Results 1 to 6 of 6
Thread: 2007 audi q7 4.2 engine control module failure
    Dec 2016
    Hello! I have a 2007 Audi q7 that needs a ecu the part number is 4L0 910 560 C. I found a place in Davie florida to give us a new one and install the immobilizer and vin into the ecu.. i think the just sent us a pos.. Basically what I am asking on here if anyone knows of a place that sells or rebuilds the ecu for this car and i know i cant get around the immo with ross tech but if i order a new one from the dealer can i enter the vin into the new ecu.. waited 3 weeks to get the junk ecu from florida and i need to perform a miracle...
    Friday,05,April,2019,14:29:00:18005
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    Mileage: 195830km-121683mi   Repair Order:
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
              47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
       Mileage: 195830km-121683miles
    01-Engine -- Status: Sporadic communication error 1000
    05-Acc/Start Auth. -- Status: Not registered 0011
    0E-Media Player 1 -- Status: Malfunction 0010
    67-Voice Control -- Status: Malfunction 0010
    Address 01: Engine        Labels:
       VCID: D5E2D9642C4783E25E-FFFE
       Note: Excessive Comm Errors
       Part No SW: 09D 927 750 FH    HW: 09D 927 750 FH
       Component: AL 750 6A           0959
       Revision: 00H52000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: F9BAB5D4B09F87821A-80AC
                        Fault Frequency: 9
                        Reset counter: 0
                        Date: 2006.03.15
                        Time: 12:00:00
                        Fault Frequency: 9
                        Reset counter: 0
                        Date: 2006.03.15
                        Time: 12:00:00
                        Fault Frequency: 9
                        Reset counter: 0
                        Date: 2006.03.15
                        Time: 12:00:00
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H21001
       Coding: 0021553
       VCID: A81CA0901BB5CE0A35-80FC
                        Reset counter: 144
                        Count: 192
                        Count: 11009
                        Count: 128
                        Count: 23552
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:59:13
                        Count: 64
                        Count: 8193
                        Count: 8194
                        Count: 36608
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0210
       Revision: 00H08000    Serial number: 10603902231455
       Coding: 0000135
       Shop #: WSC 47975 001 1048576
       VCID: A502A9A46CA7D3620E-80F0
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 KSG   H27 0080
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0060
    00190 - Driver's Door Handle Touch Sensor (G415)
                007 - Short to Ground
                        Fault Status: 01110111
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 09:59:54
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 09:59:54
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 09:59:54
    02241 - Engine Control Module; Immobilizer Data not Adapted
                        Fault Status: 01110000
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 07:46:52
    00230 - Transmission Park Selector Switch (F305)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.05.09
                        Time: 10:30:55
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731     HW: 4E0 035 729 A
       Component: Interfacebox    H43 2740
       Revision: 00000000    Serial number: 354FQ067505274
       Coding: 0002003
       VCID: E582E9A42C271362CE-80B0
       Component: E0380 BedienteilH01 0050
       Subsystem 2 - Serial number: 00000000441346
       Subsystem 3 - Serial number: 0112.06.060000000100010680˙
       Subsystem 4 - Serial number: 010680˙
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.01.31
                        Time: 12:16:51
                        Bin. Bits:       10
    02849 - Control Module for Lane Change Assistance (J769)
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.01.31
                        Time: 12:15:46
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 54
                        Mileage: 193359 km
                        Date: 2018.09.06
                        Time: 12:20:02
                        Fault Frequency: 17
                        Reset counter: 40
                        Mileage: 193359 km
                        Date: 2018.09.07
                        Time: 07:37:52
    00532 - Supply Voltage B+
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:45:31
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Revision: 00---008    Serial number: 00000000044183
       Coding: 0786472
       VCID: E18AFDB4380F7F4232-80B4
    8 Faults Found:
    00712 - Right Footwell Flap Positioning Motor (V109)
                        Fault Status: 00100011
                        Fault Frequency: 97
                        Reset counter: 184
                        Mileage: 190989 km
                        Date: 2018.05.22
                        Time: 19:04:35
                        Voltage: 13.10 V
                        Temperature: 20.0°C
                        (no units): 75.0
                        (no units): 53.0
                        Temperature: 17.0°C
