Results 1 to 8 of 8
Thread: MAF failure
    Mar 2019
    MAF failure
    Hi
    How can I read the MAF?
    The control modules in my vehicle is UDS. I found many tutorials but are non UDS.
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
       License Plate: 16032019
    Mileage: 163640km-101681mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61
    VIN: WVWZZZ3CZAE075321   Mileage: 163640km-101681miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 GL    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5810
       Revision: --------    Serial number: 00000000000000
       Coding: 00114014032501080000
       ASAM Dataset: EV_ECM16TDI02103L906023GL 001006
       ROD: EV_ECM16TDI_001_VW46.rod
       VCID: 76B410CDD84FCD57B41-8022
       Part No SW: 3C0 614 109 AK    HW: 3C0 614 109 AK
       Component: J104    C4 440 V2   0027
       Revision: --025---    Serial number: 00000795856674
       Coding: 0034287
       Shop #: WSC 05311 000 00000
       VCID: 678A4D89836524DF3F7-8032
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000003
       Shop #: WSC 05311 115 00000
       ROD: EV_ClimaBasis_VW46.rod
       VCID: 6D863FA1AD190E8F45B-8038
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C8 937 049 AA    HW: 3C8 937 049 AA
       Component: Bordnetz-SG     H57 3204
       Revision: 00H57000    Serial number: 00000003339756
       Coding: A0900F0700041A00470A00000F000000000159435C000100000308000000
       Shop #: WSC 05124 123 12345
       VCID: 70B826D5B6ABE3676ED-8024
       Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 191009 022  0612
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__00J VW10 HI   1916
       Revision: 20013000    Serial number: 003E2PP3YD2Z
       Coding: 0012362
       VCID: 44D0BA05D2932FC7FA5-8010
       Subsystem 1 - Serial number: 6332MTS633892949
       Subsystem 2 - Serial number: 6342MTS658412949
       Subsystem 3 - Serial number: 6351HTS6SKE829KR
       Subsystem 4 - Serial number: 6361HTS6G4C729KR
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 BP    HW: 5K0 953 569 AA
       Component: LENKS.MODUL   009 0122
       Revision: FF010E35    Serial number: 20091105200027
       Coding: 4180270002
       ASAM Dataset: EV_VW360SteerWheelUDS A03002
       VCID: 74B02AC5CE33DF478A5-8020
       Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
       Component: KOMBI         H03 0305
       Coding: 160F00
       Shop #: WSC 05314 115 12345
       VCID: 2D06FFA16D99CE8F05B-8078
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 N    HW: 3C0 907 951
       Component: J5
    The following measuring values should available in that ECU:
    IDE00347-ENG167462 -- Air mass: actual value: (OBD, so likely g/s)
    IDE00350-ENG99082 -- Air mass: specified value - MAF_SP_MMV (mg/stroke)
    IDE03949-ENG103150 -- Air mass: actual value - MAF_MMV,LINEAR (mg/stroke)
    To make them easier to find, type Air mass into the search/filter box.
  3. Likes stone4779 liked this post
    Mar 2019
    Thank you for info. The readings have to be taken when the engine is warm?
    Quote Originally Posted by alexliebt View Post
    Depends what you exactly you are trying to accomplish.
    In general, the best way on a diesel is to log specified and actual while driving under a variety of conditions.
    What makes you think you have a possible MAF failure?
    Mar 2019
    About 2 days ago, my wife started the car in the morning and she managed to drive less then 1 mile and the car lossed the power and the engine died. She started the car few times and it happend again. 5 minutes later the car was fine, even now is alright. Iíve scan with VCDS and I canít find any fault.
    A MAF failure generally won't cause the engine to die.
  8. Likes stone4779 liked this post
    It can but is very rare!
    This sounds like a fuel or contaminated fuel issue, would be wise to check/change filter and TV function.
    Check all ground points and battery connections!
    Check motor mounts and for torn intake/charge boots!
    LOG requested Boost versus Actual
    Component: 1,6l R4 CR td H23 5810 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< <<<<<<<<< Update firmware needed!
  10. #8
    Mar 2019
    I changed all filter 2 months ago. Iím using only Shell diesel. Iíll check all the ground points.
