Results 1 to 5 of 5
Thread: 3C Passat 53 Park Brake Coding
    Feb 2019
    New Zealand
    [Solved] 3C Passat 53 Park Brake Coding
    Autoscan before repair
    Tuesday,09,April,2019,08:41:11:01672
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ3CZ8P090715   License Plate: LPN413
    Mileage: 50440km-31341mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8P090715   Mileage: 50440km-31341miles
    Address 01: Engine (   )       Labels:. 06J-907-115-BZB.clb
       Part No SW: 06J 906 026 A    HW: 06J 906 026
       Component: MED17.5             2933
       Revision: A8H03---    Serial number: VWZCZ000000000
       Coding: 0404000319070160
       Shop #: WSC 62981 001 1048576
       VCID: 285FFCE19BF5930AB5-807C
                   P0300 - 000 -  - Intermittent
                        Mileage: 50319 km
                        Time: 23:53:47
                        RPM: 943 /min
                        Load: 39.6 %
                        Temperature: 18.0C
                        Temperature: 13.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.970 V
    000769 - Cylinder 1
                   P0301 - 000 - Misfire Detected - Intermittent
                        Mileage: 50319 km
                        Time: 23:54:26
                        RPM: 1009 /min
                        Load: 18.8 %
                        Speed: 33.0 km/h
                        Temperature: 25.0C
                        Temperature: 14.0C
                        Voltage: 14.224 V
       Part No SW: 09G 927 750 JJ    HW: 09G 927 750 JJ
       Component: AQ 250 6F           1178
       Revision: 00H76000    Serial number:
       Coding: 0000328
       Shop #: WSC 00028 028 00001
       VCID: 020B8E495D09995ACB-8056
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
       Component: J104    C4 440 V2   0003
       Revision: --020---    Serial number: 00000776889163
       Coding: 0003384
       VCID: 1F4DE73DCEBB54B2C4-804A
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
       Component: ClimatronicPQ46 132 0811
       Revision: 00132023    Serial number: 00000000000000
       VCID: 73E5DB8D12B3A0D2D0-8026
       Revision: 00H54000    Serial number: 01000005486178
       Coding: 01840F0700041A00470A00000F00000000095D435C000100000000000000
       VCID: 71E9D18568AF92C222-8024
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 070108 022  0601
       Coding: 00046997
       Shop #: WSC 00028
    01598 - Drive Battery Voltage
                000 -  -  - Intermittent
                        Reset counter: 239
                        Mileage: 49948 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.20 V
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__014 VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPSM0DUC
       Coding: 0012596
       VCID: 7AFBF6A935D9D19A93-802E
       Subsystem 1 - Serial number: 6333FTS676843527
       Subsystem 2 - Serial number: 6343FTS644813447
       Subsystem 3 - Serial number: 6353ETS6FI4DSVNH
       Subsystem 4 - Serial number: 6363ETS6TP1DSVNP
       Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C5953507AP
       Coding: 0001013
       VCID: 6CD7C0F14F8D7F2A11-8038
       Part No SW: 3C0 920 860 M    HW: 3C0 920 860 M
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007505
       VCID: 2C5700F18F0DBF2A51-8078
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P07C1404CC
       Coding: FD807F060002021003
       VCID: 2345EBCDE2D37052E0-8076
       Part No SW: 3C0 959 433 S    HW: 3C0 959 433 S
       Component:    IMMO         041 0383
       Revision: 00041000    Serial number: VWZCZ000000000
       VCID: 3A7B36A97559119AD3-806E
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1132
       Revision: 31008001    Serial number: 00000063788104
       Coding: 0000695
       VCID: 3C7730B17F6D2FAAC1-8068
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.134 H08 1901
       VCID: 366322994141F5FA37-8062
       Component:    KSG PQ46 ELV 041 0472
       Coding: 00910A0001860E763004941570085F0B6078A1
       Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1132
       Revision: 31008001    Serial number: 00000532679126
       Coding: 0000694
       VCID: 3D713DB5647726A2F6-8068
       Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
       Component: J540 EPB3  VW-09393 0009
       Revision:   008       Serial number: 00000000314238
       Coding: 0000057
       VCID: 2959F9E580FFAA02AA-807C
    03200 - Switch for Electric Parking Brake (E538)
                        Fault Status: 00111100
                        Fault Frequency: 17
                        Reset counter: 251
                        Mileage: 49719 km
                        Voltage: 12.50 V
                        Count: 10
                        Hex Value: 0x12F0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    16352 - Control Module - Electrical Error
                        Fault Status: 00101110
                        Fault Frequency: 10