                        Fault Status: 00100111
                        Reset counter: 169
                        Mileage: 195592 km
                        Date: 2019.01.24
                        Time: 18:19:31
                        Temperature: 14.0°C
                        Fault Frequency: 10
                        Reset counter: 144
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:32:15
                000 -  -  - Intermittent
                        Fault Frequency: 31
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:42:14
                        Voltage: 9.20 V
    01809 - Actuating Motor for Temperature Flap; Left (V158)
                        Fault Frequency: 185
                        Reset counter: 181
                        Mileage: 193380 km
                        Date: 2018.12.04
                        Time: 18:42:20
                        Voltage: 13.30 V
                        Temperature: 19.0°C
                        (no units): 156.0
                        (no units): 164.0
                        Temperature: 6.0°C
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:46:35
                        Voltage: 7.00 V
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.02.06
                        Time: 15:38:59
                        Bin. Bits:    01111
                        Fault Status: 00101001
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 07:12:16
                        Temperature: 9.0°C
                        Temperature: 11.0°C
                        Temperature: 9.0°C
                        RPM: 6000 /min
                        Absolute Pres.: 3.2 bar
                        Current: 0.005 A
                        Temperature: 5.0°C
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0113123
       VCID: B02C48F0236586CAED-80E4
       Component: Wischer AU716   H12 0080
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Reset counter: 184
                        Mileage: 195836 km
                        Reset counter: 184
                        Mileage: 195836 km
       Part No SW: 4L0 910 111 A    HW: 4L0 035 111
       Component: CD-Changer      H41 0100
       Revision: 00000000    Serial number: AUZ5ZBF3023482
       VCID: 9E70864849F100BA4F-80CA
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.02.09
                        Time: 12:36:38
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:46:37
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 D    HW: 4E0 035 593
       Component: SDAR SIRIUS     H04 0670
       Revision: 00000000    Serial number: AUZ4Z7F2028799
                        Fault Frequency: 7
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:42:56
                        Voltage: 8.40 V
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:42:57
                        Voltage: 8.40 V
                        Reset counter: 18
                        Mileage: 193377 km
                        Date: 2018.12.01
                        Time: 12:43:01
       Component: 73 AIRBAG AUDI8RH39 0210
       Revision: 03H39000    Serial number: 0038QD031SZV
       Coding: 0014131
       VCID: AB165F9C0A43E512D8-80FE
       Subsystem 1 - Part No: 4L0 910 339
       Component: BF-Gewichtsens. H02 0020
       Subsystem 2 - Serial number: 6332QSME103C2D4BL
       Subsystem 3 - Serial number: 6342QSME107C2E4BR
       Subsystem 4 - Serial number: 6352QSME10080D69E
       Subsystem 5 - Serial number: 6362QSME107A2D1DP
       Subsystem 6 - Serial number: 63734SME0D4E043D9
       Subsystem 7 - Serial number: 63834SME0E101B25-
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
       Revision: 00H03000    Serial number: 90026061590027
       Coding: 0012242
       VCID: A71EA3AC16ABC1723C-80F2
       Component: E0221           H07 0090
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
       Component: KOMBIINSTR. M73 H17 0110
       Revision: 00200000    Serial number: 5HH37YF66
       Coding: 2673263
       VCID: A306B7BC62932D5260-80F6
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:49
                        Fault Frequency: 25
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:59:14
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D066078286
       Coding: D5F7FE7F347A02
       Shop #: WSC 08353 444 90281
       VCID: EC949C80CFCD222A91-80B8
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:59:12
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:59:13
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 07:46:39
       Part No SW: 4L0 910 158     HW: 4L0 919 158 D
       Revision: 00---006    Serial number: 00000000044437
       Coding: 0000006
       VCID: E89CE090DB350E0AF5-80BC
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 179
                        Mileage: 190989 km
                        Date: 2018.05.22
                        Time: 19:04:40
                        Fault Frequency: 31
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:42:14
                        Voltage: 9.30 V
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:46:35
                        Voltage: 7.10 V
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 B    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7550
       Revision: --H03001    Serial number: 15.1528-0095.2
       Coding: 0015510
       Shop #: WSC 08353 444 101374
       VCID: A91AA59400BFF7022A-80FC
