Maps 2019 Golf R 2.0L DLRA maps
Maps
Jef
HQ
Note, this car had not had the PDI done... basically fresh off the truck just prior to me scanning it so keep that in mind.... I wasn't able to take it out of transport mode.
Saturday,06,April,2019,13:55:29:29015
VCDS Version: 19.3.0.1 (x64)  HEX-NET CB: 0.4503.4
Data version: 20190131 DS306.0
VIN: WVWVA7AU6KW123685   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
          4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVA7AU6KW123685   Mileage: 11km-6miles
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DLRA)       Labels: None
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q_VW37.rod
   VCID: CEDF6D6E91A6F23824-809A
17176 - Databus
                    Mileage: 1 km
                    Date: 2019.02.15
                    Time: 23:03:46
                    Coolant temperature: 67 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.890 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
16993 - Loading Mode active
          P169A 00 [175] - -
                    Mileage: 1 km
                    Date: 2019.02.16
                    Time: 00:36:37
                    Coolant temperature: 61 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.558 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 102 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 15.625000 %
                    FUP_H_SAE: 11880.0 kPa
Readiness: 0010 0101
   Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V07
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: A40BEFC6AFAA2868A2-80F0
Internal ROD error:
EV_TCMDQ381061_VW37.rod:FFMUX
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 63458000000325
   Coding: 01FA6BA15022216F457D030860C86980D60A84A2C0069677384250D8D2A84B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 864F954E3956FA78DC-80D2
0147 - Door Contact Switch
          C1076 29 [008] - Signal Implausible
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2019.03.29
                    Time: 13:08:57
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6096552430
   Coding: 132C0C0723
   VCID: C3C94C5A4AE40F50BB-8096
1077250 - Transport Mode Active
          U1105 00 [008] - -
          [Transportmodus active]
                    Fault Frequency: 26
                    Reset counter: 40
                    Mileage: 1 km
                    Date: 2019.02.16
                    Time: 00:36:01
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.579 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500001211140A
   VCID: ED9DCAE23CE029203D-80B8
Internal ROD error:
EV_ACClimaBHBVW37X_006_VW37.rod:FFMUX
1048838 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 9
                    Reset counter: 40
                    Mileage: 1 km
                    Date: 2019.02.16
                    Time: 00:36:21
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 00001903800350
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 8B59A47A2234871083-80DE
   Component: WWS    181217  043 0551
   Serial number:         190118233654
   Component: RLHS  052 0107
   Serial number: SBY19M02D06H06M49S27
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000022011920240952
527872 - Transport Mode Active
          U1105 00 [009] - -
                    Reset counter: 0
                    Mileage: 1 km
                    Date: 2019.02.16
                    Time: 00:36:01
   Serial number: 000308418019023
   Coding: 0471155811
   VCID: CCDB676667BAC0284A-8098
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 330000C159FFC728949C810580401600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: C4CB4F464FEA086882-8090
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 16
                    Reset counter: 40
                    Mileage: 11 km
                    Date: 2019.04.06
                    Time: 16:53:21
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 12.1 V
0110 - Transport Mode Active
          U1105 00 [009] - -
          [FAULT_SYC_TRANSPORTMODE_ACTIVE]
                    Reset counter: 0
                    Mileage: 1 km
                    Date: 2019.02.16
                    Time: 00:36:03
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 12.5 V
   Serial number: 10011941350666
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: B8332BB603225C881E-80EC
   Serial number: 003GCR0B7US5
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: C7D1584A7EDC237067-8092
   Occupant Detection:
   Serial number: IBH00000000000AYA34L
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 000 102 19
   Serial number: 357000000008D934083K
   Subsystem 3 - Part No SW: -----------    HW: 480 000 402 19
   Serial number: 35800000000B0329C83L
   Subsystem 4 - Part No SW: -----------    HW: 480 403 101 19
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001AF2E1DC52A7FU
   Subsystem 5 - Part No SW: -----------    HW: 480 403 101 19
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001242B75346942R
   Subsystem 6 - Part No SW: -----------    HW: 480 400 502 19
   Component: FrontSensor_D  004 6149
   Serial number: 35500010E2B7F1C4B29G
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 502 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600010E2B7F1C4D3DO
   Part No SW: 5G1 920 891 B    HW: 5G1 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
   VCID: AC1B07E6C77AE0286A-80F8
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5366
   Serial number: 30121810800878
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: EE9FCDEE31E6D23804-80BA
   Component: 0-01-0d-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29190000043520079026
   Coding: 2DFFFF
   Serial number: 5363390405
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00015.01.19
   Coding: 0001
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000420764014
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: B1251692E0588DC059-80E4
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 40
                    Mileage: 2 km
                    Date: 2019.02.16
                    Time: 01:23:16
   Component: HRE_Master    H12 0081
   Serial number: 0505462504
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BD3D3AA22C0079A0CD-80E8
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0506109116
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SAL0870C
