Audi Q7 61 Battery Regul Cannot be reached.
PARFITTMOBILE
C?ID=276150
Hi
I wonder if someone can point me in the right direction.
I have an Audi Q7 2008 with the following autoscan.....
Tuesday,09,April,2019,17:52:17:20916
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ4L28D055959   License Plate: DV08NBN
Mileage: 180040km-111871mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 34 37 42 46 47 4F
           52 55 56 61 62 67 6D 6F 72 76 77
VIN: WAUZZZ4L28D055959   Mileage: 180040km-111871miles
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: Malfunction 1010
1E-Media Player 2 -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
    Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
    Component: 3.0TDI EDC17G100AG  0080
    Revision: --H01---    Serial number:
    Coding: 0121002C190F0168
    Shop #: WSC 00052 210 88667
    VCID: 24405212E78A4B6A99-8070
049425 - No Communication with Battery Energy Control Module
                U0111 - 001 -
                     Fault Status: 01100001
                     Fault Frequency: 52
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:30:37
                     RPM: 777 /min
                     Load: 0.0 %
                     Voltage: 13.30 V
                     Bin. Bits: 00000000
                     (no units): 4.0
                     Bin. Bits: 00000000
008598 - Oxygen (Lambda) Sensor B1 S1
                P2196 - 000 - Signal too High (Rich)
                     Mileage: 179386 km
                     Date: 2019.08.10
                     Time: 15:52:53
                     RPM: 2079 /min
                     Speed: 106.4 km/h
                     Lambda: 67.9 %
                     (no units): 0.0
                     Voltage: 0.980 V
001378 - System Voltage
                P0562 - 000 - Too Low - Intermittent
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 14:52:04
                     Voltage: 8.44 V
                     Load: 0.0 %
                     Temperature: 48.6°C
                     Lambda: 0.0 %
                     Torque: 0.0 Nm
049682 - Steering Column Control Module
                U0212 - 002 - No Communications - Intermittent
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 14:01:29
                     Load: 0.0 %
                     Voltage: 11.55 V
                     Bin. Bits: 00000000
                     (no units): 8.0
                     Bin. Bits: 00000000
Address 02: Auto Trans        Labels: 09D-927-750.clb
    Part No SW: 09D 927 750 HT    HW: 09D 927 750 HT
    Component: AL 750 6A           1164
    Revision: 00H78000    Serial number:
    Coding: 0000504
    Shop #: WSC 31414 790 00001
    VCID: 071A259E767C80729C-8052
18275 - Powertrain Data Bus
             P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
00364 - Terminal 15 Slave
Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
    Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
    Component: ESP ALLRAD MK25E1   0010
    Revision: 00H30001
    Coding: 0103569
    VCID: 295E432680A89602AA-807C
                     Fault Frequency: 7
                     Reset counter: 44
                     Mileage: 179375 km
                     Date: 2019.08.10
                     Time: 10:58:39
                     Count: 10305
                     Count: 128
                     Count: 35072
             000 -  -
                     Reset counter: 44
                     Mileage: 179451 km
                     Count: 128
                     Count: 2881
                     Count: 297
                     Count: 26880
    Part No SW: 4F0 910 852     HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV   H31 0230
    Revision: 09010701    Serial number: 10601501008404
    Coding: 0000147
    VCID: 63C2110EA2040C52A0-8036
    Component: FBSAUDIC6 EZS   H46 0080
    Component: FBSAUDIC6 IDG   H01 0040
02072 - Control Module for Energy Management (J644)
                     Reset counter: 35
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:30:44
00532 - Supply Voltage B+
                     Fault Frequency: 12
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 12:06:54
                     Fault Frequency: 37
                     Reset counter: 84
                     Mileage: 179412 km
                     Date: 2019.08.11
                     Time: 11:10:26
00230 - Transmission Park Selector Switch (F305)
                     Fault Status: 00101010
                     Reset counter: 82
                     Mileage: 179938 km
                     Date: 2007.05.16
                     Time: 13:37:36
Address 07: Control Head
    Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
    Component: KLIMABETAETIGUNGH07 0030
    Revision: 00---013    Serial number: 00000000158125
    Coding: 0001046
    VCID: 2342510EE2844C52E0-8076
10 Faults Found:
01854 - Heated Seat; Front Right (Z46)
                     Fault Status: 01101011
                     Reset counter: 44
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:23:53
                     Temperature: 18.0°C
                     Reset counter: 35
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:23:53
                     Bin. Bits:   001111
             000 -  -  - Intermittent
                     Fault Frequency: 12
                     Reset counter: 84
                     Mileage: 179375 km
                     Date: 2019.08.10
