Results 1 to 9 of 9
Thread: 2013 jetta hybrid EPC light on since reparing clockspring.
    Apr 2019
    Readers digest version, looking for help with the 4 codes in the steering wheel section.
    Background/additional info:
    This is my first post here, hoping someone can assist me. Had to change the clockspring on the wifes 2013 VW Jetta awhile back. Everything seemingly went smooth, used genuine VW part, but when done, dash was lit up pretty good, EPC light, Air bag, steering wheel, etc.. Didn't know about having to reprogram everything at the time. Bought Ross Tech and went to work. Got all lights cleared except the EPC. Thought maybe I was just missing something so i brought to dealer to correct the programming. Got hit up for an hour labor and EPC light still on. When I asked about the EPC light, they claimed whatever was causing that was something else, and they'd be happy to take more money and tell me what the problem was. I left. Car is running ok, but it really is time to fix this. One other issue since changing clockspring, the wipers will intermittently come on. Usually just one swipe, but sometimes 2 or 3. Won't happen everyday, or even every week, but it happens..
    Any help would be greatly appreciated.
    Saturday,19,January,2019,15:48:08:52610
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: 3VW637AJ7DM259408   License Plate:
    Mileage: 195790km-121658mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 51
              52 55 56 61 62 72 8C
    VIN: 3VW637AJ7DM259408   Mileage: 195790km-121658miles
    Address 01: Engine (J623-CNLA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023     HW: 04E 907 309 B
       Component: 1.4l TFSI hy  H01 5267
       Revision: V8H01---    Serial number: 00000000000000
       Coding: 00250012442401001000
       Shop #: WSC 30002 001 104857
       ASAM Dataset: EV_ECM14TFS01104E906023 002017
       ROD: EV_ECM14TFS01104E906023_002.rod
       VCID: 5DE767B83DBD56CFD5B-8008
    4332 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:41:16
                        Engine speed: 851.50 /min
                        Normed load value: 16.1 %
                        Coolant temperature: 86 C
                        Intake air temperature: 31 C
                        Voltage terminal 30: 14.818 V
                        Median injection timing: 0.735 ms
    Readiness: 1110 1101
       Part No SW: 0CG 300 045 F    HW: 0AM 927 769 H
       Component: GSG DSG AG7     431 5307
       Revision: 00043014    Serial number: CU501211205630
       Shop #: WSC 54464 000 1048576
       VCID: 2C01FA7C3A07EF47125-8078
    006247 - Powertrain Data Bus
                   P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                        Reset counter: 10
                        Mileage: 195794 km
                        Date: 2013.06.11
                        Time: 15:39:53
       Part No SW: 1K0 907 379 AR    HW: 1K0 907 379 AR
       Component: ESP MK60EC1   H31 0135
       Revision: 00H31001
       Coding: A14B400C49272003850F02E492210440A71800
       VCID: 025D74C4E403C937889-8056
                        Reset counter: 71
                        Mileage: 195794 km
                        Date: 2013.06.11
                        Time: 15:29:15
                        Count: 3
                        Count: 13
                        Count: 12800
                        Count: 16390
                        Count: 34304
                        Count: 1
                        Count: 766
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434 A
       Revision: 00085000    Serial number: 0153838823
       Coding: 030C0C
       ASAM Dataset: EV_KESSYPQ35G A02014
       ROD: EV_KESSYPQ35G_A02_VW36.rod
       VCID: 3431E21CEEB7B7874A5-8060
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: -----------    HW: -----------
       Component: Climatronic   0202
       Revision: --------
       Coding: 0010401002
       Shop #: WSC 00066 000 00120
       ASAM Dataset: EV_ACClimaBHBVW361Hybri 001001
       ROD: EV_ACClimaBHBVW361Hybri.rod
       VCID: 6FBB2D70C711D45F777-803A
       Air Conditioning Compressor:
       Subsystem 1 - Part No SW: 5C0 820 803 F    HW: 5C0 820 803 F
       Component: J842 eKK  H03 0001
       Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
       Component: BCM PQ35 M    021 1068
       Revision: BJ021001
       Coding: 6F200A1A912F06C40088088100000D4C0104000844808DB0E4842600A043
       VCID: 3FDBBD30D77164DFA77-806A
       Part No SW: 5C0 959 655 J    HW: 5C0 959 655 J
       Component: AirbagVW10    101 0911
       Serial number: 003KLD00384T
       Coding: 00004838
       Shop #: WSC 00066 790 00184
       ASAM Dataset: EV_AirbaVW10SMEVW360 001024
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 392FD328C9D54AEF993-806C
       Serial number: 6940000Y120000NAR40Y
       Coding: 303036
       Serial number: 3572MSME1C437271ZZZU
       Serial number: 3582MSME7B407271ZZZX
       Serial number: 3516KSME0D322720ZZZI
       Serial number: 3526KSME62222720ZZZD
       Serial number: 3556LSME0D4C601FZZZ2
       Serial number: 3566LSME531A581FZZZ0
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
                        Reset counter: 111
