Hi guys. Need a hand with something, that really bugs me for a while...
Friends bought this vehicle and ever since they bought the damn thing they have this issue with this controller...
Long story short: evidently the control module was wrong in the beginning, but they fixed that, and now the car has the correct module installed. I didn't do this swap-someone else has done it. But the funny thing is-the "new"(second hand, but in perfect condition and fully operational!) module has now absolutely identical fault as the old, wrong one! 00003 module defective. 4 times intermittent and one actual, as you can see in the auto scan.
And this won't go away, no matter what I try! Not even the intermittent ones-it just stays as it is...
Even funnies thing is, when I try to perform output tests, as suggested in the Ross-tech procedures strange message pops out, that really baffles me...
I can't get the screenshot to work here, so I will quote:
WARNING!
Running out tests on the Airbag controller can lead to unexpected results, such as a vehicle that will not start!
wtf???
I am genuinely scared to perform output tests on an airbag controller, and never had, but what in the world has airbag controller to do with ABS controller???
I didn't go further with this and decided to ask is it going to be safe first? I do not want to turn this vehicle into a war zone with series of internal explosions, you know...
HELP...
There goes the auto scan:
WARNING!
wtf???
HELP...
Sunday,14,April,2019,12:34:29:60816
VCDS Version: 18.9.1.0
VIN: WAUZZZ4EX6N000426 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUZZZ4EX6N000426 Mileage: 211260km-131270miles
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0E1359563
Coding: 0011773
Shop #: WSC 12560 002 1048576
VCID: 2F6DF1FABEF0DC3274-807A
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Readiness: 0010 0000
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0030
Revision: --H01--- Serial number: 0055116
Shop #: WSC 49945 002 1048576
VCID: 326BF88EADC2F1DA1B-8066
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008597
Shop #: WSC 12345 000 00000
VCID: 224B08CEFD22615AEB-8076
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E1359563
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BF6A26EBFEFB8AC5-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 02313 785 00200
VCID: 23450DCAE2386852E0-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 K HW: 4E0 035 729
Component: Interfacebox H43 3460
Revision: 00000000 Serial number: 343CU057555936
Coding: 0010003
VCID: 2A5BE0EE8512B91AA3-807E
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 X460
Subsystem 2 - Serial number: 317IV027504678
Subsystem 3 - Serial number: ÿÿ20.09.02ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000063500
Coding: 0069851
VCID: 1C373636DF4657AA21-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0143121
VCID: 3169F782A8C4CAC262-8064
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 12345
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00141886
Shop #: WSC 12345
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C54DCAA2B82852A0-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Coding: 0012141
VCID: 65C153D2AC8C56624E-8030
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 T HW: 4E0 920 900 T
Component: KOMBIINSTR. VDO H70 0400
Revision: D01 Serial number: AUDID3E2000166
Coding: 0016113
Shop #: WSC 00011 888 96745
VCID: 306FF286A3CEC3CA6D-8064
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 265 081 K
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000111
VCID: 1A3B302ED572299A33-804E
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003052170130
Coding: FCFE7FDF2B7104
VCID: 275D19DA96008472BC-8072
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7131380
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000017 Serial number: 00000000025478
Coding: 0000000
VCID: 61C947C2B8A43A42B2-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285F1AE69B1E8B0AB5-807C
Component: Sitzmemory FS H08 0060
Coding: 4063338
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H44 1060
Revision: 00000000 Serial number: 305CU057575288
VCID: 3B75D5AA7A883092C8-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000504900085
Coding: 0069030
VCID: 1D313B32C45C5EA2D6-8048
00211 - Control Circuit for Rear Illumination Lights
Reset counter: 211
Mileage: 211264 km
Date: 2019.04.14
Time: 00:42:00
02162 - Indicator Lamp on Rear Interior Light Switch (K190)
Fault Status: 00100110
Reset counter: 251
Mileage: 211264 km
Date: 2019.04.14
Time: 00:43:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0060
Coding: 0032749
VCID: 204F02C6F32E734AFD-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503110140
Coding: 0004728
Component: Heckdeckel P14H06 0070
Component: Neigungssensor H03 0020
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 210
Mileage: 292583 km
Date: 2017.02.08
Time: 17:57:27
01134 - Alarm Horn (H12)
Fault Frequency: 63
Reset counter: 210
Mileage: 210752 km
Date: 2019.03.23
Time: 14:24:08
Fault Frequency: 63
Reset counter: 210
Mileage: 210752 km
Date: 2019.03.23
Time: 14:24:08
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000012297
Coding: 0000016
VCID: 254113D2EC0C96628E-8070
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000056905
Coding: 0010111
VCID: 1E333C3EC95A45BACF-804A
02258 - Door Opener Transmitter
Reset counter: 211
Mileage: 211264 km
Date: 2019.04.14
Time: 00:37:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0060
Coding: 0032749
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000018
Shop #: WSC 00342 447 45725
VCID: 264314DE910A9D7A87-8072
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH02 0020
02627 - Dynamic Cornering Light Motor; Left (V318)
Fault Status: 11100001
Reset counter: 211
Mileage: 211272 km
Date: 2019.04.14
Time: 00:38:39
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 E
Revision: 00000000 Serial number: 396C 057505959
VCID: 2E53ECFEB9FAD53A7F-807A
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000003382
Shop #: WSC 00880 264 10380
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 8552021721
Coding: 344530393135313035412056413038353532303231373231
Shop #: WSC 00011 888 06946
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0032749
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900030922
Coding: 0212127
VCID: 5FCD413A8ED00CB284-800A
000 - - - MIL ON
Fault Status: 11100000
Mileage: 211072 km
Date: 2019.04.08
Time: 20:41:42
Speed: 30.0 km/h
Voltage: 25.50 V
(no units): 0.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 R HW: 4E0 035 753 A
Component: SDS 3500 DE H45 0630
Revision: 00000000 Serial number: 00000502160269
Shop #: WSC 12336 024 394758
VCID: 3561C3925CACE6E23E-8060
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0032749
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720506401608
Coding: 0001108
VCID: 214907C2F8247A42F2-8074
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUDX0505HNS0
Coding: 0000004
End-------------------------(Elapsed Time: 04:05)--------------------------
