Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: 2010 beetle oxygen sensor faults... please help!!!
    Apr 2019
    I have A 2010 vw Beetle with 2.5 L engine. I keep getting trouble codes associated with oxygen sensor B1S3. I have replaced the sensor twice and the same codes keep appearing. There are no noticeable drive ability issues other than the cel being on.
    They are as follows;
    000327 - heating circuit malfunction B1s3
    000326 - no activity b1s3
    I have also checked wires to ecm and no breaks in the wires. Voltage at the sensor connector with car running, sensor connected are;
    Pin 1 = batt voltage
    Pin 2 = batt voltage ( i believe this is supposed to ground)
    Voltage with sensor disconnected, (ecm side)
    Pin 2 = 3.3 v
    complete scan...
    Friday,05,April,2019,12:28:20:11370
    VCDS Version: 17.1.1.0 (x64)
    Data version: 20170106 DS267.0
    VIN: 3VWPG3AG3AM023128   License Plate:
    Mileage: 145480km-90397mi   Repair Order: TOMS BEETLE
    Chassis Type: AG (1Y - VW New Beetle Cab (2003 > 2010))
    Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
    VIN: 3VWPG3AG3AM023128   Mileage: 145480km-90397miles
    Address 01: Engine (BPR)       Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 CM    HW: 07K 906 032 AA
       Component: NB R5 AT        G   4585
       Revision: 1SH04---    Serial number: VWX5Z0J2088201
       Coding: 0000003
       VCID: 76E3F9C401EB57F1FF-8022
    000327 - Oxygen (Lambda) Sensor B1 S3; Heating Circuit
                   P0147 - 008 - Malfunction - MIL ON
                        Fault Status: 11101000
                        Mileage: 145446 km
                        RPM: 1583 /min
                        Load: 40.0 %
                        Speed: 80.0 km/h
                        Temperature: 81.0C
                        Temperature: 12.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.224 V
    000326 - Oxygen (Lambda) Sensor B1 S3
                   P0146 - 004 - No Activity - MIL ON
                        Fault Status: 11100100
                        Mileage: 145448 km
                        RPM: 2224 /min
                        Load: 34.5 %
                        Speed: 65.0 km/h
                        Temperature: 81.0C
                        Temperature: 9.0C
                        Voltage: 14.097 V
    Readiness: 0000 1000
       Part No SW: 09G 927 750 KR    HW: 09G 927 750 KR
       Component: AQ 250 6F           1593
       Revision: 00H91000    Serial number:
       Coding: 0000008
       VCID: 0B15B83069693A19B0-5124
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 Q
       Coding: 0019978
       VCID: 387F37FC487FE1812D-5124
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No: 6Q0 909 605 AK
       Component: 01 AIRBAG VW71      0911
       Coding: 0012337
       VCID: 000F9F1C572F6941D5-8054
       Subsystem 1 - Component: BF-Gewichtsens.
    Address 17: Instruments        Labels: None
       Part No: 1C0 920 801 L
       Component: KOMBI+WEGFAHRS. M73 V05
       Coding: 11234
       Shop #: WSC 00066
       VCID: 2447F38CB4F7956191-4B02
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V052
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EFCFDC308F79C125-4B02
    Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
       Part No SW: 1C0 920 801 L    HW: 1C0 920 801 L
       Component: IMMO                X007
       Revision: xxxxxxxx    Serial number: VWX5Z0J2088201
       Shop #: WSC 29453 001 1048576
       VCID: 2447F38CE4F7956191-5142
    Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
       Part No: 1C0 962 258 AC
       Component: 4G Zentr.Verriegel. 0004
       Coding: 00016
       Shop #: WSC 00066
       VCID: 68DFA7BC085FB1017D-4B02
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1C0 035 196 CS
       Component:  RADIO DE2         0006
       Coding: 00401
       Shop #: WSC 00066
       VCID: 72EBC5D43E834BD1D3-51B8
    00856 - Radio Antenna
    Address 65: Tire Pressure        Labels: None
       Part No SW: 1C0 907 273 A    HW: 1C0 907 273 A
       Component:    RDK          H02 0230
       Revision: --H02-E0    Serial number: 13115700247749
       Coding: 0100101
       VCID: 2149FA98F8E58049FA-8074
    End-------------------------(Elapsed Time: 04:27)--------------------------
    Do you have a wiring diagram?
