Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Changed Transmission Input Speed Sensor, still get same error.
    Mar 2019
    On a 2005 Beetle. Bought it for $400 with a transmission error.
    17100 - Transmission Input Speed Sensor (G182)
    P0716 - 000 - Implausible Signal - Intermittent
    Took out the transmission, it was white glove clean and perfect inside, changed the sensor.
    While I was in there also changed the DMF, pilot, CVs and most of the front suspension.
    Rear main looked perfectly clean and dry so I left it.
    Put the thing back together and the transmission error is unchanged, transmission still randomly downshifts and misses upshifts.
    I assume at this point I need to change the mechatronic unit?
    Is there anything else that could cause this?
    Sunday,14,April,2019,18:34:00:10819
    VIN: 3VWCR31C55M403812   License Plate: BEEBEE
    Mileage: 275950km-171467mi   Repair Order:
    Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
    VIN: 3VWCR31C55M403812   Mileage: 275950km-171467miles
       Part No SW: 038 906 016 P    HW: 028 101 181 3
       Component: R4 1,9L EDC G000DG  7000
       Revision: 12345678    Serial number: VWZ5Z0D6261194
       Coding: 0150038
       Shop #: WSC 00066 000 00000
       VCID: 211F18FF5DDB4E3FB13-5160
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
                P0672 - 000 - Electrical Fault
                        RPM: 1197 /min
                        Torque: 62.0 Nm
                        Load: 0.0 %
                        Voltage: 11.25 V
                        Bin. Bits: 00101100
                        Temperature: 5.4°C
                        Bin. Bits: 10110000
    16512 - Coolant Thermostat Valve (N214)
                P0128 - 000 - Temperature below Control Range
                        RPM: 1764 /min
                        Torque: 164.0 Nm
                        Speed: 49.0 km/h
                        Temperature: 57.6°C
                        Fuel Consump.: 6.80 l/h
                        Temperature: 32.4°C
                        Temperature: 32.4°C
                        Absolute Pres.: 1560.6 mbar
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 000 - Signal too Low - Intermittent
                        RPM: 1134 /min
                        Torque: 60.0 Nm
                        Load: 0.0 %
                        Duty Cycle: 100.6 %
                        Bin. Bits: 00101100
                        Mass Air / Rev.: 660.0 mg/str
                        Mass Air / Rev.: 0.0 mg/str
    Readiness: 0 1 0 0 0
       Part No SW: 02E 300 041 S    HW: 02E 927 770 AD
       Component: GSG DSG         041 0806
       Revision: 00004010    Serial number: 00000405270014
       Shop #: WSC 44551 111 44551
       VCID: 221D17F358DD5527A89-5160
       Part No: 1C0 907 379 M
       Coding: 0019458
       VCID: 3431E1ABF229CB974A5-5160
    Address 15: Airbags        Labels: None
       VCID: 55F77C2F5D13F29F9DB-5160
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 951 M
       Component: KOMBI+WEGFAHRS. M73 V02
       Coding: 11232
       Shop #: WSC 23069
       VCID: 2B03FAD72A17946F1BF-4B1E
       3VWCR31C55M403812     VWZ5Z0D6261194
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V022
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B92DBBC3B1B7B76ED-4B1E
       Part No: 1C0 959 799 G
       Component: 2K Komfortgerát HLO 0004
       Coding: 00016
       Shop #: WSC 23072
       VCID: 3B23CA97DA7704EF8BF-4B1E
                35-00 -  -
       Part No: 1C0 035 196 M
       Component:  RADIO DE2         0003
       Coding: 06031
       Shop #: WSC 00066
       VCID: 290F00DF20EB867FE93-51CE
    End----------(Elapsed Time: 03:49, VBatt start/end: 13.7V/13.7V)-----------
    Near Philadelphia, PA, USA
    Quote Originally Posted by JohnInSeattle View Post
    Broken wire? Skinned/Chafed wire shorting to case? Loose pin in a connector? I doubt it is the mechatronic unit given it is an intermittent condition.
    Mar 2019
    Quote Originally Posted by Bruce View Post
    The sensor, wire and it's connector to the Mechatronic are entirely inside the transmission.
    The new sensor came with the wire and connector as part of it.
    The wiring to the TCM is in visually perfect condition, all the factory clips and holders were, and are back, in place.
    How would I start tracking down a broken connection?
    Sep 2016
    Riga, Latvia
    Implausible signal is the worst DTC description to diagnose. It could be not only electrical but mechanical fault, too. For example implausibility between engine rpm value received via CAN and rpm reading of G182. Something wrong with clutch(es)? Incorrect parts installed? What part is G182 reading from? Damaged teeth of impulse wheel? Incorrect mechatronic hw/sw/coding (not compatible with engine)?
    Mar 2019
    Quote Originally Posted by MartinsX View Post
    Definitely not mechanical or damaged teeth.
    Clutches are perfect as is the entire inside of the transmission, gleaming with zero residue, metallic, rubber or clutch.
    Just replaced the DMF (old one seemed fine) so it's not slipping.
    This Trans worked in this car until about a year ago,when it developed this issue. So not incorrect parts or coding
    I want to try driving with the input speed G182 and the engine RPM graphing, see if they differ.
    G182 is the Transmission input sensor, reading from the TCM.
    I do have a core DSG 02E that is known working. I can swap the Mechatronic unit for only labor, assuming it's reasonably clean when I open it up.
    I know I have to grab the code from the old one and update it.
    I assume from the AutoScan that is "Coding: 0000020"?
    Proper sensor for air gap of phase?
    Did you change correct speed sensor?
    The Mech itself could be faulty internally, no?
    FOD!
    Mar 2019
    FOD!
    There is only the one changeable speed sensor in this transmission, all the rest are part of the mechatronic unit and not serviceable.
    Yes I verified several times that the sensor is the G182 sensor, if it isn't then I have to change the mechatronic unit in any case.
    There was no adjustment to be seen on the sensor, it seats in a hole and is held in place with one bolt.
  10. #8
    Just an FYI this transmission is one big dog landmine.
    Did you induce the DTC to trace the sensor is indeed correct & load light or shield the wire?
  11. #9
    Mar 2019
    I have no idea what any of that means.
    I have several of these cars with the DSG transmissions, this is the first issue I have seen, it has 170K miles and is mechanically pristine inside.
    WAY better than the 09As I have opened up.
    I am familiar with shielding wires electrically as I have an electrical engineering degree.
    But I don't see how that applies here, I don't think I need to redesign the system.
  12. #10
    Never mind, you know what your doing than, please carry on and commence, using the alleged "good engineering judgement" you have used so far?
    But did you do basic settings?
    http://wiki.ross-tech.com/wiki/index...rbox_(DSG/02E)
