- Joined
- Mar 20, 2019
- Messages
- 58
- Reaction score
- 16
- Location
- South Africa
- VCDS Serial number
- C?ID=357723
hi there. new shape polo i cant calibrate g85 in abs unit. vehicle were involved in a accident. did remove steering crash data. but tire monitoring light flashing and esp light on dashboard remain on. could some kind members please advise on what to try next. many thanks.
after i made attempt to calibrate steering sensor in abs after i locked in security access. fault code changed in abs as follows.
many thanks.
Friday,12,April,2019,09:18:17:62451
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: AAVZZZ6RZJU017572 License Plate:
Chassis Type: 6R-VW25 (6RU)
Scan: 01 03 04 09 15 17 19 25 44 56
VIN: AAVZZZ6RZJU017572 Mileage: 8050km-5002miles
Address 01: Engine (J623-CLPB) Labels: None
Part No SW: 03C 906 014 GN HW: 03C 906 014
Component: CLPB-MM7GV H02 4035
Revision: --H02--- Serial number:
Coding: 00110012020400000000
Shop #: WSC 31414 790 00200
VCID: 6FBA27CF6782334F777-51CE
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Component: ESP9.0i front H04 0003
Serial number: --------------
Coding: 62DD2485212403C7461924708453C088090D
ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 005874734A8C3C379ED-8054
0625 - Display for Tire Pressure Monitoring
Fault Frequency: 69
Reset counter: 142
Mileage: 7025 km
Date: 2014.06.17
Time: 00:30:30
0272 - Steering angle sensor
B1168 04 [009] - Internal System Fault
Fault Frequency: 11
Reset counter: 140
Mileage: 7025 km
Date: 2014.06.17
Time: 00:30:20
0994 - Steering angle sensor
B1168 04 [008] - Internal System Fault
Fault Frequency: 54
Reset counter: 40
Mileage: 7025 km
Date: 2014.06.17
Time: 00:30:23
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 20021813470829
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40A8B30784AC7EC1-802A
1140736 - Steering angle sensor
B1168 07 [008] - Mechanical Failure
Fault Frequency: 35
Reset counter: 182
Mileage: 7025 km
Date: 2014.06.17
Time: 00:30:23
Voltage terminal 15: 14.10 V
Voltage terminal 30: 14.40 V
Terminal 15 status: On
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 R HW: 6RU 937 086 R
Component: BCM IM M+4 H42 0452
Revision: BY042001 Serial number: 6700 126180224
Coding: 3AB02BBF08A12400100000002C2904800040600F60040100220000000A00
VCID: 70B824B37AAC2CB76ED-8024
Subsystem 1 - Part No: 5Z0 947 105 F
Component: DWA-Sensor 00 003 0008
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Component: VW10Airbag00M H10 0020
Revision: -------- Serial number: 003GW01F34J7
Coding: 00304D
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CEA95739363D7F093-801C
Part No SW: 6RF 920 861 C HW: 6RF 920 861 C
Component: KOMBI H01 0217
Coding: 1102010000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4BC2935F334A2F6F3BF-801E
Part No SW: 6RU 909 901 HW: 6RU 937 086 R
Component: GW-K-CAN TP20 H42 0452
Revision: BY042001
Coding: 002300
VCID: 196E3917C9968DFF793-804C
Component: IMMO H01 0217
VCID: 6A8C36DB5CF0D667209-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0101010100000000
ASAM Dataset: EV_SteerAssisNSK 014008
ROD: EV_SteerAssisNSK_014.rod
VCID: 41DEB1770106F53FD13-8014
0215 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[CAN Status-Check / CAN ID -Check LW1-Message]
Fault Frequency: 33
Reset counter: 165
Time: 00:00:00
Voltage terminal 15: 13.629 V
Voltage terminal 30: 14.360 V
Engine speed: 770.00 /min
Vehicle speed: 4 km/h
Status: Release
Address 56: Radio (J503) Labels: None
Part No SW: 6RG 035 181 HW: 6RG 035 181
Component: Radio 022 0130
Revision: -------- Serial number: VWZGZ1U1300323
Coding: 0000020002000F
VCID: 015E71774106353F913-8054
Reset counter: 177
Mileage: 7154 km
Date: 2014.06.26
Time: 04:49:20
Bin. Bits: 010
End----------(Elapsed Time: 01:10, VBatt start/end: 12.8V/12.7V)-----------
Friday,12,April,2019,09:25:12:62451
Address 03: ABS Brakes Labels: None
Control Module Part Number: 6R0 907 379 CB HW: 6R0 907 379 AS
Component and/or Version: ESP9.0i front H04 0003
Software Coding: 62DD2485212403C7461924708453C088090D
Work Shop Code: WSC 31414 790 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003031 (VW25)
Reset counter: 142
Mileage: 8052 km
Date: 2014.06.27
Time: 21:23:34
0993 - Steering angle sensor
Reset counter: 142
Mileage: 8052 km
Date: 2014.06.27
Time: 21:23:34
Friday,12,April,2019,09:41:29:62451
Address 44: Steering Assist Labels: 1Sx-909-144-44.clb
Control Module Part Number: 1S2 909 144 P HW: 1S2 909 144 P
Component and/or Version: EPS_ECU H61 1702
Software Coding: 0101010100000000
ASAM Dataset: EV_SteerAssisNSK 014008 (VW12)
U1113 00 [009] - -
Reset counter: 126
Time: 00:00:00
Voltage terminal 15: 12.076 V
Voltage terminal 30: 12.715 V
Status: Wait
