Results 1 to 4 of 4
Thread: 5301 - Throttle Actuator Control Circuit - PLEASE HELP. LIMP MODE AND NOW DPF PROBLEM
    Pirate
    Apr 2019
    Hi All,
    I have been having some trouble with my car. I got a check light on and read the code.
    Removed.  Data from a clone/pirate copy of VCDS is not welcome here.
    I had a read and thought that it was the throttle body or ASV. I changed it for a new one as when i opened it up all the cogs have been warn away and it was slipping like mad.
    However, i still can not clear the fault code on VCDS. I read that there should be a fuse that probably gone. I can not find any fuses gone, I check with a multi meter. Where is these fuse ?
    Also, how can i activate the throttle body in VCDA to see if it is working and what blocks can i check for it status?
    This whole thing have caused my DPF to block and i cant regen in VCDS. (I hope if i clear the fault it will regen)
    PLEASE HELP
    Nov 2015
    Given the lack of information available in your post, it's not possible to even guess. It's forum policy to include a ful autoscan which will help massively.
    Pirate
    Apr 2019
    Sorry,
    This is the full scan.
    All codes are clear now apart from the 1- Engine ones.
    Any guidance would be great.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#uk