   Coding: 003E13208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000027188218
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: BC3B37A6371A70A8FA-80E8
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD04AY6Z
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: AE1F0DEEF166923844-80FA
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 31011910521380
   Coding: 000000050900165206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: B52D22821430A1E005-80E0
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SAM2661E
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000027177564
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: B3291C9A1A44BFD02B-80E6
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJW0233214
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 22101815K11894
   Coding: 0003070000000201002213548150490084000E200120
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 181115201185
   VCID: AF2110EAF66C9B304F-80FA
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: B9352EB238284580E1-80EC
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 14.6V/14.6V)-----------
Cold start idle:
;SW:8V0-906-259-Q   HW:06K-907-425-J ---  Engine
;Component:R4 2.0l TFSI  H13 0002, Coding:092500122466010E3004
;EV_ECM20TFS0208V0906259Q,001003,EV_ECM20TFS0208V0906259Q_VW37.rod
;Saturday,06,April,2019,13:52:05:29015
;VCDS Version: Alpha 19.3.0 (x64)  Data version: 20190131 DS306.0
;VCID: CEDF6D6E91A6F23824-809A
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WVWVA7AU6KW123685,
IDE00018,Voltage terminal 15,14.199, V
IDE00019,Voltage terminal 30,14.414, V
IDE00021,Engine speed,791, /min
IDE00025,Coolant temperature,34, °C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,49, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,25, %
IDE00085,Normed load value,16.9, %
IDE00086,Accelerator position,15, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,33.0, °C
IDE00148,Median injection timing,0.6, ms
IDE00149,Ignition angle of current cylinder: actual value,-0.75, °
IDE00150,Pressure in brake booster,1.150, bar
IDE00151,Oil fill level,78, mm
IDE00155,Timing angle retardation cylinder 1,0.00, °
IDE00156,Timing angle retardation cylinder 2,0.00, °
IDE00157,Timing angle retardation cylinder 3,0.00, °
IDE00158,Timing angle retardation cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,213.6, °C
IDE00172,A/C compressor torque,0.00, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,4.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,3.8, °
IDE00178,Camshaft adjustment intake bank 1: specified value,16.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,15.8, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.3, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-2.6, °
IDE00186,Fuel low pressure: actual value,6.666, bar
IDE00187,Coolant temperature at engine start,21.7, °C
IDE00188,Fuel high pressure: actual value,125.7, bar
IDE00189,Activation of fuel pump electronics,56.82, %
IDE00190,Charge air pressure specified value,2.000, bar
IDE00191,Charge air pressure: actual value,0.990, bar
IDE00192,Coolant temperature at radiator outlet: actual value,21.4, °C
IDE00193,Coolant temperature at engine outlet: specified value,34.5, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,12.7, °C
IDE00196,Engine oil temperature,21.0, °C
IDE00199,Mean engine air mass,14, kg/h
IDE00200,Median vehicle speed,0.00, km/h
IDE00201,High fuel pressure: specified value,125.7, bar
IDE00202,Low fuel pressure: specified value,5.087, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00304,Fuel level,7, l
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00348,Intake air temperature,26, °C
IDE00349,Throttle valve position: normed,2, %
IDE00350,Air mass: specified value,14, kg/h
IDE00355,Cruise Control System (CCS): status,main switch off,
IDE00357,Fuel temperature,25.5, °C
IDE00358,Limitation: torque,220.0, Nm
IDE00371,Fuel consumption,0.93, l/h
IDE00375,Generator: load signal,32.28, %
IDE00380,Coolant fan 1: activation,10.16, %
IDE00381,Coolant fan 2: activation,10.16, %
IDE00392,Accelerator pedal: sensor voltage 1,0.742, V
IDE00393,Accelerator pedal: sensor voltage 2,0.371, V
IDE00396,Charge Pressure Actuator: acknowledgment,3.521, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,14.84, %
IDE00405,Crankshaft speed (RPM),797, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,00,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 acknowledgment,01,
IDE00417,Starter control: shut-off conditions 1,00 01,
IDE00432,Particle filter: time since last regeneration,61, min
IDE00434,Particle filter: soot mass calculated,0.00, g
IDE00436,Particle filter: kilometers since last regeneration,11.5,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,11, mg/stroke
IDE00474,Ambient air pressure,99, kPa abs
IDE00476,Fuel Metering Valve,29.73, %
IDE00477,Torque request: sum of auxiliary aggregate,8.5, Nm
IDE00478,Engine-drag torque,16.9, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,21.0, °C
IDE00496,Activation of oil pressure switch valve,High pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,closed,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside air temperature,23, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.991 Lambda / -0.023 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.785, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,99.2, %
IDE00582,Equivalence ratio target value,0.992, Lambda
IDE00583,Throttle valve specified value,2, %
IDE00584,Distance driven since erasing DTC memory,10, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,9, km
IDE00588,Fuel tank fill level,12.9, %
IDE00589,Fuel pressure,12830, kPa rel
IDE00592,Oxygen sensor control status,Closed loop,  / using O2 sensors ,
IDE00593,Ignition timing adjustment cylinder 1,-2.5, Degrees
IDE00594,Absolute intake pressure,34, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 B1S2 ,
IDE00597,Long term adaptation of mixture formation bank 1,-1.6, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,-3.9, %
IDE00608,Type of fuel,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00727,Test steps still to be performed,0,
IDE00787,Cause for cancellation,0,
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,0, min