                        Fault Status: 11100100
                        Fault Frequency: 16
                        Reset counter: 0
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Error Code: 112
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Error Code: 13
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Error Code: 64
                        Fault Frequency: 16
                        Reset counter: 0
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Error Code: 112
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory FS   H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0082954
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2006.04.21
                        Time: 05:35:08
       Part No SW: 4E0 910 888 C    HW: 4E0 919 887 D
       Component: MNS US          H48 0960
       Revision: 00000000    Serial number: 313FH067501751
       Shop #: WSC 08353 444 58704
       VCID: AE1056883951903AFF-80FA
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:46:01
                        Hex Value: 0x4448
                        Hex Value: 0x7968
                        Hex Value: 0x0053
       Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH06 0060
       Revision: 00H06000    Serial number: 6PZ 009 014-00
       VCID: AC145C800F4DE22AD1-80F8
       Subsystem 1 - Part No: 4L0 910 568 A
       Component: J0770_SWA_Slave_H05 0060
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F24.06.0600H0500000010061˙
       Subsystem 4 - Serial number: 010061˙
                        Reset counter: 184
                        Mileage: 195832 km
                        Date: 2019.01.31
                        Time: 10:42:43
    02857 - Supply Voltage for Lane Change Assistance Control Module 2
                        Fault Frequency: 7
                        Reset counter: 184
                        Mileage: 195832 km
                        Date: 2019.01.31
                        Time: 10:42:48
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.02.01
                        Time: 14:03:32
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00000000    Serial number: Dpr
       Coding: 0051915
       VCID: AF2E4B8C3E5B9932F4-80FA
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01015008420000
       Coding: 7632925
       VCID: B12A4DF4286F8FC2E2-80E4
                        Reset counter: 144
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:30:03
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:47:33
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 D    HW: 4L0 035 223 A
       Component: DSP-High AU716  H02 0110
       Revision: PROD_01     Serial number: 00000000003348
       Coding: 0000000
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.02.09
                        Time: 12:36:40
                        Voltage: 8.30 V
                        Fault Frequency: 11
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2019.02.05
                        Time: 15:58:05
                        Voltage: 8.40 V
                        Fault Frequency: 168
                        Reset counter: 144
    02084 - Component Protection
                        Fault Status: 01100101
                        Mileage: 191690 km
                        Date: 2018.07.15
                        Time: 11:50:45
                        Reset counter: 144
                        Mileage: 195836 km
                        Date: 2019.02.04
                        Time: 07:33:32
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000028528
       Coding: 0012001
       VCID: DEF0C648097140BA0F-808A
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2006.04.21
                        Time: 05:36:00
                        Voltage: 6.400 V
                        Temperature: -1.0°C
                        Fault Frequency: 31
                        Reset counter: 144
                        Mileage: 195836 km
                        Date: 2006.04.21
                        Time: 05:59:00
                        Voltage: 10.200 V
                        Temperature: 77.0°C
                        Fault Status: 00110010
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2006.04.21
                        Time: 05:35:00
                        Voltage: 6.500 V
                        Temperature: -1.0°C
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Reset counter: 184
                        Mileage: 195836 km
                        Date: 2006.05.09
                        Time: 10:29:00
                        Voltage: 15.600 V
                        Temperature: 77.0°C
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0051915
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:46:35
       Coding: 0000022
                        Reset counter: 40
                        Mileage: 195832 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Fault Frequency: 28
                        Reset counter: 144
                        Mileage: 195832 km
                        Date: 2006.04.21
                        Time: 05:59:12
       Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
       Component: TUNER EU/US/RDW H42 0570
       Revision: 00000000    Serial number: 388F.067534168
       VCID: AA185A9805B9FC1A23-80FE
                        Fault Frequency: 9
                        Reset counter: 184
                        Mileage: 193380 km
                        Date: 2018.12.02
