Results 1 to 3 of 3
Thread: Audi Q7 61 Battery Regul Cannot be reached.
    Apr 2018
    Hi
    I wonder if someone can point me in the right direction.
    I have an Audi Q7 2008 with the following autoscan.....
    Tuesday,09,April,2019,17:52:17:20916
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ4L28D055959   License Plate: DV08NBN
    Mileage: 180040km-111871mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 1E 34 37 42 46 47 4F
               52 55 56 61 62 67 6D 6F 72 76 77
    VIN: WAUZZZ4L28D055959   Mileage: 180040km-111871miles
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    18-Aux. Heat -- Status: Malfunction 1010
    1E-Media Player 2 -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: Cannot be reached 1100
    67-Voice Control -- Status: Cannot be reached 1100
    Address 01: Engine (CAS)       Labels:. 059-907-401-CAT1.clb
        Part No SW: 4L1 910 401 D    HW: 4L0 907 401 A
        Component: 3.0TDI EDC17G100AG  0080
        Revision: --H01---    Serial number:
        Coding: 0121002C190F0168
        Shop #: WSC 00052 210 88667
        VCID: 24405212E78A4B6A99-8070
    049425 - No Communication with Battery Energy Control Module
                    U0111 - 001 -
                         Fault Status: 01100001
                         Fault Frequency: 52
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:30:37
                         RPM: 777 /min
                         Voltage: 13.30 V
                         Bin. Bits: 00000000
                         (no units): 4.0
                         Bin. Bits: 00000000
    008598 - Oxygen (Lambda) Sensor B1 S1
                    P2196 - 000 - Signal too High (Rich)
                         Mileage: 179386 km
                         Date: 2019.08.10
                         Time: 15:52:53
                         RPM: 2079 /min
                         Speed: 106.4 km/h
                         Lambda: 67.9 %
                         (no units): 0.0
                         Voltage: 0.980 V
    001378 - System Voltage
                    P0562 - 000 - Too Low - Intermittent
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 14:52:04
                         Voltage: 8.44 V
                         Temperature: 48.6°C
                         Lambda: 0.0 %
                         Torque: 0.0 Nm
    049682 - Steering Column Control Module
                    U0212 - 002 - No Communications - Intermittent
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 14:01:29
                         Voltage: 11.55 V
                         Bin. Bits: 00000000
                         (no units): 8.0
                         Bin. Bits: 00000000
        Part No SW: 09D 927 750 HT    HW: 09D 927 750 HT
        Component: AL 750 6A           1164
        Revision: 00H78000    Serial number:
        Coding: 0000504
        Shop #: WSC 31414 790 00001
        VCID: 071A259E767C80729C-8052
    18275 - Powertrain Data Bus
                 P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
    00364 - Terminal 15 Slave
        Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
        Component: ESP ALLRAD MK25E1   0010
        Revision: 00H30001
        Coding: 0103569
        VCID: 295E432680A89602AA-807C
                         Fault Frequency: 7
                         Reset counter: 44
                         Mileage: 179375 km
                         Date: 2019.08.10
                         Time: 10:58:39
                         Count: 10305
                         Count: 128
                         Count: 35072
                         Reset counter: 44
                         Mileage: 179451 km
                         Count: 128
                         Count: 2881
                         Count: 297
                         Count: 26880
        Component: FBSAUDIC6 ELV   H31 0230
        Revision: 09010701    Serial number: 10601501008404
        Coding: 0000147
        VCID: 63C2110EA2040C52A0-8036
        Subsystem 1 - Part No: 4F0 910 131 E
        Component: FBSAUDIC6 EZS   H46 0080
        Component: FBSAUDIC6 IDG   H01 0040
                         Reset counter: 35
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:30:44
    00532 - Supply Voltage B+
                         Fault Frequency: 12
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 12:06:54
                         Fault Frequency: 37
                         Reset counter: 84
                         Mileage: 179412 km
                         Date: 2019.08.11
                         Time: 11:10:26
    00230 - Transmission Park Selector Switch (F305)
                         Fault Status: 00101010
                         Reset counter: 82
                         Mileage: 179938 km
                         Date: 2007.05.16
                         Time: 13:37:36
    Address 07: Control Head
        Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
        Component: KLIMABETAETIGUNGH07 0030
        Revision: 00---013    Serial number: 00000000158125
        Coding: 0001046
        VCID: 2342510EE2844C52E0-8076
    10 Faults Found:
    01854 - Heated Seat; Front Right (Z46)
                         Reset counter: 44
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:23:53
                         Temperature: 18.0°C
                         Reset counter: 35
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:23:53
                         Bin. Bits:   001111
                 000 -  -  - Intermittent
                         Fault Frequency: 12
                         Reset counter: 84
                         Mileage: 179375 km
                         Date: 2019.08.10