IDE01076-MAS00111,Time since ignition off-Seconds,0, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01377,Throttle valve adapter: actual value,2.8, °
IDE01378,High fuel pressure: control deviation,0.7, bar
IDE01385,Wear index,0.00000116,
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,Before starter activation,
IDE01407,Particle filter: fuel consumption since last regeneration,2.04, l
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage bank 1 after catalytic converter,0.797, V
IDE01649,Throttle valve position 1,0.640, V
IDE01650,Throttle valve position 2,13, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,pressed,
IDE01672,Starter control: automatic start,not possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mech. test of starter complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch complete,
IDE01677,Result of O2 sensor test ready bank 1 after cat. conv.,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire sum counter,0,
IDE01774,Status misfire recognition,active,
IDE01775,Misfires per 1000 revolutions of cylinder 1,0,
IDE01776,Misfires per 1000 revolutions of cylinder 2,0,
IDE01777,Misfires per 1000 revolutions of cylinder 3,0,
IDE01778,Misfires per 1000 revolutions of cylinder 4,0,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.000,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator position 2,15, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,34.24, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,0.0, Nm
IDE01905,Average of ignition timing angle delay adjustment,15.00, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,-3.00, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,0,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,11, km
IDE01923,Control module distance driven,11, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of load shift flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,44.6, °
IDE01929,Open cam shaft angle at quantity control valve,5.9, °
IDE01931,High pressure pump injection volume control deviation,-1, mg/stroke
IDE01932,High pressure pump injection volume,9, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,0,
IDE01976,Numb.of misfir.: cylinder 2,0,
IDE01977,Numb.of misfir.: cylinder 3,0,
IDE01978,Numb.of misfir.: cylinder 4,0,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,288.4, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exh.gas temp.sen 1,782.8, °C
IDE02756,Number of manual engine starts,33,
IDE02757,Number of automatic engine starts,0,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function restriction,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start-stop sensor system,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration operation,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function restriction,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Diagnosis of air system,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power insufficient,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary consumers power too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Test of thermostat not complete,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,0,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration operation,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-Event memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Adaptation active,0,
IDE03010-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Tighter traffic flow detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Motor protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel salinization protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust emission control diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in the start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function restriction,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power insufficient,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary consumers power too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-Cat. heater,0,
IDE03011-MAS11563,Number of requested start processes-Engine hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Motor protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel salinization protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in the start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.492, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.796, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.190, V
IDE03267,Intake air temperature: unconditioned voltage,2.124, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.597, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.799, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver request torque,37.0, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status for transmission neutral position sensor,1,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3.479, V
IDE03582,Temperature sensor for engine temperature management,-48.0, °C
IDE03585,System status for the start/stop function master,System malfunction,
IDE03587-IDE02697,Stop overrides for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stop overrides for active participants-A/C,not active,
IDE03587-MAS00127,Stop overrides for active participants-brakes,not active,
IDE03587-MAS00506,Stop overrides for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stop overrides for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stop overrides for active participants-Transmission,not active,
IDE03587-MAS01106,Stop overrides for active participants-Level control system,not active,
IDE03587-MAS01490,Stop overrides for active participants-Energy management,not active,
IDE03587-MAS01627,Stop overrides for active participants-Steering,not active,
IDE03587-MAS02237,Stop overrides for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stop overrides for active participants-All-wheel electronics,not active,
IDE03587-MAS03757,Stop overrides for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stop overrides for active participants-Engine,not active,
IDE03587-MAS06709,Stop overrides for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stop overrides for active participants-Parking aid,not active,
