Hi
Guys please help with coding steering module , no chance select on the coding section ( cruse control on indicator stalk ) unit rejected
The cruse control problem some one change coding .
Wednesday,10,April,2019,13:53:32:01410
VCDS Version: 18.9.1.0 (x64)
VIN: VSSZZZ1PZBR064131 License Plate:
Mileage: 71800km-44614mi Repair Order:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: VSSZZZ1PZBR064131 Mileage: 71800km-44614miles
Address 01: Engine (J623-CFJA) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HC HW: 03L 906 018 FJ
Component: R4 2.0l TDI H23 9977
Revision: 42H23--- Serial number:
Coding: 00190012042500080000
Shop #: WSC 12345 210 12345
ASAM Dataset: EV_ECM20TDI01103L906018HC 003005
ROD: EV_ECM20TDI01103L906018DP.rod
VCID: 72EC646AA5AAA3DADB-8026
4481 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 163B6012092800FE680C06E7901A0082350800
Shop #: WSC 04941 000 00000
VCID: 76E4587AC1C2BFFAF7-8022
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0702
Revision: 00001001
Coding: 0000000002
Shop #: WSC 06402 785 00200
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3D768756AC742CA2F6-8068
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0046
Revision: BC011001
Coding: 46180A3E8025B0C0428800809500810442519DA8427D81605C8042000040
Shop #: WSC 04941 123 12345
VCID: 3B72894EBA602292C8-806E
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 14031 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 5P0 919 475
Component: PARKHILFE 4K H07 0005
Revision: -------- Serial number: 89341105906395
Coding: 000004
VCID: 3A7C8C4AB55A1B9AD3-806E
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__A0E VW10 HI 1918
Revision: 22014000 Serial number: 003K0P4QJNRI
Coding: 0012357
VCID: 4C90DA922FCE952A71-8018
Subsystem 1 - Serial number: 6332MTS610250551
Subsystem 2 - Serial number: 6342MTS602470551
Subsystem 3 - Serial number: 6351HTS6U589R9KJ
Subsystem 4 - Serial number: 6361HTS6AG64R9KR
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20190206200108
Coding: 318CA40000
Shop #: WSC 01286 386 08256
VCID: 020C34AA950A935ACB-8056
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
335876 - Powertrain Databus
U0002 00 [009] - No Communications
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
1140738 - Steering angle sensor
Part No SW: 1P0 920 954 B HW: 1P0 920 954 B
Component: KOMBI H06 0420
Coding: 410B00
VCID: 3068AE626B26D1CA6D-8064
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 120311F2001899
Coding: 350203
VCID: 3068AE626326D1CA6D-8064
Component: IMMO H06 0420
VCID: 6ADC7C0A8D7A6B1A63-803E
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669536194
VCID: 285846025BF6990AB5-807C
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0508
Revision: 12110009 Serial number: 0002255768
Coding: 0012B0
ROD: EV_TSGFPQ35BRFVW46X_SE35.rod
VCID: 6DD67716BC947C2206-8038
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389__TSG-HR 006 1401
Serial number: 00000005666912
Coding: 000290
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 142 3201
Revision: 00H20000
VCID: 3460A272573EEDEA09-8060
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0508
Revision: 14110009 Serial number: 0002259464
Coding: 0012B0
VCID: 6ED4701AB192873A3F-803A
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388__TSG-HL 006 1401
Serial number: 00000005641248
Coding: 000290
Part No SW: 5P0 035 186 B HW: 5P0 035 186 B
Component: Media2.0 H02 0079
Revision: 00000001 Serial number: SEZ1Z3L4523307
Coding: 01060400040000
VCID: 2E54B01A7912C73A7F-807A
End-------------------------(Elapsed Time: 02:51)--------------------------
