hi friends
i have skoda octavia 2014 i fit malfunction steering wheel to control radio i also replaced the can gate way and component protection was removed
the control of instrument from steering wheel worked ok but radio controls did not worked i thing i need to decode the information system may you help me with the coding
this full scan is with original can gateway
king regards
Wednesday,10,April,2019,15:11:48:54163
VCDS Version: 18.9.1.0 (x64)
VIN: TMBAG6NE7E0147981 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBAG6NE7E0147981 Mileage: 412932km-256584miles
02-Auto Trans -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6545
Revision: 84H22---
Coding: 01110012030400090000
Shop #: WSC 73430 031 00133
ASAM Dataset: EV_ECM16TDI01104L906021M 002011
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F6D2CDF76CEDF3274-807A
4967 - Fuel Temp. Sensor A (G81)
P0183 00 [172] - Open or Short to Plus
Mileage: 412819 km
Date: 2019.04.07
Time: 07:55:31
Engine speed: 994.50 /min
Normed load value: 16.1 %
Coolant temperature: 99 °C
Intake air temperature: 70 °C
Ambient air pressure: 910 mbar
Voltage terminal 30: 14.200 V
Fuel consumption: 0.53 l/h
Engine oil temperature: 108.5 °C
Oil warning threshold: 28.988 mm
Status of oil pressure switches-Bits 0-7: 1
Oil fill level: 53.656 mm
Extern.temp.sens.1 bank 1: raw value: 12.5 °C
Fuel temp. sensor 1 bank 1: raw value: 33.1 °C
Readiness: 1 1 0 0 X
Address 02: Auto Trans
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 633030000000C4
Coding: 1A076291142409730080060841C4245846289000608224B000400030C002
Shop #: WSC 73430 031 00063
VCID: 4B95584FE216831278-801E
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5E0 820 047 H HW: 5E0 820 047 H
Component: AC Manuell H03 0705
Revision: 00001K06
Coding: 01010104000100000000000000400000
ASAM Dataset: EV_ACManueBHBVW37X 003017
ROD: EV_ACManueBHBVW37X_003_SK37.rod
VCID: 275DC4FF5E3E8772BC-8072
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 142
Mileage: 412754 km
Date: 2019.04.06
Time: 19:26:30
Outside air temperature: 25.5 °C
Engine speed: 0 /min
Temperature after evaporator: 36.0 °C
System run time-Terminal 15 on: 11 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 AB HW: 5Q0 937 084 AB
Component: BCM MQBAB B H16 0124
Serial number: 00011334600721
Coding: 0C0008424047005347E04000000407000000000000000000000000000000
Shop #: WSC 73430 790 00133
ROD: EV_BCMBOSCH_012.rod
VCID: 78FFD783C300D88AE5-802C
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 131227 041 0570
Serial number: 140102233042
Coding: 065DDD
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Reset counter: 182
Mileage: 412782 km
Date: 2019.04.06
Time: 23:58:08
Part No SW: 3Q0 959 655 AD HW: 3Q0 959 655 AD
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P5PRLWW20
Coding: 88CCC00000000000400000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 000FBF639BD0904ADD-8054
Subsystem 1 - Part No SW: ----------- HW: 454 001 012 13
Serial number: 3576U000000873B47E0J
Subsystem 2 - Part No SW: ----------- HW: 454 001 112 13
Serial number: 3586U0000002F3B47E0M
Subsystem 3 - Part No SW: ----------- HW: 454 800 301 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R8AB6A4020000007
Subsystem 4 - Part No SW: ----------- HW: 454 801 112 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R17EF9E02000000J
Subsystem 5 - Part No SW: ----------- HW: 454 801 911 13
Component: FrontSensor_D 114 0149
Serial number: 3556VC1823302000000
Part No SW: 5Q0 953 549 E HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 02121504720224
Coding: 1000
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 3E73019BA1A426BAEF-806A
Part No SW: 5E0 920 851 E HW: 5E0 920 851 E
Component: KOMBI 103 3390
Coding: 072502002100000801080800040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 285FC7C35320880AB5-807C
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0000848885
Coding: 030100042B086400EF0000481C0F00010001000000000000000000000000
Shop #: WSC 73430 790 00125
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 3A7B0D8BBD8C0A9AD3-806E
131703 - No Communication with Transmission Control Module
U0101 00 [009] - -
Reset counter: 142
Mileage: 412754 km
Date: 2019.04.06
Time: 19:28:30
Supply voltage: Terminal 30: 12.5 V
Terminal 15: On
197175 - Control unit for battery monitoring
U1050 00 [009] - No Communication
Reset counter: 142
Mileage: 412754 km
Date: 2019.04.06
Time: 19:28:30
Supply voltage: Terminal 30: 12.6 V
Terminal 15: On
197169 - Controls in Steering Wheel
Reset counter: 142
Mileage: 412754 km
Date: 2019.04.06
Time: 19:28:30
Terminal 15: On
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000088017258
Coding: 00110120D000040000001100
VCID: 44877373CF484C6AB9-8010
Serial number: 00000000000001429182
Coding: 010200
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 142
Mileage: 412754 km
Date: 2019.04.06
Time: 19:26:30
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0102
Shop #: WSC 73430 790 00123
ROD: EV_SteerAssisMQB_010.rod
VCID: 41897A67D05A594292-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000088243590
VCID: 4385706FCA464B5280-8016
Serial number: 00000000000001457899
Coding: 190200
Reset counter: 142
Mileage: 412754 km
Date: 2019.04.06
Time: 19:26:30
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-ENT1.clb
Part No SW: 5E0 035 887 HW: 5E0 035 887
Component: MU-E--ER 180 0141
Revision: -------- Serial number: 000085595901000
Coding: 037301003C0000005011000100000000000000840000010000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_MUEnt4CCONT 004052
ROD: EV_MUEnt4CCONT.rod
VCID: 69D982C788AA71026A-803C
B1064 13 [008] - Open Circuit
Reset counter: 182
Mileage: 412754 km
Date: 2019.04.06
Time: 19:26:32
Voltage terminal 30: 13.0 V
End-------------------------(Elapsed Time: 03:04)--------------------------
king regards