IDE03587-MAS13018,Stop overrides for active participants-Front sensor system for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Engine,active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor system for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication error,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-Engine hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch not complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Test of thermostat complete,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,11, kg/h
IDE03767,Engine status,Idling,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,34.74, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,closed,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,392, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,50.78, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,162, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,32.42, %
IDE03832,Oxygen sensor bank 1 sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,2.282, V
IDE03918,Engine reverse rotation recognition,not recognized,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Initializing,
IDE03921,Mixture adaptation factor at partial load,0.53, %
IDE03922,Mixture adaptation factor at idle speed,-3.17, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,0.04, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.516, V
IDE03935,Charge pressure actuator: adaptation for upper stop,0.516, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.60, %
IDE03957,Throttle valve angle: specified value,2.7, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,91.80, %
IDE04002,Charge press. ctrl.,BP_A act:99, kPa
IDE04010,Engine torque: normalized,4, %
IDE04011,Nominal torque,1000, Nm
IDE04110,Additional inputs and outputs,,
IDE04405,Mixture deviation in adapted partial load range 1,0.60, %
IDE04409,Intake manifold pressure: corrected,0.338, bar
IDE04410,Intake manifold pressure: target value,0.346, bar
IDE04412,Pressure before throttle valve: corrected,0.990, bar
IDE04415,Oxygen ctrl factor with precontrol correction,-2.68, %
IDE04629,AVS operating condition,Test is running,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,40,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature management actuator,0.00, %
IDE04638,Transmission coolant valve,Open,
IDE04677,O2 sensor 1 bank 1: O2 sensor actual value,0,
IDE04680,O2 sensor 1: bank 1: voltage raw value O2 signal,1.982, V
IDE04713,Active brake system status,operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.342, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,0.00, %
IDE05311,Charge air pressure control valve position: actual value,0.04, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.5156, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-14.80, %
IDE05314-ENG112584,Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0],00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.5156, V
IDE05316,Charge air pressure control valve voltage: position open,0.5157, V
IDE05317-ENG112583,Charge air pressure control valve adaptation performed-LV_BPA_AD_ASA_SUC[0],00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.375, bar
IDE05622-ENG125277,Status of tank leak diagnosis with electrical diagnostic pump-STATE_DMTL_EOL,255,
IDE06006,Idle speed specified value,786, /min
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06192,Knock sensor: cylinder 2: voltage,0.689, V
IDE06193,Knock sensor: cylinder 3: voltage,0.518, V
IDE06194,Knock sensor: cylinder 4: voltage,0.603, V
IDE06195,Knock sensor: cylinder 1: voltage,0.620, V
IDE06296-ENG104200,Activation of oxygen control after main cat-Lambda probe 2: bank 1: status,00000000 ,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Function locked due to excessive stalling,
IDE06307,Stop prevention history data,Brake pedal information: plausibility,
IDE06307,Stop prevention history data,Exhaust emission control diagnosis,
IDE06307,Stop prevention history data,Auxiliary consumers power too high,
IDE06307,Stop prevention history data,Motor protection active,
IDE06307,Stop prevention history data,Brake under pressure too low,
IDE06307,Stop prevention history data,Test of thermostat not complete,
IDE06307,Stop prevention history data,Clutch protection K0,
IDE06307,Stop prevention history data,Diagnosis of exhaust system,
IDE06307,Stop prevention history data,Fuel salinization protection active,
IDE06307,Stop prevention history data,Deceleration takeover active,
IDE06307,Stop prevention history data,Regeneration operation,
IDE06307,Stop prevention history data,Steering angle,
IDE06307,Stop prevention history data,Adaptation active,
IDE06307,Stop prevention history data,Engine temperature,
IDE06307,Stop prevention history data,Tighter traffic flow detected,
IDE06307,Stop prevention history data,Mixture adaptation,
IDE06307,Stop prevention history data,Engine hood open,
IDE06307,Stop prevention history data,Event memory entry in engine control module,
IDE06307,Stop prevention history data,Poor start detection,
IDE06307,Stop prevention history data,Ambient air pressure,
IDE06307,Stop prevention history data,Restriction in the start system,
IDE06307,Stop prevention history data,Sporadic function restriction,
IDE06307,Stop prevention history data,Steering,
IDE06307,Stop prevention history data,Hybrid battery power insufficient,
IDE06307,Stop prevention history data,E machine output too low,
IDE06307,Stop prevention history data,Driving situation,
IDE06307,Stop prevention history data,Play protection,
IDE06307,Stop prevention history data,Diagnosis of air system,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Auxiliary consumers power too high,
IDE06308,Start request history data,Hybrid battery power insufficient,
IDE06308,Start request history data,Engine temperature too high,
IDE06308,Start request history data,SCR System requires restart,
IDE06308,Start request history data,Restriction in the start system,
IDE06308,Start request history data,Sporadic function restriction,
IDE06308,Start request history data,Fuel salinization protection active,
IDE06308,Start request history data,Deceleration takeover active,
IDE06308,Start request history data,Rolling vehicle,
IDE06308,Start request history data,Motor protection active,
IDE06308,Start request history data,Brake under pressure too low,
IDE06308,Start request history data,Engine temperature too low,
IDE06308,Start request history data,Steering,
IDE06308,Start request history data,Cat. heater,
