Results 1 to 8 of 8
Thread: Canīt bleed my abs system in my Passat
    Pirate
    Apr 2019
    Spain
    im trying to blade the ABS system of my 2000 1.9 tdi ATJ engine code but i cant do it.
    Once I do this
    [Select]
    [03 - ABS Brakes]
    [Basic Settings - 04]
    i canīt choose any option in the dropdown menu like i show u in this pic
    Here another pic that says that my car has abs 5.3
    Should I write any code number in the "login-11" or "recode-07"?which number?
    Internet PIC
    thanks
    Nov 2015
    I'd say you need to post a full autoscan. But then again best use an up to date VCDS tool first.
  3. Likes Uwe liked this post
    VCDS 12.12.0 is now 7 years out of date, you really need to download and install the latest version.
    BTW did your cable come with software on a CD?
  5. Likes Uwe liked this post
    Pirate
    Apr 2019
    Spain
    With the 18.9 software+12.12 cable doesnt work
    And the second question, yes, they came together
    Thanks
    Pirate
    Apr 2019
    Spain
    Removed.  Data from a clone/pirate copy of VCDS is not welcome here
    Here.
    Thanks
    Nov 2015
    Quote Originally Posted by jmb racing View Post
    Thanks
    Then best suggestion would be buying a genuine interface. I'm sure Uwe will point you in the general direction of one in due course.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php
  10. #8
    I just KNEW this would end up in the Hall of Shame
  11. Likes Uwe liked this post
