Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: A4 B6 2002 - Cannot perform VIN Adaptation Steering Control Module - Cruise Control
    Hey Eric did you go through a gateway or simulated direct and or try a 100 Ohm resistor bridged on the CAN high/low to see if K line wakes up?
  2. #12
    Mar 2019
    Well as far as my cruise control is concerned, I am sorted. But it is curious (not to mention annoying, as that is what I really got VCDS for!) I had to use another VCDS unit and computer to achieve the adaptation. As I said above, when I get a chance I will find another computer/windows version to see if I can access the adaptation field with my own VCDS HEXV2.
  3. #13
    Quote Originally Posted by timknights View Post
    Visited an audi independent today who also had a HEXV2 interface and VCDS 18.9.x (didn't get to check the exact subversion).
    Knowing exactly what version he used vs. what version you used would be rather useful, no?
    1. There can be an issue with the version of windows or laptop
    2. My HEXV2 interface is defective.
    3. There is a significant difference in recent subversions or firmware of the interface that could lead to the problem.
    Process of elimination: Your interface on his laptop or vice-versa.
    It's also easy enough to check firmware versions in the interfaces: [Options] -> [Test] will show 'em.
  4. #14
    Mar 2019
    Apologies! It would indeed be good to know which version of software proved successful! I will try to get that information, though it may now be after Easter. There was some pressure of time this morning.
    Meantime, I did get out another older laptop with Windows 7 and very little else installed, I then installed 18.9.1 software and checked out my own interface on the car again, trying to access the VIN adaptation function of the steering module 16. Once again I got the same result as before, IE "New Value" greyed out, so its not something as simple as my W10 laptop configuration being a source of incompatibility. (The VIN is now learnt as of this morning, but I assume the function would still normally be available).
    I know the firmware on my HEXV2 is the latest, I had updated it just a couple of weeks ago through the application.
    Details:
    Interface: H11-005081
    CB: 0.4437
    Firmware: 0251
    Is it possible to download an older version of the application than 18.9.1 to test that out?
    Tim
  5. #15
    Details:
    CB: 0.4437
    Firmware: 0251
    Yes, that's the latest Release. But not the latest Beta.
    However, it strikes me as doubtful that the shop you visited was using Beta firmware. Can you PM me their name so I can look them up?
    That's certainly possible, but trying random older versions would be rather tedious. Let's find out what the shop had.
  7. #16
    Jan 2019
    I'm having the same issue with [Read] not loading a Stored Value and not being able to enter a New Value. My autoscan is below. Can I share any other information to help debug?
    Sunday,03,May,2020,16:32:36:51067
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAULC68E72A168557   License Plate:
    Chassis Type: 8E (8E - NoTouchRadio)
    Scan: 01 03 08 09 15 16 17 45 46
    VIN: WAULC68E72A168557   Mileage: 246330km-153062miles
    Address 01: Engine        Labels: 06B-909-518-AMB.lbl
       Part No SW: 8E0 909 518 F    HW: 8E0 909 018
       Component: 1.8L R4/5VT     G   0001
       Coding: 0016701
       Shop #: WSC 63351 000 00000
       VCID: 33331DC8A7291F239E9-5160
    Readiness: 0110 0101
       Part No: 8E0 614 517 A
       Component: ABS/ESP allrad      1726
       Coding: 00000
       VCID: 2615F49C61FB7A8B097-51F2
                66-10 - Not Matched - Intermittent
                35-00 - -
       Part No: 8E0 820 043 L
       Component:   A4 Klimaautomat   1016
       Coding: 00000
       Shop #: WSC 63351
       VCID: 2A0D00AC75E35EEB2DF-5160
                41-10 - Blocked or No Voltage - Intermittent
       Part No: 8E0 907 279 E
       Component: int. Lastmodul  USA 0305
       Coding: 00003
       Shop #: WSC 63351
       VCID: 34311ED4A727181B873-4B00
    01494 - Bulb for Parking Lamps; Left (M1)
                57-00 - Electric Circuit Failure
