Problems with Passat B7. Pls help
abhijeetveer
New Member
India
Hello from India.
This is going to be a long post.
I purchased a used 2011 Passat b7 Highline automatic DSG here last year. It had done abt 55k kms when bought and currently it is at 65k kms. I have had quite a lot of problems with it.
Firstly, while on a long road trip the car died on me without any warnings. I did not have access to any VAG COM or any scanner for that matter as I was far away from the city in a remote area with no knowledgeable mechanics. The car used to crank and fire up but die in few seconds with no warnings on the dashboard. I managed to get hold of a mechanic from far who did whatever he knew, towed the car to his garage, got hold of one of his friends who had the launch scanner which did not show any errors either, kept the car for a day. He called me next day saying he removed the injectors and cleaned them and he’s kept the car running all night to see if it is dying but it did not. We thought it could be the fuel as India has a lot of fuel adulteration issues. On my way back the car dies on the highway again without any warning. It cranks but does not start. And sometimes it did but it died immediately a few seconds later. I didn’t know what the problem was so I got it towed to a mechanic I knew. Little did he know anything too which I figured out later.
He said my HPFP gave up along with my injectors etc. I couldn’t believe him as the car worked fine till mid highway before going dead without any warnings. But I had no option as the car wouldn’t even drive back till home. After few days of him experimenting the car started. He said he changed the HPFP and 2 of my injectors now the car starts but during hard acceleration the car goes in limp mode and he thinks it is the other 2 injectors but he didn’t have them in stock. So, after being frustrated I just took the car home and started looking for more reliable garages with proper scanners. VW wanted to charge me a bomb to replace the whole fuel system they asked me for almost 50% of what I bought the car for. I didn’t have that sort of money to pay them. In fact, I didn’t even know if the problem was true and if it’s worth paying so much for it. So, my search for a good garage began and I landed up with a garage having a VAG COM thankfully. They told me that all my 4 injectors are showing low pressure and need to be replaced. Thankfully they had a refurbished set with them. The HPFP according to them was perfectly fine. It may or may not be another one as I don’t trust the other garage anymore. A week later after 2 months of trial and error the car came back home and was back as normal.
I started looking up for VCDS tweaks for the car and came across a page http://www.ukpassats.co.uk/phpbb/viewtopic.php?t=89352 which said the headlight intensity can be increased via VCDS by changing a code in body control module. Before changing the code, we took a picture of the long code and what we were changing it to.
Under 09 Cent. Elect. Byte 9 we changed the digits from 1C to 11 with the help of long coding helper. We got a whole lot of errors related to headlights and DRL on the dash. Most of my electronics inside and outside the car stopped working like it should or stopped working completely. The headlight stopped working automatically, manually it wouldn’t go in high beam, the cigarette socket stopped working etc. So, I reverted back to my original code and restored everything back. Thankfully that was an easy process. Everything started working back again like it should but the light errors on the dash doesn’t seem to go. We cross checked the long code according to the pictures we clicked but its still the same. Please help as we can’t seem to figure out what can be done. The garage guy says it maybe that the Binary was changed when we changed the long code and we should have clicked a picture of all the 30 Bytes before changing anything. The electronics work as they should but there are errors on the dash which refuse to go away. Fuses etc all seem to be normal. I don’t know where to begin.
Heres an auto scan of the car. Apologies if I have made any mistake here.
