV_KombiUDSMM9RM10 A04752
       ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
       VCID: 5EB412E841920ABA8F-800A
       Part No SW: 6N0 909 901     HW: 1S0 937 090 B
       Component: GW-K-CAN TP20 H59 0563
       Revision: -8------
       Coding: 031100
       VCID: 70E85C50A3068CCA2D-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 1ST 920 960 L
       Component: IMMO          H32 0205
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6ADC4E388DDA761A63-803E
    Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
       Part No SW: 6R2 909 144 R    HW: 6R2 909 144 E
       Component: EPS_TRW_ALow  321 3111
       Serial number: CE1H0729
       Coding: 0007
       Shop #: WSC 56026 001 1048576
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 479AD78CFE086B725C-8012
       Part No SW: 1ST 035 156 Q    HW: 1ST 035 156 Q
       Component: Radio         H03 0063
       Revision: R0000000    Serial number: SKZAZ1N0672433
       Coding: 0000040901
       VCID: 5DB615E4449411A296-8008
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 51
                        Mileage: 55164 km
                        Date: 2019.04.17
                        Time: 13:32:27
       Part No SW: 1S0 907 534     HW: 1S0 937 090 B
       Component: Batt-regelung H59 0563
       Coding: 032B7864
       Subsystem 1 - Part No SW: 1S0 915 181 B    HW: 1S0 915 181 B
       Component: J367-BDM  H08 0210
    End-------------------------(Elapsed Time: 01:43)--------------------------
    I am aware of the faults. Nothing major, so please don't worry about.
    Special thanks goes once again to Uwe, for not moving my post straight away to Hall of Shame.
  9. Likes Uwe, PetrolDave liked this post
