Hi guys
Anyone can help with long codding on abs ? All scan system attach with vin number. Thnaks in advance ...
Thursday,11,April,2019,16:39:18:25225
VCDS Version: 18.9.0.2
VIN: WVWZZZ6RZBU083419 License Plate:
Mileage: 102720km-63827mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU083419 Mileage: 102720km-63827miles
Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 9877
Revision: --H03--- Serial number:
Coding: 00110016000400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12MPI02103E906019M 001010
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 2E59E14D7175CC3A77-807A
6056 - No Communications with HVAC Control Module (J301)
U0164 00 [037] - -
Mileage: 102721 km
Date: 2019.04.11
Time: 03:34:59
Coolant temperature: 27 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.577 V
Time since engine start: 0 s
Engine torque: 110.00000 Nm
Accelerator pedal travel-Accelerator position: 0.00 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 0.000 °
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 0F275CC9D63FE5325C-805A
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
Reset counter: 229
Mileage: 102709 km
Date: 2019.02.10
Time: 00:00:05
0887 - Control Module
C104A F0 [137] - Incorrect VIN
Reset counter: 229
Mileage: 102709 km
Date: 2019.02.10
Time: 00:00:05
0897 - Coding Not Possible
U10BC 00 [009] - -
Reset counter: 236
Mileage: 102721 km
Date: 2019.04.11
Time: 03:40:41
0883 - Control module not coded
U1013 00 [137] - -
Fault Frequency: 10
Reset counter: 236
Time: 00:00:00
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 02051304651911
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF9110DE195FCBAA7-802A
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 085 F HW: 6R0 937 085
Component: BCM PQ25 M+ H32 0407
Revision: BB032001 Serial number: 0537 105130116
Coding: 64B0293F08A10048002008002D2B0C900040410F60060000200000000000
Shop #: WSC 00788 648 00255
VCID: 3E79D10DA9153CBAE7-806A
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU015031300015524
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU020031300013955
Coding: 18BC30
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01X H10 0020
Revision: -------- Serial number: 003GX01PCSXM
Coding: 003158
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A918DDDEDDD801A4B-801E
Serial number: 3575HRB40024UOB87OO+
Serial number: 3585HRB40084UOB89HT5
Serial number: 3515RRB401450D66EH3N
Serial number: 3525RRB400250H0S9H6$
12670208 - Databus
Reset counter: 21
Mileage: 102711 km
Date: 2019.04.11
Time: 17:31:54
Part No SW: 6R0 920 960 F HW: 6R0 920 960 F
Component: KOMBI H04 0304
Coding: 440A00
VCID: 3875C7158331028A2D-806C
Part No SW: 6N0 909 901 HW: 6R0 937 085
Component: GW-K-CAN TP20 H32 0407
Revision: BB032001
Coding: 002100
VCID: 70E53F35A3C19ACA25-8024
Reset counter: 20
Mileage: 102711 km
Date: 2013.09.01
Time: 17:31:55
Component: IMMO H04 0304
VCID: 6AD12D5D8D1D601A6B-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 38856
VCID: 3065FF35F741DACA65-8064
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L0388895
Coding: 0100040002
Shop #: WSC 31414 790 31414
VCID: 6BDF28598AE7791210-803E
00856 - Radio Antenna
007 - Short to Ground
Fault Status: 01100111
Reset counter: 236
Mileage: 102711 km
Date: 2013.08.31
Time: 22:39:31
End-------------------------(Elapsed Time: 02:01)--------------------------
