Results 1 to 10 of 10
Thread: Q7 3.0 TDI - turbo actuator fault J724 - P3348-004
    Apr 2019
    I recently had the car go into limp mode but with no EML.
    When scanned with the VCDS I had the error
    013128 - Control circuit for controller for Turbocharger 1 (J724)
    P3348-004- Electrical malfunction - Intermittent
    The output test on the actuator shows both outputs cycling between 20% - 80%
    The error code could be deleted and the car would be ok for a mile or two then revert to the limp mode.
    I decided to replace the Turbo actuator but I am getting the following fault
    P3348-005- Electrical malfunction.
    This time the code just wont clear - so I suspect the new actuator is faulty or has not been programmed by the supplier
    The output test now shows one output cycling between 20-80% and the other sat at 80.9%
    Does this point to the new actuator being faulty or just set up badly?
    It would be easier to help you if you would please post the full Auto-Scan here, between CODE tags if possible (see my signature).
  3. Likes Uwe, andyha2000, Jack@European_Parts liked this post
    Apr 2019
    Thank you - I will post the Auto Scan later
    Apr 2019
    I have attached my scan below.
    After getting the actuator sorted I am still getting the following. The car lost power on a drive but with no EML so I stopped, turned the ignition off and on again.
    Power was back and then I floored it and the glow plug light started flashing and the EML light came on.
    These are the codes
    : WAUZZZ4L57D048583   License Plate: N222
    Mileage: 210940km-131072mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 3C 42 46 47 4F
              52 56 61 62 6D 6F 72 76 77
    VIN: WAUZZZ4L57D048583   Mileage: 210940km-131072miles
       Part No SW: 4L0 910 401 M    HW: 4L0 907 401
       Component: 3.0L V6TDI  G001AG  0030
       Revision: --H03---    Serial number:
       Coding: 0011775
       Shop #: WSC 66565 257 00032
       VCID: 2C57313C8F9A462A51-8078
    013128 - Control Circuit for Controller for Turbocharger 1 (J724)
                   P3348 - 004 - Electrical Malfunction
                        Fault Frequency: 6
                        Mileage: 210937 km
                        Date: 2019.04.11
                        Time: 19:38:47
                        RPM: 1449 /min
                        Torque: 202.8 Nm
                        Speed: 12.3 km/h
                        Temperature: 42.3C
                        Duty Cycle: 75.8 %
                        Voltage: 14.14 V
                        Duty Cycle: 88.8 %
    000564 - Boost Pressure Regulation
                   P0234 - 001 - Limit Exceeded (Overboost Condition) - MIL ON
                        Fault Status: 11100001
                        Mileage: 210947 km
                        Date: 2019.04.11
                        Time: 19:55:50
                        RPM: 3150 /min
                        Torque: 565.5 Nm
                        Speed: 63.8 km/h
                        Absolute Pres.: 2468.4 mbar
                        Absolute Pres.: 2590.8 mbar
                        (no units): 0.0
                        Temperature: 15.3C
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 FK    HW: 09D 927 750 FK
       Component: AL 750 6A           0940
       Revision: 00H52000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 7CF7C17C3F7A16AA81-8028
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H21001
       Coding: 0038033
       VCID: 285FCD2C9B626A0AB5-807C
                000 -  -  - Intermittent
                        Reset counter: 218
                        Mileage: 210927 km
                        Date: 2019.04.07
                        Time: 18:31:15
                        Count: 128
                        Count: 12549
                        Count: 297
                        Count: 50432
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100541765
       Coding: 0000147
       Shop #: WSC 18416 000 1048576
       VCID: 63C59A00A2C4C952A0-8036
       Component: FBSAUDIC6 EZS   H45 0080
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L1 910 732 G    HW: 4E0 035 729
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 386IT067521172
       Coding: 0002002
       VCID: 2E533B34B986343A7F-807A
       Subsystem 1 - Part No: 4L0 910 609
       Component: E0380 BedienteilH01 0060
       Subsystem 2 - Serial number: 00000002172244
       Subsystem 3 - Serial number: 0126.02.140000000100010304
       Subsystem 4 - Serial number: 010304
       Part No SW: 4L0 910 043     HW: 4L0 820 043 E
       Component: KLIMABETAETIGUNGH05 0060
       Revision: 00---009    Serial number: 00000000070401
       Coding: 0001046
       VCID: 61C99008B8D8DB42B2-8034
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H17 0240
       Coding: 0011101
       VCID: 31692048A8B82BC262-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H08 0080
       Coding: 00064792
       Shop #: WSC 31414
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH12 0090
       Coding: 00077101
       Shop #: WSC 31414
       Part No SW: 4L0 910 111 A    HW: 4L0 035 111
       Component: CD-Changer      H41 0100
       Revision: 00000000    Serial number: AUZ5ZBF3044509
       VCID: 1E33EBF4C926A4BACF-804A
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH38 0120
