Results 1 to 7 of 7
Thread: Audi A6 C7 Keyless Entry retrofit
    Mar 2019
    Serbia
    I would like to retrofit Audi A6 C7 keyless entry.
    I was buy 8K0907247 antenna in the door 2pc and 4G8927753 door sensor x 4pcs.
    Also I think that I need to replace BCM2 4H0907064FN with another who have support for keyless entry.
    I would be appreciate if someone have experience with this issue and provide me part number(BCM2) what I need.
    Also I would like to know how to adapt my keys with new BCM2.
    Here is my autoscan:
    Tuesday,26,March,2019,16:23:39:48786
    VCDS Version: 19.1.2.0 (x64)  HEX-V2 CB: 0.4502.4
    Data version: 20190131 DS301.0
    VIN: WAUZZZ4GXFN075726   License Plate: SU106US
    Mileage: 138796km-86243mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 36 3B 3C 42 44 46 52
              53 55 5F 62 6D 72 85 8B 8E 8F 90 AC
    VIN: WAUZZZ4GXFN075726   Mileage: 138796km-86243miles
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FQ    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 0655
       Revision: 85H23---
       Coding: 0A25401A234401080000
       ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
       ROD: EV_ECM20TDI01104L906021FQ_002.rod
       VCID: 79AFEF19E952BBEFEFD-802C
       Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
       Component: 0CK 20TDI RdW H01 0002
       Revision: --H01---    Serial number: 0000000191
       Coding: 100001
       ASAM Dataset: EV_TCMDL382021 002014
       ROD: EV_TCMDL382021_AU48.rod
       VCID: 323D183574A488B76E7-8066
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 06A29E49604579929B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3FDB4101B7F655DF919-806A
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0560
       Coding: 01A8700E000000000000
       VCID: 7AADF015ECD4B0F7E67-802E
       Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
       Component: KLIMA 2 ZONEN H14 0112
       Serial number: 02031500110355
       Coding: 34110908250000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 619FA77961C2432FC7D-8034
       Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
       Revision: 15020001    Serial number: 00001021731202
       Coding: 0105001440349FE2C1014083A0001800CF9CC3082E08020100000494E10114020040002C030000
       VCID: 71BFD739B1A2F3AF57D-8024
       Component: WWS57X 150211  H37 0080
       Serial number:         150216124312
       Coding: 0045F7
       Serial number: 23783453
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 26 02 2015  00000172
       Serial number: 70884397000000000001
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7A04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290FFF595972CB6FDFD-807C
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P1003J2GQ
       Coding: 30333130313630323437554A304C34473053
       VCID: 3B233511A3EE49FFBD1-806E
       Serial number: 3575HRB405R33HNKA83Q
       Serial number: 3585HRB4055373K63137
       Serial number: 3515JRB405V35IMQ80V9
       Serial number: 3525JRB405136K44BPC
       Serial number: 3554VRB4055352USNH2
       Serial number: 3564VRB405L352USD9A2
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372OC40003T
       Coding: 0000DC
       VCID: 372B29219F466D9F599-8062
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0010
       Serial number: 14 02 2015  B0046748
       Part No SW: 4G8 920 933 F    HW: 4G8 920 933 F
       Component: TDieRdwAcc    H08 0043
       Revision: 04001037    Serial number: 658050315596015
       Coding: 138E0A004F452008010400
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K.rod
       VCID: 33331D318BBE81BF651-8066
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 G    HW: 4H0 265 105 G
       Component: Standheizung  H24 0260
       Revision: 66006006    Serial number: 20140912135011
       Coding: 5D3F01
       VCID: 2615F46548ECE417F2F-8072
       Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001752716
       Coding: C0CD074418
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 73B3DD31CB3EC1BFA51-8026
       Serial number: 6114185803
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
       Serial number: 1412220000000000033D
       Revision: AA001002
       VCID: 7CA1F60DE6E08EC7F4B-8028
       Revision: AA000000    Serial number: 00000138195316
       Coding: 0058130000006001000001010101102030303232203232
       VCID: 77ABE921DFC6AD9F999-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA82093LMG
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3635242598CC949742F-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0366301422
       Coding: 040311
       VCID: 392F2F19A9D27BEFAFD-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0367089970
       Coding: 040311
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F17015E00628002080013
       VCID: 45D753E9D5AA0F0FDB5-8010
       Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
       Component: RCEPS         H43 0012
       Revision: 00001000    Serial number: 0020537707
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 009013
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0362711599
       Coding: 0100063800B93080C32008840C010E470000000000000000000000000000
       Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00011413809
       Coding: 011F17015E00628002080002
       VCID: 46D554E5E8AC0417D2F-8012
       Revision: --------    Serial number: 00000001381341
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D070B496D9AD74F335-8078
       Coding: 04FA02102A600200
       VCID: 34311E2D8EB086877CB-8060
       Coding: E01E00
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels: Redir Fail!
       Part No SW: 4G1 035 193 A    HW: 4G1 035 193 A
       Component: RMC Cnct Nav  H61 0139
       Coding: 0100000101D5DB474C2B060301010000000001
       VCID: 221DE87524C418379E7-8076
       Subsystem 1 - Part No: 8X0 919 884 H
       Component: P28-50-14.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464B/0F2705992
       Subsystem 3 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
       Serial number: 90349OC50006O
       Coding: 010F15004000628002080002
       VCID: 49CF5FD9F9B2EB6F3FD-801C
       Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
       Component: HDSG-Modul    H02 0049
       Revision: 13002001    Serial number: 044500038
       Coding: 111104C000
       ASAM Dataset: EV_HDSGAu571 001022
       ROD: EV_HDSGAu571.rod
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 7A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01064D5680DE4724B-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7A04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 270BF9614F66FD1FC99-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000620503157
       Coding: 04C099181211
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 00660600031F0376000308014248D2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F173971A2B3AF17D-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 150360032
       ROD: EV_RDCMA00100_008.rod
    End----------(Elapsed Time: 02:05, VBatt start/end: 12.4V/12.3V)-----------
    Thank in advanced.
  2. Likes Boki Ar liked this post
  3. #2
    Quote Originally Posted by CuturiloD View Post
    Audi dealer, or an independent mechanic with a legitimate ODIS and GeKo access credentials.
    Oct 2016
    Ukraine
    Hey. As I remember, block 46 is not necessary to change. Its parameter is required.
    Mar 2019
    Serbia
    I was try to recode my Modul 46 ( byte 2 bit 3 and byte 7 bit 0), also modul 05 (byte 0 bit 2 and byte 2 bit 4).
    When I press DO IT for coding VCDS give to me message “code is out of area” or “code is rejected” or something like that.
    It is correct procedure or I doing something wrong?
    Oct 2016
    Ukraine
    Hello. This is done with other tools(VCP,SRT CAN). It is necessary to fill in the data set in the block.
    Mar 2019
    Serbia
    Hello, thanks for answer. I was find the guy who have this tools. But I need data for my BCM. Do you maybe correct have data?
    Oct 2016
    Ukraine
    Hello.
    Vcp----A6_start_auth_4H0907064Fx.zdc
    I think a person who has tools knows how to use them))))
