Passat B5.5 W8 ABS codes and then some
budvidua
Indiana
C?ID=356887
2004 Passat B5.5 W8 M/T
Greetings, picked up a oddball wtf 8 cylinder 1 of 11 Silverstone Gray sedan Passat and having troublesome on a few codes.
First scan when I got home, and what I've done and think I might know, or not.
03: ABS Brakes-First start the car, sometimes but not always, the ABS and Traction Control lights are on. And sometimes they don't, until after a few minute, or begin driving. I've checked connections from left front all the way to inside wheel well. ABS wheel inside rotor has light surface rust. Cleaned and inspected sensor. (doesn't mean it's good though) Checked measuring blocks and all 4 wheels are reading same mph even with lights on. Engine light comes on 10-30 min of driving which I assume is related to front left ABS fault. Vehicle speed sensor has been replaced, but throws code as shown. Also, speedo is 5 mph fast by 3 different GPS devices. OEM rims and correct tire size in place.
08: Auto HVAC-Flaps work fine to any position I put them to. Clueless to the faults.
17: Instruments, 19: CAN Gateway, 75: Telematics No label?-Throwing different faults because it's an aftermarket Kenwood DDX372BT. Not much to do about that, correct? Would rather have original Monsoon.
36: Seat Mem. Drvr - Seat(s) work fine in all positions.
55: Headlight Range - Most likely a frayed, bare wire touching inside the housing due to hotter than hell xenon and insulation age. Common VAG problem that I've yet to pull front clip and headlights to inspect and most likely heat shrink and polish lens to new.
Any advice or direction is greatly appreciated on these issues. It's a great car that got bad reviews because of the W8, but with 3" duals straight back from cats and a 6-spd m/t to boot, it's different and a blast to drive. Reviews anyways are like 1.8's and 2.8's. Everyone has one, even me.:facepalm:
Also, can't seem to pull up the Gateway list. It's like, not there.
Monday,25,March,2019,20:08:17:45417
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
Workshop Code: 444 46561 004666
VIN: WVWKK63B84P146078   License Plate:
VIN: WVWKK63B84P146078   Mileage: 309440km-192277miles
Address 01: Engine        Labels: 07D-906-018-BDP.lbl
   Part No: 07D 906 018 AP
   Component:   B5S-4.0L-HS-LEG   5204
   Coding: 00172
   Shop #: WSC 14627
   VCID: 74A4DBB6460A46EAC9-513C
   WVWKK63B84P146078     VWZ7Z0C8148920
16885 - Vehicle Speed Sensor
            P0501 - 35-00 - Implausible Signal
   Part No: 4B0 614 517 AA
   Component: ABS/ESP allrad      2329
   Coding: 05395
   Shop #: WSC 00028
   VCID: 608CA7E6E2F2CA4ABD-51CE
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            30-00 - Open or Short to Plus
   Part No: 3B7 907 044
   Component: CLIMATRONIC B5W8    0005
   Coding: 27210
   Shop #: WSC 05311
   VCID: 6484ABF6F6EAD66A59-5184
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-00 - Faulty
01271 - Positioning Motor for Temperature Flap (V68)
            37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
            37-00 - Faulty
            37-00 - Faulty
   Part No: 1C0 909 605 C
   Component: 0C AIRBAG VW61 04   0003
   Coding: 12355
   Shop #: WSC 00028
   VCID: 2404EBF6B66A966A99-513C
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F2E14DAEFAC253274-5160
   Part No: 3B7 920 949 A
   Coding: 31236
   VCID: 2E1009DEE8A62C3A7F-513C
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70ACD7A632127ACA2D-513C
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: °301
   Shop #: WSC 00000 008 00000
   VCID: 2F2E14DABFAC253274-513C
9 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
            000 -  -
00994 - Sensor for Front Height Adjustment On Drivers Seat (G215)
00995 - Sensor for Rear Height Adjustment On Drivers Seat (G216)
01009 - Sensor for Driver's Seat Position Fore/Aft (G218)
01010 - Sensor for Driver's Seat Recline (G219)
00999 - Motor for Front Height Adjustment of Driver's Seat (V29)
            000 -  -
01000 - Motor for Rear Height Adjustment of Driver's Seat (V30)
            000 -  -
01173 - Motor for Driver Seat Fore/Aft Adjustment (V28)
            000 -  -
00998 - Motor for Driver's Seat Recline (V45)
            000 -  -
   Part No: 1C0 959 799 C
   Component: 09 Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 373E2CBA17FCEDF22C-4B00
   Subsystem 1 - Part No: 1C0959801
   Component: 09 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C0959802A
   Component: 09 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 09 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 09 Tõrsteuer.HR KLO 0202
   Part No: 4Z7 907 357
   Coding: 00008
   Shop #: WSC 00028
   VCID: 04448B7616AA766AF9-4B3C
00774 - Level Control System Sensor; Rear Left (G76)
Address 58: Aux Fuel Tank        Labels: 3B7-906-268.lbl
   Part No: 3B7 906 268 A
   Component: Kraftst. Zusatztank 0005
   VCID: 2C1403D6DEBA5E2A51-513C
Address 75: Telematics        Labels: None
   Part No SW: 3B0 035 617 G    HW: 3B0 035 617 G
   Component: Telematik NAR1      0410
   Coding: 0041110
   Shop #: WSC 01080 444 00741
   VCID: 2208EDEEFC7E985AEB-5118
01304 - Radio
01304 - Radio
End----------(Elapsed Time: 04:01, VBatt start/end: 14.1V/14.0V)-----------
A W8 with 6MT? Awesome!