Friday,05,April,2019,15:20:06:02594
VCDS Version: 18.2.0.3  HEX-NET CB: 0.4411.4
VIN: WVWH113CXCA000064   License Plate: 1242
Mileage: 65330km-40594mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 36 42 44 46 4C 4F 52 53
          55 56 61 62 6C 72 77
VIN: WVWH113CXCA000064   Mileage: 65330km-40594miles
2E-Media Player 3 -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CLLA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 FF    HW: 03L 907 309 N
   Component: R4 2.0l TDI   H24 9977
   Revision: 47H24---    Serial number: VWZCZ000000000
   Coding: 001D0032042501080000
   Shop #: WSC 12802 938 00000
   ASAM Dataset: EV_ECM20TDI01103L906018FF 003009
   ROD: EV_ECM20TDI01103L906018FF.rod
   VCID: F3A6B5735ABF8ADC95-80A6
   Part No SW: 02E 300 057     HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2703
   Revision: 05351113    Serial number: 00001105280508
   Shop #: WSC 73430 790 00054
   VCID: D6E0ECE7610DFFF492-8082
   Part No SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
   Component: J104   C2 450M VD89 0022
   Revision: --H07---    Serial number: 00000004308128
   Coding: 0139196
   VCID: EE90A407F99DA7347A-80BA
   Part No SW: 5K0 907 044 EK    HW: 5K0 907 044 EK
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001003
   Shop #: WSC 73430 115 00054
   VCID: F8BC825F43D9E984A0-80AC
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 E    HW: 3AA 937 087 E
   Component: BCM PQ47 H+   413 0455
   Revision: BC413001
   Coding: 0008000000000000001C00817000A9F467F50088657C8560E480C7240041
   VCID: BC345E4F3F6105A484-80E8
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 12051  26  0612
   Coding: 00B795
   Component: RLS 060611 05  54  0403
   Coding: 0230ED
01506 - Bulb for Rear Fog; Right (L47)
                    Fault Status: 00101010
                    Reset counter: 177
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:14:54
                        Term 15 On
                    Voltage: 12.25 V
                    Fault Status: 01101010
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:13:33
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:13:33
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:15:09
                        Term 15 On
                    Voltage: 12.60 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:15:09
                        Term 15 On
                    Voltage: 12.60 V
02199 - Bulb for Tail Light 2; Right (M50)
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:13:34
                        Term 15 On
                    Voltage: 12.30 V
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56231115904690
   Coding: 349305
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000.rod
   VCID: C4C426AF4F917D64FC-8090
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__10P VW10 HI   1918
   Revision: 22014000    Serial number: 003JZPB2TXF0
   Coding: 0012368
   VCID: CBD60D93AACFB21C3D-809E
   Subsystem 1 - Serial number: 6332MTS619751311
   Subsystem 2 - Serial number: 6342MTS638891331
   Subsystem 3 - Serial number: 6351HTS66L53M9KR
   Subsystem 4 - Serial number: 6361HTS6T6B3M9KR
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110521100542
   Coding: 0992250001
   VCID: EB96AD13028F521C5D-80BE
   Coding: E30000
   Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
   Component: KOMBI         H03 0407
   Coding: 160F01
   Shop #: WSC 00015 115 00054
   VCID: B32675731A3FCADC55-80E6
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 230511F2001829
   Coding: 461007
   VCID: B93A475B3053308C9F-80EC
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:01:57
03272 - Control Module for Audio Interface
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:01:57
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799
   Component:    IMMO         083 0400
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: C6C03CA7B1AD4F74E2-8092
Address 2E: Media Player 3
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2301
   Revision: 00H05000
   Coding: 000039
   VCID: B3267573123FCADC55-80E6
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0002926542
   Coding: 0213FF
   VCID: B5224B6B144BD4EC7B-80E0
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002193317
   Coding: 0002D8
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 197    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: B424766FD731CDE44C-80E0
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 01 KESSY PQ47   083 0337
   Coding: 00910A0002C60E76300494157E00DF0B00780103243498
   Subsystem 4 - Component:       ViP n.mounted
00190 - Driver's Door Handle Touch Sensor (G415)
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:01:35
00191 - Passenger's Door Handle Touch Sensor (G416)
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:01:35
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
                    Fault Status: 01101100
                    Fault Frequency: 6
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:09:01
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: EFAEB9033E97AE3C71-80BA
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0002929259
   Coding: 0213FE
   VCID: B6204C67094DDFF472-80E2
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002201830
   Coding: 0002D8
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000019845
   Coding: 0022167
   VCID: B5224B6BDC4BD4EC7B-80E0
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0100
   Coding: 029600000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
Address 56: Radio        Labels:
   VCID: D5E2EBEB2C0BF4EC9B-FFFE
   Component: Batt.regelung H41 1620
   Coding: 0303115A
   VCID: F1AABF7B28A3B8CC67-80A4
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:02:50
Address 6C: Back-up Cam.