                        Reset counter: 251
                        Mileage: 49719 km
                        Voltage: 13.10 V
                        Count: 42
                        Hex Value: 0x12E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 56: Radio (J0503)       Labels: 1K0-035-1xx-56.lbl
       Part No SW: 1K0 035 182 AA    HW: 1K0 035 182 AA
       Component: Radio RCD510  036 0132
       Revision: 00000001    Serial number: VWZ1Z3H3236375
       Coding: 0500040004
       Shop #: WSC 00981 981 28888
       VCID: 61C9A1C5784F2242B2-8034
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0308
       Revision: 41004101    Serial number: 00000000158196
       Coding: 0000144
       VCID: 70EFD48163A59BCA2D-8024
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0308
       Revision: 41004101    Serial number: 00000000168977
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:53)--------------------------
    Autoscan after New Park Brake module fitted
    Tuesday,09,April,2019,10:23:32:01672
    VIN: WVWZZZ3CZ8P090715   License Plate: LNP413
                        Mileage: 50319 km
                        Time: 23:53:47
                        RPM: 943 /min
                        Load: 39.6 %
                        Temperature: 18.0C
                        Temperature: 13.0C
                        Voltage: 13.970 V
    000769 - Cylinder 1
                        Mileage: 50319 km
                        Time: 23:54:26
                        RPM: 1009 /min
                        Load: 18.8 %
                        Speed: 33.0 km/h
                        Temperature: 25.0C
                        Temperature: 14.0C
                        Voltage: 14.224 V
                   U1017 - 000 -  - Intermittent
                        Mileage: 50447 km
                        Time: 00:10:48
                        RPM: 763 /min
                        Load: 14.5 %
                        Temperature: 66.0C
                        Temperature: 39.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.716 V
                        Mileage: 50447 km
                        Time: 00:10:53
                        RPM: 757 /min
                        Load: 14.9 %
                        Temperature: 66.0C
                        Temperature: 39.0C
                        Voltage: 13.716 V
       Coding: 0000328
       Coding: 0003384
       Coding: 00046997
       Shop #: WSC 00028
                        Reset counter: 239
                        Mileage: 49948 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.20 V
       Coding: 0012596
       Coding: 0001013
       Coding: 0007505
       Coding: 0000695
       Coding: 0000694
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H21       Serial number: 00000000156164
       Coding: 0010000
       VCID: 387F2CA14B55038A25-806C
                        Fault Status: 01110000
                        Reset counter: 216
                        Voltage: 13.90 V
                        Count: 98
                        Hex Value: 0x0140
                        Hex Value: 0x0082
                        Hex Value: 0x4040
                        Reset counter: 216
                        Voltage: 13.90 V
                        Count: 41
                        Hex Value: 0x0140
                        Hex Value: 0x0082
                        Hex Value: 0x4040
       Coding: 0500040004
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Hi just wonder if i can have some help coding the Parking brake, I have coded the ABS unit and done all the basic settings, However when I access coding for 53 Park brake it says incorrect range
    I am using the original coding of 00057,
    how ever it does not allow me 16 Security access and VCDS does not come up with a code for 16 Security access
    How confident are you that the 3AA / EPB4 module is a suitable replacement for the original 3C0 / EPB3 module?
    The coding for the 3AA / EPB4 is completely different than the 3C0 / EPB3 was.
    I would try something like 0021056 to start with. But this assumes the car does not have Start/Stop, and does not have Auto-Hold.
  3. Likes Jetta ,97 liked this post
    Feb 2019
    New Zealand
    Vehicle does not have Start stop but does have Auto-Hold,
    I am not confident that 3AA EPB4 module will replace a 3C0 EPB3 Module, sorry didn't even see that was different but that is what was supplied from the dealer.
    Feb 2019
    New Zealand
    Spoke to dealer who supplied the module they advise that it correct module for vehicle and it was a superseded part.
    Module accepted coding of 0021057
    Thanks for the help Uwe
  6. Likes Uwe, Jetta ,97 liked this post
    Nov 2016
    Quote Originally Posted by Peter.ZLZ View Post
    As above. 3aa has been the replacement for 3c0 for a while now for epb. The long code helper has all the information you need to code it too, as I found when I upgraded my module