                         Time: 10:58:57
                         Voltage: 9.90 V
                         Reset counter: 84
                         Mileage: 179781 km
                         Date: 2019.08.16
                         Time: 16:48:44
                         Bin. Bits:    01111
                         Reset counter: 81
                         Mileage: 179856 km
                         Date: 2019.08.17
                         Time: 13:29:07
                         Reset counter: 81
                         Mileage: 179938 km
                         Date: 2007.05.16
                         Time: 13:34:17
                         Voltage: 8.20 V
                         Reset counter: 82
                         Mileage: 179938 km
                         Date: 2007.05.16
                         Time: 13:37:40
                         Temperature: 49.0°C
                         Temperature: 18.0°C
                         Load: 8.8 %
                         Temperature: -55.0°C
                         RPM: 760 /min
                         Absolute Pres.: 7.0 bar
                         Current: 0.000 A
                         Temperature: 10.0°C
    01853 - Heated Seat; Left Front (Z45)
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 12:00:48
                         Temperature: 8.0°C
    01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                         Fault Status: 01101010
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 12:00:48
                         Temperature: 8.0°C
                         Fault Status: 00101100
                         Reset counter: 84
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 14:01:28
        Part No SW: 4F0 910 279 K    HW: 4F0 907 279
        Component: ILM Fahrer      H18 0250
        Coding: 0013121
        VCID: 316EAB46A878EEC262-8064
        Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
        Component: Wischer AU716   H13 0110
        Coding: 00022806
        Shop #: WSC 31414
        Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
        Component: REGENLICHTSENSORH13 0100
        Coding: 00150059
        Shop #: WSC 31414
                         Fault Status: 00101011
                         Reset counter: 75
                         Mileage: 179368 km
                         Date: 2019.08.10
                         Time: 10:33:00
                         Reset counter: 80
                         Mileage: 179780 km
                         Date: 2019.08.16
                         Time: 16:50:00
                         Fault Frequency: 15
                         Reset counter: 84
                         Mileage: 179472 km
                         Date: 2019.08.13
                         Time: 14:06:00
                         Reset counter: 84
                         Mileage: 179472 km
                         Date: 2019.08.14
                         Time: 12:04:00
    Address 0E: Media Player 1
        Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
        Component: 71 AIRBAG AUDI8RH42 0230
        Revision: 03H42000    Serial number: 00399D046S6Z
        Coding: 0014129
        VCID: 2E54B03AB946F13A7F-807A
        Subsystem 1 - Serial number: 6332QSME512E2E3BR
        Subsystem 2 - Serial number: 6342QSME5B540839L
        Subsystem 3 - Serial number: 6352QSME5B540707G
        Subsystem 4 - Serial number: 6362QSME5B571739Q
        Subsystem 5 - Serial number: 63734SME5247240D
        Subsystem 6 - Serial number: 63834SME526D096DD
                 000 -  -  - Intermittent - MIL ON
        Revision: 00H03000    Serial number: 90055080420161
        Coding: 0102142
        VCID: 275A451E96BCA072BC-8072
                         Fault Frequency: 39
                         Reset counter: 44
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:23:55
                         Reset counter: 84
                         Mileage: 179646 km
                         Date: 2019.08.15
                         Time: 18:13:06
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
        Part No SW: 4F0 910 930 C    HW: 4L0 920 981 B
        Component: KOMBIINSTR. M73 H23 0240
        Revision: 00000000    Serial number: 741548X28
        Coding: 3681458
        Shop #: WSC 50741 067 57207
                         Reset counter: 81
                         Mileage: 179475 km
                         Date: 2019.08.13
                         Time: 14:05:49
    00771 - Fuel Level Sensor (G)
                         Fault Status: 00100111
                         Reset counter: 81
                         Mileage: 179856 km
                         Date: 2019.08.17
                         Time: 15:33:19
    00438 - Fuel Supply Sensor 2 (G169)
                         Reset counter: 81
                         Mileage: 179856 km
                         Date: 2019.08.17
                         Time: 15:33:19
    Address 18: Aux. Heat        Labels: None
        Part No SW: 4L0 910 105     HW: 4L0 815 071 E
        Component: Heizgeraet      H08 0090
        Revision: 0000000D    Serial number: 00000009014264
        VCID: 60C81E02B312174ABD-8034
    00664 - Fuel gauge
        Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
        Component: J533__Gateway   H06 0060
        Revision: 00H06000    Serial number: 1100B08219835B
        Coding: F55BBE7F70720200
        VCID: 2D56B736B4408A2246-8078
    6 Faults Found:
                         Reset counter: 35
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:24:04
                         Reset counter: 35
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:25:00
    00384 - Optical Databus
