Hello everybody, this is my first post here. I was directed here from a different forum as I was told I may get some support here.
I do not own a VCDS software, my autoscan is a courtesy of my mechanic.
I own a 2014 Skoda Citigo Greentech and after doing some research I've decided to add MFSW to my car. I have resourced right buttons for my citigo (VAG #5E0 919 719 C) as I wanted to keep things as original as possible, Citigo's only had buttons on one side when fitted at the factory - to my knowledge at least. I have followed fitting instructions from Polo's Forum. Ive added LIN wire and +12V to the steering wheel...
Unfortunetly, I have stumbled across an unexpected issue, my BCM doesnt have a required PIN at all. yes, I've discovered it when was struggling to add LIN wire to the T73b/17 connector. In my case, this PIN doesnt exist on the BCM its unassigned/empty.
Accordingly to car specific pin assigment diagram T73b/17 shows as unassigned where t73b/24 is described as 'LIN 2 Roof' and it is on the BCM. What is more interesting, on actual wiring diagrams for this car it shows that MFSW should be connected to T73b/17... very confusing.
To the point, question to the guys with know-how, will it make any difference if I would connect it to T73b/24 or should I start looking for new BCM. If so, which modules I should be looking for?
My apologies for creating new thread but as Im NOT verified member I could not continue on THIS THREAD
Your wisdom will be much appreciated...
Removed. Data from a clone/pirate copy of VCDS is not welcome here.