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:29:19
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20170424200947
       Coding: 288AA00000
       Shop #: WSC 01286 386 08256
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 025D74C4E483C937889-8056
       Serial number: 0653981
       Coding: 820000
    49675 - Control Circuit for Ignition Key Lock Solenoid
              B114A 13 [009] - Open Circuit
                        Reset counter: 71
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:29:02
    147464 - Terminal 15
              B1148 29 [009] - Signal Implausible
                        Reset counter: 71
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:27:53
    342030 - Comfort System CAN Bus (SAE Medium Speed Bus)
              U0010 00 [008] - Malfunction
                        Reset counter: 111
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:39:51
    617736 - Selector Lever Park Position Lock Switch
              B1162 29 [009] - Signal Implausible
                        Reset counter: 71
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:27:53
       Part No SW: 5C6 920 970 D    HW: 5C6 920 970 D
       Component: KOMBI         H08 0710
       Coding: 281E01
       Shop #: WSC 00066 000 00198
       VCID: 2D07F7780D9DE64F05B-8078
       Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
       Component: J533  Gateway H50 1634
       Revision:   H50       Serial number: 06121203290523
       Coding: 351002
       VCID: 76B51814B8CBE597B41-8022
       Component: IMMO          H08 0710
       Coding: 000007
       VCID: 6A8D3C64FCF33177209-803E
       Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
       Component: ELV-PQ35      H20 0240
       Revision: 00000000    Serial number: 12000242907004
       Coding: 4900000000000000
       Shop #: WSC 00066 790 50316
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2F3BED700791945F377-807A
              U1400 00 [008] - -
              [Under voltage (temporary)]
                        Reset counter: 111
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:29:43
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: B0 01
                        WFS State: 67 1A
                        Vehicle speed: 0.00 km/h
                        Voltage: 4B
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663774802
       Coding: 020100
       VCID: 2A0DFC643CF3F177E09-807E
       Part No SW: 5C0 035 274 B    HW: 5C0 035 274 B
       Component: RNS315-NAR    H53 0319
       Serial number: VWZAZ2M4270747
       Coding: 04090041010006000000100A
       Shop #: WSC 01383 790 50316
       ROD: EV_RNS315NARV2UDS_VW32.rod
       VCID: 1F1B1DB0773104DF877-804A
              B11CF 53 [009] - Deactivated
                        Reset counter: 71
                        Mileage: 195794 km
                        Date: 2019.01.19
                        Time: 15:30:16
       Revision: 13110009    Serial number: 0005849774
       Coding: 0004B5
       VCID: 5BE369A023A958FFABF-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1508
       Serial number: 00000007341606
       Coding: 000490
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 69     3305
       Revision: 00H22000
       VCID: 372BD510F3415C9F6F7-8062
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H07 6813
       Revision: --------    Serial number: EAA098A0002652
       VCID: 26150854286BD517C41-8072
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
       Component: EZE_2         H50 1634
       Coding: 01030100
       VCID: 6FBB2D70C791D45F777-803A
       Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H10 0007
       Serial number:     WRH0007ELJV
       Coding: 180000
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5C0 907 080 C    HW: 5C0 907 080 C
       Component: VW361H0108000 H02 0532
       Revision: 00H02000    Serial number: 00000000000000
       Coding: 40020000000000000000
       Shop #: WSC 00066 000 00205
       ASAM Dataset: EV_DMCM04510115C0907080C 001021
       ROD: EV_DMCM04510115C0907080C.rod
       VCID: 231311405B59203FA3F-8076
       Revision: 15110009    Serial number: 0005904346
       Coding: 0004B4
       VCID: 5CE16ABC26A75FC7A25-8008
       Slave Passenger:
       Component: J389__TSG-HR  008 1508
       Serial number: 00000007365163
       Coding: 000490
       Component: AFS-ECU       H04 0111
       Coding: 081200010B000200
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: 372BD510FFC15C9F6F7-8062
       Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AH
       Component: Batt.regelung H50 1634
       Coding: 16660164
       VCID: 71BF2B08D1A5C2AF613-8024
       Subsystem 1 - Part No SW: 1S0 915 181 A    HW: 1S0 915 181 A
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970493988
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5C6 915 182 B    HW: 5C6 915 182 B
       Component: BECM          H09 0601
       Serial number: 288 SYEQ727B41
       ASAM Dataset: EV_BECM06020115C6915182 005021
       ROD: EV_BECM06020115C6915182.rod
       VCID: 2A0DFC643C73F177E09-807E
    End----------(Elapsed Time: 01:27, VBatt start/end: 14.8V/14.9V)-----------
    Part numbers you replaced from dealer & please post the invoice of parts you changed.