                         Reset counter: 75
                         Mileage: 179451 km
                         Date: 2019.08.11
                         Time: 12:10:52
    01207 - Control Module for Auxiliary Heater (J364)
                         Reset counter: 80
                         Mileage: 179856 km
                         Date: 2019.08.17
                         Time: 15:36:23
                         Reset counter: 81
                         Mileage: 179938 km
                         Date: 2007.05.16
                         Time: 13:34:17
                         Reset counter: 84
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 14:00:26
    Address 1E: Media Player 2
    Address 34: Level Control        Labels: 4L0-910-553.lbl
        Part No SW: 4L0 910 553 C    HW: 4L0 907 553
        Component: LUFTFDR.-CDC    H03 7660
        Revision: --H03001    Serial number: 15.1528-0096.2
        Coding: 0015510
        VCID: 2A5CBC2A85AE9D1AA3-807E
                         Fault Frequency: 27
                         Reset counter: 168
                         Mileage: 179375 km
                         Date: 2019.08.10
                         Time: 10:58:33
                         Error Code: 13
                         Reset counter: 168
                         Error Code: 64
    01577 - Turn-Off due to Over-Temp
                         Fault Status: 00100001
                         Reset counter: 78
                         Mileage: 179675 km
                         Date: 2019.08.15
                         Time: 18:44:28
                         Error Code: 68
                         Fault Status: 00101001
                         Reset counter: 79
                         Mileage: 179781 km
                         Date: 2019.08.16
                         Time: 16:52:52
                         Error Code: 8
                 013 - Check DTC Memory
                         Fault Status: 11101101
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 12:58:46
                         Error Code: 98
    Address 37: Navigation
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
        Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
        Component: TSG FA          H12 0150
        Revision: 00-00000
        Coding: 0002651
        VCID: 2F6AAD3EBE4CF83274-807A
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 12:00:36
        Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
        Component: Komfortgeraet   H08 0060
        Revision: 0060 ---    Serial number: 01094255600000
        Coding: 7348475
        VCID: 3362A14E5264DCD210-8066
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                         Fault Status: 01101001
                         Fault Frequency: 17
                         Reset counter: 44
                         Mileage: 179412 km
                         Date: 2019.08.10
                         Time: 16:39:34
                         Fault Frequency: 16
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.17
                         Time: 09:42:41
    03073 - Rear Lid Closed Sensor 1
                         Reset counter: 81
                         Mileage: 179938 km
                         Date: 2007.05.16
                         Time: 12:39:01
                         Reset counter: 84
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 15:07:51
    Address 47: Sound System
        Part No SW: 4F0 910 280     HW: 4F0 907 280 E
        Component: ILM Beifahrer   H12 0100
        Revision:             Serial number: 00000000075665
        Coding: 0011101
        VCID: 5EB420FA896621BA8F-800A
                         Reset counter: 44
                         Mileage: 179368 km
                         Date: 2019.08.10
                         Time: 10:30:00
                         Voltage: 13.300 V
                         Temperature: 5.0°C
                         Reset counter: 80
                         Mileage: 179856 km
                         Date: 2019.08.17
                         Time: 13:19:00
                         Voltage: 11.700 V
                         Temperature: 77.0°C
                         Fault Status: 00110010
                         Reset counter: 84
                         Mileage: 179472 km
                         Date: 2019.08.14
                         Time: 19:05:00
                         Voltage: 8.400 V
                         Temperature: 77.0°C
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
        Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
        Component: TSG BF          H12 0150
        Revision: 00-00000
        Coding: 0002651
                         Fault Frequency: 94
                         Reset counter: 44
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:24:10
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 19:10:39
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 19:10:39
        Part No SW: 4L0 910 357     HW: 4L0 907 357
        Component: AFS 1           H01 0040
        Coding: 0000022
        VCID: 69DE0326402856026A-803C
        Component: AFS-Modul rechtsH07 0004
    02233 - Left Headlight Power Output Stage (J667)
                         Reset counter: 79
                         Mileage: 179781 km
                         Date: 2019.08.16
                         Time: 16:51:42
                         Reset counter: 44
                         Mileage: 179856 km
                         Date: 2019.08.17
                         Time: 13:27:08
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.20
                         Time: 12:07:34
    Address 56: Radio
    Address 61: Battery Regul.
