Page 1 of 11 123 ... LastLast
Results 1 to 10 of 105
Thread: 2007 4.2L FSI MAF codes & trans harsh/flares
    Verified VCDS User stone4779's Avatar
    Mar 2019
    Firstly, here is my shiny new AutoScan:
    Monday,08,April,2019,12:24:34:25339
    Dealer/Shop Name: Devil Diagnostics
    VIN: WA1AV74L17D026123   License Plate:
    Mileage: 236580km-147003mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 3C 42 46 47 4F 52
              55 56 61 62 65 67 69 6C 6D 6F 72 76 77
    VIN: WA1AV74L17D026123   Mileage: 236580km-147003miles
    Address 01: Engine        Labels:. 079-907-560-BAR.clb
       Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
       Component: 4.2l V8/4V          0060
       Revision: --H16---    Serial number:
       Coding: 01210009190F0960
       Shop #: WSC 42286 444 85842
       VCID: 2809F9FE5EF534F7F6D-807C
    005241 - Brake Boost Vacuum System
                   P1479 - 008 - Mechanical Failure
                        Mileage: 236542 km
                        Date: 2019.04.06
                        Time: 20:52:36
                        RPM: 1849 /min
                        Load: 75.3 %
                        Speed: 13.0 km/h
                        Temperature: 106.0°C
                        Temperature: 56.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.208 V
    004105 - Mass Air Flow Sensor 1/2
                   P1009 - 008 - Implausible Signal from Load Calculation - MIL ON
                        Fault Status: 11101000
                        Mileage: 236543 km
                        Date: 2019.04.06
                        Time: 20:54:31
                        RPM: 1464 /min
                        Load: 70.6 %
                        Speed: 16.0 km/h
                        Temperature: 105.0°C
                        Temperature: 53.0°C
                        Voltage: 13.462 V
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 008 - Implausible Signal - MIL ON
                        Mileage: 236543 km
                        Date: 2019.04.06
                        Time: 20:54:48
                        RPM: 2015 /min
                        Load: 68.6 %
                        Speed: 31.0 km/h
                        Temperature: 51.0°C
                        Voltage: 12.954 V
    000267 - Mass Air Flow Sensor (G246)
                   P010B - 008 - Implausible Signal - MIL ON
                        Mileage: 236543 km
                        Date: 2019.04.06
                        Time: 20:54:48
                        RPM: 2015 /min
                        Load: 68.6 %
                        Speed: 31.0 km/h
                        Temperature: 51.0°C
                        Voltage: 12.954 V
    Readiness: 0000 1100
       Part No SW: 09D 927 750 FH    HW: 09D 927 750 FH
       Component: AL 750 6A           0959
       Revision: 00H52000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 79AFECBAF5DF7D7FD93-802C
                013 - Check DTC Memory
                        Fault Frequency: 16
                        Reset counter: 0
                        Date: 2005.09.20
                        Time: 12:00:02
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H21001
       Coding: 0017457
                        Fault Status: 01101101
                        Reset counter: 138
                        Mileage: 236582 km
                        Date: 2019.04.08
                        Time: 12:08:04
                        Count: 12545
                        Count: 8196
                        Count: 41472
       Component: FBSAUDIC6 ELV   H31 0210
       Revision: 27120501    Serial number: 10601000454533
       Coding: 0000135
       Shop #: WSC 25103 444 180956
       VCID: 6393AED2675397AFE3F-8036
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 KSG   H27 0080
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0053
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 732 R    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 354FO067505065
       Coding: 0002003
       VCID: 382929BE8E55A47766D-806C
       Subsystem 2 - Serial number: 00000001418939
       Subsystem 3 - Serial number: 0114.10.090000000100010899’
       Subsystem 4 - Serial number: 010899’
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Revision: 00---008    Serial number: 00000000040837