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660210919
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: B424766F1F31CDE44C-80E0
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2019.04.05
                    Time: 15:01:38
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2019.04.05
                    Time: 15:01:38
End----------(Elapsed Time: 02:07, VBatt start/end: 12.6V/12.5V)-----------
abhijeetveer
New Member
India
You should always make and save a complete Auto-Scan from a car before doing anything to it.
But just in case you don't, VCDS does keep a log of changes made.
https://forums.ross-tech.com/showthread.php?1029
Thank you for the quick reply.
I had taken a picture of the long code before changing it. So, the long code has been matched and rechecked. The lights started behaving normally only after the old long code was put back. Before that all the electronics were misbehaving. The mechanic also tried swapping the BCM from another car by matching the part number but he said the same errors keep showing up on the dashboard even after BCM swap. I am not sure if this has been done but I am just going by his word. According to him there are Binary uder every Byte which also can be changed. And that may be the issue. He says we may have messed up the binary while changing the long code and we should have taken a picture of all the 30 bytes instead of just the long code. I am not sure if he is correct. He also says that I should go to VW authorised workshop and ask them to reflash the whole car.
I can try and get the log file by tomorrow if it will help. But I am pretty sure the long code is same as before.
Regards,
Abhijeet
The "Binary" is just a bit-wise representation of the selected byte. If you change it, the selected byte in the long coding changes. If you change the byte itself, then the binary changes. They are just different ways of looking at the same thing.
abhijeetveer
New Member
India
Sorry for the late reply. It took me a while to search for my car’s codes in the mechanic's machine.
Understood. So, the binary is just a 1 or 0 representation of the long code if I’m correct?
But then another question arises. I have reverted the long code to what it was before changing anything but still, I have errors on the dashboard whereas everything works. What could this point out to? Anybody?
Address 09	3AA 937 087 E	recoded (Long Coding)	from	0008000000000000001C00817000A9F467F50088657C8560E480C7240041	to	0008000000000000001100817000A9F467F50088657C8560E480C7240041
Address 09	3AA 937 087 E	recoded (Long Coding)	from	08000000000000001100817000A9F467F50088657C8560E480C724004100	to	0800000000000000111C817000A9F467F50088657C8560E480C724004100
Address 09	3AA 937 087 E	recoded (Long Coding)	from	00000000000000111C817000A9F467F50088657C8560E480C72400410000	to	00000000000000111C1D7000A9F467F50088657C8560E480C72400410000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	000000000000111C1D1F00A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	0008000000000000001C00817000A9F467F50088657C8560E480C7240041
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	000000000000111C1D1C00A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	000000000000111C1D1100A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	000000000800111C1D1C00A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	080000000800111E1D7000A1F467F50080657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	082000002800117C1D1C20A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	000000000000119C1D7000A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	000000000000111E1D7000A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	000000000000111C1D7000A9F467F50088657C8560E480C7240041000000	to	020000000000111C1D7000A9F467F50088657C8560E480C7240041000000
Address 09	3AA 937 087 E	recoded (Long Coding)	from	08000000000000001C00817000A9F467F50088657C8560E480C724004100	to	0008000000000000001C00817000A9F467F50088657C8560E480C7240041
Address 09	3AA 937 087 E	recoded (Long Coding)	from	08000000000000001C00817000A9F467F50088657C8560E480C724004100	to	00080000000000001C00817000A9F467F50088657C8560E480C724004100
Address 09	3AA 937 087 E	recoded (Long Coding)	from	080000000000001C00817000A9F467F50088657C8560E480C72400410000	to	0008000000000000001C00817000A9F467F50088657C8560E480C7240041
And then finally back to original
   Revision: BC413001
   Coding: 00B795
   Coding: 0230ED
                    Reset counter: 177
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:14:54
                        Term 15 On
                    Voltage: 12.25 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:13:33
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:13:33
                        Term 15 On
                    Voltage: 12.05 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:15:09
                        Term 15 On
                    Voltage: 12.60 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:15:09
                        Term 15 On
                    Voltage: 12.60 V
                    Reset counter: 137
                    Mileage: 65330 km
                    Date: 2013.08.26
                    Time: 15:13:34
                        Term 15 On
                    Voltage: 12.30 V
DV52
C?ID=194404
abhijeetveer" Hi - I have to preface my reply by admitting from the outset that I know absolutely nothing about 7N0 platform vehicles!