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
        Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
        Component: TSG HL          H21 0150
        Coding: 0002058
                         Fault Frequency: 138
                         Reset counter: 44
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:24:17
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 19:10:39
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 19:10:39
    Address 67: Voice Control
        Part No SW: 4L0 910 945     HW: 4L0 827 851 C
        Component: ValeoHeckdeckel H25 0290
        Revision: --H25001    Serial number: E5030000B
        Shop #: WSC 00613 210 88222
        VCID: 6CD07A324FDA432A11-8038
        Subsystem 3 - Serial number: RD28.02.08--H25001001C0113˙
        Subsystem 4 - Serial number: 1C0113˙
                         Fault Frequency: 27
                         Reset counter: 44
                         Mileage: 180041 km
                         Date: 2007.05.16
                         Time: 14:18:42
        Part No SW: 4L0 910 290     HW: 4L0 907 290
        Revision: AAH05061    Serial number: 003510394-----
        VCID: 65C60F16AC3072624E-8030
                         Fault Frequency: 137
                         Reset counter: 44
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:24:21
    01516 - Terminal 30; Left
                         Reset counter: 80
                         Mileage: 179451 km
                         Date: 2019.08.11
                         Time: 12:31:13
                         Fault Frequency: 17
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 12:06:54
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
        Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
        Component: TSG HR          H21 0150
        Coding: 0002058
                         Fault Frequency: 134
                         Reset counter: 44
                         Mileage: 179371 km
                         Date: 2019.08.10
                         Time: 10:24:22
                         Reset counter: 84
                         Mileage: 179475 km
                         Date: 2019.08.14
                         Time: 19:10:39
        Part No SW: 4F0 910 283 K    HW: 4F0 919 283 K
        Component: Parkhilfe 8-Kan H12 0100
        Revision: 00H12000    Serial number: 69830804903838
        Coding: 0201146
        VCID: 2C50BA328F5A832A51-8078
                         Reset counter: 81
                         Mileage: 179938 km
                         Date: 2007.05.16
                         Time: 13:34:18
                         Fault Frequency: 7
                         Reset counter: 84
                         Mileage: 179412 km
                         Date: 2019.08.11
                         Time: 11:10:34
    Address 77: Telephone
    End-------------------------(Elapsed Time: 03:07)--------------------------
    Loads of codes but the main issue is poor charging and flat battery issues
    It has had a new battery but I have not been able to code the energy management because I can't establish communication with 61. Battery Regul.
    I have good live and earth at the module and opposing seemingly ok CAN signals. I have tried a new module.
    So many fault codes!
    Has anyone seen this before?
    Well, it looks like the whole MMI system on the optical MOST bus is off-line, but that shouldn't affect the 61-Battery Regulation module, which is just plain old CAN. I'm not certain which of the multiple CAN buses it's on. Check wiring diagrams, and then check continuity between the two CAN pins at that module and the corresponding CAN pins at the Gateway.
    Apr 2018
    Thanks! I will take a look
