Results 1 to 6 of 6
Thread: Adaptive xenon headlights issue
    New User
    Apr 2019
    I need your help with a problem related to the xenon adaptive headlights.
    I have an A4 B9 from 2016 and, for a few weeks, the adaptive xenon headlights no longer move with the steering wheel and the cornering light are also inactive.
    I think I did some coding or adaptation and the headlight settings were lost.
    The problem is that I can not start the learning procedure from module 09 - Central Electric.
    Every time I tried to start the procedure, after a second, appears Not Running, as can be seen from the link below.
    In VCDS, in Basic Settings, at the Label File appears, NONE.
    The car has no stored error.
    Could you please tell me if I need an extra file for 09 module?
    What can I do to start the learning procedure of the headlights?
    Thank you very much.
    https://imgur.com/a/Us4eVqu
    Sunday,14,April,2019,13:36:16:64772
    VCDS Version: 18.9.1.0
    Data version: 20190215 DS296.0
    VIN: WAUZZZF45GA016188 License Plate: BB14
    Mileage: 79001km-49088mi Repair Order:
    Chassis Type F4-AU49 (4M2)
    Scan: 01 02 03 08 09 13 15 16 17 19 3C 42 44 46 52 5F 6C 81 8B A5
    AC BB BC CF DE
    VIN: WAUZZZF45GA016188 Mileage: 79001km-49088miles
    CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
    DE-Charger 1 for mobile dev -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DETA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 026 AD HW: 04L 907 309 L
    Component: R4 2.0l TDI H33 1970
    Revision: B1H33---
    Coding: 0A254032236405083428
    Shop #: WSC 06314 790 00001
    ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
    ROD: EV_ECM20TDI01104L906026AD.rod
    VCID: 6CEFA00A8776F32A11-8038
    Address 09: Cent. Elect. (J519) Labels:* None
    Part No SW: 8W0 907 063 AC HW: 8W0 907 063 C
    Component: BCM1 MLBevo H12 0229
    Coding: 80451B42457D00CD01459754182C10F9590331000300000000 00000024001AA0274700ABC25706
    Shop #: WSC 12345 123 61029
    ASAM Dataset: EV_BCM1BOSCHAU736 015005
    ROD: EV_BCM1BOSCHAU736_015.rod
    VCID: 7CCF904AF71663AA81-8028
    Subsystem 1 - Part No SW: 8W1 955 119 HW: 8V1 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS491 150926 043 0813
    Serial number: 894353?0301526901192
    Coding: 5BC7F7
    Component: G397_RLFS H06 0004
    Serial number: 60895146
    Coding: 03005D
    Light switch:
    Subsystem 3 - Part No SW: 4M0 941 531 N HW: 4M0 941 531 N
    Component: E1 - LDS H05 0007
    Serial number: 20 08 2015 00074489
    Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
    Component: Y7_Innenspieg H09 0002
    Serial number: GX1CE119101511910105
    Coding: 030000
    Interior Light Module:
    Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
    Component: J528-Dachele H13 0080
    Serial number: Q00014647
    Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
    Component: SL-B9/Q5NF H15 0010
    Serial number: 2615000091884004
    Address 13: Auto Dist. Reg (J428) Labels:* None
    Part No SW: 8W0 907 561 A HW: 8W0 907 561
    Component: LRR4 H08 0160
    Coding: 347FFF725CFFEF08949C80B6
    ASAM Dataset: EV_ACCBOSCHAU49X 001016
    ROD: EV_ACCBOSCHAU736.rod
    VCID: 3C4F504AB796A3AAC1-8068
    Oct 2017
    Northwest UK
    Hi
    Can you please post a full autoscan. Thanks
    Did you run an autoscan before making changes? If so then you'll have a backup of your original settings in a file on your PC.
  3. Likes PetrolDave liked this post
    New User
    Apr 2019
    Thank you very much for your answer.
    I did not post the entire autoscan file because it was over 13 thousand characters.
    I also set back the old 09 -Central electric code, but it still does not work.
    I think the Basic Settings can not be return, they need to be reinitialized (please tell me if I'm wrong).
    Thank you.
    Quote Originally Posted by vasile76 View Post
    That is correct, must be so.
    Do you have equipment to adjust Headlights ?