       Coding: 0524328
       VCID: 619FA4DA7D4F85BFF13-8034
    02508 - Temperature Sensor for Refrigerant (G454)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 138
                        Mileage: 236582 km
                        Date: 2019.04.08
                        Time: 12:08:09
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0114123
       VCID: 3039119E66257C372ED-8064
       Component: Wischer AU716   H11 0030
       Coding: 00064792
       Shop #: WSC 31414
       Component: REGENLICHTSENSORH12 0090
       Coding: 00150059
       Shop #: WSC 31414
       Part No SW: 4L0 910 111 A    HW: 4L0 035 111
       Component: CD-Changer      H41 0100
       Revision: 00000000    Serial number: AUZ5ZBG3056632
       VCID: 1E65DF260CB1FA478C1-804A
       Component: 73 AIRBAG AUDI8RH39 0210
       Revision: 03H39000    Serial number: 0038QD030XTT
       Coding: 0014131
       VCID: 2B0306F24F031FEF1BF-807E
       Subsystem 1 - Part No: 4L0 910 339
       Component: BF-Gewichtsens. H02 0020
       Subsystem 2 - Serial number: 6332QSME0F4C517FY
       Subsystem 3 - Serial number: 6342QSME101A3E71D
       Subsystem 4 - Serial number: 6352QSME0F6C3647U
       Subsystem 5 - Serial number: 6362QSME0F79043BR
       Subsystem 6 - Serial number: 63734SME0D5C17433
       Subsystem 7 - Serial number: 63834SME0E10287F6
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
       Revision: 00H03000    Serial number: 90055061450037
       Coding: 0012242
       VCID: 270BFAC253EB3B8FFF7-8072
       Component: E0221           H07 0090
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 H
       Component: KOMBIINSTR. M73 H17 0070
       Revision: 00000000    Serial number: 5HH54PY56
       Coding: 2641263
       Shop #: WSC 22302 444 84850
       VCID: 2313EED227D3D7AFA3F-8076
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D06607811B
       Coding: F7D7FE77347202
       VCID: 6C81C5EE8A8DD8D7525-8038
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory FS   H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0082954
       Part No SW: 4E0 910 888 C    HW: 4E0 919 887 D
       Component: MNS US          H48 0960
       Revision: 00000000    Serial number: 313EG067500446
       VCID: 2E050FE67C116AC73C1-807A
       Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH06 0060
       Revision: 00H06000    Serial number: 6PZ 009 014-00
       Coding: 0010001
       VCID: 2C0105EE4A0D18D7125-8078
       Subsystem 1 - Part No: 4L0 910 568 B
       Component: J0770_SWA_Slave_H10 0130
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F20.09.1200H10000AMS14955’
       Subsystem 4 - Serial number: S14955’
    16365 - Control Module - Electrical Error; CPU 2
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 84
                        Mileage: 112692 km
                        Date: 2013.06.25
                        Time: 18:14:59
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00000000    Serial number:  p
       Coding: 0051915
       VCID: 2F3B12E27B1B63CF377-807A
       Part No SW: 4L0 910 289 FA    HW: 4L0 907 289 C
       Component: Komfortgeraet   H08 0060
       Revision: 0060 ---    Serial number: 01903970480000
       Coding: 7624733
       Shop #: WSC 25103 444 98732
       VCID: 74B1DD8ED2BD00178A5-8020
    01503 - Bulb for 3rd Brake Light (M25)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 138
                        Mileage: 125759 km
                        Date: 2013.12.09
                        Time: 08:24:55
    01134 - Alarm Horn (H12)
                        Reset counter: 138
                        Mileage: 127271 km
                        Date: 2014.01.09
                        Time: 10:40:45
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H02 0150
       Revision: PROD_01     Serial number: 00000000102991
       Coding: 0000026
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000027247
       Coding: 0012001
       VCID: 5EE59F264C31BA47CC1-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0051915
       Coding: 0000021
       VCID: 290FFCFA45FF0DFFE93-807C
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
       Revision: 00000000    Serial number: 388ET067531335
       VCID: 313F149A6D2F753F213-8064