                     Time: 10:58:57
                     Voltage: 9.90 V
                     Reset counter: 84
                     Mileage: 179781 km
                     Date: 2019.08.16
                     Time: 16:48:44
                     Bin. Bits:    01111
                     Reset counter: 81
                     Mileage: 179856 km
                     Date: 2019.08.17
                     Time: 13:29:07
                     Reset counter: 81
                     Mileage: 179938 km
                     Date: 2007.05.16
                     Time: 13:34:17
                     Voltage: 8.20 V
                     Reset counter: 82
                     Mileage: 179938 km
                     Date: 2007.05.16
                     Time: 13:37:40
                     Temperature: 49.0°C
                     Temperature: 18.0°C
                     Load: 8.8 %
                     Temperature: -55.0°C
                     RPM: 760 /min
                     Absolute Pres.: 7.0 bar
                     Current: 0.000 A
                     Temperature: 10.0°C
01853 - Heated Seat; Left Front (Z45)
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 12:00:48
                     Temperature: 8.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                     Fault Status: 01101010
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 12:00:48
                     Temperature: 8.0°C
                     Fault Status: 00101100
                     Reset counter: 84
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 14:01:28
    Part No SW: 4F0 910 279 K    HW: 4F0 907 279
    Component: ILM Fahrer      H18 0250
    Coding: 0013121
    VCID: 316EAB46A878EEC262-8064
    Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
    Component: Wischer AU716   H13 0110
    Coding: 00022806
    Shop #: WSC 31414
    Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00150059
    Shop #: WSC 31414
                     Fault Status: 00101011
                     Reset counter: 75
                     Mileage: 179368 km
                     Date: 2019.08.10
                     Time: 10:33:00
00908 - Control Module for Wiper Motor
                     Reset counter: 80
                     Mileage: 179780 km
                     Date: 2019.08.16
                     Time: 16:50:00
                     Fault Frequency: 15
                     Reset counter: 84
                     Mileage: 179472 km
                     Date: 2019.08.13
                     Time: 14:06:00
                     Fault Frequency: 8
                     Reset counter: 84
                     Mileage: 179472 km
                     Date: 2019.08.14
                     Time: 12:04:00
Address 0E: Media Player 1
    Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
    Component: 71 AIRBAG AUDI8RH42 0230
    Revision: 03H42000    Serial number: 00399D046S6Z
    Coding: 0014129
    VCID: 2E54B03AB946F13A7F-807A
    Subsystem 1 - Serial number: 6332QSME512E2E3BR
    Subsystem 2 - Serial number: 6342QSME5B540839L
    Subsystem 3 - Serial number: 6352QSME5B540707G
    Subsystem 4 - Serial number: 6362QSME5B571739Q
    Subsystem 5 - Serial number: 63734SME5247240D
    Subsystem 6 - Serial number: 63834SME526D096DD
             002 - Lower Limit Exceeded - Intermittent - MIL ON
             000 -  -  - Intermittent - MIL ON
    Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
    Component: J0527               0410
    Revision: 00H03000    Serial number: 90055080420161
    Coding: 0102142
    VCID: 275A451E96BCA072BC-8072
    Component: E0221           H02 0030
                     Fault Frequency: 39
                     Reset counter: 44
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:23:55
                     Reset counter: 84
                     Mileage: 179646 km
                     Date: 2019.08.15
                     Time: 18:13:06
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C    HW: 4L0 920 981 B
    Component: KOMBIINSTR. M73 H23 0240
    Revision: 00000000    Serial number: 741548X28
    Coding: 3681458
    Shop #: WSC 50741 067 57207
                     Fault Frequency: 6
                     Reset counter: 81
                     Mileage: 179475 km
                     Date: 2019.08.13
                     Time: 14:05:49
00771 - Fuel Level Sensor (G)
                     Fault Status: 00100111
                     Reset counter: 81
                     Mileage: 179856 km
                     Date: 2019.08.17
                     Time: 15:33:19
00438 - Fuel Supply Sensor 2 (G169)
                     Reset counter: 81
                     Mileage: 179856 km
                     Date: 2019.08.17
                     Time: 15:33:19
    Part No SW: 4L0 910 105     HW: 4L0 815 071 E
    Component: Heizgeraet      H08 0090
    Revision: 0000000D    Serial number: 00000009014264
    Coding: 0000001
    VCID: 60C81E02B312174ABD-8034
00664 - Fuel gauge
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
    Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
    Component: J533__Gateway   H06 0060
    Revision: 00H06000    Serial number: 1100B08219835B
    Coding: F55BBE7F70720200
    VCID: 2D56B736B4408A2246-8078
                     Reset counter: 35
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:24:04
                     Reset counter: 35