IDE06308,Start request history data,Engine hood open,
IDE06386,Oil level: static measurement,129, mm
IDE06387,Oil level: last valid dynamic value,129, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,-127, mm
IDE06390,Oil level: minimum value,385, mm
IDE06391,Oil temperature sensor 2,20.0, °C
IDE06392,Oil temperature sensor 2: raw value,20.000, V
IDE06393,Oil level: dynamic average value,129, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,0.000, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,2.648, V
IDE06397,Temperature sensor for engine temp. management: target value,106.5, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,2.644, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.728, V
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.958, V
IDE06567,Start-stop function deactivation frequency counter,0,
IDE06568,Stop prevention by driver frequency counter,1,
IDE06569,Vehicle stopped frequency counter,2,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Vehicle standstill with stop frequency counter,0,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,Yes,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,Yes,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until at standstill/Stop & Go,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,0.00, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,0.00, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,0,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,not active,
IDE07001,Piston-cooling jets: activation,On,
IDE07002,Exhaust flap: activation,10.00, %
IDE07003-ENG123034,Exhaust flap bank 2: activation-PWM_EF[1],10.004, %
IDE07008,Tank leak: number no leak detected,0,
IDE07011,Tank leak: number communication errors to engine control,0,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,137646,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,0, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,163.75, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,163.50, °
IDE07550,Engine temp. management actuator: raw value,2592,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Start,
IDE07553,Engine temperature management actuator: after-run stop,3948,
IDE07554,Engine temperature management actuator: stop open,145,
IDE07564,Required torque adjustment by idling regulator,9.3, Nm
IDE07571,Engine torque,19.2, Nm
IDE07572,High pressure regulation: adaptation value,1.95, mg
IDE07574,Long-term fuel trim bank 1 at idle,-0.34, mg/stroke
IDE07575,Driver request torque,11.3, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,not activated,
IDE07598-MAS00325,Cruise control switch actuation-Setting,not activated,
IDE07598-MAS00326,Cruise control switch actuation-Activation,not activated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,not activated,
IDE07598-MAS02310,Cruise control switch actuation-Decelerate,not activated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,not activated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,not activated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,not activated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,not activated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,not activated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,Yes,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,No,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,Yes,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,Yes,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,Yes,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 Bank 1 after cat operation readiness Status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,1,
IDE07905-ENG118117,Brake light switch status-actuated__activated,operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,1,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,not completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,not completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring of oxygen sensor,not completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring of oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring of Exhaust Gas recirc. (EGR),not completed successfully,
IDE08071-ENG119931,Remote start cancellation reason store 1-LF_ST_REQ_EXT_DVC_DEAC_1,0,
IDE08072-ENG119932,Remote start cancellation reason store 2-LF_ST_REQ_EXT_DVC_DEAC_2,0,
IDE08073-ENG119933,Remote start cancellation reason store 3-LF_ST_REQ_EXT_DVC_DEAC_3,0,
IDE08074-ENG119934,Remote start cancellation reason store 4-LF_ST_REQ_EXT_DVC_DEAC_4,0,
IDE08075-ENG119935,Remote start cancellation reason store 5-LF_ST_REQ_EXT_DVC_DEAC_5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.234, counts
IDE08806,EVAP valve diag. activation condition at maximum load,651, mbar
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.568, V
IDE10380,Knock sensor average voltage bank 1,0.645, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,0,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,1,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,Yes,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10970-MAS11563,Number of prevented stop processes-Engine hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to excessive stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2127,
IDE10989-MAS00107,Immobilizer: historic data-Month,15,
IDE10989-MAS00108,Immobilizer: historic data-Day,31,
IDE10989-MAS00109,Immobilizer: historic data-Hours,31,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,63,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,63,
IDE10989,Immobilizer: historic data,Engine hood open,
IDE10989,Immobilizer: historic data,Function locked due to excessive stalling,
IDE10989,Immobilizer: historic data,Brake pedal information: plausibility,
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,-48.00, °C
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,10.0, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
IDE12210,Particle filter: water mass,182.2, g
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,6.40, g
IDE13086,Particle filter: maximum soot build-up reached,8.00, g
IDE13087,Particle filter: maximum ash build-up reached,30.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.000, counts
IDE13089,Particle filter: high soot accumulation ratio,3.000, counts