                        Time: 18:11:35
                        Fault Frequency: 31
                        Reset counter: 184
    00856 - Radio Antenna
                        Fault Frequency: 25
                        Reset counter: 176
                        Mileage: 183533 km
                        Date: 2016.05.12
                        Time: 15:30:31
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000022980
       VCID: E484F4A0271D6A6AD9-80B0
       Component: von VA0  VAO1234567
       Coding: 344630393135313035442056413056414F31323334353637
       Shop #: WSC 47242 001 1048576
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Date: 2006.04.21
                        Time: 05:55:55
                        Fault Frequency: 11
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:59:27
    02256 - Quiescent Current
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 18:58:15
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.24
                        Time: 06:38:49
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0051722
       Revision: 00050100    Serial number: 00000700023779
       Coding: 0062424
       VCID: A208B2B87D89245A6B-80F6
                        Fault Status: 10100010
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:36:56
                        (no units): 255.0
                        Voltage: 6.50 V
                        (no units): 42.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.05.09
                        Time: 10:29:57
                        (no units): 0.0
                        Voltage: 13.20 V
                        (no units): 27.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000605170049
       Shop #: WSC 12336 024 394758
       VCID: B42444E0D77DBAEA89-80E0
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:43:17
       Part No SW: 4L0 910 441     HW: 4L0 907 441
       Component: J772__Rearview      0020
       Revision: --H10---    Serial number: 525PA8-J660580
       Coding: 1001001
       VCID: E386F7BC22136D5220-80B6
                        Reset counter: 184
                            Reverse OFF
                        Count: 3
                        Reset counter: 184
                            Reverse OFF
                        Count: 3
       Part No SW: 4L0 910 945     HW: 4L0 827 851 A
       Component: ValeoHeckdeckel H20 0280
       Revision: --H20001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD24.06.06--H20001001B0119˙
       Subsystem 4 - Serial number: 1B0119˙
       Component: ILM HINTEN 2    H05 0040
       Revision: AAH05044    Serial number: 001735776-----
       Coding: 0003595
       VCID: A600AEA811A1D87A07-80F2
       Component: J_245_EE14_SKB09H10 0160
       Component: J_394_EE14_SKB09H10 0160
       Component: J_392_EE14_SKB09H10 0160
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0051722
                        Fault Frequency: 13
                        Reset counter: 144
                        Mileage: 195837 km
                        Date: 2006.05.03
                        Time: 03:33:27
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06220615800904
       Coding: 0021246
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
                        Reset counter: 184
                        Mileage: 195837 km
                        Date: 2006.04.21
                        Time: 05:35:08
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005087136
       Coding: 0010900
       Shop #: WSC 08353 444 16678
                        Reset counter: 184
                        Mileage: 195835 km
                        Date: 2019.01.31
                        Time: 10:46:34
    End----------(Elapsed Time: 03:26, VBatt start/end: 12.9V/12.7V)-----------
    Gateway Installation List:  4L0 910 468
  2. Likes stone4779 liked this post
  3. #2
    The above scan was presumably done with the used, replacement ECU?
    Does the original ECU communicate?
    Dec 2016
    Thats with the replacement computer.. original computer did not communicate either however found lots of corrosion due to plugged drain.. We load tested all the wires and hooked up a ecu out of another one and was able to commuicate.. sorry should of said that originally..
  5. Likes Uwe, stone4779, Jack@European_Parts liked this post
  6. #4
    Verified VCDS User stone4779's Avatar
    Mar 2019
    Quote Originally Posted by customs025 View Post
    That sucks man..Just got a 2007 Q7 4.2 FSI as well and having some electrical issues as well. Hope you get it worked out!
    Figured I would subscribe to this thread anyways since we have the same vehicle!
    Let me know if you need any wiring diagrams, I have some for this vehicle.
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    You could send equipment to me with credentials?
    https://www.ebay.com/itm/332355903398
  9. #6
    Dec 2016
    That’s what i have been waiting for... unfortunately I ordered a new one from the dealer i just don’t think i will be able to reprogram it due to no communication. My friend is letting me use his xtool however i might have to tow it to Audi just need to get my customer his car back pronto... However next time i will definitely remember that and i will know who to look for on eBay! I actually saw that listing and was considering trying that out without know it was a reputable guy!
