2010 beetle oxygen sensor faults... please help!!!
tomk_22
C?ID=220270
I have A 2010 vw Beetle with 2.5 L engine. I keep getting trouble codes associated with oxygen sensor B1S3. I have replaced the sensor twice and the same codes keep appearing. There are no noticeable drive ability issues other than the cel being on.
They are as follows;
000327 - heating circuit malfunction B1s3
000326 - no activity b1s3
I have also checked wires to ecm and no breaks in the wires. Voltage at the sensor connector with car running, sensor connected are;
Pin 1 = batt voltage
Pin 2 = batt voltage ( i believe this is supposed to ground)
Voltage with sensor disconnected, (ecm side)
Pin 2 = 3.3 v
complete scan...
Friday,05,April,2019,12:28:20:11370
VCDS Version: 17.1.1.0 (x64)
Data version: 20170106 DS267.0
VIN: 3VWPG3AG3AM023128   License Plate:
Mileage: 145480km-90397mi   Repair Order: TOMS BEETLE
Chassis Type: AG (1Y - VW New Beetle Cab (2003 > 2010))
VIN: 3VWPG3AG3AM023128   Mileage: 145480km-90397miles
Address 01: Engine (BPR)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 CM    HW: 07K 906 032 AA
   Component: NB R5 AT        G   4585
   Revision: 1SH04---    Serial number: VWX5Z0J2088201
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 76E3F9C401EB57F1FF-8022
000327 - Oxygen (Lambda) Sensor B1 S3; Heating Circuit
               P0147 - 008 - Malfunction - MIL ON
                    Fault Status: 11101000
                    Mileage: 145446 km
                    RPM: 1583 /min
                    Load: 40.0 %
                    Speed: 80.0 km/h
                    Temperature: 81.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
000326 - Oxygen (Lambda) Sensor B1 S3
               P0146 - 004 - No Activity - MIL ON
                    Fault Status: 11100100
                    Mileage: 145448 km
                    RPM: 2224 /min
                    Load: 34.5 %
                    Speed: 65.0 km/h
                    Temperature: 81.0°C
                    Temperature: 9.0°C
                    Voltage: 14.097 V
Readiness: 0000 1000
   Part No SW: 09G 927 750 KR    HW: 09G 927 750 KR
   Component: AQ 250 6F           1593
   Revision: 00H91000    Serial number:
   Coding: 0000008
   VCID: 0B15B83069693A19B0-5124
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 387F37FC487FE1812D-5124
   Part No: 6Q0 909 605 AK
   Component: 01 AIRBAG VW71      0911
   Coding: 0012337
   VCID: 000F9F1C572F6941D5-8054
   Subsystem 1 - Component: BF-Gewichtsens.
   Part No: 1C0 920 801 L
   Component: KOMBI+WEGFAHRS. M73 V05
   Coding: 11234
   Shop #: WSC 00066
   VCID: 2447F38CB4F7956191-4B02
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V052
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70EFCFDC308F79C125-4B02
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 801 L    HW: 1C0 920 801 L
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWX5Z0J2088201
   Shop #: WSC 29453 001 1048576
   VCID: 2447F38CE4F7956191-5142
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
   Part No: 1C0 962 258 AC
   Component: 4G Zentr.Verriegel. 0004
   Coding: 00016
   Shop #: WSC 00066
   VCID: 68DFA7BC085FB1017D-4B02
   Part No: 1C0 035 196 CS
   Component:  RADIO DE2         0006
   Coding: 00401
   Shop #: WSC 00066
   VCID: 72EBC5D43E834BD1D3-51B8
00856 - Radio Antenna
            36-10 - Open Circuit - Intermittent
Address 65: Tire Pressure        Labels: None
   Part No SW: 1C0 907 273 A    HW: 1C0 907 273 A
   Component:    RDK          H02 0230
   Revision: --H02-E0    Serial number: 13115700247749
   Coding: 0100101
   VCID: 2149FA98F8E58049FA-8074
End-------------------------(Elapsed Time: 04:27)--------------------------
tomk_22
C?ID=220270
i have the diagram for a jetta, but it appears to be pretty "simple". 1 wire from fuse box and the others go to ecm.
