Results 1 to 6 of 6
Thread: MK60EC1 Coding - 2014 Passat
    Jan 2015
    I accidentally turned the key on with the cluster out and it lost ABS coding before I scanned the car. I know you like to have a full auto scan, but I only have the log with ABS faults and the vin - car is with customer. Returning tonight for the coding if you can help me.
    1VWAT7A36FC013224
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 BM HW: 1K0 907 379 BM
    Component and/or Version: ESP MK60EC1 H46 0164
    Software Coding: 0000000000000000000000000000000000000000
    Work Shop Code: WSC 09003 957 00200
    VCID: 7EF30E70E9A76EBAAF-802A
    Reset counter: 76
    Date: 2053.14.06
    Time: 00:11:00
    Count: 3
    Count: 12
    Count: 20992
    Count: 195
    Count: 44544
    We'll need the full unedited Auto-Scan as that has additional information needed to suggest ABS coding, so when the customer returns the car post the Auto-Scan here ASAP.
  3. Likes DrPeter, Jack@European_Parts liked this post
    16.4905 S, 151.7375 W
    I agree, a full Auto-Scan would be helpful, but here is an idea, did you ever perform an Auto-Scan on this vehicle before this concern?
    If so the coding should be listed within a saved scan. Have a look in the ...\Ross-Tech\VCDS\Scans or ...\Ross-Tech\VCDS\Logs folders, even if you did not [Save] it.
    This Ross-Tech wiki page maybe helpful when you get the coding concern worked out.
    Brake Electronics (MK60EC1)
    Worth a try - hope this helps and let us know how it works out for you!
    drpeter
  5. Likes Uwe, PetrolDave liked this post
  6. #4
    Jan 2015
    Wednesday,10,April,2019,15:01:37:20507
    VCDS Version: 18.9.1.0 (x64)
    VIN: 1VWAT7A36FC013224   License Plate:
    Mileage: 119440km-74216mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72 75
              77
    VIN: 1VWAT7A36FC013224   Mileage: 119440km-74216miles
    17-Instruments -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 997 071 G    HW: 06K 907 425 C
       Component: R4 1.8l TFS   H13 9372
       Revision: --H13---
       Coding: 001A0012242400170000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM18TFS02006K997071G 001005
       ROD: EV_ECM18TFS02006K997071E.rod
       VCID: 3979DD6CB8098982DA-806C
    17178 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:07
                        Coolant temperature: 73 C
                        Intake air temperature: 37 C
                        Voltage terminal 30: 12.812 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    26384 - Databus
              U1123 00 [109] - Received Error Message
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:11:08
                        Engine speed: 2155.25 /min
                        Normed load value: 51.0 %
                        Vehicle speed: 18 km/h
                        Coolant temperature: 72 C
                        Intake air temperature: 35 C
                        Voltage terminal 30: 14.160 V
                        Engine: operating status: PL
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 3 s
                        MAP_MES_SAE: 97 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                        FAC_TPS_1_SAE: 32.421875 %
                        FUP_H_SAE: 14940.0 kPa
    19868 - No Communication with Instrument Cluster
              U0155 00 [032] - -
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:21
                        Coolant temperature: 87 C
                        Intake air temperature: 32 C
                        Voltage terminal 30: 12.304 V
                        Engine: operating status: ES
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 92.0 C
                        Time since engine start: 0.0 s
                        T_ES: 3 min
                        Cruise control switch actuation-Main switch hardware: operated
                        Cruise control switch actuation-Main switch CAN: operated
                        STATE_ERR_ABC_PRED: 0
    Readiness: 0000 0100
    Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
       Part No SW: 09G 927 749 B    HW: 09G 927 749 B
       Component: AISIN AG6 G3  109 2855
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 001004
       ROD: EV_TCMAQ250031_001_VW25.rod
       VCID: 387FD8688303908A25-806C
    22616 - No Communication with Instrument Cluster
              U0155 00 [040] - -
                        Reset counter: 80
                        Mileage: 119441 km
                        Engine speed: 0.0 /min
                        Transmission input speed: 0 /min
                        Transmission output speed: 0 /min
                        Engine torque: 108 Nm
                        Transmission fluid temperature: 89 C
                        Accelerator position: 0.0 %
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
                        Lock Up Clutch: Open
                        Electrical Oil Pump target revolution: 65534 /min
                        Electrical Oil Pump actual revolution: 65279 /min
                        Engine Speed signal Current: 65279 /min
                        Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                        Electrical Oil Pump target current: 65278 mA
    22617 - No Communication with Instrument Cluster
              U0155 00 [040] - -
                        Reset counter: 80
                        Mileage: 119441 km
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
    22618 - No Communication with Instrument Cluster
              U0155 00 [040] - -
                        Reset counter: 80
                        Mileage: 119441 km
                        Clutch_C1: Open
                        Clutch_C2: Open
                        Clutch_C3: Open
                        Clutch_C4: Open
                        Clutch_B1: Open
                        Clutch_B2: Open
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
    6 Faults Found:
    03306 - Coding Not Valid
                000 -  -  - Intermittent
                        Reset counter: 80
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 00:08:55
                        Count: 3
                        Count: 12
                        Count: 20480
                        Count: 4161
                        Count: 43008
                        Reset counter: 76
                        Date: 2019.04.09
                        Time: 00:11:00
