Results 1 to 5 of 5
Thread: Audi Q7 2017, Recoding, DRL OFF
    Jun 2018
    Hi all,
    Does anybody know how to turn OFF the DRL lights normally fitted in the front bumper?
    I suspect that the solution lies in the 09 coding. But... Which bytes/bits? Since there is no coding info available (yet).
    Tuesday,02,April,2019,18:12:03:29464
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ4M0HD028302   License Plate:
    Mileage: 105705km-65682mi   Repair Order:
    Chassis Type  4M-AU73 (8W7)
    Scan: 01 02 03 06 08 09 13 15 16 17 19 23 36 3C 42 44 46 47 51 52
              5F 65 69 6C 6D 74 81 8B 8C A5 AC BA BB BC C5 C6 CA CF
    VIN: WAUZZZ4M0HD028302   Mileage: 105705km-65682miles
    46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
    74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
    BA-Motor Mounts -- Status: OK 0000
    C5-Therm. mgt. -- Status: OK 0000
    C6-Batt. Chrg. -- Status: OK 0000
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CVZA)       Labels: Redir Fail!
       Part No SW: 4M0 907 401 A    HW: 059 907 309 F
       Component: 3.0TDI MD1    H23 0008
       Revision: C7H23---
       Coding: 2A2A4032056E050334382B00000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114M0907401A 001016
       ROD: EV_ECM30TDI0114M0907401A.rod
       VCID: 275DE2975E9E0C72BC-8072
       Active accelerator pedal:
       Subsystem 1 - Part No SW: 4M1 723 523     HW: 4M1 723 523
       Component: J1115 - FFP  H17 0007
       Serial number: 123456789ABCDEFGHIJK
       Clutch Control Unit Sub:
       Subsystem 2 - Part No SW: 0D7 142 057 D    HW: 0D7 142 057 D
       Component: J1128 CCU  H04 0031
    17156 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
                        Coolant temperature: 16 癈
                        Intake air temperature: 18 癈
                        Voltage terminal 30: 12.940 V
                        Engine status: COENG_READY
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 4M0 927 158 M    HW: 0D7 927 156 B
       Component: 0D7 30TDIRdW  H03 1009
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002011
       ROD: EV_TCMALX52011.rod
       VCID: 3E7327F3A104ADBAEF-806A
       Automatic Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
       Component:     V552 ATFP  D.4 0000
       Serial number:             00001057
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 P    HW: 4M0 907 379 P
       Component: ESP9 Premium  H09 0649
       Coding: 2C9830B232A40A9E91A11891187F12A2F6A6DA340C4C5089181848456F655B
       Shop #: WSC 48910 002 1048576
       ASAM Dataset: EV_ESP9BOSCHAU536P 011013
       ROD: EV_ESP9BOSCHAU536P_AU73.rod
       VCID: 4487551BCFE8C76AB9-8010
       Part No SW: 4M1 959 760 B    HW: 4M1 959 760 B
       Component: MEM-BFS       008 0031
       Serial number: 00000226078717
       Coding: 001010000000B0810060010101010000110000171700171700000000000000
       ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
       VCID: 387F31EB8320938A25-806C
       Subsystem 1 - Part No SW: 4M0 907 182     HW: 4M0 907 182
       Component: N477 VB1 BFSv  H06 0030
       Serial number: SJ800103111601100171
       Coding: B72F00
       Part No SW: 4M0 820 043 AE    HW: 4M0 820 043 AE
       Component: Klima Zone 3  H52 0093
       Coding: 661A08094544400D022C0280800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 68DFA1AB9300C30A75-803C
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000001131476
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: A3F9C65800PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: Klima Heck  H40 0073
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0266
       Coding: 07501943C13900CD0503571958AF8CF9130331019000000000000000600016810A4502AB22B71A
       VCID: 020B9303957C095ACB-8056
       Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 160916  043 0893
       Serial number: 89555300401626000867
       Coding: 1BC7F7
       Serial number: 62394104
       Coding: 02006E
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 30 06 2016  00525165
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE101081611521465
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 CK    HW: 4M0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: Q00213587
       Electrically Adjustable Steering Column:
       Subsystem 6 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
       Component: J866-EVLS-SG  H03 0080
       Serial number: WA125705000026451315
       Coding: 020100
       Subsystem 7 - Part No SW: 4M0 925 301 H    HW: 4M0 925 301 H
       Component: SL-Q7NF/AU736  H10 0013
       Serial number: 00000000000000004659
       Subsystem 8 - Part No SW: 4M0 963 575     HW: 4M0 963 575
       Component: V512 LLR1SLvL  H03 0012
       Serial number: L14DG22300367
       Subsystem 9 - Part No SW: 4M0 963 575     HW: 4M0 963 575
       Component: V514 LLR1SKvL  H03 0012
       Serial number: L14DG22300048
       Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
       Component: V516 LLR1SLvR  H03 0012
       Serial number: L14DG22201686
       Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
       Component: V518 LLR1SKvR  H03 0012
       Serial number: L14DG22300046
    67735 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:07
                        average_Voltage_terminals: 13.00 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 16.50 癈
                        interior_temperature: 18.00 癈
                        Vehicle speed: 0.00 km/h
    67737 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 18:03:04
                        average_Voltage_terminals: 12.90 V
       Part No SW: 4M0 907 561 D    HW: 4M0 907 561
       Component: LRR4          H10 0220
       Coding: 5477E7F358FFEC0A949C80E0
       ASAM Dataset: EV_ACCBOSCHAU736 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 31690CCF605A42C262-8064
    1229 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
                        Control Module temperature: 28 癈
                        Voltage terminal 15: 12.8 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s?
