Results 1 to 10 of 19
Thread: Which measuring block to monitor VNT actuator position, 2006 Jetta TDI?
    Apr 2017
    Want to verify that the G500 position sensor is putting out a signal. Turbo rebuilder said one of the pins seemed lose.
    Not seeing anything documented for that sensor in your ECU.
    Apr 2017
    Well that's odd. Pretty sure it would throw a code if disconnected.
    Just because disconnecting something might throw a code doesn't mean the value from that thing is available via measuring blocks.
    Also, don't take my statement as definitive. I looked through the label file for your BEW engine and didn't see anything. I could have missed something. It's also possible that what you're looking for is in there somewhere but was never documented.
    Apr 2017
    This is a BRM engine.
  6. #6
    Quote Originally Posted by atikovi View Post
    So it's not the same car you posted about over here?
    https://forums.ross-tech.com/showthread.php?18566
    Because the (obviously FOD!) software in that ECU corresponds to a BEW label file.
  7. #7
    Apr 2017
    Yes same car. From what I have read the 06 Jetta TDI is a BRM engine.
  8. #8
    I don't suppose you have a scan of this car from when it had stock software in it?
  9. #9
    Dallas (McKinney) ,TX ,USA
    It is not MBV, you need to go in Basic settings 011 and when test starts look difference between lower and higher numbers , It can not be more then 120. Best is around 90-100.
    I usually record this with Phone then look very careful numbers.
    Once you do this , post it here and I will tell you what is your problem in second post .
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  10. #10
    Uwe is it BRM engine , I just looked at that post.
    Immobilizer/ECU
  11. Likes Uwe liked this post
