MK60EC1 Coding - 2014 Passat
Workshop2
C?ID=53368
I accidentally turned the key on with the cluster out and it lost ABS coding before I scanned the car. I know you like to have a full auto scan, but I only have the log with ABS faults and the vin - car is with customer. Returning tonight for the coding if you can help me.
1VWAT7A36FC013224
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BM HW: 1K0 907 379 BM
Component and/or Version: ESP MK60EC1 H46 0164
Software Coding: 0000000000000000000000000000000000000000
Work Shop Code: WSC 09003 957 00200
VCID: 7EF30E70E9A76EBAAF-802A
Reset counter: 76
Date: 2053.14.06
Time: 00:11:00
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 44544
We'll need the full unedited Auto-Scan as that has additional information needed to suggest ABS coding, so when the customer returns the car post the Auto-Scan here ASAP.
DrPeter
16.4905° S, 151.7375° W
I agree, a full Auto-Scan would be helpful, but here is an idea, did you ever perform an Auto-Scan on this vehicle before this concern?
If so the coding should be listed within a saved scan. Have a look in the ...\Ross-Tech\VCDS\Scans or ...\Ross-Tech\VCDS\Logs folders, even if you did not [Save] it.
This Ross-Tech wiki page maybe helpful when you get the coding concern worked out.
Brake Electronics (MK60EC1)
Worth a try ;) - hope this helps and let us know how it works out for you!
drpeter
Workshop2
C?ID=53368
Wednesday,10,April,2019,15:01:37:20507
VCDS Version: 18.9.1.0 (x64)
VIN: 1VWAT7A36FC013224   License Plate:
Mileage: 119440km-74216mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72 75
          77
VIN: 1VWAT7A36FC013224   Mileage: 119440km-74216miles
17-Instruments -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 997 071 G    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 9372
   Revision: --H13---
   Coding: 001A0012242400170000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K997071G 001005
   ROD: EV_ECM18TFS02006K997071E.rod
   VCID: 3979DD6CB8098982DA-806C
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:07
                    Coolant temperature: 73 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.812 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
26384 - Databus
          U1123 00 [109] - Received Error Message
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:11:08
                    Engine speed: 2155.25 /min
                    Normed load value: 51.0 %
                    Vehicle speed: 18 km/h
                    Coolant temperature: 72 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 14.160 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 3 s
                    MAP_MES_SAE: 97 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 32.421875 %
                    FUP_H_SAE: 14940.0 kPa
19868 - No Communication with Instrument Cluster
          U0155 00 [032] - -
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:21
                    Coolant temperature: 87 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 12.304 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 92.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 3 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: Yes
                    STATE_ERR_ABC_PRED: 0
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
   Part No SW: 09G 927 749 B    HW: 09G 927 749 B
   Component: AISIN AG6 G3  109 2855
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 001004
   ROD: EV_TCMAQ250031_001_VW25.rod
   VCID: 387FD8688303908A25-806C
22616 - No Communication with Instrument Cluster
          U0155 00 [040] - -
                    Reset counter: 80
                    Mileage: 119441 km
                    Engine speed: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: 108 Nm
                    Transmission fluid temperature: 89 °C
                    Accelerator position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
22617 - No Communication with Instrument Cluster
          U0155 00 [040] - -
                    Reset counter: 80
                    Mileage: 119441 km
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
22618 - No Communication with Instrument Cluster
          U0155 00 [040] - -
                    Reset counter: 80
                    Mileage: 119441 km
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 80
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 00:08:55
                    Count: 3
                    Count: 12
                    Count: 20480
                    Count: 4161
                    Count: 43008
            000 -  -
                    Reset counter: 76
                    Date: 2019.04.09
                    Time: 00:11:00
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 44544
                    Fault Status: 01100101
                    Reset counter: 76
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:55
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 212
                    Count: 44800
                    Count: 256
                    Reset counter: 76
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:55
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 279
                    Count: 44800
                    Count: 256