Vehicle Identification No.3VWPG3AG3AM023128
ModelNew Beetle
BE
Date of production25.03.2010
Year2010
Sales type1C15RA
Engine CodeBPR or is it BPS?
Transmission CodeKGR
Emission standard0GTEmission standard SULEV AVWXV02.5257
Isn't this under warranty & for FREE for useful life?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=156577&viewfull=1#post156577
OP: Can you clear codes and re-post a fresh new auto-scan and also post the OBD2 MODE's 1,3,7 & 9 please?
tomk_22
C?ID=220270
sorry for the delayed response guys, it took me a while to get everything together...the engine code is BPR and here is a complete scan after clearing and no codes present along with the OBD scans that you requested. thanks for your help
Thursday,11,April,2019,08:09:31:11370
Mileage: 145530km-90428mi   Repair Order:
Chassis Type: AG (AG - VW New Beetle NAR (2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWPG3AG3AM023128   Mileage: 145530km-90428miles
   Coding: 0000003
Readiness: 0110 1101
   Coding: 0000008
   Coding: 0019978
   Coding: 0012337
   Coding: 11234
   Shop #: WSC 00066
   VCID: 2447F38CB4F7956191-4AE8
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70EFCFDC308F79C125-4AE8
   VCID: 2447F38CE4F7956191-5124
   Coding: 00016
   Shop #: WSC 00066
   Coding: 00401
   Shop #: WSC 00066
   Coding: 0100101
End-------------------------(Elapsed Time: 04:05)--------------------------
tomk_22
C?ID=220270
the mode one stuff came up as an excel spreadsheet and im not sure how to post that.
Thursday,11,April,2019,08:17:28:11370
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Thursday,11,April,2019,08:16:23:11370
Mode 07: Pending emission related fault codes
Thursday,11,April,2019,08:15:41:11370
Type 02 - VIN : 3VWPG3AG3AM023128 (Address E8)
Type 04 - Calibration ID : 07K906032CM 4585 (Address E8)
Type 04 - Calibration ID : 09G927750KR 1593 (Address E9)
Type 06 - Calibration Verification Number : 268340D1 (Address E8)
Type 06 - Calibration Verification Number : F76CAEBF (Address E9)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 3841
    Ignition cycle count : 11605
    Conditions completion count / Specificied conditions encountered count
         Catalyst monitor bank 1 : 4061 / 3729
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 4167 / 3837
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 10392 / 3841
         AIR monitor : 995 / 994
         EVAP monitor : 685 / 641
         Secondary O2 Sensor monitor bank 1 : 3624 / 3732
         Secondary O2 Sensor monitor bank 2 : 0 / 0
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
tomk_22
C?ID=220270
so i have narrowed this down to an intermittent power feed issue. as stated before i have diagrams for a jetta but not a beetle. in the jetta manual is shows that the o2 sensors are fed 12v+ through a common connection 87a, can someone please tell me where this connection is located on this style Beetle? ive torn the car apart trying to trace wires with no luck.
thanks
This or buy a book.........
tomk_22
C?ID=220270
i was able to get the beetle specific diagrams, but as i suspected it is very similar to the jetta one that i had. shows 2 feed wires from fuse #43, that feed all three oxygen sensors and the fuel pump. these are described in the manual as "(E30)-Connection (87a) (in engine wiring harness)". my understanding is this description denotes connection 87a of a relay located within the (E-box) ? im assuming that it would be the fuel pump relay because it is a connected to the same 12v+ feed lines as the oxygen sensors. but after a visual inspection of the relay carrier there is no wires going to any of the relays matching the colors (blue/yellow) of the components that im having trouble with. can you please verify that connection 87a is located within a relay? and if so, why is there a color change?