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000022409
       Shop #: WSC 22186 444 85943
       VCID: 6491ADCE625D90971A5-8030
       Component: von VA0  320920K0UH
       Coding: 34463039313531303544205641303332303932304B305548
                        Reset counter: 178
                        Mileage: 236582 km
                        Date: 2019.04.08
                        Time: 12:08:04
                        Mileage: 236582 km
                        Date: 2019.04.08
                        Time: 12:15:50
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0051722
       Revision: 00050100    Serial number: 00000700022670
       Coding: 0062424
       VCID: 221DEBD638C9DEA7A89-8076
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000605100098
       Shop #: WSC 12336 024 394758
       VCID: 34311D8E923D40174A5-8060
    Address 69: Trailer        Labels: 4E0-910-383.lbl
       Part No SW: 4E0 910 383 C    HW: 4E0 907 383 C
       Component: ANHAENGERELEKTR 004 0060
       VCID: 2411EDCE22DDD097DA5-8070
       Part No SW: 4L0 910 441     HW: 4L0 907 441
       Component: J772__Rearview      0020
       Revision: --H10---    Serial number: 525PA8-J651976
       Coding: 1001101
       Part No SW: 4L0 910 945     HW: 4L0 827 851 C
       Component: ValeoHeckdeckel H28 0290
       Revision: --H28001    Serial number: E5030000B
       Shop #: WSC 22302 444 12508
       Subsystem 3 - Serial number: RD30.09.09--H28001001B0348’
       Subsystem 4 - Serial number: 1B0348’
       Component: ILM HINTEN 2    H05 0040
       Revision: AAH05044    Serial number: 001705295-----
       Coding: 0003595
       VCID: 2615F7C654E12287C41-8072
       Component: J_245_EE14_SKB09H10 0160
       Component: J_394_EE14_SKB09H10 0160
       Component: J_392_EE14_SKB09H10 0160
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0051722
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06220615200501
       Coding: 0031246
    Address 77: Telephone
    End----(Elapsed Time: 02:18, VBatt start/end: 11.3V/11.4V. VIgn 11.3V)-----
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    We bought the car with a whole mess of electrical issues ..which most of them were sorted out by replacing the MMI control board, and replacing the N402 high pressure fuel pump on the driver's side.
    Before replacing the MMI control board, the MMI would turn off after a couple seconds and attempt to turn on again and then turn back off over and over.
    Before replacing the n402 high pressure fuel pump on the driver's side, when attempting to go wide open throttle or anything past 50% throttle it would fall flat on its face and/or shutter. After a short time it would blow fuse s13 taking a bunch of important stuff offline with it when it blew...
    Also at idle there would be uncontrollable bucking and surging with a terrible erratic idle.
    Also after a few engine on engine off cycles and a few miles from clearing the generic DTC with a generic scanner, they would come back after a short time maybe 30 miles City driving tops. If I clear the codes with a generic scanner, the erratic and surging idle would go away for a little while.
    With the new fuel pump on their it idles silky smooth and have not had any surging related to the engine at least.
    Sometimes the transmission is a little clunky and sometimes it shifts seem like they are a little bit delayed during deceleration. And I stated sometimes there are flare-ups between shifts on upshift. For instance during heavy braking, say you are going down from 5th gear to 1st gear at a stop sign, it seems like there is a delay and a small thud or surge after you have actually completed the stop.
    Also I evacuated the air conditioning system refrigerant, and refilled it with about four cans of R134a.
    I also replaced two ignition coils because originally it had a misfire code for two cylinders that NOW I am pretty sure those were actually related to the high pressure fuel pump blowing that S13 fuse.
    I use an ohmmeter to test the resistance of the old faulty fuel pump and it was showing 0.5 ohm. It would blow fuse s13 if I would plug-in that driver side fuel pump(the faulty one) before.
    With the new fuel pump on there it no longer blows that fuse.