    There is no problem posting 1000..2000 lines from Autoscan, between CODE tags.
  6. Likes PetrolDave liked this post
    Jun 2014
    Newcastle, England
    I did not post the entire autoscan file because it was over 13 thousand characters...
    Don't worry; the Forum can handle it.
  8. Likes PetrolDave, Uwe liked this post
  9. #6
    New User
    Apr 2019
    headlight issue
    I also set back the coding of the "09 Central Electric" module, but that did not change the headlight function, their position remaining fixed without adapting with the steering wheel or chassis position (headlight are set in the correct position).
    when I use the "Static Headlight ...." test, their position goes down to the lowest point, then returns to the initial position.
    Below are 2 complete autoscan reports.
    Thank you very much for your help.
              AC BB BC CF DE
       Revision: B1H33---
       Part No SW: 8W0 927 155 G    HW: 0CK 927 156 S
       Component: 0CK 20TDI RdW H04 0006
       Revision: --H04---    Serial number: 0000000274
       Coding: 010001
       ASAM Dataset: EV_TCMDL382021 002021
       ROD: EV_TCMDL382021_AU48.rod
       VCID: 43BD2BB6CA68DC5280-8016
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041170335001470
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.lbl
       Part No SW: 8W0 907 379 F    HW: 8W0 907 379 D
       Component: ESP9 Premium  H09 0593
       Coding: 0CAA489910A30A9C159F4899008552A2E6A59A30120850A812004A4567A559
       Shop #: WSC 61907 001 1048576
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X_012.rod
       VCID: 48A73C9AF34EFF0A55-801C
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
       Component: Klima Zone 3  H32 0050
       Coding: 141800285544400D02000100800000000000000000000000000000000000
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 37454F668EB080F22C-8062
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000660865
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 7EA845D7000000000001
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: Klima Heck  H34 0050
       Coding: 80451B42457D00CD01459754182C10F959033100030000000000000024001AA0274700ABC25706
       Coding: 5BC7F7
       Coding: 03005D
       Light switch:
       Coding: 030000
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.lbl
       Part No SW: 8W0 959 655     HW: 8W0 959 655
       Component: Airbag10.44   H52 0084
       Serial number: 003M6000D48D
       Coding: AECCF0C00C800000985400F3C00C00000000
       Shop #: WSC 06325 790 00001
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 063BF2A2B9DA297AE7-8052
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 8W0857705A0310P00463
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 8W0857706A0301P01262
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 062 610 15
       Serial number: 3577Y00A51A87821342V
       Subsystem 4 - Part No SW: -----------    HW: 442 062 610 15
       Serial number: 3587Y00AF1A87821B2AD
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 110 15
       Serial number: 3517700B11D5E5B251AG
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 010 15
       Serial number: 3527700C91D5E5B6B17X
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 610 15
       Serial number: 3557500C91C3DEB522CZ
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C0 610 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500C11C3DEB3346N
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C1 410 15
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500BD1D4F23282BG
       Subsystem 10 - Part No SW: -----------    HW: 442 430 311 15
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00B71A537D2832E
       Subsystem 11 - Part No SW: -----------    HW: 442 430 311 15
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00B71A537D2B0FS
       Part No SW: 4M0 907 129 HH    HW: 4M0 907 129 HH
       Component: Lenks.Modul   H11 0008
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 7DC99D4EEC0C6AA2B6-8028
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 B    HW: 8W5 920 790 B
       Component: FBenRDW       H11 0281
       Coding: 08EF50C06F8E00080180EBEB50E0001000000000
       ASAM Dataset: EV_DashBoardAU736 001020
       VCID: 41B121BED074CE4292-8014
       Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
       Component: Gateway       H13 4079
       Revision: 3C030052    Serial number: 5243C007C15925
       Coding: 0301000301000F4044000000005B00125C100007000000000700000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU49.rod
       VCID: 365B426289BA79FA37-8062
       Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20151102010603 RD102
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9052
       Serial number: 9078338203
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 B    HW: 4M0 907 566
       Component: MRR1Rear      H13 0230
       Revision: --------
       Coding: 0EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 345F786A9FC66BEA09-8060
       Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
       Component: TSG FS        009 0052
       Serial number: 0000171753622
       Coding: 001F8B215C000080000010B8
       VCID: 42B32EB2D572D55A8B-8016
       Part No SW: 8W0 909 144 F    HW: 8W0 909 144 A
       Component: EPS_MLBEVO_ZF H07 0407
       Coding: 2D008380008080
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X_002.rod
       VCID: 40B724BADB7EC74A9D-8014
    Address 46: Central Conv.
       Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
       Component: TSG BFS       009 0039
       Serial number: 0000172373694
       Coding: 001F9B215C000080000010B0
       VCID: 3E4B5A42A18AB1BAEF-806A
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.lbl
       Part No SW: 8W0 035 036 A    HW: 8W0 035 036 A
       Component: MU-P-LN-EU    050 0333
       Serial number: A667J0F7503459
       Coding: 01940101FF00000073110001004B01332F0801A573F10D00DE
       ASAM Dataset: EV_MUHig4CGen2HBAS 001115
       VCID: 3151717E60D45EC262-8064
       Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
       Component: ECE 2018  --- 0166
       Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
       Component: AU49x_DU_HIGH  H40 0008
       Serial number: AUZ8Z9FBJ003SF
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 P    HW: 8W0 919 614 P
       Component: ControlUnit_H  H22 0139
       Serial number: C1000024091500050542
       Component: Gracenote2  --- 1011
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0130
       Coding: 0294010102002301000060
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
       ROD: EV_CamSysRVRVCPANAMLBEv_004_AU49.rod
       VCID: 72D3BE72A55225DADB-8026
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
       Component: GSM-LL        H07 0068
       Revision: 0L0D5012    Serial number: 20151021001984
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736_AU49.rod
       VCID: 3559456E94BC72E23E-8060
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 8W0 907 541 A    HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 001016
       ROD: EV_ACC2BOSCHAU49X_001.rod
       VCID: 3A435652BDA29D9AD3-806E
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 B    HW: 8W0 907 217
       Component: BVS           H13 0042
       Coding: 040409010000040102222366E50000FCB0F0C010C220
       ROD: EV_BVSMLBevKOSTAAU736.rod
       VCID: 3B4D5356B298A492C8-806E
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       VCID: 6EEBAA02B16A013A3F-803A
       Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
       Component: TSG HFS       009 0039
       Serial number: 0000173147630
       Coding: 000F892000000080000010A0
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       Component: TSG HBFS      009 0039
       Serial number: 0000173147670
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    Address CF: Lane Chge Asst 2
    Interface not compatible.
    Address DE: Charger 1 for mobile dev
    End-------------------------(Elapsed Time: 04:52)--------------------------
    Sunday,03,March,2019,12:38:42:27677
    VCDS Version: 17.1.3.0
    Data version: 20170203 DS267.2
    Mileage: 78137   Repair Order:
    Chassis Type  F4 (4M2)
    Scan: 01 02 03 08 09 13 15 16 17 19 3C 42 44 52 5F 6C 81 8B A5 AC
              BB BC
    Address 01: Engine (J623-DETA)       Labels: None
       Revision: B1H33---
       ROD: EV_ECM20TDI011_AU49.rod
       VCID: 6CD0089287E7EA2125-8038
    Address 02: Auto Trans (J217)       Labels: None
       Coding: 010001
       ASAM Dataset: EV_TCMDL380221 002021
       ROD: N/A
       VCID: 4382832ECAF9C559B4-8016
    No ASAM data for: "EV_TCMDL380221" (AU49)
       ASAM Dataset: EV_SEP9BOSCHAU49X 012014
       ROD: N/A
       VCID: 48989402F3DFE60161-801C
    No ASAM data for: "EV_SEP9BOSCHAU49X" (AU49)
    Address 08: Auto HVAC (E87)       Labels: None
       ASAM Dataset: EV_IarCondiBHTCAU491 001013