IDE13090,Particle filter: maximum soot loading ratio reached,4.000, counts
IDE13091,Particle filter: ash loading ratio,1.000, counts
IDE13092,Particle filter: soot accumulation ratio,0.041, counts
ENG102981,AC compressor: speed increase,00000000 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,0.11539,
ENG103474,Activation of oil pressure switching valve,00000000 ,
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,10.47, kg/h
ENG104264,Alternator load,650, W
ENG103910,Ambient temperature,22.50, °C
ENG112539,AR_THR_AD_ADD_MMV,0.0036, cm²
ENG98377,As,none,
ENG103165,Battery voltage,14.4, V
ENG07601,Bypasstool_a2l_name,ORIGINAL A2L,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,8V0259Q 0002BVCK,
ENG99697,Calibration Verification Number,CF C4 C7 8C,
ENG128780,CAM_DIF_VCP[EX_1],0.188, °
ENG128781,CAM_DIF_VCP[IN_1],-0.352, °
ENG102002,CAM_OFS_IVVT_IN[1],0.000, °
ENG112540,CAM_PHA_ENG[GES_EX][CBK_1],4.141, °
ENG112541,CAM_PHA_ENG[GES_IN][CBK_1],15.016, °
ENG101169,CAM_PHA_OFS_MAF[IN][1],0.000, °
ENG112542,CAM_SP_IND_VCP[EX_1],4.000, °
ENG112543,CAM_SP_IND_VCP[IN_1],15.000, °
ENG112544,CAM_VCP[EX_1],3.891, °
ENG112545,CAM_VCP[IN_1],15.180, °
ENG103849,Cat. ageing: bank 1: actual,0.000,
ENG102214,CPU_LOAD,52.8, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ[0],0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ[1],0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ[2],0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ[3],0,
ENG101127,CTR_CDN_OBD_RBM,0,
ENG114826,CTR_EDGE_CAM_EX[1],179,
ENG114827,CTR_EDGE_CAM_IN[1],184,
ENG100536,CTR_IGK_CYC_RBM,32,
ENG125193,CTR_LAMB_SP_PI_REQ[0],0,
ENG125194,CTR_LAMB_SP_PI_REQ[1],0,
ENG125195,CTR_LAMB_SP_PI_REQ[2],0,
ENG125196,CTR_LAMB_SP_PI_REQ[3],0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE[0],0,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE[1],0,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE[2],0,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE[3],0,
ENG112558,CTR_MIS_TOT_NVMY_SAE,0,
ENG125197,CTR_REQ_IV_OFF_PI_FAST[0],0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST[1],0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST[2],0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST[3],0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW[0],0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW[1],0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW[2],0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW[3],0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP[0],0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP[1],0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP[2],0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP[3],0,
ENG100764,CTR_SUM_SRV_INTL,0.0,
ENG125205,CTR_TQI_POW_MAX_PI_REQ[0],0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ[1],0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ[2],0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ[3],0,
ENG119929,CTR_VLD_CAT_GAP_AFL[1],0,
ENG119930,CTR_VLD_CAT_GAP_AFR[1],0,
ENG99428,CTR_VLFT_1_SWI_NOT[0],0,
ENG103626,CTR_VLFT_1_SWI_NOT[1],0,
ENG100809,CTR_VLFT_1_SWI_NOT[2],0,
ENG99336,CTR_VLFT_1_SWI_NOT[3],0,
ENG103025,CTR_VLFT_STND_SWI_NOT[0],0,
ENG100017,CTR_VLFT_STND_SWI_NOT[1],0,
ENG100438,CTR_VLFT_STND_SWI_NOT[2],0,
ENG100736,CTR_VLFT_STND_SWI_NOT[3],0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,40,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,9,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,24,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST[0],VLCAvl_errSigAcc_VW,
ENG99120,DIAG_INST[1],MOD_TRPT,
ENG103260,DIAG_INST[2],NO_ERROR,
ENG99710,DIAG_INST[3],NO_ERROR,
ENG102667,DIAG_INST[4],NO_ERROR,
ENG102739,DIAG_INST[5],NO_ERROR,
ENG100162,DIAG_INST[6],NO_ERROR,
ENG99103,DIAG_INST[7],NO_ERROR,
ENG99261,DIAG_INST[8],NO_ERROR,
ENG103622,DIAG_INST[9],NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,9, km
ENG112561,DIST_DTC_CLR_SAE,10, km
ENG103766,DIST_ENG_RUN_IN,1.1, m
ENG100531,DIST_ST,11400, m
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG115973,Engine Exhaust Flow Rate,14.0, kg/h
ENG20102,Engine Friction - Percent Torque,2.0, %
ENG104044,Engine load,16.015625, %
ENG102494,Engine speed: actual,768, /min
ENG102783,Engine: operating status,IS,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,65.00, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD[1],0.000, %
ENG104151,FAC_L_RNG_LAM_AD[1],0.601, %
ENG100298,FAC_LAM_CP,-0.978, %
ENG100108,FAC_LAM_LIM[1],-0.935, %
ENG99722,FAC_LAM_TCO_A[1],0.000, %
ENG103521,FAC_LAM_TCO_B[1],0.000, %
ENG103641,FAC_LAM_TCO_C[1],0.000, %
ENG101578,FAC_LAM_TCO_D[1],0.000, %
ENG100685,FAC_LAM_TCO_E[1],0.000, %
ENG103307,FAC_MAF_MAX,0.22971,
ENG99791,FAC_SLOP_IV[1],0.00000,
ENG102306,FAC_TPS_1_SAE,12.109375, %
ENG102292,FAC_TPS_1_SAE,12.500000, %
ENG99630,Fan control relay: fan run-on,2,
ENG101437,Fan request from air conditioner,0.0, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,12.94117668, %
ENG104248,Fuel consumption signal,41292, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG115974-ENG55378,Fuel Rate-Engine Fuel Rate,0.26, g/s
ENG115974-ENG116137,Fuel Rate-Vehicle Fuel Rate,0.26, g/s
ENG100250,Fuel regulating valve: duty cycle,28.349, %
ENG101692,Fuel supply system: high-pressure regulator,243.761, hPa
ENG114828,FUP_EFP_MES,6665.24, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,120027.4, hPa
ENG112563,FUP_H_SAE,11890.0, kPa
ENG103368,Gearbox -CAN bus messages,126847,
ENG99170,Height correction,990.70, hPa
ENG103575,High-pressure system: regulator,0.59, mg
ENG103879,High-pressure system: regulator: mobile part,-2.82, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,0.5, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK[0],0.000, °
ENG103593,IGA_ADJ_KNK[1],0.000, °
ENG103360,IGA_ADJ_KNK[2],0.000, °
ENG99404,IGA_ADJ_KNK[3],0.000, °
ENG100425,IGA_IGC[0],0.000, °
ENG101655,IGA_IGC[1],1.875, °
ENG100410,IGA_IGC[2],-1.500, °
ENG100407,IGA_IGC[3],-1.500, °
ENG112564,IGA_IGC_SAE,-1.0, °
ENG101741,Intake air temperature,25.50, °C
ENG100634,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2,00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG125209,KNKS_ERR_REL[0],0.0781, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ[1],0.00000,
ENG99601,LAMB_DELTA_I_LAM_ADJ[1],0.00000,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD[1],0.00201,