                        Status_ACC_System: ACC_irreversible error
    2153 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
       Part No SW: 4M0 959 655     HW: 4M0 959 655
       Component: Airbag10.44   H70 0086
       Serial number: 003L10031LZ%
       Coding: AAFCF0C00CA0000098F600F3C04C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 78FFF1EBC3A0538AE5-802C
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705D0301Q01481
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706J0301Q01102
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 061 510 16
       Serial number: 3577Y00A31FD753264D9
       Subsystem 4 - Part No SW: -----------    HW: 442 061 510 16
       Serial number: 3587Y00A51FD7531B144
       Subsystem 5 - Part No SW: -----------    HW: 442 0B0 310 16
       Serial number: 3517700A921E1146713$
       Subsystem 6 - Part No SW: -----------    HW: 442 0B3 009 16
       Serial number: 35277009921590A0B1B6
       Subsystem 7 - Part No SW: -----------    HW: 442 0C2 109 16
       Serial number: 3557500C321ADC74733G
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 109 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500BF218C285205B
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C2 109 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A721438F3437+
       Subsystem 10 - Part No SW: -----------    HW: 442 420 809 16
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00991FFD131326R
       Subsystem 11 - Part No SW: -----------    HW: 442 420 809 16
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00B71FB75F3428$
       Central Sensor XY:
       Subsystem 12 - Part No SW: -----------    HW: 410 203 110 16
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O78009D21A82B4323$
    1060613 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
    1060614 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
    1060615 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:06
    1060617 - Databus
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:06
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 01099C0F907A1242D2-8054
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 794 B    HW: 4M0 920 794 B
       Component: FHybRDW       H15 0302
       Coding: 040401C07C9800080DA6E9701204400000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 326B03C3655C79DA1B-8066
              U1014 00 [009] - -
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
       Part No SW: 8W7 907 468 D    HW: 8W7 907 468 C
       Component: Gateway       H30 0308
       Revision: 5C000001    Serial number: 0185C289016A26
       Coding: 02010101000206C08C82010000590032DC520007180000000175079E10000000
       ASAM Dataset: EV_CGateCONTIAU491 002040
       ROD: EV_CGateCONTIAU491_002_AU49.rod
       VCID: 4C977D3BE7B80F2A71-8018
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20161031171629 01046
       Serial number: 3523561904
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 4M0 909 059 C    HW: 4M0 909 059
       Component: J539 EBKV H11 0194
       Serial number:   085430010122
       ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
       ROD: EV_BrakeBoostBOSCHAU736_AU73.rod
       VCID: 346705DB9F4877EA09-8060
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 4M0 909 057 A    HW: 4M0 909 057
       Component: VX70BrakeAssi  H04 0153
       Serial number: 05802861240916212422
       Component: MEM-FS        008 0031
       Serial number: 00000226074333
       Coding: 00181B000000B0810000010101010000110000171700171700000000000000
       Component: N475 VB1 FSv  H06 0030
       Serial number: SJ80010311160110018A
       Coding: BF2F00
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 B    HW: 4M0 907 566
       Component: MRR1Rear      H13 0230
       Revision: --------
       Coding: 0EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
       Component: TSG FS        009 0052
       Serial number: 0000223132042
       Coding: 005D9B005E000080000130B2
       VCID: 428B5303D5FCC95A8B-8016
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0005
       Serial number: 0000333734
       Coding: B0110101010001
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
    Address 46: Central Conv.
    Interface not compatible.