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 44544
                        Fault Status: 01100101
                        Reset counter: 76
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:55
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 212
                        Count: 44800
                        Count: 256
                        Reset counter: 76
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:55
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 279
                        Count: 44800
                        Count: 256
                        Reset counter: 76
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:55
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 270
                        Count: 44800
                        Count: 256
                        Reset counter: 76
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:55
                        Count: 3
                        Count: 12
                        Count: 4096
                        Count: 291
                        Count: 44800
                        Count: 256
       Part No SW: 561 907 426 E    HW: 561 907 426 E
       Component: AC Manuell    H02 0303
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1D3129FC0CE1D5A2D6-8048
              U1111 00 [008] - -
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
       Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
       Component: BCM PQ35 B+   122 0174
       Revision: BH122001
       Coding: EF200E18902B08D4098000010600044800F1A08640801D20648060000C70
       VCID: 73E52F44D2E533D2D0-8026
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
                        Voltage: 12.35 V
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD01DRJ3
       Coding: 00004D4E
       Shop #: WSC 64156 001 1048576
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 72EB2A40A5FF3ADADB-8026
       Serial number: 6940000Y14000173020S
       Coding: 303044
       Serial number: 3572MSME19645945ZZZ-
       Serial number: 3582MSME31195945ZZZV
       Serial number: 3516KSME0A36782EZZZ$
       Serial number: 3526KSME1769792EZZZ2
       Serial number: 3556LSME4806192FZZZ$
       Serial number: 3566LSME5E24182FZZZ3
    12674816 - Immobilizer Control Module
              U0167 00 [008] - No Communications
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
              U0155 00 [008] - -
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
       Part No SW: 1K5 953 521 BN    HW: 5K0 953 569 AE
       Revision: FF010042    Serial number: 20140526101311
       Coding: 488A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7AFB0260FD8F429A93-802E
       Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
       Component: E221__MFL-YVJ  H07 0022
       Coding: 620000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 960 D    HW: 561 920 960 D
       Component: KOMBI         H04 0809
       Coding: 230E01
       VCID: 1A3B22E01DCFA29A33-804E
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 17071403000307
       Coding: 461000
       VCID: 000F70889353184ADD-8054
                        Fault Status: 00110100
                        Reset counter: 120
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
       Component: IMMO          H04 0809
       VCID: 6ADB32208D2FF21A63-803E
    Address 2E: Media Player 3
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0008603684
       Coding: 040495
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5BB567E452759B92E8-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630140714222651
       Coding: 800000
    68102 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 211    3501
       Revision: 00H22000
       VCID: 3979DD6C70098982DA-806C
                        Fault Status: 11100101
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:07
                        Battery Volts: 12.9 V
                            DD
                        Temperature: 18.0C
                        Count: 3
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
                        Voltage: 12.38 V
                            DD
                        Temperature: 26.0C
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 00000008
       VCID: 6FED2334BECD173234-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0008631325
       Coding: 040494
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5CB764F8577B9CAAE1-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14102631140722153237
       Coding: 800000
              U1111 00 [008] - -
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H04 0005
       Revision: -----08S    Serial number: VWZ4Z6P3816189
       Coding: 0100040002000B
       VCID: 2541011C2CB11D628E-8070
                        Reset counter: 76
                        Mileage: 119339 km
                        Date: 2019.04.09
                        Time: 00:10:07
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:22
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140524
       Coding: 02140102C2161A107F1606000000
       ROD: EV_OCULow_001.rod
       VCID: 53A58FC43AA553D230-8006
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 80
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 00:13:38
       Component: TELEFON       H05 0592
       Revision: 1B001001    Serial number: 00007666316658
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 2E53FE3071475E3A7F-807A
              U0155 00 [008] - -
                        Reset counter: 120
                        Mileage: 119441 km
                        Date: 2019.04.10
                        Time: 14:48:21
    End-------------------------(Elapsed Time: 03:10)--------------------------
    Address 03,1K0 907 379 BM,recoded (Long Coding),from,0000000000000000000000000000000000000000,to,0000401C092300FD000D02E6901D0040040400,(09003/957/00200),
    Address 03,1K0 907 379 BM,recoded (Long Coding),from,00000000000000000000000000000000000000,to,0000401C092300FD000D02E6901D0040040400,(09003/957/00200),
    Hi, thanks for the Auto-Scan... Based on some research your coding should be as follows:
    [C54BC0F5492300FDA30D03E6921D0041A1100012]
    After coding you will need to complete the Basic Settings. The Replacement section at the bottom of that page should be helpful.
    Hope this helps,
    drpeter
  8. Likes Dana, Uwe, Jack@European_Parts liked this post
  9. #6
    OP:
    Report please?