ENG99674,Lambda controller: bank 1 (averaged value),-0.783, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000000 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00000,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,399, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.924, V
ENG102763,Lambda probes actual: bank1,0.9727,
ENG104114,Lambda probes specified: bank1,0.9941,
ENG06592,LF_COSI_CTL_ERR_A,0,
ENG06593,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW[1],16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW[2],16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW[1],65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW[2],65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW[1],0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW[2],0,
ENG112572,LF_IV_ERR_RAW_BSW[0],0,
ENG112573,LF_IV_ERR_RAW_BSW[1],0,
ENG112574,LF_IV_ERR_RAW_BSW[2],0,
ENG112575,LF_IV_ERR_RAW_BSW[3],0,
ENG112576,LF_IV_ERR_VLD_BSW[0],8191,
ENG112577,LF_IV_ERR_VLD_BSW[1],8191,
ENG112578,LF_IV_ERR_VLD_BSW[2],8191,
ENG112579,LF_IV_ERR_VLD_BSW[3],8191,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2127,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,15,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,31,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,31,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,63,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,63,
ENG127734,Life_cycle_data_start_requirement_development,brakes,
ENG127734,Life_cycle_data_start_requirement_development,Immobilizer,
ENG127734,Life_cycle_data_start_requirement_development,Kessy,
ENG127734,Life_cycle_data_start_requirement_development,Engine,
ENG127734,Life_cycle_data_start_requirement_development,Quattro Sport,
ENG127734,Life_cycle_data_start_requirement_development,12 V electrical system,
ENG127734,Life_cycle_data_start_requirement_development,Transmission,
ENG127734,Life_cycle_data_start_requirement_development,Front axis lift system,
ENG127734,Life_cycle_data_start_requirement_development,Level control system,
ENG127734,Life_cycle_data_start_requirement_development,ACC,
ENG127734,Life_cycle_data_start_requirement_development,Front sensor system for driver assistance systems,
ENG127734,Life_cycle_data_start_requirement_development,All-wheel electronics,
ENG127734,Life_cycle_data_start_requirement_development,Convertible top control module,
ENG127734,Life_cycle_data_start_requirement_development,Steering,
ENG127734,Life_cycle_data_start_requirement_development,A/C,
ENG127734,Life_cycle_data_start_requirement_development,Multifunction unit control module,
ENG127734,Life_cycle_data_start_requirement_development,Parking aid,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2127,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,15,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,31,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,31,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,63,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,63,
ENG127735,Life_cycle_data_stop_prohibition_development,Engine,
ENG127735,Life_cycle_data_stop_prohibition_development,A/C,
ENG127735,Life_cycle_data_stop_prohibition_development,Convertible top control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Multifunction unit control module,
ENG127735,Life_cycle_data_stop_prohibition_development,Parking aid,
ENG127735,Life_cycle_data_stop_prohibition_development,12 V electrical system,
ENG127735,Life_cycle_data_stop_prohibition_development,ACC,
ENG127735,Life_cycle_data_stop_prohibition_development,Transmission,
ENG127735,Life_cycle_data_stop_prohibition_development,Front axis lift system,
ENG127735,Life_cycle_data_stop_prohibition_development,brakes,
ENG127735,Life_cycle_data_stop_prohibition_development,Immobilizer,
ENG127735,Life_cycle_data_stop_prohibition_development,Kessy,
ENG127735,Life_cycle_data_stop_prohibition_development,Quattro Sport,
ENG127735,Life_cycle_data_stop_prohibition_development,Steering,
ENG127735,Life_cycle_data_stop_prohibition_development,Level control system,
ENG127735,Life_cycle_data_stop_prohibition_development,Front sensor system for driver assistance systems,
ENG127735,Life_cycle_data_stop_prohibition_development,All-wheel electronics,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2019,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,4,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,6,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,18,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,51,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,10,
ENG127733,Life_cycle_data_system_failure,not active,
ENG127733,Life_cycle_data_system_failure,Engine,
ENG122701,LMVDes_st_Mod_Out_VW,0,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,238.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,0.00, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ[0],0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG07619,LV_ECRAS_FB_DIAG_POS_RESP[1],00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI[1],00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI[2],00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI[3],00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI[4],00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI[1],00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI[2],00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI[3],00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI[4],00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000001 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY[0],00000001 ,
ENG36574,LV_ST_PROT_ACT_ERR,00000000 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG102523,MAF,145.52, mg/stroke
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,33, kPa
ENG103501,MASS_SA_REL[0],0.000,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD[1],0.00, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD[1][1],0.00, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,762, /min
ENG103004,N_TCHA,20727.5, /min
ENG112590,N_TOOTH,758, /min
ENG107737-ENG112538,NC_NR_DIAG_RBM-NC Value,203,
ENG126111,NL_PRE[0],0.17899, V
ENG126112,NL_PRE[1],0.15045, V
ENG126113,NL_PRE[2],0.17258, V
ENG126114,NL_PRE[3],0.30678, V
ENG128789,NR_CYC_AD_DC_BAL_HOM[RNG_H],0,
