Just a scan of my new Cupra. Faults are due to Seat Sound System and highline camera retrofits that need parametrization and calibration. Any suggestions are more than welcome.
Sunday,07,April,2019,14:16:13:52034
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: VSSZZZ5FZKR033386   License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 32 42 44 4B 52 5F 6C A9 BB
          BC D6 D7
VIN: VSSZZZ5FZKR033386   Mileage: 3762km-2337miles
BB-Door Rear Drv -- Status: Not registered 0001
Address 01: Engine (J623-DNUC)       Labels: None
   Part No SW: 8V0 906 259 R    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0B2540122424010B2000
   Shop #: WSC 00049 770 00185
   ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
   ROD: EV_ECM20TFS0208V0906259R.rod
   VCID: 4FFA86EA5751985F577-801A
Readiness: 1110 0001
   Part No SW: 0GC 300 020 F    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2301
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 25160442656DB20FCDB-8070
   Part No SW: 5Q0 614 517 DG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0654
   Revision: 00000000    Serial number: 62818000000025
   Coding: 20EE6B925423216F877A060860C96904D62A84E160069677204250F5C206430100000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
   VCID: 79AE1832B955E6EFD93-802C
   Part No SW: 5F0 907 044 AM    HW: 5F0 907 044 AM
   Component: Climatronic   H05 1801
   Revision: 00001K09
   Coding: 00000014200114011005000000101020
   Shop #: WSC 00049 770 00103
   ROD: EV_ACClimaBHBVW37X_006_SE37.rod
   VCID: 71BE2012E125AEAF613-8024
   Air quality sensor:
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001830401711
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7DA60C22AD7DDACFF5B-8028
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 181013  041 0574
   Serial number:         181022160952
   Coding: 0BC5FD
   Serial number: 21972964X81A955555A0
   Coding: 00005D
   Sun Roof:
   Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS72.405  H04 0005
   Serial number: 0000FST0026VNZP00000
   Coding: 180102
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018275
   Coding: 0471151011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC091E6A647A347325-8018
   Serial number: 24071841351228
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3828DD36C2DF3FE766D-806C
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PMUFQXI
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 055664C2C5AD920FADB-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 001 810 18
   Serial number: 35700000000567405234
   Subsystem 2 - Part No SW: -----------    HW: 454 001 810 18
   Serial number: 35800000000381CCE13R
   Subsystem 3 - Part No SW: -----------    HW: 454 801 610 18
   Serial number: 3510023129C160000002
   Subsystem 4 - Part No SW: -----------    HW: 454 801 210 18
   Serial number: 352004EE79F16000000.
   Subsystem 5 - Part No SW: -----------    HW: 454 801 210 18
   Serial number: 35500534D3B16000000G
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 28101820240153
   Coding: 1410
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 0A4C57FEECB3FD77C09-805E
   Part No SW: 5F0 920 790 A    HW: 5F0 920 790 A
   Component: KOMBI         609 1701
   Coding: 04AC29083B800008010872001001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 270A0E4A1F61A01FFF7-8072
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008592886
   Coding: 030100F42F085900EB0082699C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D26CC22EDFD1ACFB5B-8068
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000H0769091018
   Coding: 012000
   Serial number: 75886002001810090719
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00020.07.18
   Coding: 0101
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FC8F9E4463F5B7789-8006
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 0000349612563
   Coding: 00140320DC00020000001000
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000024396683
   Coding: 310000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5082
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C20C126F6E713C7825-8068
Address 4B: Multifunc. Module (J745)       Labels:* None
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 19101810520178
   Coding: 000000070900094A07000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3536D402D5CDC28F7DB-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 0000349881950
   Coding: 00140120DE00020000001000
   VCID: 4EC49BEE505B91575C1-801A
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000024655943
   Coding: 290000
   Part No SW: 5F0 035 877     HW: 5F0 035 877
   Component: MU-S-ND-ER    H50 0514
   Serial number: SEZAZ2U0842737
   Coding: 04738001D70A00001111000400080A002F0202A101200400CE
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   VCID: 698E4872C9F5566F293-803C
   Subsystem 1 - Part No SW: 5F0 919 606 A    HW: 5F0 919 606 A
   Component: ABTm-2_8-BL  H41 1042
   Serial number: SEZ8Z9V6D002G9
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 122
                    Mileage: 3762 km
                    Date: 2019.04.07
                    Time: 14:10:56
                    Voltage terminal 30: 12.1 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
   Coding: 0184020122002017000040
   Shop #: WSC 12345 123 12345
   ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
   VCID: 392ED832F9D526EF993-806C
10489856 - No Basic Setting
          B2010 00 [009] -  -
          [RearView system not calibrated]
                    Reset counter: 122
                    Mileage: 3762 km
                    Date: 2019.04.07
                    Time: 14:10:56
                    passive
   Part No SW: 5F0 907 159 E    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 180823202836
   VCID: 2F3AE66A3791F85F377-807A
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA40B2EA07BC1D7EC1-802A
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW37.rod
End----------(Elapsed Time: 01:30, VBatt start/end: 12.1V/12.1V)-----------