There was a guy on Vortex way back when with one. He had the sig, "My car will pass anything, except a gas station". :D
I'd start with the ABS wheel speed sensor. That's either a bad sensor, or a break in the wiring.
HAVC: Have you run Basic Settings? Should be Group 001.
As for a Gateway Installation List: This is a B5. It's late 1990's tech, diagnostics all via K-Line. Looking for a Gateway Installation list here is like looking for acceleration from an old Prius; it simply doesn't have it.
PS: Are you familiar with this flow chart?
budvidua
Indiana
C?ID=356887
W8
I'll check HVAC tmrw along with swapping L+R sensors to see what I get. Wanting to clean ABS wheel anyhow. I've read that will throw a fault because of rust, but they all rust!
LOL! Yes, so I've read. But with receipts from last two owners as thick as King James version I'm in the clear, for now. Relieved it's not a tip. Horror stories on the torque converter. And, some nice fella had chains/guides/water pump/thermostat done. Was told twice, but only have proof for most recent. And this small bonus, along with OM. That price tho. :eek:
Sorry, couldn't get image code to work.
13eB8DtPMJ9PULh6qcWmaQ2PaM5E6Zu1jcmaJAUu2gseJxFPc
1l7IHoxHdmj7Z6BJyB6ZGYpHIVnukMlzew_R--ADMeoeJxFPc
_Val
Latvia
C?ID=356659
Fault says to check level sensor at "rear axle" not the headlight.
budvidua
Indiana
C?ID=356887
Wait, what? They stuck a level arm sensor on the rear? I only know about the one in front left. Thought it was referring to motor mechanism arms inside housing. Had that problem with my A6 C6 and it was inside housing.
To sense the attitude (nose up, level, nose down) of the car needs level sensors at both front and rear - with only 1 sensor all you can sense is ride height.
Even my 2000MY Audi S3 had level sensors front & rear for Xenon aim adjustment, so it's not a new thing.
budvidua
Indiana
C?ID=356887
update
Update..
Narrowed the ABS problem down to a bad module. Sent it off to Matt at cheapabs and had it back within 5 days. Reinstalled, recoded per RT Wiki along with steering angle. All good! No error lights except what I'm seeing in scan. ESP works as well. Car runs amazing and strong after the module being fixed. But what I don't understand is why it ran weird when those errors were lit? RPM's were odd when shifting and I couldn't get over 5k rpm's. My buddy who has wrenched for years tells me the ABS has nothing to do with how the engine runs, but I find that hard to believe.
And yes, rear sensor arm was broke for headlights. Fixed and relearned headlights. One is somewhat brighter than the other so I would suspect a not matched D2, plus the tiny DRL's are out. Pulling clip to pull them for a renew so I'll know more once I do this. They've been like this since I picked up the car in FEB. Lights are the same in DRL or turned on. Are the xenons suppose to be on in DRL and somewhat softer on the W8's?
Did the basics on HVAC and down to just the two errors. When you first turn key, you can hear them positioning themselves. They seem to work tho, so not sure what the deal is.
Thanks for the continued support. The knowledge on here is first to none.
Tuesday,21,May,2019,20:23:45:45417
Mileage: 309970km-192606mi   Repair Order:
VIN: WVWKK63B84P146078   Mileage: 309970km-192606miles
   Coding: 00172
   Shop #: WSC 14627
Readiness: 0000 0001
   VCID: 55E28632ADB03FE2DE-51CE
No Faults Found
   Coding: 27210
   Shop #: WSC 05311
            37-00 - Faulty
            37-00 - Faulty
   Coding: 12355
   Shop #: WSC 00028
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F2E14DAEFAC253274-5184
   Coding: 31236
01316 - ABS Control Module
01304 - Radio
   Coding: 00006
   Shop #: WSC 00028
01304 - Radio
   Component: °301
   Shop #: WSC 65536 065 00000
9 Faults Found:
            000 -  -
            000 -  -
            000 -  -
            000 -  -
            000 -  -
   Coding: 00008
   Shop #: WSC 00028
   Coding: 0041110
   VCID: 2208EDEEFC7E985AEB-513C
01304 - Radio
01304 - Radio
End----------(Elapsed Time: 03:50, VBatt start/end: 14.4V/14.7V)-----------
The ABS will absolutely run interference with TQ request limitations if module is bad from bad solder joints.
An easy way to see is just unplug it to isolate on the network when such things are experienced.
I have seen an ignition switch or poor ground do similar things with ABS too.