                    Reset counter: 76
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:55
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 270
                    Count: 44800
                    Count: 256
                    Reset counter: 76
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:55
                    Count: 3
                    Count: 12
                    Count: 4096
                    Count: 291
                    Count: 44800
                    Count: 256
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1D3129FC0CE1D5A2D6-8048
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF200E18902B08D4098000010600044800F1A08640801D20648060000C70
   VCID: 73E52F44D2E533D2D0-8026
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
                        Term 15 On
                    Voltage: 12.35 V
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD01DRJ3
   Coding: 00004D4E
   Shop #: WSC 64156 001 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72EB2A40A5FF3ADADB-8026
   Serial number: 6940000Y14000173020S
   Coding: 303044
   Serial number: 3572MSME19645945ZZZ-
   Serial number: 3582MSME31195945ZZZV
   Serial number: 3516KSME0A36782EZZZ$
   Serial number: 3526KSME1769792EZZZ2
   Serial number: 3556LSME4806192FZZZ$
   Serial number: 3566LSME5E24182FZZZ3
12674816 - Immobilizer Control Module
          U0167 00 [008] - No Communications
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
   Part No SW: 1K5 953 521 BN    HW: 5K0 953 569 AE
   Revision: FF010042    Serial number: 20140526101311
   Coding: 488A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7AFB0260FD8F429A93-802E
   Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
   Component: E221__MFL-YVJ  H07 0022
   Coding: 620000
Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
   Part No SW: 561 920 960 D    HW: 561 920 960 D
   Component: KOMBI         H04 0809
   Coding: 230E01
   VCID: 1A3B22E01DCFA29A33-804E
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 17071403000307
   Coding: 461000
   VCID: 000F70889353184ADD-8054
                    Fault Status: 00110100
                    Reset counter: 120
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
   Component: IMMO          H04 0809
   VCID: 6ADB32208D2FF21A63-803E
Address 2E: Media Player 3
   Part No SW: 561 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0008603684
   Coding: 040495
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BB567E452759B92E8-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140714222651
   Coding: 800000
68102 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 211    3501
   Revision: 00H22000
   VCID: 3979DD6C70098982DA-806C
                    Fault Status: 11100101
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:07
                    Battery Volts: 12.9 V
                        DD
                    Temperature: 18.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
                    Voltage: 12.38 V
                        DD
                    Temperature: 26.0°C
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1653
   Coding: 00000008
   VCID: 6FED2334BECD173234-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Part No SW: 561 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0008631325
   Coding: 040494
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CB764F8577B9CAAE1-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140722153237
   Coding: 800000
          U1111 00 [008] - -
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H04 0005
   Revision: -----08S    Serial number: VWZ4Z6P3816189
   Coding: 0100040002000B
   VCID: 2541011C2CB11D628E-8070
            000 -  -
                    Reset counter: 76
                    Mileage: 119339 km
                    Date: 2019.04.09
                    Time: 00:10:07
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:22
   Component: OCULowUSA     014 0102
   Serial number: 000003554140524
   Coding: 02140102C2161A107F1606000000
   ROD: EV_OCULow_001.rod
   VCID: 53A58FC43AA553D230-8006
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 80
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 00:13:38
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666316658
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E53FE3071475E3A7F-807A
          U0155 00 [008] - -
                    Reset counter: 120
                    Mileage: 119441 km
                    Date: 2019.04.10
                    Time: 14:48:21
End-------------------------(Elapsed Time: 03:10)--------------------------
Address 03,1K0 907 379 BM,recoded (Long Coding),from,0000000000000000000000000000000000000000,to,0000401C092300FD000D02E6901D0040040400,(09003/957/00200),
Address 03,1K0 907 379 BM,recoded (Long Coding),from,00000000000000000000000000000000000000,to,0000401C092300FD000D02E6901D0040040400,(09003/957/00200),
DrPeter
Hi, thanks for the Auto-Scan... Based on some research your coding should be as follows:
[C54BC0F5492300FDA30D03E6921D0041A1100012]
After coding you will need to complete the Basic Settings. The Replacement section at the bottom of that page should be helpful.
Hope this helps,
drpeter
OP:
Report please?