However, I do have a fondness for base 16 (Hexadecimal) and base 2 (Binary) number-sets (IMHO, they are much more efficient ways for counting than the more usual decimal system) and I am strangely attracted to number patterns. Yes, I know that it's a weird obsession, but I'm in therapy and my psychologist says that I'm doing well! ;). So - it's entirely these two attributes that compels my response.
Anyhow- again with the caveat that I'm ignorant about Passat B7s - I notice that there appears to have been a shift in the Byte pattern for the records that you included in your post #5. Unfortunately, your records are missing their time stamp, but usually these type of VCDS reports are sequential - which means that the 2 x important numbers are the first "from" entry and the last "to" entry. If I re-phrase the format of these two numbers from your records and I compare them on a Byte-to-Byte basis , I find the following:
Name	last "from" entry	first "to" entry
Byte	Hex	Binary 	        Hex	Binary
0	08	00001000	00	00000000
1	00	00000000	08	00001000
2	00	00000000	00	00000000
3	00	00000000	00	00000000
4	00	00000000	00	00000000
5	00	00000000	00	00000000
6	00	00000000	00	00000000
7	00	00000000	00	00000000
8	1C	00011100	00	00000000
9	00	00000000	11	00010001
10	81	10000001	00	00000000
11	70	01110000	81	10000001
12	00	00000000	70	01110000
13	A9	10101001	00	00000000
14	F4	11110100	A9	10101001
15	67	01100111	F4	11110100
16	F5	11110101	67	01100111
17	00	00000000	F5	11110101
18	88	10001000	00	00000000
19	65	01100101	88	10001000
20	7C	01111100	65	01100101
21	85	10000101	7C	01111100
22	60	01100000	85	10000101
23	E4	11100100	60	01100000
24	80	10000000	E4	11100100
25	C7	11000111	80	10000000
26	24	00100100	C7	11000111
27	00	00000000	24	00100100
28	41	01000001	00	00000000
29	00	00000000	41	01000001
30		00000000		00000000
I also note that your auto-scan has adopted the code-string from the first "to" entry in your history records
Notice the difference in the Byte pattern - despite the fact that both code-strings are 30 Bytes in length, there appears to have been a "right-shift" between the two.
As I have said - I know nothing about what effect this might have to a Passat, but generally this ain't a good thing to do to control modules - I think!
Something to consider in your search for an answer - perhaps?
abhijeetveer
New Member
India
Thank you for your reply.
I can try and get you the timestamp if its really required but the changes mentioned above were one after the other immediately. What exactly had happened was the person changed the headlight dimming by using a drop-down arrow in byte 9, which changed the long code from 1C to 11 as mentioned in the first post but after applying it, instead of changing it from 1C to 11, it was changed to something completely different as can be seen in my last post. So, we thought we probably messed it up and wanted to change it back as there were a lot of errors thrown on the MID. I noticed the shift of codes every time we changed the long code back to original, but every time the long code was changed to original it was changing to something else completely different. The person said there could be something wrong with his machine so I went to a different guy having a VCDS that is when he put the original code and the lights were restored. But the errors have stayed. I just need to get rid of the errors.
Here’s what I understood: I will have to buy a new CECM/BCM? Am I correct?
If yes then will it be a plug and play affair or will is there a way to go around it?
Regards
DV52
C?ID=194404
abhijeetveer:Without intending any offense and again from the perspective of someone (i.e.,me) sans Passat B7 expertise - I wonder if this exercise might have a problem of distinguishing between the forest and the trees!
Let's get back to basics - seems like the first question to answer is - what was the original code string for your BCM. Or, said another way: is the last "from" entry in your history records which you posted truly the factory code-string for your the hex09 module? Once you have answered this question - then (and only then) should you contemplate the correct process for winding back the Byte 9 value (I reckon).
Because I'm intrigued why applying a right-shifted code-string to a BCM hasn't rendered the car unworkable - I'd like to help with the first question. So, purely to satiate my intellectual curiosity - can you post-up a complete (i.e. unabridged, unedited, uncut, full-text) set of records from the VCDS sub-directory of the computer on which the changes were made -please?