    Apr 2019
    i have the diagram for a jetta, but it appears to be pretty "simple". 1 wire from fuse box and the others go to ecm.
    Vehicle Identification No. 3VWPG3AG3AM023128
    Model New Beetle
    BE
    Date of production 25.03.2010
    Year 2010
    Sales type 1C15RA
    Engine Code BPR or is it BPS?
    Transmission Code KGR
    Emission standard 0GT Emission standard SULEV AVWXV02.5257
    Isn't this under warranty & for FREE for useful life?
    https://forums.ross-tech.com/showthr...l=1#post156577
    OP: Can you clear codes and re-post a fresh new auto-scan and also post the OBD2 MODE's 1,3,7 & 9 please?
    Apr 2019
    sorry for the delayed response guys, it took me a while to get everything together...the engine code is BPR and here is a complete scan after clearing and no codes present along with the OBD scans that you requested. thanks for your help
    Thursday,11,April,2019,08:09:31:11370
    Mileage: 145530km-90428mi   Repair Order:
    Chassis Type: AG (AG - VW New Beetle NAR (2010))
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
    VIN: 3VWPG3AG3AM023128   Mileage: 145530km-90428miles
       Coding: 0000003
    Readiness: 0110 1101
       Coding: 0000008
       Coding: 0019978
       Coding: 0012337
       Coding: 11234
       Shop #: WSC 00066
       VCID: 2447F38CB4F7956191-4AE8
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70EFCFDC308F79C125-4AE8
       VCID: 2447F38CE4F7956191-5124
       Coding: 00016
       Shop #: WSC 00066
       Coding: 00401
       Shop #: WSC 00066
       Coding: 0100101
    End-------------------------(Elapsed Time: 04:05)--------------------------
    Apr 2019
    the mode one stuff came up as an excel spreadsheet and im not sure how to post that.
    Thursday,11,April,2019,08:17:28:11370
    Mode 03: Emission related fault codes
    Address 7E8: No fault code found.
    Address 7E9: No fault code found.
    Thursday,11,April,2019,08:16:23:11370
    Mode 07: Pending emission related fault codes
    Thursday,11,April,2019,08:15:41:11370
    Mode 9 : Calibration Identification
    Type 02 - VIN : 3VWPG3AG3AM023128 (Address E8)
    Type 04 - Calibration ID : 07K906032CM 4585 (Address E8)
    Type 04 - Calibration ID : 09G927750KR 1593 (Address E9)
    Type 06 - Calibration Verification Number : 268340D1 (Address E8)
    Type 06 - Calibration Verification Number : F76CAEBF (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 3841
        Ignition cycle count : 11605
        Conditions completion count / Specificied conditions encountered count
             Catalyst monitor bank 1 : 4061 / 3729
             Catalyst monitor bank 2 : 0 / 0
             O2 Sensor monitor bank 1 : 4167 / 3837
             O2 Sensor monitor bank 2 : 0 / 0
             EGR-VVT monitor : 10392 / 3841
             AIR monitor : 995 / 994
             EVAP monitor : 685 / 641
             Secondary O2 Sensor monitor bank 1 : 3624 / 3732
             Secondary O2 Sensor monitor bank 2 : 0 / 0
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
  7. Likes Jack@European_Parts liked this post
    Apr 2019
    so i have narrowed this down to an intermittent power feed issue. as stated before i have diagrams for a jetta but not a beetle. in the jetta manual is shows that the o2 sensors are fed 12v+ through a common connection 87a, can someone please tell me where this connection is located on this style Beetle? ive torn the car apart trying to trace wires with no luck.
    thanks
  9. #8
    This or buy a book.........
  10. #9
    Apr 2019
    i was able to get the beetle specific diagrams, but as i suspected it is very similar to the jetta one that i had. shows 2 feed wires from fuse #43, that feed all three oxygen sensors and the fuel pump. these are described in the manual as "(E30)-Connection (87a) (in engine wiring harness)". my understanding is this description denotes connection 87a of a relay located within the (E-box) ? im assuming that it would be the fuel pump relay because it is a connected to the same 12v+ feed lines as the oxygen sensors. but after a visual inspection of the relay carrier there is no wires going to any of the relays matching the colors (blue/yellow) of the components that im having trouble with. can you please verify that connection 87a is located within a relay? and if so, why is there a color change?
  11. #10
    Post the schematics you are using please?
    Did you check to see this is covered under warranty?