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:25:00
00384 - Optical Databus
                     Reset counter: 75
                     Mileage: 179451 km
                     Date: 2019.08.11
                     Time: 12:10:52
                     Reset counter: 80
                     Mileage: 179856 km
                     Date: 2019.08.17
                     Time: 15:36:23
                     Reset counter: 81
                     Mileage: 179938 km
                     Date: 2007.05.16
                     Time: 13:34:17
                     Reset counter: 84
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 14:00:26
Address 1E: Media Player 2
Address 34: Level Control        Labels: 4L0-910-553.lbl
    Part No SW: 4L0 910 553 C    HW: 4L0 907 553
    Component: LUFTFDR.-CDC    H03 7660
    Revision: --H03001    Serial number: 15.1528-0096.2
    Coding: 0015510
    VCID: 2A5CBC2A85AE9D1AA3-807E
                     Fault Frequency: 27
                     Reset counter: 168
                     Mileage: 179375 km
                     Date: 2019.08.10
                     Time: 10:58:33
                     Error Code: 13
                     Reset counter: 168
                     Error Code: 64
01577 - Turn-Off due to Over-Temp
                     Fault Status: 00100001
                     Reset counter: 78
                     Mileage: 179675 km
                     Date: 2019.08.15
                     Time: 18:44:28
                     Error Code: 68
                     Fault Status: 00101001
                     Reset counter: 79
                     Mileage: 179781 km
                     Date: 2019.08.16
                     Time: 16:52:52
                     Error Code: 8
01316 - ABS Control Module
             013 - Check DTC Memory
                     Fault Status: 11101101
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 12:58:46
                     Error Code: 98
Address 37: Navigation
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
    Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
    Component: TSG FA          H12 0150
    Revision: 00-00000
    Coding: 0002651
    VCID: 2F6AAD3EBE4CF83274-807A
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 12:00:36
    Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
    Component: Komfortgeraet   H08 0060
    Revision: 0060 ---    Serial number: 01094255600000
    Coding: 7348475
    VCID: 3362A14E5264DCD210-8066
01699 - Motor for Central Locking; Hatch/Trunk (V53)
                     Fault Status: 01101001
                     Fault Frequency: 17
                     Reset counter: 44
                     Mileage: 179412 km
                     Date: 2019.08.10
                     Time: 16:39:34
                     Fault Frequency: 16
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.17
                     Time: 09:42:41
03073 - Rear Lid Closed Sensor 1
                     Reset counter: 81
                     Mileage: 179938 km
                     Date: 2007.05.16
                     Time: 12:39:01
                     Reset counter: 84
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 15:07:51
Address 47: Sound System
    Part No SW: 4F0 910 280     HW: 4F0 907 280 E
    Component: ILM Beifahrer   H12 0100
    Revision:             Serial number: 00000000075665
    Coding: 0011101
    VCID: 5EB420FA896621BA8F-800A
                     Reset counter: 44
                     Mileage: 179368 km
                     Date: 2019.08.10
                     Time: 10:30:00
                     Voltage: 13.300 V
                     Temperature: 5.0°C
                     Reset counter: 80
                     Mileage: 179856 km
                     Date: 2019.08.17
                     Time: 13:19:00
                     Voltage: 11.700 V
                     Temperature: 77.0°C
                     Fault Status: 00110010
                     Fault Frequency: 6
                     Reset counter: 84
                     Mileage: 179472 km
                     Date: 2019.08.14
                     Time: 19:05:00
                     Voltage: 8.400 V
                     Temperature: 77.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
    Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
    Component: TSG BF          H12 0150
    Revision: 00-00000
    Coding: 0002651
                     Fault Frequency: 94
                     Reset counter: 44
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:24:10
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 19:10:39
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 19:10:39
    Part No SW: 4L0 910 357     HW: 4L0 907 357
    Component: AFS 1           H01 0040
    Coding: 0000022
    VCID: 69DE0326402856026A-803C
    Component: AFS-Modul links H06 0002
    Subsystem 2 - Part No: 7L6 941 329 A
    Component: AFS-Modul rechtsH07 0004
02233 - Left Headlight Power Output Stage (J667)
                     Reset counter: 79
                     Mileage: 179781 km
                     Date: 2019.08.16
                     Time: 16:51:42
                     Reset counter: 44
                     Mileage: 179856 km
                     Date: 2019.08.17
                     Time: 13:27:08
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.20
                     Time: 12:07:34
Address 56: Radio
Address 61: Battery Regul.