    Please also post the OBD2 mode 1,3,7 & 9
    Quote Originally Posted by paulfesta View Post
    I don't suppose you have a scan from before you changed the clockspring?
    Hint: Look in the Scans sub-folder.
    HQ
    Coding: 288AA00000
    Please try coding the J527 with a value of 000A140000, then clear codes out of everything. Now play with every button/switch/level/knob/zipper on the steering column. Then lets see where things stand and post fresh Auto-Scan.
    Jef
    Apr 2019
    Thank you to all who replied. Changing the coding as specified here did the trick..Everything seems to work on the column and wheel. Time will tell if it fixed the wipers from occasionally coming on. I reset all fault codes and re-scanned (posted below). I still have one fault code on the engine I'll need to look at. Could that be because the monitors are not yet ready from resetting all fault codes?
    To answer an earlier question, part number is 5K0953569AL..
    Here is the scan after code change and clearing everything.
    Thanks again..
    Saturday,13,April,2019,01:02:20:52610
    Mileage: 200990km-124889mi   Repair Order:
    VIN: 3VW637AJ7DM259408   Mileage: 200990km-124889miles
       Component: 1.4l TFSI hy  H01 7928
       Coding: 00250012442401000000
       Shop #: WSC 00003 444 00000
       ASAM Dataset: EV_ECM14TFS01104E906023 002024
    4482 - Function Restriction due to Implausible Message(s)
              U1112 00 [039] - -
                        Mileage: 200997 km
                        Date: 2019.04.13
                        Time: 23:48:45
                        Coolant temperature: 87 C
                        Intake air temperature: 38 C
                        Voltage terminal 30: 14.724 V
                        Median injection timing: 0.502 ms
       Part No SW: 0CG 300 045 G    HW: 0AM 927 769 H
       Component: GSG DSG AG7     441 5802
       Revision: 00044014    Serial number: CU501808016597
       Shop #: WSC 04940 001 00001
       VCID: 2D07F778011DE64F05B-8078
       Revision: 00H31001
       Coding: 030C0C
       Revision: --------
       Coding: 0010401002
       Coding: 00004838
       Coding: 303036
       Coding: 000A140000
       Coding: 820000
       Coding: 281E01
       Coding: 351002
       Coding: 000007
       Coding: 020100
                        Reset counter: 16
                        Mileage: 200997 km
                        Date: 2019.04.13
                        Time: 23:52:33
       Coding: 0004B5
       Slave Driver:
       Coding: 000490
       Revision: 00H22000
    Address 46: Central Conv.
       Coding: 01030100
       Coding: 180000
       Part No SW: 5C0 907 080 E    HW: 5C0 907 080 C
       Component: VW361H0108000 H02 0535
       ASAM Dataset: EV_DMCM04510115C0907080E 001021
       ROD: EV_DMCM04510115C0907080E.rod
       VCID: 25170F58556DDE0FCDB-8070
       Coding: 0004B4
       Slave Passenger:
       Coding: 000490
       Coding: 16660164
    End----------(Elapsed Time: 01:29, VBatt start/end: 14.6V/14.7V)-----------
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #6
    Apr 2019
    I have a followup question. Can you tell me what it was about the incorrect coding on the steering wheel that would have turned on the EPC light? I've been arguing with the dealer service manager who is telling me that it is completely unrelated, and that it is 100% coincidence that the EPC light that has been on for 14 months went off immediately after me hitting enter on the new steering wheel code you gave me. The other issue that had been occurring was an occassional swipe or two of the wipers several times a day, hasn't happened in the last 5 days either.
    Seems quite clear to me that the incorrect steering wheel code, and the EPC light (and wiper issue) were directly related, just hoping to understand why.. Any help would be great..
  10. #7
    HQ
    P1647 00 [167] - -
    The J527 is tied to the Powertrain Data Bus, so if the J527 isn't coded correctly, it is like a lame friend at a party that just brings everyone else down.
    Jef
  11. Likes PetrolDave, Uwe liked this post
  12. #8
    Apr 2019
    Thank you again. Unreal that the service manager at the dealer doesn't know this. I explained to him that I entered the code you gave me and the EPC light went off, and he remained insistent that it's not possible.
    This is why I hate dealers and would rather work on stuff myself.
  13. #9
    Apr 2019
    Can I ask one more question? Is the clockspring the same as the J527 steering wheel control unit, or are these 2 different things? I really appreciate all the help.