    00984 - Left Tail Light (M4)
    01502 - Bulb for Rear Fog; Left (L46)
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    Address 15: Airbags        Labels: 8E0-959-655-84.lbl
       Part No: 8E0 959 655 A
       Component: Airbag 8.4E         4000
       Coding: 0010607
       VCID: 353723D0A95D0113B0D-5160
       Part No: 8E0 953 549 L
       Component: Lenksáulenmodul     0308
       Coding: 01141
       Shop #: WSC 63351
       VCID: 3C2136F48F77D05B4F3-4B00
    01794 - Control Module - Incorrect Chassis (VIN) Number
                35-00 - -
       Part No: 8E0 920 950 H
       Component: KOMBI+WEGFAHRS. RB4 D26
       Coding: 03200
       Shop #: WSC 00006
       VCID: 2E050CBC490B32CBF17-5184
       WAULC68E72A168557     AUZ6Z0A0316266
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0504
       Coding: 00001
       VCID: 6B83C5A8BA9987E3969-5118
       Part No: 8E0 959 433 T
       Component: Komfortgerát T5B    0617
       Coding: 11788
       Shop #: WSC 63351
       VCID: 42DD480CED93A6AB05F-4B00
       Subsystem 1 - Part No: 8E1959801
       Component: Tőrsteuer.FS BRM 0002
       Subsystem 2 - Part No: 8E1959802E
       Component: Tőrsteuer.BF BRM 0002
       Component: Tőrsteuer.HL BRM 0002
    7 Faults Found:
    01134 - Alarm Horn (H12)
                29-00 - Short to Ground
    01702 - Footwell Lighting; Left (W9)
    01703 - Footwell Lighting; Right (W10)
    01697 - Footwell Lighting; Rear Right (W46)
    01696 - Footwell Lighting; Rear Left (W45)
    01561 - Rear left door
                59-10 - Can't Unlock - Intermittent
    01562 - Rear right door
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.6V/12.6V)-----------
  8. Likes Dana liked this post
  9. #17
    Quote Originally Posted by jnm View Post
    Let's start with the basics:
    Go to Options, put 1024 in the field labeled 'Debug Level', then click [Apply].
    Without exiting VCDS, try to read the channel in your steering wheel module.
    Exit the module (and VCDS) gracefully.
    Go to your Debug sub-folder and look for the file named DEBUG16.DLM.
    Send it to Support@Ross-Tech.com along with a link to this thread.
  10. Likes Jack@European_Parts, Dana, PetrolDave, jnm liked this post
  11. #18
    Jan 2019
    Thanks. I sent the DEBUG16.DLM file, but I wanted to let you know that I was eventually able to do the VIN adaptation. I opened Measuring Blocks for the steering wheel and noticed that it was alternating between showing the readings successfully and displaying "Data for Group 001 Not Available" (screenshots below). Thinking that there was some intermittent problem, maybe with communications getting stuck, I went back to Adaptation and just clicked Read repeatedly until it worked. I think it took something like 6-8 tries before a Stored value appeared. After entering 00111 as the New value, I needed to click Test several times before it was accepted and the Save button enabled. I'm happy to assist with debugging if you'd like, but I'm no longer stuck
  12. Likes Eric, Dana, Uwe liked this post
  13. #19
    I looked at the debug and saw that it takes the module too long to come back for VCDS to handle it properly, which matches your description. I'm guessing at some point you get lucky and the module isn't too busy to reply within 2 seconds (which is an eternity in car diagnostics). We've been aware of this issue, but it's not something Shaun and I can tackle without having it on-site. My various attempts at wiring 8E modules on the bench, and our various attempts at getting an 8E that exhibits this problem locally have been unsuccessful so far. Let us know if you ever make it up to the Philly area
  14. Likes Dana, Bruce, Uwe, PetrolDave, jnm, Fredrick Awuor liked this post
  15. #20
    United States
    Although this is a work-around at best I wanted to post this link in the event that another B6/B7 guy has Adp problems before we get a handle on the cause:
    https://forums.ross-tech.com/showthr...l=1#post201495
    Increasing Blk Int slows things down so that happened to get him over the hump in channel 081 of address 09. I suspect it would have the same results in AW 16.
  16. Likes Uwe, PetrolDave liked this post
