Results 1 to 2 of 2
Thread: Skoda Fabia 1.6 TDI ABS long coding help (ABS8.2)
    Apr 2019
    Ukraine
    Hi
    I nead help to repair ABS Long coding
    Long coding all zero and fault code is abs not coded
    Friday,29,March,2019,19:52:05:04810
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: sswift
    Workshop Code: 321 12345 054321
    VIN: TMB1SB5J0B3090036   License Plate:
    Mileage: 162200km-100786mi   Repair Order:
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: TMB1SB5J0B3090036   Mileage: 162200km-100786miles
    56-Radio -- Status: Not registered 0001
    Address 01: Engine (J623-CAYA)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 DJ    HW: 03L 906 023 DL
       Component: 1,6l R4 CR td H13 7506
       Revision: --------    Serial number:
       Coding: 00114014000400080000
       Shop #: WSC 13765 031 00041
       ASAM Dataset: EV_ECM16TDI02103L906023DJ 003001
       ROD: EV_ECM16TDI02103L906023AH_003.rod
       VCID: 71AA21ECA0BBD0C222-8024
    7300 - Throttle Position Sensor (G69)
              P0123 00 [165] - Signal too High
                        Mileage: 162209 km
                        Date: 2019.03.29
                        Time: 00:22:14
                        Coolant temperature: 12 C
                        Intake air temperature: 13 C
                        Voltage terminal 30: 12.085 V
                        Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
                        Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
                        Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
                        Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.995 V
                        Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.688 V
                        Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
                        Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
    Readiness: 0010 1000
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Shop #: WSC 13765 790 00041
       VCID: 4ED09A101DC5EF3A1F-801A
                        Reset counter: 115
                        Mileage: 285126 km
                        Date: 2013.08.19
                        Time: 01:49:54
                        Hex Value: 0x0005
                        Hex Value: 0x0000
                        Hex Value: 0x3213
                        Hex Value: 0x1499
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7F00
                        Hex Value: 0x0000
                        Reset counter: 155
                        Mileage: 285127 km
                        Date: 2013.08.19
                        Time: 00:00:09
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x2283
                        Hex Value: 0x139C
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
                        Reset counter: 155
                        Mileage: 285127 km
                        Date: 2013.08.19
                        Time: 00:00:10
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x22E6
                        Hex Value: 0x139C
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 5J0 820 045 C    HW: 5J0 820 045 C
       Component: Man AC         02 0101
       Revision: 0003S 02
       VCID: 250205BC2CF3CC628E-8070
       Part No SW: 6R7 937 085 D    HW: 6R7 937 085 D
       Component: PQ25 BCM      H12 0022
       Revision: -5------    Serial number: 1002480401
       Coding: 64980B1808010040002000003E0B08800000400F600000000000
       VCID: 43C6BB24C287125280-8016
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3210
       Coding: 020000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3210
       Coding: 020000
    03591 - Control Circuit for Horn
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagT20 H09 0020
       Revision: --------    Serial number: 003GX00ALBLT
       Coding: 003230
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4AD89600EDADC31A43-801E
       Serial number: 3495RRB405D036N2M9GH
       Serial number: 3505RRB405D036N2EODD
       Part No SW: 5J0 920 800 D    HW: 5J0 920 800 D
       Component: KOMBI         H15 0206
       Coding: 120200
       VCID: 260002B059F5C77A87-8072
       Part No SW: 6N0 909 901     HW: 6R7 937 085 D
       Component: GW-K-CAN TP20 0022
       Revision: -5------
       Coding: 232200
       VCID: 70AC24E8A3B1D9CA2D-8024
       Component: IMMO          H15 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
       VCID: 6A9836808D6D231A63-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10110
       Shop #: WSC 13765
       VCID: 2F2EE794EA0F863274-807A
       Part No SW: 5J0 035 152 A    HW: 5J0 035 152 A
       Component: Radio         H10 0010
       Revision: R0000000    Serial number: SKZAZ6M4359859
       Coding: 050002000006
       Shop #: WSC 13765 790 00018
       VCID: 200C14A833D1294AFD-8074
    End----------(Elapsed Time: 00:42, VBatt start/end: 12.2V/12.2V)-----------
    First try:
     410100DB007600B2022500E500D700420000
    This is for left-hand drive, without any additional ABS functions like Hill Hold or TPMS, and without specifying rear brake or suspension type.
    PR Codes might be useful to refine this further.
  3. Likes pbsbogdan liked this post