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
    Component: TSG HL          H21 0150
    Coding: 0002058
                     Fault Frequency: 138
                     Reset counter: 44
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:24:17
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 19:10:39
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 19:10:39
Address 67: Voice Control
    Part No SW: 4L0 910 945     HW: 4L0 827 851 C
    Component: ValeoHeckdeckel H25 0290
    Revision: --H25001    Serial number: E5030000B
    Shop #: WSC 00613 210 88222
    VCID: 6CD07A324FDA432A11-8038
    Subsystem 3 - Serial number: RD28.02.08--H25001001C0113ÿ
    Subsystem 4 - Serial number: 1C0113ÿ
                     Fault Frequency: 27
                     Reset counter: 44
                     Mileage: 180041 km
                     Date: 2007.05.16
                     Time: 14:18:42
    Part No SW: 4L0 910 290     HW: 4L0 907 290
    Component: ILM HINTEN 2    H05 0060
    Revision: AAH05061    Serial number: 003510394-----
    Coding: 0000001
    VCID: 65C60F16AC3072624E-8030
                     Fault Frequency: 137
                     Reset counter: 44
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:24:21
01516 - Terminal 30; Left
                     Fault Frequency: 6
                     Reset counter: 80
                     Mileage: 179451 km
                     Date: 2019.08.11
                     Time: 12:31:13
                     Fault Frequency: 17
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 12:06:54
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
    Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
    Component: TSG HR          H21 0150
    Coding: 0002058
                     Fault Frequency: 134
                     Reset counter: 44
                     Mileage: 179371 km
                     Date: 2019.08.10
                     Time: 10:24:22
                     Reset counter: 84
                     Mileage: 179475 km
                     Date: 2019.08.14
                     Time: 19:10:39
    Part No SW: 4F0 910 283 K    HW: 4F0 919 283 K
    Component: Parkhilfe 8-Kan H12 0100
    Revision: 00H12000    Serial number: 69830804903838
    Coding: 0201146
    VCID: 2C50BA328F5A832A51-8078
                     Reset counter: 81
                     Mileage: 179938 km
                     Date: 2007.05.16
                     Time: 13:34:18
                     Fault Frequency: 7
                     Reset counter: 84
                     Mileage: 179412 km
                     Date: 2019.08.11
                     Time: 11:10:34
Address 77: Telephone
End-------------------------(Elapsed Time: 03:07)--------------------------
Loads of codes but the main issue is poor charging and flat battery issues
It has had a new battery but I have not been able to code the energy management because I can't establish communication with 61. Battery Regul.
I have good live and earth at the module and opposing seemingly ok CAN signals. I have tried a new module.
So many fault codes!
Has anyone seen this before?
Thanks
Well, it looks like the whole MMI system on the optical MOST bus is off-line, but that shouldn't affect the 61-Battery Regulation module, which is just plain old CAN. I'm not certain which of the multiple CAN buses it's on. Check wiring diagrams, and then check continuity between the two CAN pins at that module and the corresponding CAN pins at the Gateway.
PARFITTMOBILE
C?ID=276150
Thanks! I will take a look