       Part No SW: 4M0 035 223 C    HW: 4M0 035 223
       Component: MIB2_amp_PD   H03 0440
       Serial number: 00000000000457
       Coding: 0135960B008AF53AAF0000010001
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
       VCID: 2345F6872AA6E052E0-8076
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 4M1 907 080 B    HW: 4M1 907 080 B
       Component: A73P7828S1000 H02 0018
       Revision: --H02---
       Coding: 01000000000000000000
       ASAM Dataset: EV_DMCM08530214M1907080B 001002
       ROD: EV_DMCM08530214M2907080.rod
       VCID: 2C571DBB47782F2A51-8078
       Part No SW: 4M0 959 792 G    HW: 4M0 959 792 C
       Component: TSG BFS       009 0052
       Serial number: 0000223497033
       Coding: 005D9B005E000080000130B0
       VCID: 41895C0FD0FAD24292-8014
    Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
       Part No SW: 4M1 035 035     HW: 4M1 035 035
       Component: MU-P-LND-EU   033 0917
       Serial number: A641J0GB005440
       Coding: 013796010000000053111102000A00332F001DE5017001009E
       VCID: 62CBB383753CA95AAB-8036
       Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9GJ4035J7
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
       Component: ControlUnit_P  H15 0209
       Serial number: 27101600000000000193
       Component: Gracenote2  --- 1015
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
       Component: RDKHUFAU736   H04 0010
       Serial number: 30000000008201
       ASAM Dataset: EV_RDKHUFAU736 002007
       ROD: EV_RDKHUFAU736_AU37.rod
       VCID: 2F6D0AB7766E543274-807A
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: ConWysTrailer H20 0211
       Serial number: 0384670490
       Coding: 0100000202000000
       VCID: 336506C79A4670D210-8066
       Part No SW: 4M0 907 428 E    HW: 4M0 907 428
       Component: Areaview 2    H13 0315
       Serial number: C854607JG004990
       Coding: 02350601BE0FA10008404100
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 31022644600000
       Coding: 0070
    Address 74: Chassis Control
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M1 713 041 F    HW: 4M1 713 041 F
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20161026001336
       ROD: EV_GSMWaehlZFAU736_AU73.rod
       VCID: 285FE1AB5380030AB5-807C
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 D    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
    Address 8C: Hybrid Battery
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
       Component: BVS           H14 0042
       Coding: 040703060000040202202386CD0000B4B0F0C020E280
       ROD: EV_BVSMLBevKOSTAAU736.rod
    0646 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 100
                        Mileage: 105705 km
                        Date: 2019.04.02
                        Time: 17:43:05
                        Control Module temperature: 25 癈
                        Voltage terminal 15: 13.10 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0005
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736.rod
       VCID: 306F09CB6B504BCA6D-8064
    Address BA: Motor Mounts (J931)       Labels: None
       Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
       Component: AEMevo        H09 0111
       ASAM Dataset: EV_AEMZFAU736 006012
       ROD: EV_AEMZFAU736_006.rod
       Part No SW: 4M0 959 795 G    HW: 4M0 959 795 C
       Component: TSG HFS       009 0052
       Serial number: 0000223986999
       Coding: 004D990000000080000030A0
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       Component: TSG HBFS      009 0052
       Serial number: 0000223986998
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    Address C5: Therm. mgt. (J1024)       Labels:* None
       Part No SW: 4M0 965 429 D    HW: 4M0 965 429 B
       Component: TME-Max       H04 0021
       Serial number: 0027841
       Coding: 00
       ASAM Dataset: EV_ThermContrVISAU49X 001023
       ROD: EV_ThermContrVISAU49X_VW37.rod
       Subsystem 1 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
       Component: G395 pT-Sens1  H10 0009
       Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
       Component: J848 HV-PTC  H09 0208
       Serial number: LM161623003810000271
       Subsystem 3 - Part No SW: 4M0 816 797 A    HW: 4M0 816 797 A
       Component: J842 EKK es33  H02 0012
       Serial number: 00000000016102600130
       Refrigerant Pressure And Temperature Sender 2:
       Subsystem 4 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
       Component: G826 pT-Sens2  H10 0009
       Refrigerant Pressure And Temperature Sender 3:
       Subsystem 5 - Part No SW: 4M0 959 603 B    HW: 4M0 959 603 B
       Component: G827 pT-Sens3  H10 0009
       Refrigerant Expansion Valve 1:
       Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
       Component: N636 EV1_KaMi  H12 0102
       Serial number: 00000000000150142410
       Refrigerant Shut Off Valve 2:
       Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N640 AV2_KaMi  H12 0102
       Serial number: 00000000000130143082
       Refrigerant Shut Off Valve 3:
       Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N641 AV3_KaMi  H12 0102
       Serial number: 00000000000130143174
       Refrigerant Shut Off Valve 4:
       Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N642 AV4_KaMi  H12 0102
       Serial number: 00000000000130143092
       Refrigerant Shut Off Valve 5:
       Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
       Component: N643 AV5_KaMi  H12 0102
       Serial number: 00000000000130143170
    Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
       Part No SW: 5QE 915 681 G    HW: 5QE 915 681 G
       Component: OBC Delta-ES  H55 0721
       Coding: 11508B207000
       ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
       ROD: EV_OBCTwoPhaseDT2AU736.rod
       VCID: 50AF694B0B902BCA0D-8004
    Address CA: Sunroof
    There are lots of DRL-related bits in the "experimental" coding that you'd have access to if you were using an interface that's fully compatible with the vehicle.
    Setting Byte 2, bit 1 may give you options in your MMI.
    Unsetting Byte 2, bit 0 may kill off the DRLs entirely.
    Quote Originally Posted by dcggames View Post
    I thought that DRLs were a legal requirement in the EU on all cars introduced after 2014?
    Jun 2018
    Thanks Uwe. I will give it a try. Fortunately I should be updating my interface soon.
    Jun 2018
    It should be just the DRLs originally fitted to the front bumper. I haven't seen the car yet myself, but if I understand the newly fitted bumper is part of a original ABT package for this car.