       Revision: 05H38000    Serial number: 0037GD06NUX2
       Coding: 0013105
       Subsystem 1 - Serial number: 6332QSME142845436
       Subsystem 2 - Serial number: 6342QSME1102281B2
       Subsystem 3 - Serial number: 6352QSME104D7A45L
       Subsystem 4 - Serial number: 6362QSME145222532
       Subsystem 5 - Serial number: 63734SME1524160DX
       Subsystem 6 - Serial number: 63834SME15233A79%
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksulenmodul H08 0230
       Revision: 00H08000    Serial number: 90055062420134
       Coding: 0102142
       VCID: 66C3831451F6BC7A47-8032
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
       Component: KOMBIINSTR. M73 H17 0120
       Revision: 00600000    Serial number: 5HJ59GL96
       Coding: 2593443
       Shop #: WSC 12345 067 57207
       VCID: 2345DA00E2448952E0-8076
       Part No SW: 4L0 910 105     HW: 4L0 815 071 C
       Component: Heizgeraet      H07 0060
       Revision: 0000000E    Serial number: 00000009011043
       VCID: 60CF950CB3D2D24ABD-8034
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D068228085
       Coding: F55BBE5F343202
       Shop #: WSC 00694 210 91850
       VCID: 6CD7F13C4F1A862A11-8038
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 C    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7660
       Revision: --H03001    Serial number: 15.1528-0095.2
       Coding: 0015510
       Shop #: WSC 36630 001 1048576
       VCID: 2A5B3724856E581AA3-807E
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 399IZ067537104
       Shop #: WSC 00694 210 86009
       VCID: 3B7502607AF4D192C8-806E
    Address 3C: Lane Change        Labels: None
       Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH06 0060
       Revision: 00H06000    Serial number: 6PZ 009 014-00
       Coding: 0001101
       Subsystem 1 - Part No: 4L0 910 568 A
       Component: J0770_SWA_Slave_H05 0060
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F11.09.0600H0500000010143
       Subsystem 4 - Serial number: 010143
    02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 179
                        Mileage: 210936 km
                        Date: 2019.04.07
                        Time: 19:57:18
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00-00000
       Coding: 0002651
       VCID: 2F6D2630BE8C3D3274-807A
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01019594130000
       Coding: 7610619
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H02 0150
       Revision: PROD_01     Serial number: 00000000104057
       Coding: 0000043
       Shop #: WSC 62088 001 1048576
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000009973
       Coding: 0011101
       VCID: 5EB3ABF489A6E4BA8F-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0002651
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
       Revision: 00000000    Serial number: 388IT067553300
       Coding: 0000001
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000044295
       VCID: 64C7991CA7CACE6A59-8030
       Component: von VA0  2609085156
       Coding: 344630393135313035442056413032363039303835313536
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Component: TSG HL          H21 0050
       Coding: 0002058
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD21.09.06--H21001001C0057
       Subsystem 4 - Serial number: 1C0057
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 001953714-----
       Coding: 0003587
       VCID: 2643C31491767C7A87-8072
       Subsystem 1 - Part No: 4L0 910 591
       Component: J_245_EE15_SKB09H10 0180
       Subsystem 2 - Part No: 4L0 910 591
       Component: J_394_EE15_SKB09H10 0180
       Subsystem 3 - Part No: 4L0 910 591
       Component: J_392_EE15_SKB09H10 0180
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Component: TSG HR          H21 0050
       Coding: 0002058
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330625700226
       Coding: 0201146
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 K    HW: n
       Component:  0950
       Coding: 0020900
       Shop #: WSC 06335 000 00000
    Got the OP Verified. Moving to Car Repair Support.
    Tartu, Estonia
    You can't just replace actuator. You need to calibrate it with corresponding VAS tester that connects directly to servo.
    PS! Servos can only be replaced on turbochargers that end with 715, on 702 you need to buy new turbocharger.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  8. Likes MartinsX, Uwe, andyha2000 liked this post
    Apr 2019
    I bought a programmed actuator
    It all looks ok on the output test on VCDS, cycling between the parameters that are specified.
    Will drive ok for a short while then loses power again.
    I’m wondering now if I have sticky vanes in which case it’s new turbo time from what I’ve read.
  10. #8
    Tartu, Estonia
    Actuator has to be programmed while installed to Turbo, so it's not possible to buy "programmed actuator".
  11. Likes Uwe, Jack@European_Parts liked this post
  12. #9
    Apr 2019
    Ok I will look into that - the local Audi dealer supplied it and said they had supplied quite a few pre-programmed units and it was a straightforward swap. The programming was only needed on a bare unit.
  13. #10
    Apr 2019
    Turned out to be a broken wastegate so it now has a new turbo
  14. Likes Uwe, Jack@European_Parts liked this post
