Results 1 to 10 of 11
Thread: Lost AAC and Cruise control by disconnecting battery
    New User
    Nov 2018
    Hi. As per title. Disconnected battery to work on alternator. Reconnected battery lost front assist. Just looking for any info b4 it goes in to the stealers. They’re talking about £500 to re calibrate.
    2018 skoda Octavia
    Latest version of vcds does not allow any login or reset of auto dist module 13. Surely it can’t be out of alignment if the radar and bumper has never been touched. Security access code 14117 does not work on these second generation Bosch MQB H10 0654 modules.
    I could post a full scan and the angles of misalignment in proper area later The fault code C1103 sensor for automatic distance regulation incorrectly positioned. ACC reversible error.
    Just looking for any knowledgeable people on this subject to inform me what’s going on. If it is out of alignment then I will have no issues paying the dealer to fix as I realise it’s a safety feature that has to be precise if a computer controls brakes and throttle.
    Regards
    What type of cable do you have - HEX+CAN, HEX-V2 or HEX-NET?
    A full Auto-Scan would be very helpful.
    New User
    Nov 2018
    Yes it’s hex can. I need to upgrade. Going to go out to car soon get a fresh scan and a screen print of the misalignment angles then read up on how to post properly again as it’s been a while.
    Quote Originally Posted by Jdobbins View Post
    IIRC HEX-CAN can't fully access/setup all the modules on a 2018 Octavia - at least that's what I'm reading owners posting on briskoda.net
    For how to post an Auto-Scan see my signature.
    For images you need to host them online, somewhere like imgur, then copy the link and paste it in img tags.
    New User
    Nov 2018
    Sunday,14,April,2019,11:54:04:04365
    VCDS Version: 18.9.1.0 (x64)
    VIN: TMBBP7NE6J03XXXXX   License Plate:
    Chassis Type: NE-SK37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 47 52 5F 6C
    VIN: TMBBP7NE6J03XXXXX   Mileage: 51140km-31776miles
    Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 BH    HW: 04C 907 309 AE
       Component: R3 1.0l TFS   H26 4038
       Revision: W1H26---
       Coding: 01250032236419081000
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ECM10TFS01104C906026BH 002003
       ROD: EV_ECM10TFS01104C906026BH.rod
       VCID: 68DFEF689362D60A75-803C
       CAN Converter 01:
       Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1601
       Revision: 00005008    Serial number: CU501802195086
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 377D7C148E5C89F22C-8062
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 60698000001032
       Coding: 24078A912420216D407F060960C5242451248402600624723621F070C002430B00000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
       VCID: 0305D8C48A041552C0-8056
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0473395930
       Coding: 032C0C
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C776338B77AAAAAC1-8068
       Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
       Component: Climatronic   H04 2002
       Revision: 00001K00
       Coding: 01110004000110011005000800101022
       ASAM Dataset: EV_ACClimaBHBVW37X 006147
       VCID: 74E78B18DFAA22EAC9-8020
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001806100580
       ROD: EV_BCMBOSCH_018.rod
       VCID: 081FCFE8B322360A95-805C
       Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 180131  051 0916
       Serial number: 887253F0401803100811
       Coding: 164DDD
       Component: RLHS  047 0105
       Serial number: S9Y18M03D09H06M09S19
       Coding: 00885D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY17245295V
       Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223980182586
       Sun Roof:
       Subsystem 5 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.405  H04 0005
       Serial number: 0000FST001YLBKF00000
       Coding: 981803
       Serial number: 000308418018058
       Coding: 0471151051
       VCID: 4B9530E4E2D41D1278-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 3300600141FFC728949C810520400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E736930A166B8BAEF-806A
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] -  -
                        Reset counter: 22
                        Mileage: 51140 km
                        Date: 2019.04.14
                        Time: 11:47:59
                        Control Module temperature: 22 °C
                        Voltage terminal 15: 12.1 V
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W4P40ZE4Z
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW21TS6VW48X_VW37.rod
       VCID: 0501C6DC84302B62EE-8050
       Subsystem 1 - Part No SW: -----------    HW: 454 002 502 18
       Serial number: 35700000000FB09D6D2+
       Subsystem 2 - Part No SW: -----------    HW: 454 002 302 18
       Serial number: 35800000000450887D2K
       Subsystem 3 - Part No SW: -----------    HW: 454 802 402 18
       Serial number: 35100EF32BC13000000R
       Subsystem 4 - Part No SW: -----------    HW: 454 802 002 18
       Serial number: 3520024DDBB13000000P
       Subsystem 5 - Part No SW: -----------    HW: 454 801 902 18
       Serial number: 355008CD58313000000N
       Part No SW: 5Q0 953 507 JB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 02031804400638
       Coding: 6410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7F0D5434E6EC71B2A4-802A
       Part No SW: 5E0 920 950 F    HW: 5E0 920 950 F
       Component: KOMBI         303 0310
       Coding: 23A402182580860001886A011001000000000000
       VCID: 2959AA6C48E82F02AA-807C
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007518863
       Coding: 030100047F085700EB0002581C0F00010001070000000000000000000000
       Shop #: WSC 73430 790 00000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW37.rod
       VCID: 387F7F288342868A25-806C
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000A2191070318
       Serial number: 75886000001803110BC4
       Revision: 00000000    Serial number: 18000058674007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34674B189F2A62EA09-8060
       Serial number: 0000308203087
       Coding: 00110020D001040000001100
       VCID: 479D0CD4FEBCF9725C-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000019590172
       Coding: 1D0200
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1081
       Coding: 01170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73E58804DAA425D2D0-8026
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1HJE041G3T
       Coding: 0373010000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
       ROD: EV_AMPMst16C4Gen2ALPI.rod
       VCID: 59B9DAAC58087F82FA-800C
       Serial number: 0000307850848
       Coding: 00110020DC01040000001100
       VCID: 468301D0F9B6E07AA7-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000019833307
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
       Component: MU-S-ND-ER    H41 0471
       Serial number: SKZAZ2U0475647
       Coding: 037301010000000041111202008800002F0208E601200500CF
       ROD: EV_MUStd4CTSAT_VW36.rod
       Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: SKZ6ZHT2113199
       Subsystem 2 - Part No SW: 5L0 051 236 AR    HW: -----------
       Component: ECE1 2019/20  --- 1115
       Coding: 0473010122002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
       VCID: 39797A2CB8489F82DA-806C
    End-------------------------(Elapsed Time: 04:56)--------------------------
    New User
    Nov 2018
    New User
    Nov 2018
    Thanks PetrolDave, I've contacted Gendan about a trade in for a nice new interface
  8. #8
    Try and drive some trips, highway, above 50 km/h, 30-50 meter behind other cars.
    See if DTC is not changing to intermittent.
  9. Likes Uwe liked this post
  10. #9
    New User
    Nov 2018
    Car back from dealers. Quoted me £575 for Radar calibration. After I stopped laughing, I offered the Service manager a bare knuckle boxing match in the car park and got him down to £360. Apparently in 6 months time this could happen again. It was ready to disable this system and disconnecting battery was just a fluke
  11. #10
    Jul 2014
    Tallinn, Estonia
    Thats an absolutely insane price for only ACC radar calibration - I'm curious whats the quote contains?