Post the schematics you are using please?
Did you check to see this is covered under warranty?
tomk_22
C?ID=220270
here are the diagrams that i am using. its my understanding that the warranty on this vehicle is 6 years/72k miles
Maybe you should read up about the advantages of the warranty of the CARB SULEV & for useful life components as a PZEV and even base warranty for EPA as affirmed too & when certified huh?
Oxygen sensors are indeed on that list of warranty-able components, now are they, "well are they" ? :rolleyes:
https://en.wikipedia.org/wiki/Partial_zero-emissions_vehicle
Why spend money on things you can be reimbursed for or that are under warranty? :p
tomk_22
C?ID=220270
the car has a salvage title so im sure the dealer will use that as an excuse to void the warranty.
tomk_22
C?ID=220270
thanks jack for the info regarding the warranty. im pretty confident that my problem is either a wiring or a ECM issue. because the same "intermittent" faults with several different sensors. im now leaning towards a faulty ECM because i have run overlay harness of the o2 heater circuit wires and the same fault for the heater circuit returned. is there a way to verify that the o2 circuit of the ECM is faulty? if so, can i use a used ECM on this vehicle?
Isn't the ECU, the harness to the ECU and all the OXS sensors all part of the function and therefore vicariously a required AECD warranty from the OEM and by shear definition?
:rolleyes:
Law Enforcement is here to help right, ever think of using them to do the work you paid them for?
tomk_22
C?ID=220270
O2 sensor diagnostic help
i have been having repeated O2 sensor codes 000327 & 000326, all related to B1S3 with a 2010 Beetle 2.5 engine code BPR. I have tried a couple of different sensors that I had laying around and they all gave the same codes after about 15 miles of driving. ive checked everything I can possibly think of as far as electrical issues and wires from the sensor to the ECU and everything seems to be in perfect order. electrical diagnostic of emission related components is not my strong point, but im learning. its my understanding that the sensor signal voltage should fluctuate between 0.1-0.9 V with a frequency of around 1 sec with the sensors hot. so today I graphed what the ECU was receiving for signal voltage from the sensors in this scenario. the data I collected was at 2000 rpm (shown in the attached photo) was that sensor 2 voltage ranged from 0.1-0.8 v with a frequency of about 5 seconds. and sensor 3, the one that is giving the codes hovered around 0.45 v the whole time. so just to verify the voltages read by the ECU matched what was being sent by the sensors, I hooked my lab scope to the sensor connectors and the reading there matched what was being read by the ECU. because the readings matched, im assuming that I can rule out bad wires or ECU. my questions are; what would cause the frequency of sensor 2 to be so long? and what would cause the sensor 3 voltage to hover around 0.45? also, would my assumption that because the MBV matched the sensor output voltages at the sensor, mean that its not a wiring or ECU issue?
thanks in advance for your help
sensor graph:
RED = Sensor 2
Yellow = Sensor 3
vertical scale = 0.1 volts
Horizontal scale = 5 secs
http://tinypic.com/r/2ls9p9j/9
I've merged the above post (#17) into an existing thread regarding the same problem in the same car.
I bet the OXS sensors are clones or are not genuine & even one of them being improper will throw you for a loop, what you think?
It is my opinion that this is done to deliberately force purchase of genuine sensors so the aftermarket sensors fail to comport, huh?
Why are you punishing yourself and not getting this repair done for free by the factory local franchise vw dealer?
HMC
C?ID=28246
Hi tomk_22,
I am not familiar with US spec cars but is the B1S3 O2 sensor not the post cat sensor for OBD emissions checking? If yes then it will not cycle the voltage but have a relatively stable voltage. The fault code is for the heating element so if you have good voltage and a GOOD ground, then as Jack say's the ECU does not like the resistance of the sensors you are using.
Regards HMC