       ROD: N/A
       VCID: 377AE7FE8E2199F918-8062
    No ASAM data for: "EV_IarCondiBHTCAU491" (AU49)
       Coding: 80451B42457D00CD03459754182C10F959033100030000000000000064001AA0274100ABC25706
       ASAM Dataset: EV_BCM1BOSCAHU736 015005
       ROD: N/A
       VCID: 7CF038D2F7877AA1B5-8028
       Coding: 5BC7F7
       Coding: 02005D
       Coding: 030000
    No ASAM data for: "EV_BCM1BOSCAHU736" (AU49)
    Address 13: Auto Dist. Reg (J428)       Labels: None
       VCID: 3C70F8D2B707BAA1F5-8068
    Address 15: Airbags (J234)       Labels: None
       ASAM Dataset: EV_AirbaAU1B0PAAU736 005012
       ROD: N/A
       VCID: 06045A3AB94B3071D3-8052
       Coding: 88001B
       Coding: 88001B
    No ASAM data for: "EV_AirbaAU1B0PAAU736" (AU49)
       VCID: 7DF635D6EC9D73A982-8028
    Address 17: Instruments (J285)       Labels: None
       Coding: 08EF50C06F8E00080180EFEB50E0001000000000
       ASAM Dataset: EV_DahsBoardAU736 001020
       ROD: N/A
       VCID: 418E8926D0E5D749A6-8014
    No ASAM data for: "EV_DahsBoardAU736" (AU49)
       ASAM Dataset: EV_GatecWONTIAU736 002040
       ROD: N/A
       VCID: 3664EAFA892B60F103-8062
    No ASAM data for: "EV_GatecWONTIAU736" (AU49)
    Address 3C: Lane Change (J769)       Labels: None
       Revision: --------
       Coding: 0EC002
       VCID: 3460D0F29F5772E13D-8060
       ASAM Dataset: EV_DCU2DriveSidmEAXHCONT 001005
       ROD: N/A
       VCID: 428C862AD5E3CC51BF-8016
    No ASAM data for: "EV_DCU2DriveSidmEAXHCONT" (AU49)
    Address 44: Steering Assist (J500)       Labels: None
       Coding: 0D008080008080
       ASAM Dataset: EV_ESPZFAU49X 002015
       ROD: N/A
       VCID: 40888C22DBEFDE41A9-8014
    No ASAM data for: "EV_ESPZFAU49X" (AU49)
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       VCID: 3E74F2DAA11BA8B1DB-806A
       Coding: 01940101FF00000073110001004B01332F0301A573F10D00DE
       ASAM Dataset: EV_MUHgi4CGen2HBAS 001115
       ROD: N/A
       VCID: 316ED9E6604547C956-8064
    No ASAM data for: "EV_MUHgi4CGen2HBAS" (AU49)
    Address 6C: Back-up Cam. (J772)       Labels: None
       ASAM Dataset: EV_CamSsyRVRVCPANAMLBEv 004008
       ROD: N/A
       VCID: 72EC16EAA5C33CD1EF-8026
    No ASAM data for: "EV_CamSsyRVRVCPANAMLBEv" (AU49)
       ASAM Dataset: EV_GSMAwehlZFAU736 001013
       ROD: N/A
       VCID: 3566EDF6942D6BE90A-8060
    No ASAM data for: "EV_GSMAwehlZFAU736" (AU49)
       ASAM Dataset: EV_ACC2BOSCHA4U9X 001016
       ROD: N/A
       VCID: 3A7CFECABD338491E7-806E
    No ASAM data for: "EV_ACC2BOSCHA4U9X" (AU49)
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: None
       Coding: 0404090100000401022223E6E50000FDB0F0C010C220
       ASAM Dataset: EV_BVSMLBekVOSTAAU736 002026
       ROD: N/A
       VCID: 3B72FBCEB209BD99FC-806E
    No ASAM data for: "EV_BVSMLBekVOSTAAU736" (AU49)
       ASAM Dataset: EV_RDMCINERGAU736 005009
       ROD: N/A
       VCID: 6ED4029AB1FB18310B-803A
    No ASAM data for: "EV_RDMCINERGAU736" (AU49)
    Address BB: Door Rear Drv (J388)       Labels: None
       ASAM Dataset: EV_DCU2RearDrievMAXHCONT 001005
       ROD: N/A
    No ASAM data for: "EV_DCU2RearDrievMAXHCONT" (AU49)
    Address BC: Door Rear Pass (J389)       Labels: None
       ASAM Dataset: EV_DCU2ReapRasseMAXHCONT 001005
       ROD: N/A
    No ASAM data for: "EV_DCU2ReapRasseMAXHCONT" (AU49)
    End-------------------------(Elapsed Time: 04:48)--------------------------
  10. Likes Uwe liked this post