    I can't really think of anything else I've done other than replace the windshield wipers and fill the washer fluid.
    Mar 2019
    OK so I think the main two things I should investigate are the two MAF sensors G70 & G246...here is the wiring diagram for those and also the G42 Inlet Air Temperature Sensor. If it was only one MAF fault I would suspect the MAF sensor itself, but since both MAFs (and other things) are acting up, this leads me to believe that either a common ground or power supply has issues, or there is a vacuum leak/ intake leak somewhere.
    This one could be related:
    "005241 - Brake Boost Vacuum System
    P1479 - 008 - Mechanical Failure"
    Here is a link to the corresponding code in the ROss-Tech wiki:
    http://wiki.ross-tech.com/wiki/index...7/P1479/005241
    Here is the component locations for the Brake Vacuum System:
    Here is the wiring diagram for the Brake Vacuum System:
    V192 Brake System Vacuum Pump
    AND a diagram showing where track 187 goes from V192:
    G294 Brake Booster Pressure Sensor Wiring Diagram
    J569 Brake Booster Relay wiring diagram
    Maybe there is a vacuum leak related to the brake vacuum system? Maybe an intake leak? Maybe air duct leak between the MAF sensors and the throttle control valve? Maybe that gasket to the throttle control valve? Maybe the wiring to one of those?
    I will find out!
    Mar 2019
    I need to find out how to use the ohm meter (what are resistance values for good/bad for each sensor?) to test the components or some way to test them using VCDS or (even better)both. I havent gotten to play with the VCDS much since I got it since the Audi has been running better because it actually gets use now.
    I think there is a procedure to test some of those items. Will report back
    Mar 2019
    Also, there is this fault:
    "02508 - Temperature Sensor for Refrigerant (G454)
    010 - Open or Short to Plus"
    that could also be related.
    Here are the wiring diagrams containing G454:
    and some component location information for G454 as well:
    I havent fully gone over the diagrams yet, but just in case it is related I figured I would post those diagrams anyways. I will need to check if G454 is causing other issues, (or if not) to fully eliminate the possibility of G454 being related.
    Please clear fault codes and post a new fresher auto-scan with additionally OBD2 data Mode's 1,3,7&9 please.
    Do this before even starting engine.
    JPPSG for FOD to commence!
  6. Likes stone4779 liked this post
    Mar 2019
    Thanks for the reply Jack.
    To clarify, you mean to clear the codes and do an autoscan without ever starting the vehicle? With the key ON in run position?
    Or do you mean to clear fault codes, then start vehicle, then perform a new autoscan?
    Dec 2016
    i had a a8 with a 4.2 that would fall flat if i would give it 50% or greater throttle.. almost felt like a bad throttle body i checked fuel pressure at the point it would act up and pressure would drop found the guy bottomed the car out and kinked the fuel lines under the car..
  9. Likes Uwe liked this post
  10. #8
    Yeah do both and the OBD2 data too & one scan clear codes then shut off key 1 minute then back on without engine running scan it, then scan again after car idled for 2 minutes..........
  11. Likes stone4779 liked this post
  12. #9
    Mar 2019
    Quote Originally Posted by customs025 View Post
    that makes a lot of sense..that is what I was thinking, I went checking things related to the throttle body, but logs were showing that it was in fact opening when I pressed on the accelerator pedal etc.
    Then began looking into fueling, and found a thread about the high pressure fuel pump, which thankfully it ended up being. No more falling on it's face. Now the main issue is 1. the MAFs throw codes and 2. the trans flares a bit, I think that it may be low on transmission fluid. Tomorrow the Trans Go shift kit (part # SK09D) comes in. I still need to get trans fluid for that and a bench grinder to grind the caps off the solenoids.
    If I stick with it I will get it!
  13. Likes Uwe liked this post
  14. #10
    Mar 2019
    OK I will do my best to follow the proper instructions sir
  15. Likes Uwe liked this post
