I have A 2010 vw Beetle with 2.5 L engine. I keep getting trouble codes associated with oxygen sensor B1S3. I have replaced the sensor twice and the same codes keep appearing. There are no noticeable drive ability issues other than the cel being on.
They are as follows;
000327 - heating circuit malfunction B1s3
000326 - no activity b1s3
I have also checked wires to ecm and no breaks in the wires. Voltage at the sensor connector with car running, sensor connected are;
Pin 1 = batt voltage
Pin 2 = batt voltage ( i believe this is supposed to ground)
Voltage with sensor disconnected, (ecm side)
Pin 2 = 3.3 v
complete scan...
Pin 2 = 3.3 v
complete scan...
Friday,05,April,2019,12:28:20:11370
VCDS Version: 17.1.1.0 (x64)
Data version: 20170106 DS267.0
VIN: 3VWPG3AG3AM023128 License Plate:
Mileage: 145480km-90397mi Repair Order: TOMS BEETLE
Chassis Type: AG (1Y - VW New Beetle Cab (2003 > 2010))
VIN: 3VWPG3AG3AM023128 Mileage: 145480km-90397miles
Address 01: Engine (BPR) Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 CM HW: 07K 906 032 AA
Component: NB R5 AT G 4585
Revision: 1SH04--- Serial number: VWX5Z0J2088201
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 76E3F9C401EB57F1FF-8022
000327 - Oxygen (Lambda) Sensor B1 S3; Heating Circuit
P0147 - 008 - Malfunction - MIL ON
Fault Status: 11101000
Mileage: 145446 km
RPM: 1583 /min
Load: 40.0 %
Speed: 80.0 km/h
Temperature: 81.0°C
Temperature: 12.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000326 - Oxygen (Lambda) Sensor B1 S3
P0146 - 004 - No Activity - MIL ON
Fault Status: 11100100
Mileage: 145448 km
RPM: 2224 /min
Load: 34.5 %
Speed: 65.0 km/h
Temperature: 81.0°C
Temperature: 9.0°C
Voltage: 14.097 V
Readiness: 0000 1000
Part No SW: 09G 927 750 KR HW: 09G 927 750 KR
Component: AQ 250 6F 1593
Revision: 00H91000 Serial number:
Coding: 0000008
VCID: 0B15B83069693A19B0-5124
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 Q
Coding: 0019978
VCID: 387F37FC487FE1812D-5124
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AK
Component: 01 AIRBAG VW71 0911
Coding: 0012337
VCID: 000F9F1C572F6941D5-8054
Subsystem 1 - Component: BF-Gewichtsens.
Address 17: Instruments Labels: None
Part No: 1C0 920 801 L
Component: KOMBI+WEGFAHRS. M73 V05
Coding: 11234
Shop #: WSC 00066
VCID: 2447F38CB4F7956191-4B02
Part No: 6N0 909 901
Component: Gateway K<->CAN V052
Coding: 00006
Shop #: WSC 00066
VCID: 70EFCFDC308F79C125-4B02
Address 25: Immobilizer Labels: 1C0-920-xxx-25.clb
Part No SW: 1C0 920 801 L HW: 1C0 920 801 L
Component: IMMO X007
Revision: xxxxxxxx Serial number: VWX5Z0J2088201
Shop #: WSC 29453 001 1048576
VCID: 2447F38CE4F7956191-5142
Address 35: Centr. Locks Labels: 1C0-962-258-III.lbl
Part No: 1C0 962 258 AC
Component: 4G Zentr.Verriegel. 0004
Coding: 00016
Shop #: WSC 00066
VCID: 68DFA7BC085FB1017D-4B02
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 196 CS
Component: RADIO DE2 0006
Coding: 00401
Shop #: WSC 00066
VCID: 72EBC5D43E834BD1D3-51B8
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
Address 65: Tire Pressure Labels: None
Part No SW: 1C0 907 273 A HW: 1C0 907 273 A
Component: RDK H02 0230
Revision: --H02-E0 Serial number: 13115700247749
Coding: 0100101
VCID: 2149FA98F8E58049FA-8074
End-------------------------(Elapsed Time: 04:27)--------------------------