ENG128790,NR_CYC_AD_DC_BAL_HOM[RNG_IS],0,
ENG128791,NR_CYC_AD_DC_BAL_HOM[RNG_L],0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM[0],0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM[1],0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM[2],0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM[3],0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV[1],0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV[1],0.00000, g
ENG99157,PRS_SA_DIF,0.00, hPa
ENG02464,PRS_UP_THR_MES,989.62, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX[1][1],-2.0000, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN[1][1],0.3125, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][1],-2.0000, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX[1][2],-3.1875, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][1],0.3125, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN[1][2],-0.8125, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP[EX_1],90.002, %
ENG112594,PWM_ACT_VCP[IN_1],90.002, %
ENG101350,PWM_ETC,-14.066, %
ENG112595,PWM_HLD_VCP[EX_1],34.692, %
ENG112596,PWM_HLD_VCP[IN_1],34.723, %
ENG112597,PWM_PAS_VCP[EX_1],9.216, %
ENG112598,PWM_PAS_VCP[IN_1],9.375, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,NO_ECF,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV[1],0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV[1],0.0000000,
ENG102377,Ready and error flags,37,
ENG112599,RVC_AV,163.50, °
ENG112601,RVC_SP,163.75, °
ENG112600,RVCPWM,0.000, %
ENG103248,SEG_AD_MMV_ER[0],0.0000, ‰
ENG101135,SEG_AD_MMV_ER[1],-0.3960, ‰
ENG99078,SEG_AD_MMV_ER[2],-0.0195, ‰
ENG103257,SEG_AD_MMV_ER[3],-0.3958, ‰
ENG102511,SEG_AD_MMV_ER_H[0],0.0000, ‰
ENG103258,SEG_AD_MMV_ER_H[1],-0.3960, ‰
ENG99291,SEG_AD_MMV_ER_H[2],-0.0195, ‰
ENG99954,SEG_AD_MMV_ER_H[3],-0.3958, ‰
ENG100568,SEG_AD_MMV_ER_L[0],0.0000, ‰
ENG100601,SEG_AD_MMV_ER_L[1],-0.3960, ‰
ENG102668,SEG_AD_MMV_ER_L[2],-0.0195, ‰
ENG101232,SEG_AD_MMV_ER_L[3],-0.3958, ‰
ENG101561,SEG_AD_MMV_ER_MID[0],0.0000, ‰
ENG102964,SEG_AD_MMV_ER_MID[1],-0.3960, ‰
ENG100890,SEG_AD_MMV_ER_MID[2],-0.0195, ‰
ENG99793,SEG_AD_MMV_ER_MID[3],-0.3958, ‰
ENG103381,Shut-off time,22.70, s
ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,0, %
ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,0, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG102033,STATE_BPA[0],OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,22888512,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE[1],CL,
ENG104238,STATE_NVLD,INI,
ENG112606,STATE_PWM_VCP[EX_1],HLD,
ENG112607,STATE_PWM_VCP[IN_1],HLD,
ENG101078,STATE_READY_OBD_1,39,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SCGA0510 CB60050,
ENG128798,STATE_T_ES_RD,0,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,enable,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,48, min
ENG112494,T_AST_SAE,115, s
ENG104148,T_COOL_LOIL,461.6, ms
ENG112613,T_DTC_CLR_SAE,54, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,0, min
ENG112615,T_ES_CNT,0,
ENG112616,T_ES_DC,115, min
ENG99463,T_ES_H,0, s
ENG128802,T_IGK,118.30, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG128803,T_PWL_CAN,96.1, s
ENG112636,T_SWI_VVL_ACR,67.8, ms
ENG101325,T_TEMP_SIG_LOIL,41.0, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,22.500, °C
ENG102048,Tank breather valve: duty cycle,16.406250, %
ENG101339,Tank breather valve: short trip result,1.1234, kg/h
ENG100439,Tank level,00000001 ,
ENG112610,TCO_1_FIRST_ST,22, °C
ENG112611,TCO_1_ST,22, °C
ENG112612,TCO_1_SYS,52, °C
ENG103434,TCO_A_LAM_AD_WUP[1],-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP[1],9.75, °C
ENG101581,TCO_C_LAM_AD_WUP[1],24.75, °C
ENG100354,TCO_D_LAM_AD_WUP[1],35.25, °C
ENG101973,TCO_E_LAM_AD_WUP[1],45.00, °C
ENG128800,TCO_MDL[STUCK_L_COOL_MON],23.000, °C
ENG124460,TCO_MDL[TH],25.359, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP[1],51.75, °C
ENG100853,TCO_MIN_LAM_AD_WUP[1],50.25, °C
ENG102279,TCS/ESP: specified torque,23.16, Nm
ENG99857,TCS: status,00000000 ,
ENG36581,TEG_DYN_LS_DOWN[0],101.7875, °C
ENG101250,TEG_DYN_LS_UP[0],286.1000, °C
ENG36582,TEG_DYN_UP_CAT[0],213.1000, °C
ENG36583,TEMP_CAT_DYN_MDL[0],160.2250, °C
ENG36584,TEMP_CAT_STAT_MDL[0],371.0375, °C
ENG112614,TEMP_CAT_UP_1_SAE,254.3, °C
ENG114837,TFPA,31, °C
ENG114838,TFU_HPP,30.75, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,2.451, °
ENG102845,Throttle valve deviation,-6.190, %
ENG126115,TI_1_MES_MPI[0],0.000, ms
ENG126116,TI_1_MES_MPI[1],0.000, ms
ENG126117,TI_1_MES_MPI[2],0.000, ms
ENG126118,TI_1_MES_MPI[3],0.000, ms
ENG126119,TI_MES_4[PLS_1][0],0.548, ms
ENG126120,TI_MES_4[PLS_1][1],0.544, ms
ENG126121,TI_MES_4[PLS_1][2],0.544, ms
ENG126122,TI_MES_4[PLS_1][3],0.532, ms
ENG126123,TI_MES_4[PLS_2][0],0.000, ms
ENG126124,TI_MES_4[PLS_2][1],0.000, ms
ENG126125,TI_MES_4[PLS_2][2],0.000, ms
ENG126126,TI_MES_4[PLS_2][3],0.000, ms
ENG126127,TI_MES_4[PLS_3][0],0.000, ms
ENG126128,TI_MES_4[PLS_3][1],0.000, ms
ENG126129,TI_MES_4[PLS_3][2],0.000, ms
ENG126130,TI_MES_4[PLS_3][3],0.000, ms
ENG128801,TIA_CHA_DOWN_MV,31.500, °C
ENG125276,TIG_MES_SAE[IM],26, °C
ENG103351,Time since engine start,121.5, s
ENG112634,TLTS_MES[TCE],54.758, °C
ENG112635,TMAG_VCP,22, °C
ENG110444,TPS_AD_CDN_MIS,32,
ENG114839,TPS_ETC,2.451, °
ENG99274,TPS_SP,2.465, °
ENG103021,TQ_CONV,2.00, Nm
ENG128804,TQI_ADD_ACT,41.43750, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG115975-ENG116124,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG115975-ENG116108,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG115975-ENG116105,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG115975-ENG116116,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG102329,TTIP_MES_LS_UP[1],720.1875, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7373, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,64.0, V
ENG103201,VCV_CLOSE_RNG,33.4, °
ENG115976,Vehicle Odometer,11.3, km
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4,
ENG122705,VLCReq_st_Dem_VW,0,
ENG112639,VLS_DOWN_SAE[1],0.735, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.002167, m³/s
ENG101929,VP_TPS_1,0.6201, V
ENG102985,VP_TPS_2,4.3750, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.5029, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.4920, V
ENG101674,VP_TPS_AD_LIH_1,0.7959, V
ENG99507,VP_TPS_AD_LIH_2,4.1895, V
Elapsed Time: 01:14
